2018 Audi Q7 4M 3.0 TDI 286bhp (MHEV)- Fuel level Sensor 1 B103E 1B [008]
Milez
C?ID=167694
Dear All,
Watch out for your fuel sensor failing (either getting stuck or sensor failing) as this may cause a raft of further faults,
the worse of which is the DPF calculated results running riot and vehicle ending in Limp Mode and a Management Information Light (MIL) requiring dealer intervention.
There are 2 sensors in the tank for the Q7 4M engine (Sensor 1 and Sensor 2, left and right of the prop shaft).
Bearing in mind this car has never had Supermarket fuel in it and does two 70 mile journeys every week. DPF should have been just fine at only 54,000 miles.
I Wanted to reset the "soot mass calculated:" DPF calculated values to less than the dealer intervention threshold of 45g using VCDS (mine was reading 46.12g) but could not do it with VCDS therefore this forced me into an Audi dealership visit.
If it had been 65g Soot Mass calculated Audi would not regen but will want to replace the DPF so had to get in there quick.
Audi carried out computer diagnostic and said I had DPF faults. Next they removed the front section of exhaust pipe in front of the DPF only to find it clean as a whistle.
Next they did forced regen to get the calculated value down to 1.7g. EML cleared and car power was back. They charged me £300. Arguably they could have just reset the value rather than carrying out a forced regen which is what I tried to do in VCDS but they did a forced regen.
The DPF was not the real cause of this but as I had cleared the DTC's before going into Audi (attempting to reset the MIL without Audi) only the remaining prevailing DPF faults were showing for the Audi Dealership and they would not listen to me saying the Fuel Sensor needed replacing then a DPF calculated value reset (not regen).
Now they have the DPF problem cleared they have invited me back immediately when the Fuel Gauge does its magic empty trick again and causes the fault to re-appear in the Fault codes.
So I have an expensive bill coming up to replace the fuel sensor, consisting of Audi diagnostics and replacement.
What I would like to know is how can I set the calculated DPF soot levels back to equal the measured values in VCDS (almost to mimic replacing the DPF) the measured values can be left alone hopefully. I think the MIL was preventing me doing this the first time round.
If I can find out how to do the DPF reset calculated soot values in VCDS then I can prevent another un-needed forced regen at Audi, just to get me to the point where I can get the Fuel Sensor replaced.
Started like this :-
(1) Tank was nearly empty so went and filled up at garage
(2) Paid for full tank of fuel got back to car and started up to find that fuel gauge was showing empty, had a conversation with the fuel station and they showed me that 80+ litres went from their underground tank. The proving test was to see if I could get any further fuel in the vehicle, which I could not, so the tank indeed was full despite gauge not showing any at all.
(3) Carried on with my normal long journeys and wondered if the car would let me continue even though it thought I had no fuel, no problem the car went on but just kept asking me to fill up.
(4) Topped up fuel a couple of times after this and the fuel gauge suddenly started reading ok again after the third top up.
(5) Eventually the gauge did exactly the same thing when car was almost empty of fuel, the next full fill resulted in nothing on the gauge.
(6) Very quickly the DPF regen light came on and requested a DPF regen. At this stage there was no EML and I still had full power.
(7) However 20 miles later the engine went into limp mode and MIL so I missed my chance to do a manual regen (not sure it would have made any difference with the fuel gauge in fault mode)
(8) Told Audi I needed a DPF reset and a price for new Fuel level Sensor. They wanted to do their own Diags which they did and then they decided forced regen was the way to go. :banghead:
2 SCAN's below:-
First one is before codes reset (showing Fuel Sensor faults and associated)
Second scan shows prevailing codes after I tried to reset MIL light by clearing all fault codes. Needless to say this did not clear the MIL light.
Friday,31,May,2024,09:19:20:56544
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4643.4
Dealer/Shop Name:
VIN: WAUZZZ4M   License Plate:
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 29 2B 36 39 42 44 46 47 50
          52 5F 61 69 6C 6D 74 81 82 8B A5 AC BB BC C4 CA CC D6 D7
VIN: WAUZZZ4M   Mileage: 86728km-53890miles
50-Seat Adj. 3rd row -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DHXA)       Labels: None
   Part No SW: 4M0 907 401 AL    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0002
   Revision: CAH26---    CVN: 4504FA950406833FB866C2ADB866C2AD00000000D6C3ECFE
   Coding: 2A2A4032057E050335086000000000000000000000000000
   Shop #: WSC 53172 004 1048576
   ASAM Dataset: EV_ECM30TDI0114M0907401AL 001002
   ROD: EV_ECM30TDI0114M0907401AL.rod
   VCID: 73B3D808EB38E692029-8026
   VINID: 9D196AAAA11D0DB5000420C60402E2A4C2
5188 - Particle Filter
          P2463 00 [175] - Excessive Soot Accumulation
                    Mileage: 86654 km
                    Date: 2024.05.28
                    Time: 17:49:17
                    Engine RPM: 1824.00 /min
                    Normed load value: 83.9 %
                    Vehicle speed: 63 km/h
                    Coolant temperature: 84 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 12.480 V
                    P Flt Ld fac Ash Cor: 0.9219
                    Particul.filter diff.pressure: 112 hPa
                    Exh t Adap T Oxi Cat Ds: 301.6 °C
                    Exh t Adap TP Flt Ds: 266.3 °C
                    Current operating mode_2-Bits 0-7: 0
                    Current operating mode_2-Bits 0-7: 16
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
36650 - Start/Stop System; Maximum Time for Restart Exceeded
          P167E 00 [032] - -
                    Mileage: 85219 km
                    Date: 2024.05.03
                    Time: 16:12:11
                    Engine RPM: 0.00 /min
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 11.780 V
                    Unlearning counter according OBD: 30
                    Engine status: COENG_READY
5189 - Particulate Trap Bank 1
          P2002 00 [175] - Efficiency Below Threshold
                    Mileage: 86654 km
                    Date: 2024.05.28
                    Time: 17:49:17
                    Ambient temperature: 14.9 °C
                    DPF: offset for differential pressure: 2 hPa
                    Particle filter: soot mass measured: 22.70 g
                    Particle filter: soot mass calculated: 36.89 g
                    Particle filter: kilometers since last regeneration: 552635 m
                    Particle filter field regeneration: cancel conditions-Bits 0-7: 0
32900 - Internal Control Module Error
          P2610 00 [032] - Engine Shut-down Timer
Readiness: 1 2 0 0 0
   Part No SW: 4M0 927 158 EB    HW: 0D5 927 156 P
   Component: 0D5 30TDIRdW  H05 0001
   Revision: --H05---    CVN: 1664F14F00009238
   Coding: 100000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 78A9EF24F25E85CA37B-802C
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H01 0705
   Serial number: 1809170278
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 T    HW: 4M0 907 379 T
   Component: ESP9 Premium  H14 0861
   Dataset Number: 4M0909504R  0003 CVN: 0C240379
   Coding: 249830B231A38A98D1A15897187E52AAF5B6D2240C8C518B1A184A55AF6D4B
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 48C95FE4C23E354A87B-801C
464128 - Delay Function
          C11EE F1 [032] - Unexpected Values from ACC Module
          [ACC_/_GRA_does_not_deactivate_while_driver_is_braking]
   Part No SW: 4M4 959 760 E    HW: 4M4 959 760 E
   Component: MEM-BFS       009 0042
   Serial number: 00000346592689 Dataset Number: 4M0909866D  0024
   Coding: 003832000001B2410000010101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 3E25393C90FA7BFA3D7-806A
   Part No SW: 4M0 820 043 R    HW: 4M0 820 043 R
   Component: Klima Zone 2  H52 0112
   Coding: 6619083D5140050900220280000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 34311B14AEB6A1AADB3-8060
   Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002823679
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Component: Humidity_Sens  H02 0007
   Serial number: 56305F4900PAG0FSA002
0386 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
                    Reset counter: 41
                    Mileage: 84838 km
                    Date: 2024.04.30
                    Time: 08:48:49
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0313
   Dataset Number: 4M0909514T  0062
   Coding: 07501943E06900CD050D87155BBF88F9130331009000000000000000A00016810A45012B125605
   Shop #: WSC 58019 001 1048576
   ASAM Dataset: EV_BCM1BOSCHAU736 019008
   ROD: EV_BCM1BOSCHAU736_019.rod
   VCID: 035388C8BB98D612129-8056
   Subsystem 1 - Part No SW: 4M8 955 119 A    HW: 4M8 955 119 A  Labels: 1KX-955-119.CLB
   Component: J400FRWISCH  052 0997
   Serial number: 904853F0401808600259
   Coding: 7DC727
   Serial number: 21645479X81A955547A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
   Component: E1 - LDS  H06 0008
   Serial number: 19 09 2018  01644246
   Serial number: GX1CE112061823610340
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 DJ    HW: 4M0 947 135 DJ
   Component: Dachmodul  H42 0413
   Serial number: Q00631590
   Coding: 0D0305
   Subsystem 6 - Part No SW: 4M0 925 301 L    HW: 4M0 925 301 L
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000091403
327712 - Databus
          [TSK: received error value in signal TSK_status_ARA]
                    Fault Frequency: 20
                    Reset counter: 20
                    Mileage: 86654 km
                    Date: 2024.05.28
                    Time: 17:49:19
                    average_Voltage_terminals: 12.40 V
                    Outside air temperature sensor-Outside air temperature on CAN: 15.00 °C
                    interior_temperature: 16.50 °C
                    Vehicle speed: 64.50 km/h
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 G    HW: 4M0 907 561
   Component: LRR4          H10 0340
   Dataset Number: 4M0909863P  0001
   Coding: 5473FFEA58FFEC0A959A83E0
   ASAM Dataset: EV_ACCBOSCHAU736 003022
   ROD: EV_ACCBOSCHAU49X_AU73.rod
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Fault Frequency: 20
                    Reset counter: 20
                    Mileage: 86654 km
                    Date: 2024.05.28
                    Time: 17:49:18
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 12.4 V
                    Velocity_vehicle_reference: 17.64 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.79 m/s²
   Part No SW: 4M0 959 655 E    HW: 4M0 959 655 E
   Component: Airbag10.44   H01 0107
   Serial number: 003UL0037AA+ Dataset Number: 4M0909602AL 0004
   Coding: AACCF0D80CA0000098F650F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 3D273E309DFC60E224D-8068
   Subsystem 1 - Part No SW: -----------    HW: 442 062 408 18
   Serial number: 3577Y009926D2BA21495
   Subsystem 2 - Part No SW: -----------    HW: 442 062 408 18
   Serial number: 3587Y009D26D2BA05313
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 607 18
   Serial number: 3517700C12978341F245
   Subsystem 4 - Part No SW: -----------    HW: 442 0B3 008 18
   Serial number: 35277009F296D2B4D30P
   Subsystem 5 - Part No SW: -----------    HW: 442 0C3 008 18
   Serial number: 35575009D2BBCCE6921+
   Subsystem 6 - Part No SW: -----------    HW: 442 0C3 008 18
   Serial number: 3567500992BBCCE460E1
   Subsystem 7 - Part No SW: -----------    HW: 442 0C3 008 18
   Serial number: 23075009F2BBCCE4C0B1
   Subsystem 8 - Part No SW: -----------    HW: 442 420 310 18
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U009D2C58C02B41S
   Subsystem 9 - Part No SW: -----------    HW: 442 420 310 18
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00C729973E4341P
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   VCID: 79AFEA20C9549CC2485-802C
   Part No SW: 4M0 920 790 D    HW: 4M0 920 790 D
   Component: FBenRDW       H19 0416
   Coding: 258400D07C80060001A3E9603000600000000000
   ASAM Dataset: EV_DashBoardAU736 001032
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 303917045AAE9D8ABFB-8064
13639428 - Databus
          [ECU for body control module 2 error value received]
                    Reset counter: 53
                    Mileage: 86418 km
                    Date: 2024.05.24
                    Time: 17:33:12
   Part No SW: 8W7 907 468 G    HW: 8W7 907 468 G
   Component: Gateway       H43 0135
   Revision: 8C000003    Serial number: 0388C804618A02 Dataset Number: 4M0909515P  0091
   Coding: 02010001000486407396000000590032589A0007180000000175078E10000000
   GVL: 01503C0808040200C2BCC8000002C80011082010000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003150
   VCID: 4FFB74F82750E272C61-801A
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0004
   Serial number: 20181005051814 30404
   Serial number: 6401149304
8519683 - Energy Management Active
          U140B 00 [008] - -
                    Reset counter: 41
                    Mileage: 84838 km
                    Date: 2024.04.30
                    Time: 08:30:30
                    EM_vehicle_state: 02 94
                    Static current shut-off stage: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   VCID: 77ABEC18FF408AB23E1-8022
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 18000295936008
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_AU49.rod
   Component: MEM-FS        009 0042
   Serial number: 00000346593738 Dataset Number: 4M0909856D  0024
   Coding: 003833000001B2410000010101010000110000313100000000000000000000
   Part No SW: 4M0 959 593 H    HW: 4M0 959 593 F
   Component: TSG FS        005 0130
   Serial number: 0000338402305  Dataset Number: 4M0909872J  0035
   Coding: 005F8A005E01000200013002
   VCID: 41DF42C0E1040402405-8014
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Dataset Number: 4M0909852T  0008
   Coding: B0040101010001
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 313F120051A49482B05-8064
   Part No SW: 8W0 907 064 ED    HW: 8W0 907 064 DD
   Component: BCM2 MLBevo   025 0387
   Dataset Number: 4M0909501L  0068
   Coding: 01351E002FB100406309A0006400580203000000804706502F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   VCID: 025D8DCCA482DF1A19F-8056
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY182320XZA
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000198903
65694 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Reset counter: 53
                    Mileage: 86418 km
                    Date: 2024.05.24
                    Time: 17:29:43
                    Supply voltages-Terminal 30 power supply: 12.419 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.473 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.446 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 98
                    fuel_sender_freeze_frame: 11111111 11111111 11111111 11111111
65896 - Databus
          [Climatronic control module: Klima_03: no signal/communication]
                    Reset counter: 60
                    Mileage: 84838 km
                    Date: 2024.04.30
                    Time: 11:52:03
                    Supply voltages-Terminal 30 power supply: 12.528 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.609 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.555 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 02 80
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H03 0440
   Serial number: 00000000123403 Dataset Number: 4M1909510E  0012
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2313E8481B583612329-8076
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
   Component: MEM-SR3       008 0016
   Serial number: 00000348046808 Dataset Number: 4M0909467C  0016
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   Part No SW: 4M0 959 592 H    HW: 4M0 959 592 F
   Component: TSG BFS       005 0130
   Serial number: 0000343563045  Dataset Number: 4M0909873J  0035
   Coding: 005F8A005E01000200013000
   VCID: 40D947C4EA0E0D0A4FB-8014
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 035 C    HW: 4M1 035 035
   Component: MU-P-LND-EU   035 1329
   Serial number: A641J0JB033130 Dataset Number: 4M0909545N  0047
   Coding: 013706010000000053111102000A00312F001BE7017001009E
   VCID: 2517F650156CC8225CD-8070
   Subsystem 1 - Part No SW: V03 959 802 TH    HW: -----------
   Component: ECE 2020  --- 0184
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9JJ407HN6
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 04101800000000000350
   Compact disc data bank:
   Component: Gracenote2  --- 1017
Address 61: Battery Regul. (J1120)       Labels: 4M0-915-105.clb
   Part No SW: 4M0 915 105 B    HW: 4M0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU37.rod
   VCID: 2809FF64627ED54A67B-807C
   Part No SW: 4M0 907 383 G    HW: 4M0 907 383 B
   Component: Anhaenger     H33 0272
   Revision: 9A001003    Serial number: 0492254179 Dataset Number: 4M0909527C  0024
   Coding: 0110000202010000
   VCID: 3635211CB8CAB3BAE57-8062
   Bend angle sensor for trailer:
   Subsystem 1 - Part No SW: 4M0 907 811 A    HW: 4M0 907 811 A
   Component: G820 KNWINSEN  H18 0019
   Serial number: 17407
656394 - Bulb for Left Tail Light on Trailer
          C10F5 15 [008] - Open or Short to Plus
                    Reset counter: 55
                    Mileage: 86461 km
                    Date: 2024.05.25
                    Time: 14:28:22
   Component: RVC Compact   H15 0250
   Dataset Number: 4M0909460B  0014
   Coding: 0237060103002025400044
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU73.rod
   VCID: 33331808ABB8A692C29-8066
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C744-8781-0 Dataset Number: 4M0909541G  0026
   Coding: 0090
   ROD: EV_DeckLidCONTIAU736_AU37.rod
   VCID: 4ACD65ECDC32C75A91F-801E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 L    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H37 1244
   Serial number: 0110180786  Dataset Number: 4M0909576S  0009
   Coding: 98505858F8
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 42DD4DCCE4021F1A59F-8016
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130418623
   Coding: 303030
   Part No SW: 4M2 713 041 H    HW: 4M2 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 18090449065666
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 2B0300687388FE528A9-807E
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
   Component: HeadUpDisplay H31 1640
   Coding: 4F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU73.rod
   VCID: 35372610A5CCB8A2ECD-8060
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 G    HW: 4M0 907 541
   Dataset Number: 4M0909885K  0001
   ASAM Dataset: EV_ACC2BOSCHAU736 003022
   ROD: EV_ACC2BOSCHAU49X_AU73.rod
   VCID: 323D1D0C54A2AF9AC9F-8066
   Part No SW: 4M0 907 217 F    HW: 4M0 907 217 E
   Component: BVS           H17 0052
   Dataset Number: 4M0909466M  0045
   Coding: 0407030600000404024023A5AD0000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0006
   Dataset Number: 4M0909571J  0002
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_AU49.rod
   Part No SW: 4M0 959 595 H    HW: 4M0 959 595 F
   Component: TSG HFS       005 0130
   Serial number: 0000347008869  Dataset Number: 4M0909897J  0035
   Coding: 004F88000001000200003000
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 43D348C8FB181612529-8016
   Component: TSG HBFS      005 0130
   Serial number: 0000347008721  Dataset Number: 4M0909896J  0035
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0324
   Dataset Number: 4M0909475D  0017
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A2D352C8CD257DA01F-806E
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: 4M0909469G  0015
   Coding: 5A8000053602
   ROD: EV_SunRoofCONTIAU736_006.rod
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 H    HW: 4N0 903 028 H
   Component: BSG-HP1-65    H16 0523
   Serial number: 11101800020252
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471D  0012
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 1675C19CD80A53BAC57-8042
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472D  0012
End----------(Elapsed Time: 02:33, VBatt start/end: 14.7V/14.7V)-----------
Second Scan (just the DPF faults left after clearing DTS) This did not reset the MIL unfortunately:-
Friday,31,May,2024,12:44:35:56544
Dealer/Shop Name:
VIN: WAUZZZ4M   Mileage: 86805km-53938miles
          P2463 00 [167] - Excessive Soot Accumulation
                    Mileage: 86805 km
                    Date: 2024.05.31
                    Time: 12:41:22
                    Engine RPM: 631.00 /min
                    Normed load value: 23.5 %
                    Coolant temperature: 80 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 12.800 V
                    Particul.filter diff.pressure: 11 hPa
                    Exh t Adap T Oxi Cat Ds: 115.9 °C
                    Exh t Adap TP Flt Ds: 110.8 °C
          P2002 00 [039] - Efficiency Below Threshold
                    Mileage: 86805 km
                    Date: 2024.05.31
                    Time: 12:41:22
                    Ambient temperature: 22.2 °C
                    Particle filter: soot mass measured: 31.22 g
                    Particle filter: soot mass calculated: 46.12 g
                    Particle filter: kilometers since last regeneration: 703382 m
   Coding: 100000
   ATF pump:
   Coding: 7DC727
   Coding: 02006E
   Coding: 210000
   Coding: 0D0305
327712 - Databus
                    Reset counter: 20
                    Mileage: 86805 km
                    Date: 2024.05.31
                    Time: 12:41:17
                    average_Voltage_terminals: 12.90 V
                    Outside air temperature sensor-Outside air temperature on CAN: 23.00 °C
                    interior_temperature: 26.50 °C
2068 - Databus
                    Reset counter: 20
                    Mileage: 86805 km
                    Date: 2024.05.31
                    Time: 12:41:17
                    Control Module temperature: 47 °C
                    Voltage terminal 15: 12.6 V
   ID - sensor:
   Subsystem 1 - Part No SW: 4M0 959 754 BQ    HW: 4M0 959 754 BQ
   Component: ID-Geber  H40 0105
   Serial number: 3618000157700007
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Coding: 0090
   Coding: 98505858F8
   Coding: 303030
   Coding: 4F01C0
End----------(Elapsed Time: 02:28, VBatt start/end: 12.9V/12.9V)-----------
Dr Sheldon
Windsor UK
C?ID=334979
Wow !!
That is Chapter & Verse !!
Fix the Fuel level sensor fault - We can go at the DPF after that !
Recon you maybe barking up the wrong tree connecting the two faults ?
Agree. ECU will not regen if it thinks the fuel level is very low -- some people say below 1/4 tank, but I'm not sure I believe it's that much.
Dr Sheldon
Windsor UK
C?ID=334979
I have heard the 1/4 tank rule too - I too think it would have to be lower than that - Perhaps when the Fuel Warning Light is on would be the threshold - Have no evidence to support that right now !!
@Milez
How Empty ?
You may be better off in the hands of a good independent ! Where in the UK are you ?
Or roll your sleeves up and do some testing ?
Or dont let it get so low !! Seems as though the float is sticking somewhere in the lower part of the tank ??
Milez
C?ID=167694
Dont forget this point at (1) Was before any fault codes at all and before Sensor fail. DPF nor fuel Sensor was in fault mode at this point.
How Empty ?
Answering the question though ..... it was fumes .... using the hidden reserve no doubt.
if you look at the fault dates they all emanate from the 24 May ....the day the Fuel sensor failed (got stuck, whatever it did).
VCDS is great for tracking the start of problems.
Dr Sheldon
Windsor UK
C?ID=334979
Your point noted however there is no exact science there - just your thoughts !! You could be bang on correct or it was a coincidence ?
Move forwards now with the facts - evidence based facts - and that will the wisest way to attack the fault in your car !!
I have to say
then
Running it that low is never going to help ??
Dr Sheldon
Windsor UK
C?ID=334979
Take a look here:
Similar thing to yours and had a Genuine Level Sensor fitted which did not cure it !!
I never saw the car again as it went to the Dealer.
I will make a phone call tomorrow to see if I can get the answer,
Milez
C?ID=167694
Granted running low is to be avoided it definitely is not a habit, but the fact prevails that the car did not run out of fuel was refilled entirely on the forecourt of an Esso garage and the car engine performed with perfect power for the next 260 miles. The first 140 miles driven with no fuel being registered on the gauge ie the tank was empty as far as the fuel gauge and possibly the ECU was concerned.
Not sure what the inference is with your ref to the fact I never use supermarket fuel. Humbly read your view, still not sure what that view is, just say it don't beat around the bush.
Anyway thanks for your input.
Using my 2nd VCDS licensed cable HEX-V2 having owned the old one since 2010 approx:-
I would just like to know the method to reset the DPF calculated soot (not measured) back to the value of measured.
Are you able to divulge?
Thanks will look forward to any info tbh
I do not see an obvious way to do that in the data for this ECU.
If I were willing to throw darts at the wall, I might try one or both of these Basic Settings:
IDE00467 -- Resetting of learned values of particle filter
IDE07372 -- Particulate filter test
But I don't have a detailed procedure for them, and it's entirely possible that you'll make things worse.
Milez
C?ID=167694
Thanks Uwe, I have noted these two and will treat them with the care they and my vehicle deserve.
Hopefully I can prevent the fuel sensor from getting stuck (if that's what happened) by filling up when the tank gets to 3/8 full rather than 0/8ths full.
The warning duly noted.
Dr Sheldon
Windsor UK
C?ID=334979
The inference being that you use only Quality Fuel (non Supermarket) which are the actions of someone that cares for his car - then run it on fumes !!
I saw a contradiction there - That's all
Milez
C?ID=167694
Thx DrS
Ahh, ok, well the occurrence was not planned or habitual I can assure.
In answer to your earlier question (just read) I am in Portsmouth area UK.
Any recommends for an independent there?
Milez
C?ID=167694
Thx Petrol Dave,
I will be giving them a call when the fault code for the Fuel sensor comes up again.
Milez
C?ID=167694
Conclusion:- Long time coming, I know but this will hopefully be useful to someone.
Essentially:-
Replacing the Fuel Level Sensor 1 fixed the problem of fuel gauge not reading correctly which in turn has fixed the problem of the DPF calculated soot mass running riot when the tank is full but the car ECU thinks the tank is empty.
(1) I purchased a used Fuel level sensor 1 from a great Ebay seller and was lucky enough to receive a complete unit, pump and housing as well, with the float (Fuel Sensor 1) unit attached to the housing.
(2) Found that the faulty unit location is behind the driver seat under the first rear seat of three (offside seat one rear)
(3) Removed all 3 rear seats to gain full access to tank. This made it easier later on to get hands into tank.
(4) Cut a sensible flap of carpet above the tank access Plate (Ally plate cover with 3 screws visible) so that carpet would still be attached to main carpet but would fold back when job was complete.
(5) Used car normally until tank was only 1/8 full.
(6) Removed car floor cover (Ally plate 3 screws). Then unplugged all connectors from top of tank access port.
(7) Used a substantial screwdriver and hammer to undo the locking ring that holds the access port closed.
(8) Practiced removing float (Fuel Level Sensor 1) on the purchased Ebay unit as if I was doing it blind.
(9) Carried out Sensor change by removing old unclipping it blind (the easy part) then fixing the new one back in using feel (essentially blind) clipping it back in (the tricky part) making sure wires were routed as before so they do not hinder the float action. Was amazed at how much diesel I managed to get on my hands and tools from a near empty tank. Stuff sticks to your hands like shit to a blanket and takes a while to get rid even after proper hand scrubbing.
(10) Refitted the closing port and locking ring and then the connectors.
(11) Tested car over 4 weeks (with the seats still out) to run fuel tank down to near empty and to refill at least 3 times.
(12) Car is back to normal guage is reading correctly through full range and ECU is not not creating wild values under calculated soot mass as ECU now has the correct feedback that fuel is in the tank.
Audi wanted £611 to replace this Fuel Level Sensor. The replacement cost me £80 from Ebay which I was lucky enough to get the whole housing as well which proved very useful to practice blind the replacement of the sensor. Plus quite a bit of my time to get it all done so I class this as good money saved overall.
Additional information about the old sensor:- I checked it with a resistance meter and indeed it went to open circuit at certain positions which corresponded to near empty tank but was good at higher levels at near full levels. The new sensor exhibited no such problem and gave proportionally rising values of resistance across the whole range of movement.
Observation of faulty sensor revealed that a very small magnet on the outside of the sensor was loose. This magnet operates some magnetic sensitive type coupling inside the sealed resistance unit that should change the resistance dependant on position. This very small magnet (sub 4mm square) in a loose state seemed to be the problem. Possibly the resistance unit inside may have been faulty but I think not as there is no physical contact between the two. Certainly the magnet on the replacement unit was soundly fixed not loose at all in its housing.
Thanks to all the guys here who offered help especially Uwe for providing a little info on reset of DPF calculated soot mass, Luckily I did not need to use this info as kept tank full to keep the faulty sensor working at its good end. This avoided going into calculated soot mass problems again. Would have carried it out if the sensor had failed completely and sent me back into high calculated soot mass territory.
I was lucky it was not sensor 2 as apparently the tank has to come out for sensor 2 and I don't think I am up for that.
Sensor 2 is on the other side of the prop shaft and behind the front passenger seat under the rear seat but not accessible as far as I know.
Thanks again all.
Hope this helps someone.
Wow! :thumbs:
I sure would like to understand why the Herr Dr. Dipl. Ing. types in their white lab coats at VAG decided that fuel level should be an input to soot level calculation. :confused:
I mean, OK, I understand why they might not wish to start a regen if they believe the fuel level is too low, but seriously, WTH does fuel level have to do with the amount of soot currently calculated to be in the DPF?
Dr Sheldon
Windsor UK
C?ID=334979
Sensor 1 and Sensor 2 have lived a very similar life, in a similar environment and done a similar amount of work !!
Milez
C?ID=167694
Wow! :thumbs:
Better to be described as diesel tank was entirely empty as far as the ECU was concerned (due to fuel level sensor 1 - resistance to high) which resulted in calculated soot mass going above soot mass limits that invoked a MIL and then a DPF regen from Audi despite the CAT being inspected and seen as clean by the Audi dealership. They inspected the CAT by de coupling the exhaust flange then, to rub it in, creating Audi Cam Footage of the CAT matrix of which I took several screenshots, the matrix showed no signs of soot build up. Unfortunately it seems the technicians at Audi are bound by process and not by observation/technical skill. The next line in the Audi process (I asked specifically at this point when they called me) was to regen the DPF anyway to remove said non existent soot and to reset the MIL.
Agreed on your point the soot level calculation importance madness by the good Dr. Dipl. Ing. Why would the car engine management designers not have used the measured values? measured values were actually showing as normal and well below DPF regen limits (I have a VCDS record of the measured values). If measured soot mass were the only link to invoking a regen then the MIL light would have stayed off and I would not have had to pay £300 for a (not needed) DPF regen.
Two things gained from this:-
(1) "Calculated soot mass" is your enemy if any one of your fuel sensors feeds empty tank detail to the ECU.
(2) Dont ignore a faulty fuel level sensor 1. Get it replaced ASAP.
Milez
C?ID=167694
Blinding!
Thanks for the highlight that Sensor 2 may kick off as well.
I am going to put that to the back of my mind for now.
Keep on scanning!!
Yes, that's the mentality from VAG for a number of years now. Technicians with a high level of skill and experience cost too much, so they put "processes" in place that they believe any kind off the street can follow, and they expect everyone who works at a dealership to follow them, no matter whether they're a complete waste of time or not.
