New to VCDS. Getting "No response from controller"
DocHalpin
C?ID=273179
Hey all, I'm new to the audi VCDS world. I bought a legitimate HEX wifi device and on many modules I receive a "No repsonse from controller" message. If someone could help me remedy this situation, it would be greatly appreciated. Thanks in advance!
2003 Allroad 2.7TT 6Spd
VR
Sean Halpin
US Army (Ret.)
Bruce
Near Philadelphia, PA, USA
Please help us by telling us how you have connected the HEX-NET. Are you using the HEX-NET with VCDS on Windows PC or are you using the HEX-NET with VCDS-Mobile on a smart device?
Also, are you aware that your Allroad may not have all diagnostic capable modules listed installed? When this happens and you query a non-installed module, the error report you have given is the response from a module that is not present. The VCDS software is reporting that a request was made but nothing was returned from the controller.
Again, please tell us more about what you are trying to do and with which modules you are trying to do this.
DocHalpin
C?ID=273179
Hey Bruce, thanks for the response.
I went ahead about bought a Lenovo Thinkpad with windows 7 that I will use predominantly for diagnostics and learning how to tune.
A couple modules I know that give me trouble are trying to access both rear doors. I can gain access to see that error codes that the rear doors "cant unlock", but I can't access the doors individually.
Also, trying to change settings so that there's an audible "beep" when the car is locked with the fob. I saw online that it can be accessed through "central convenience", but I get the "no response from controller" error when trying to get in.
Eric
HC800000
Let's see an autoscan with engine running or battery charger connected. Then we'll be able to see if there are modules that are definitely diagnostic-capable and installed, that don't answer. Rear doors and central convenience are not one of those, but it's entirely possible we have issues with other addresses.
Right, the 4B chassis (Audi A6/S6/RS6/allroad (4B) does not use diagnostic capable door modules or #46 but the Auto-Scan will show us if #35-Central Locking in addition to all of the other addresses are behaving normally.
P.S. If the beep can be modified that would be located in #35 rather than #46
DocHalpin
C?ID=273179
Hey Eric, how do I go about screenshotting or copy/pasting an autoscan?
DocHalpin
C?ID=273179
VCDS Version: Release 15.7.1 (x64) Running on Windows 7 x64
Data version: 20150904
Wednesday,21,October,2015,15:55:27:30060
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
          75 76 77
VIN: WA1YD54B03N003403
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4Z7 907 551 S
   Component: 2.7L V6/5VT     G   0020
   Coding: 07712
   Shop #: WSC 26097
   VCID: 53E6AFB5A38024A6B0-5184
   WA1YD54B03N003403     AUZ7Z0B2162462
17861 - Exhaust Gas Temp Sensor 1 (G235)
            P1453 - 35-00 - Open or Short to Plus
17865 - Exhaust Gas Temp Sensor 2 (G236)
            P1457 - 35-00 - Open or Short to Plus
Readiness: 0010 0101
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389 A
   Component: ABS/ESP allrad      D55
   Coding: 06495
   VCID: 4AD8B2D174CA656EC3-5184
01422 - Hydraulic Pump for Electronic Stability Program (V156)
            35-00 -  -
01310 - Level Control System Control Module (J197)
            49-00 - No Communications
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AD
   Component: A6-Klimavollautomat 0105
   Coding: 00010
   Shop #: WSC 02325
   VCID: 5CF44489CD5EEBDE61-2596
00716 - Air recirculation Flap Positioning Motor (V113)
            41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 J
   Component: Airbag 8.4EP        2000
   Coding: 0000707
   Shop #: WSC 02325 785 00200
   VCID: 56E056A1E072318E57-5184
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Component: Lenkradelektronik   D01
   Coding: 01005
   Shop #: WSC 02325
   VCID: 2F2EC345EC682046F4-5216
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 P
   Component: KOMBI+WEGFAHRS. VDO D11
   Coding: 06264
   Shop #: WSC 19378
   VCID: 3326CF35034004A690-5184
Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D37
   Coding: 14921
   Shop #: WSC 02325
   VCID: 3326CF35004004A690-4F0C
00947 - Trunk Lid remote Control Switch (E188)
01561 - Rear left door
            59-00 - Can't Unlock
01562 - Rear right door
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0102
   Coding: 00001
   VCID: 2C14D449DD7E5B5ED1-4B3C
01445 - Sensor for Driver Seat Fore/Aft (G227)
            36-10 - Open Circuit - Intermittent
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
            36-00 - Open Circuit
01447 - Sensor for Driver Seat; Height Adjust (G231)
            20-00 - Malfunction in Basic Setting
Address 37: Navigation        Labels: 4B0-919-887-BNS4.lbl
   Part No: 4B0 919 887 E
   Component: BNS 4.2 H05    BNO 0008
   VCID: 3522F12D0E341A96BE-4B1E
   Part No: 4B0 035 195 L
   Component: symphony II NP2    0009
   Coding: 00235
   Shop #: WSC 26097
   VCID: 291A2D5DD28C4E762A-4EEA
Address 65: Tire Pressure        Labels: 4D0-907-273.lbl
   Part No: 4D0 907 273 A
   Component: Reifendruckueberw.  D110
   Coding: 20329
   Shop #: WSC 19378
   VCID: 2502216DBE946A160E-5184
Address 75: Telematics        Labels: 8E0-035-616.lbl
   Part No SW: 8E0 035 616 A    HW: 8E0 035 616 A
   Component: Telematik USA1
   Coding: 0002333
   Shop #: WSC 26107 444 00039
   VCID: 23063F75E3A0942660-5184
01531 - Emergency Battery
            002 - Lower Limit Exceeded - MIL ON
End-------------------------(Elapsed Time: 07:01)--------------------------
Assuming this car has a manual transmission, I don't see any modules that are obviously missing, except for 34-Level Control. However based on the fault codes in other modules which indicate they can't talk to it either, it seems to be off-line.
No car has a module at every address. This car is too old to have a gateway with a list of addresses that can be read out showing what modules are actually installed in the car, so VCDS gives you a list of addresses scans a list of addresses that MIGHT be in the car. When you go to select an individual control module, it gives you a list of addresses that might be an ANY car..
DocHalpin
C?ID=273179
The previous owner did the coil conversion. I'm in the process of sourcing air bags to switch back. I would assume the level control has to do with the air suspension.
Uwe, so are you saying that everything appears to be good to go?
Well, you have fault codes indicating problems that should be addressed, but I don't see any problems with VCDS itself here. :D
DocHalpin
C?ID=273179
I've ordered a new ABS pump and both EGT sensors. Hopefully that will be the extent of mechanical repairs needed.
