Resolved Superb iii. DRL dimming. Is it possible
Resolved
professorchris
C?ID=580099
I'm new to VCDS and this frorum, and am slowly getting used to their possibilities.
I have a 2017 Skoda Superb iii estate (UK - kombi in other countries) and have been made aware that some people find hat the DRLs can turn yellow and dim, the reason being that the actual LED is driven hard, overheats and burns itself, damaging the end of the light tube it butts against in the process. The repair for this is reported to be very costly (around £1,000 for a headlight unit), or very cumbersome in dismatling of the sealed unit using heat...
Thursday,06,June,2024,19:14:50:15330
VIN: TMBKH7NP5H7555853   License Plate:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 36 42 44 4B 52 5F 6D BB BC
VIN: TMBKH7NP5H7555853   Mileage: 56739km-35255miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H24 1990
   Revision: B5H24---    CVN: 49FF1F44
   Coding: 011D0012036505086000
   Shop #: WSC 33361 790 00165
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
   ROD: EV_ECM20TDI01104L906026FL.rod
   VCID: 005997A1CA80BD2A573-8054
   VINID: 91D49B6077A01581C51452050CAF99F1DC
   Part No SW: 0D9 300 042 M    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5013
   Revision: 06454104    Serial number: TFK01703290997 CVN: 00006A1E
   ROD: EV_TCMDQ250021.rod
   VCID: 2313F82D7B5646326A1-8076
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 61137000001847
   Coding: 1E07929C34250B71477F060540C64978492CD0E2600292751861F078C202420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
   VCID: 79AFFA45A95AECE210D-802C
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 EE    HW: 3V0 907 044 EE
   Component: AC Automat    H34 4101
   Revision: 20K07000    Serial number: 00000B00494732
   Coding: 1211010400211001100500000010100A
   ASAM Dataset: EV_ACClimaPrehVW37X 002019
   VCID: 7BA3E04DA366DEF2021-802E
   Humidity sensor: exterior:
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001711104908 Dataset Number: V03935253VP 0001
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5E959B074CBDA25F-802A
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 010417  032 0121
   Serial number: 00000001703290305341
   Coding: 165DDD
   Component: RLHS  042 0105
   Serial number: S3Y17M04D24H13M31S57
   Coding: 00084D
   Serial number: 000000000ZY170873R2N
   Serial number: 00000000000069320112
   Part No SW: 5QA 919 283 A    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0038
   Serial number: 000308419617100 Dataset Number: V03935245MJ 0001
   Coding: 0601050011
   ASAM Dataset: EV_EPHVA14AU3700000 009029
   ROD: EV_EPHVA14AU3700000_009_AU37.rod
   VCID: 48C94F81A230456ADF3-801C
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Dataset Number: V03935249LS 0001
   Coding: 3200678151FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 35373675C5C2C882B45-8060
   Part No SW: 5Q0 959 655 AT    HW: 5Q0 959 655 AT
   Component: AirbagVW21    003 0318
   Serial number: 003TYR2VVSGT Dataset Number: V03935246GC 0001
   Coding: 98CCC0C0000000005C5400CF008800000065
   VCID: 127DADE994EC3FBAF17-8046
   Subsystem 1 - Part No SW: -----------    HW: 480 002 304 17
   Serial number: 35700000000F657D132O
   Subsystem 2 - Part No SW: -----------    HW: 480 002 304 17
   Serial number: 35800000000637393329
   Subsystem 3 - Part No SW: -----------    HW: 480 402 004 17
   Serial number: 3510001B5254249582C-
   Subsystem 4 - Part No SW: -----------    HW: 480 402 204 17
   Serial number: 3520001A724CEF21F77L
   Subsystem 5 - Part No SW: -----------    HW: 480 402 204 17
   Serial number: 3550001A524CEF25D6FV
   Part No SW: 5Q0 953 521 FR    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20170422500846 Dataset Number: V03935250QX 0001
   Coding: 6414
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 074B8CBDEFAE8A12169-8052
   Part No SW: 3V0 920 941 A    HW: 3V0 920 941 A
   Component: KOMBI         205 8311
   Coding: 27A4090A2F80A60001886B011000000000000000
   Shop #: WSC 73430 031 00165
   VCID: 3333086DCBB6D6B29A1-8066
   Component: GW MQB High   515 5286
   Serial number: 26041710521557 Dataset Number: V03935242BZ 0001
   Coding: 030100045F087300EB00025A1C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00132
   GVL: 01563C0008000000401C80000000C80000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3B041D279EF252FE9-807A
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000C0404210417
   Serial number: 2865003704
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0021
   Serial number: Y0006QCT10587 Dataset Number: V03935264CR 0001
   Coding: 0014000000000500018280808080000000008181000000D400
   Shop #: WSC 16061 005 1048576
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
   VCID: 3C212351E6E819CA4BB-8068
10490368 - Data Set Implausible
          B2012 00 [00001001] - -
                    Reset counter: 97
                    Mileage: 56547 km
                    Date: 2024.05.26
                    Time: 15:33:17
   Component: TSG FS        010 0032
   Serial number: 0000251978642  Dataset Number: V03935256LS 0001
   Coding: 001D0820DE01040000001100
   VCID: 47CB4CBDAF2E4A12D69-8012
   Component: EPS_MQB_ZFLS  128 1072
   Dataset Number: V03935255ZY 0001
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D746B595225802245-8010
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 27041710521565 Dataset Number: V03935254CV 0001
   Coding: 000000020100066E00003F01000000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_001_VW37.rod
   VCID: 72BDCD69F42C9FBA517-8026
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: Leimo links  H01 0006
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: Leimo rechts  H01 0006
   Component: TSG BFS       010 0032
   Serial number: 0000252659714  Dataset Number: V03935256LW 0001
   Coding: 001D0220DE01040000001100
   VCID: 46D541B9A824531A2DF-8012
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 D    HW: 3V0 035 020
   Component: MU-H-ND-EU    H50 0942
   Serial number: A676D0HS029001 Dataset Number: V03935262BB 0001
   Coding: 03840201FF00000051111204008808002F0100C601200100DE
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 270BEC3D0F6EAA12369-8072
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H47 1031
   Serial number: SKZ8Z9TLU01R2V
   Subsystem 2 - Part No SW: V03 959 820 JK    HW: -----------
   Component: ECE 2023/2024  --- 0330
   Compact disc data bank:
   Component: Gracenote2---  --- 1013
          U1014 00 [00001001] - -
                    Reset counter: 97
                    Mileage: 56547 km
                    Date: 2024.05.26
                    Time: 15:33:21
                    Voltage terminal 30: 13.5 V
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31330148500000 Dataset Number: V03935245PM 0001
   Coding: 0D00
   VCID: 41DF52A5810A742218D-8014
0032 - Warning Buzzer for Rear Lid
          B11DF 13 [00001001] - Open Circuit
                    Fault Frequency: 148
                    Reset counter: 112
                    Mileage: 56547 km
                    Date: 2024.05.26
                    Time: 15:33:17
   Part No SW: 5Q4 959 395 E    HW: 5Q4 959 395 B
   Component: TSG HFS       011 0032
   Serial number: 0000253767736  Dataset Number: V03935256ME 0001
   Coding: 001800208001040000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   ROD: EV_DCURearDriveMAXKLO.rod
   Component: TSG HBFS      011 0032
   Serial number: 0000252677416  Dataset Number: V03935256MK 0001
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
   ROD: EV_DCURearPasseMAXKLO.rod
End----(Elapsed Time: 01:44, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
To avoid this I would like to reduce the LED's intensity to, say, 70% of its factory setting so that it runs cooler.
Using VCDS I have looked at settings for the DRL (which is also sidelight, although theye use two different control units). I changed the DRL controller dimming from 127 (some digital/binary setting for 100%. down to 100 no change was apparent. Below 100 they just flickered and flashed. (the sidelight driver uses a more analogue setting of 0 - 100)
professorchris
C?ID=580099
Admap to follow..... I can't seem to find instructions on how to get the info from my admap .csv to paste between the marks. Instructions for scan, yes, but not for admap (?)
professorchris
C?ID=580099
Here are my Admap details copied from Excel. I hope the format is suitable (I'm sure somebody will guide me if I've messed this post up. It's my first attempt)
;SW:5Q0-937-084-CF   HW:5Q0-937-084-CF ---  Cent. Elect. --- SA: 31347
;Component:BCM MQBAB M+  H34 0236     Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB    17001
;Tuesday    16
;VCDS Version: Release 23.11.0 (x64)  Data version: 20240322 DS351.0
;VCID: 7EA5E959B074CBDA5DF-802A
IDE00001-ENG99061-Production mode-Access control    not active
IDE00001-ENG115730-Production mode-Exterior lighting    not active
IDE00001-ENG112304-Production mode-Heckwischer    not active
IDE00001-ENG98647-Production mode-Interior lights    not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active
IDE00002-Transport mode    active
IDE00820-Activating and deactivating all development messages    not active
IDE01550-Service position    157.494349 °
IDE02152-Characteristics in production mode    2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    not active
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl    not active
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl    not active
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit    200 ms
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit    200 ms
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit    200 ms
IDE02332-Deactivate production mode    0
IDE02488-Anti-theft system interior monitoring    100%
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    active
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen    not active
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1    8 s
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2    16 s
IDE02711-ENG112304-Rear wiper-Heckwischer    logikgesteuert
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    not active
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck    0 ms
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    -0.3 °
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit    50.0 %/s
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt    both sides
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold    0.0 km/h
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur    100.0 °C
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur    95.0 °C
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel    90 °
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur    80.0 °C
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel    30 °
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold    40.0 km/h
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift    ECE R119
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht    15 min
IDE03787-Activate left/right hand drive switch-over    not active
IDE04927-IDE01446-Window heater-Running time of heated front window    600 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.0 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.0 °C
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer    0 s
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt    not installed
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus    not installed
IDE04927-ENG126845-Window heater-FSH Automatik    active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    600 s
IDE04927-ENG141955-Window heater-heizbare Heckscheibe    installed
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe    not installed
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    not active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    not active
IDE04927-ENG141962-Window heater-Waschduesenheizung    not installed
IDE04927-ENG154810-Window heater-window heating front activation time pause    240 s
IDE04928-MAS01577-Anti-theft protection-Parking heater    not installed
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    not active
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system    active
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    driver door contact thatcham
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder    Sounder_verbaut
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor    not installed
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet    Yes
IDE04928-ENG142249-Anti-theft protection-OBD Alarm    activ
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)    No
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung    Yes
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    10 Alarme
IDE04928-ENG142008-Anti-theft protection-tilt_sensor    Yes
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel    not active
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    2 sekunden verzoegerung
IDE05144-Read parameter address    00 00 00
IDE05145-Light configuration    21 34 00 14 02 00 7F 00 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 00 00 00 00 00 00 00 00 00 04 48 00 4A 08 09 1B 14 00 64 06 00 8A 00 00 00 04 4C 00 4C 08 0A 1B 14 00 64 07 00 8A 00 00 00 01 48 00 49 14 00 7F 08 09 7F 00 00 00 00 00 00 01 4C 00 4B 14 00 7F 08 0A 7F 00 00 00 00 00 00 03 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 03 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 37 00 1E 0D 0F 7F 00 00 00 00 00 00 00 00 00 02 41 00 1F 0E 0F 7F 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00
IDE05822-Anti-theft alarm system vehicle inclination sensor    100%
IDE05823-DWA Interior monitoring parameter set    01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2E 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 45 42 57 9B 25 24 0C FA 0A 34 95 2E 09 A3 21 03 00 02 02 02 02 02 02 B1 40 A1 28 3A
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN    Heizmatten am BCM
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    1 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    23.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    22.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    23.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    22.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    36.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    35.50 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    36.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    35.50 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    41.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    40.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    41.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    40.00 °C
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe    not installed
IDE06425-Dynamometer mode: functional    not active
IDE06507-MAS13125-Button in center console-Function of button 1    Start-stop
IDE06507-MAS13129-Button in center console-Function of button 2    not coded/not installed
IDE06507-MAS13132-Button in center console-Function of button 3    Driving program
IDE06507-MAS13135-Button in center console-Function of button 4    not coded/not installed
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED    LED installed
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich    not active
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt    not active
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige    not active
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik    not active
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt    not active
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start    not installed
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung    not active
IDE07356-Position during interval mode    29.999970 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein    not active
IDE08577-Garage door opener: use of GPS data    No Response From Subnet Component
IDE08578-Garage door opener: bi-directional communic.    No Response From Subnet Component
IDE08579-Garage door opener: drift adapt.    No Response From Subnet Component
IDE08580-Garage door opener: increasing transm. power    No Response From Subnet Component
IDE08583-Garage door opener: no. of channels    No Response From Subnet Component
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A    No Response From Subnet Component
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B    No Response From Subnet Component
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C    No Response From Subnet Component
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D    No Response From Subnet Component
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E    No Response From Subnet Component
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F    No Response From Subnet Component
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G    No Response From Subnet Component
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H    No Response From Subnet Component
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I    No Response From Subnet Component
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J    No Response From Subnet Component
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K    No Response From Subnet Component
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I    No Response From Subnet Component
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II    No Response From Subnet Component
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III    No Response From Subnet Component
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV    No Response From Subnet Component
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB    No Response From Subnet Component
IDE08585-Garage door opener: activation via remote key    No Response From Subnet Component
IDE08778-Garage door opener: surround. target area    No Response From Subnet Component
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active
IDE08786-ENG141956-Assistance light functions-Humidity sensor    installed
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    not active
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion    not active
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor    LIN_REGEN_LICHT_SENSOR
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor    not installed
IDE09377-IDE00761-Multi contour seat driver's side-Run-on time    No Response From Subnet Component
IDE09377-IDE03006-Multi contour seat driver's side-Running time of massage function    No Response From Subnet Component
IDE09377-IDE03007-Multi contour seat driver's side-Component location    No Response From Subnet Component
IDE09377-IDE03099-Multi contour seat driver's side-Characteristics for manual seat adjustment    No Response From Subnet Component
IDE09377-IDE03100-Multi contour seat driver's side-Characteristics for seat adjustment using memory    No Response From Subnet Component
IDE09378-IDE00761-Multicontour seat passenger side-Run-on time    No Response From Subnet Component
IDE09378-IDE03006-Multicontour seat passenger side-Running time of massage function    No Response From Subnet Component
IDE09378-IDE03007-Multicontour seat passenger side-Component location    No Response From Subnet Component
IDE09378-IDE03099-Multicontour seat passenger side-Characteristics for manual seat adjustment    No Response From Subnet Component
IDE09378-IDE03100-Multicontour seat passenger side-Characteristics for seat adjustment using memory    No Response From Subnet Component
IDE09546-Multicontour seat on driver's side: reset compressor counter    No Response From Subnet Component
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter    No Response From Subnet Component
IDE09548-Multicontour seat on driver's side: reset adaptation    No Response From Subnet Component
IDE09549-Multicontour seat on frt. pass. side: reset adaptation    No Response From Subnet Component
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.25 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    1
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    80%
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    2
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum    20%
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer    0%
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn    0%
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    active
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen    active
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten    active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    not active
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM    not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht    not installed
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel    not installed
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel    not installed
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    active
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G    not installed
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    not active
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI    not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    not installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    installed
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI    not active
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    40%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    40%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    40%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    40%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    40%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    40%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    70%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    70%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    40%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    40%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    100%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    100%
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumatics    not installed
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung    not installed
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar    installed
IDE10298-Alternating park position 1    19.999980 °
IDE10299-Alternating park position 2    24.494481 °
IDE10308-Garage door opener: support door name    No Response From Subnet Component
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode    No Response From Subnet Component
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1    No Response From Subnet Component
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2    No Response From Subnet Component
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3    No Response From Subnet Component
IDE10350-Garage door opener: programming antenna    No Response From Subnet Component
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit    1
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach    0
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum    1
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel    1
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher    1
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko    1
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd    1
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer    0
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI    0
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2    0
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3    0
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4    0
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI    0
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2    0
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3    0
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4    0
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab    1
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf    1
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI    0
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay    0
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit    100%
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach    0%
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum    100%
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht    100%
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel    100%
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher    100%
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko    100%
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd    100%
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren    100%
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit    100%
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach    0%
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum    100%
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht    100%
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel    100%
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher    100%
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko    100%
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd    100%
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren    100%
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit    100%
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach    0%
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum    100%
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht    100%
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel    100%
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher    100%
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko    100%
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd    100%
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren    100%
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit    100%
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach    0%
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum    100%
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht    100%
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel    100%
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher    100%
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko    100%
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd    100%
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren    100%
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit    100%
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach    0%
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum    100%
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht    100%
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel    100%
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher    100%
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko    100%
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd    100%
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren    100%
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit    100%
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach    0%
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum    100%
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht    100%
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel    100%
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher    100%
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko    100%
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd    100%
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren    0%
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit    100%
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach    0%
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum    100%
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht    100%
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel    100%
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher    100%
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko    100%
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd    100%
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren    100%
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit    100%
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach    0%
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum    127%
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht    100%
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel    100%
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher    100%
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko    100%
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd    100%
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren    127%
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit    126%
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach    0%
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum    126%
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht    0%
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel    126%
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher    126%
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko    126%
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd    126%
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren    126%
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit    100%
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach    0%
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum    127%
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht    100%
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel    100%
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher    100%
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko    100%
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd    100%
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren    127%
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit    100%
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach    0%
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum    126%
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht    100%
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel    100%
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher    100%
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko    100%
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd    100%
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren    126%
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit    100%
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach    0%
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum    100%
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht    100%
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel    100%
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher    100%
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko    100%
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd    100%
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren    100%
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit    100%
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach    0%
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum    127%
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht    100%
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel    100%
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher    100%
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko    100%
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd    100%
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren    100%
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit    100%
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach    0%
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum    127%
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht    100%
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel    100%
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher    100%
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko    100%
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd    100%
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren    100%
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit    100%
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach    0%
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum    100%
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht    100%
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel    100%
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher    100%
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko    100%
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd    100%
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren    100%
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte    200 ms
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit    0.0 s
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach    0.0 s
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum    0.0 s
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht    0.0 s
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko    0.0 s
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren    0.0 s
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit    0.0 s
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach    0.0 s
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum    1.0 s
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht    0.0 s
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko    0.0 s
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren    0.0 s
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit    0.0 s
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach    0.0 s
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum    0.0 s
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht    0.0 s
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko    0.0 s
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren    0.0 s
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit    0.0 s
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach    0.0 s
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum    0.0 s
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht    0.0 s
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko    0.0 s
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren    0.0 s
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit    0.0 s
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach    0.0 s
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum    0.0 s
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht    0.0 s
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko    0.0 s
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren    0.0 s
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit    0.0 s
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach    0.0 s
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum    0.0 s
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht    0.0 s
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko    0.0 s
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren    0.0 s
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit    0.0 s
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach    0.0 s
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum    0.0 s
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht    0.0 s
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko    0.0 s
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren    0.0 s
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen    0
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1    0
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10    0
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2    0
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3    0
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4    0
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5    0
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6    0
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7    0
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8    0
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9    0
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1    0
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10    0
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2    0
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3    0
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4    0
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5    0
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6    0
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7    0
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8    0
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9    0
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1    0
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10    0
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2    0
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3    0
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4    0
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5    0
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6    0
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7    0
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8    0
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9    0
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung    not installed
IDE11944-ENG141948-Keyless access and start authorization-Kessy    not installed
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen    not active
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen    active
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung    active
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung    active
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin    0
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin    0
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin    0
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin    0
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin    0
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin    0
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin    0
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin    0
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin    0
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin    0
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin    0
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin    0
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin    0
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin    0
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin    0
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin    0
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin    0
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin    0
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin    0
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin    0
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin    0
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin    0
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin    0
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin    0
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin    0
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin    0
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin    0
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin    0
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin    0
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin    0
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer    No Response From Subnet Component
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster    No Response From Subnet Component
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung    No Response From Subnet Component
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle    No Response From Subnet Component
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle    No Response From Subnet Component
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf    No Response From Subnet Component
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m    No Response From Subnet Component
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o    No Response From Subnet Component
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u    No Response From Subnet Component
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen    No Response From Subnet Component
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz    No Response From Subnet Component
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck    No Response From Subnet Component
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m    No Response From Subnet Component
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o    No Response From Subnet Component
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u    No Response From Subnet Component
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage    No Response From Subnet Component
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen    No Response From Subnet Component
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash    No Response From Subnet Component
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung    No Response From Subnet Component
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung    No Response From Subnet Component
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung    No Response From Subnet Component
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung    No Response From Subnet Component
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung    No Response From Subnet Component
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung    No Response From Subnet Component
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster    No Response From Subnet Component
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung    No Response From Subnet Component
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle    No Response From Subnet Component
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle    No Response From Subnet Component
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf    No Response From Subnet Component
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m    No Response From Subnet Component
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o    No Response From Subnet Component
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u    No Response From Subnet Component
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen    No Response From Subnet Component
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz    No Response From Subnet Component
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck    No Response From Subnet Component
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m    No Response From Subnet Component
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o    No Response From Subnet Component
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u    No Response From Subnet Component
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage    No Response From Subnet Component
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen    No Response From Subnet Component
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash    No Response From Subnet Component
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung    No Response From Subnet Component
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung    No Response From Subnet Component
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung    No Response From Subnet Component
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung    No Response From Subnet Component
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung    No Response From Subnet Component
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD    No Response From Subnet Component
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen    No Response From Subnet Component
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD    No Response From Subnet Component
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen    No Response From Subnet Component
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf    No Response From Subnet Component
IDE80016-Analysis 16    No Response From Subnet Component
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM    No Response From Subnet Component
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO    No Response From Subnet Component
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU    No Response From Subnet Component
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH    No Response From Subnet Component
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM    No Response From Subnet Component
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO    No Response From Subnet Component
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU    No Response From Subnet Component
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH    No Response From Subnet Component
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM    No Response From Subnet Component
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO    No Response From Subnet Component
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU    No Response From Subnet Component
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH    No Response From Subnet Component
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO    No Response From Subnet Component
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU    No Response From Subnet Component
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH    No Response From Subnet Component
IDE80017-ENG133480-Analysis 17-OffsetPP1    No Response From Subnet Component
IDE80017-ENG133481-Analysis 17-OffsetPP2    No Response From Subnet Component
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy    No Response From Subnet Component
IDE80017-ENG133478-Analysis 17-OffsetT1    No Response From Subnet Component
IDE80017-ENG133479-Analysis 17-OffsetT2    No Response From Subnet Component
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout    No Response From Subnet Component
IDE80017-ENG133491-Analysis 17-p_longpush_time    No Response From Subnet Component
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins    No Response From Subnet Component
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei    No Response From Subnet Component
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei    No Response From Subnet Component
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins    No Response From Subnet Component
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf    No Response From Subnet Component
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier    No Response From Subnet Component
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei    No Response From Subnet Component
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen    No Response From Subnet Component
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung    No Response From Subnet Component
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften    No Response From Subnet Component
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt    No Response From Subnet Component
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen    No Response From Subnet Component
IDE80017-ENG133465-Analysis 17-s_MaxIntervall    No Response From Subnet Component
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung    No Response From Subnet Component
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung    No Response From Subnet Component
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung    No Response From Subnet Component
IDE80017-ENG133468-Analysis 17-s_Sitzvariante    No Response From Subnet Component
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich    No Response From Subnet Component
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich    No Response From Subnet Component
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u    No Response From Subnet Component
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o    No Response From Subnet Component
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM    No Response From Subnet Component
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU    No Response From Subnet Component
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH    No Response From Subnet Component
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM    No Response From Subnet Component
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO    No Response From Subnet Component
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU    No Response From Subnet Component
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH    No Response From Subnet Component
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM    No Response From Subnet Component
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO    No Response From Subnet Component
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU    No Response From Subnet Component
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH    No Response From Subnet Component
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO    No Response From Subnet Component
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU    No Response From Subnet Component
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH    No Response From Subnet Component
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO    No Response From Subnet Component
IDE80018-ENG133480-Analysis 18-OffsetPP1    No Response From Subnet Component
IDE80018-ENG133481-Analysis 18-OffsetPP2    No Response From Subnet Component
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy    No Response From Subnet Component
IDE80018-ENG133478-Analysis 18-OffsetT1    No Response From Subnet Component
IDE80018-ENG133479-Analysis 18-OffsetT2    No Response From Subnet Component
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout    No Response From Subnet Component
IDE80018-ENG133491-Analysis 18-p_longpush_time    No Response From Subnet Component
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins    No Response From Subnet Component
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei    No Response From Subnet Component
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei    No Response From Subnet Component
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins    No Response From Subnet Component
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf    No Response From Subnet Component
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier    No Response From Subnet Component
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei    No Response From Subnet Component
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen    No Response From Subnet Component
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung    No Response From Subnet Component
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften    No Response From Subnet Component
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt    No Response From Subnet Component
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen    No Response From Subnet Component
IDE80018-ENG133465-Analysis 18-s_MaxIntervall    No Response From Subnet Component
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung    No Response From Subnet Component
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung    No Response From Subnet Component
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung    No Response From Subnet Component
IDE80018-ENG133468-Analysis 18-s_Sitzvariante    No Response From Subnet Component
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich    No Response From Subnet Component
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich    No Response From Subnet Component
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u    No Response From Subnet Component
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u    No Response From Subnet Component
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung    active
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation    Energy management active
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug    not installed
MAS01490-ENG141950-Energy management-Hybrid vehicle    No
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement    not active
MAS01490-ENG141978-Energy management-Recuperation    active
MAS01490-ENG142037-Energy management-Zweitbatterie    not installed
MAS05055-lower turn position    29.999970 °
MAS05056-upper turn position    157.494349 °
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze    1200 lx
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze    2200 lx
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle    59395 lx
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO    600 lx
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten    1200 lx
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten    2200 lx
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red    50 00
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell    2000 lx
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway    not active
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain    not active
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity    frueh
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF    not active
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe    not active
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung    37905 mV
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke    225300 lx
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung    53255 mV
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke    0 lx
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung    2
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    active
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    active
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler    not installed
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    1
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    1
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    1
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    1
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    1
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    1
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    1
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    1
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    1
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    1
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    1
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    1
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    1
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    1
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    1
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    door
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    door
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    door
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    door
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    door
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    door
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    door
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    door
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    door
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    door
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    door
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    door
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    door
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    door
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    door
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    not installed
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    0
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    0
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    0
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    0
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    not installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    not installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung    No Response From Subnet Component
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht    No Response From Subnet Component
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1    No Response From Subnet Component
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1    No Response From Subnet Component
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2    No Response From Subnet Component
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2    No Response From Subnet Component
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung    No Response From Subnet Component
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten    No Response From Subnet Component
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3    No Response From Subnet Component
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne    No Response From Subnet Component
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung    No Response From Subnet Component
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0    No Response From Subnet Component
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1    No Response From Subnet Component
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10    No Response From Subnet Component
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2    No Response From Subnet Component
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3    No Response From Subnet Component
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4    No Response From Subnet Component
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5    No Response From Subnet Component
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6    No Response From Subnet Component
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7    No Response From Subnet Component
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8    No Response From Subnet Component
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9    No Response From Subnet Component
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0    No Response From Subnet Component
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1    No Response From Subnet Component
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10    No Response From Subnet Component
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2    No Response From Subnet Component
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3    No Response From Subnet Component
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4    No Response From Subnet Component
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5    No Response From Subnet Component
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6    No Response From Subnet Component
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7    No Response From Subnet Component
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8    No Response From Subnet Component
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9    No Response From Subnet Component
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken    not active
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken    active
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger    separte
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing    not active
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken    not active
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung    not active
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10    not active
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay    50 ms
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken    not active
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken    active
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen    3
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken    not active
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2    not active
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing    not active
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links    not active
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts    not active
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken    not active
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing    not active
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    not active
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken    not active
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz    not active
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS    not active
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN    not active
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf    not active
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu    not active
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp    GDL
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze    50 km/h
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze    50 km/h
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag    Daytime running lamps
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL    5 km/h
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich    active
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument    not active
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut    not installed
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht    active
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    not active
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    not active
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO    active
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte    not active
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit    not active
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren    in Betrieb lassen
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht    No
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit    0 km/h
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA    active
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion    not active
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe    not installed
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light    not installed
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung    abschaltbar über Energiemanagement
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung    abschaltbar über Energiemanagement
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht    Aktive Begrenzung
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten    Low beam
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus    automatic
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis    Driver door
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach    not active
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig    kein_Hinweis
ENG141656-ENG133382-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer    Faktor fuer x5 Minuten
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung    46400 lx
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung    12 lx
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige    No
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker    false
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL    Yes
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht    Yes
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht    Yes
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung    Yes
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus    Enabled
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)    discrete
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten    klemmenabhaengig
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module    not installed
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome    10 seconds
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP    10 seconds
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung    active
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP    active
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert    One-sided
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus    active
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht    active
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit    24 s
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte    not active
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation    No Response From Subnet Component
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold    No Response From Subnet Component
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation    No Response From Subnet Component
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed    No Response From Subnet Component
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold    No Response From Subnet Component
ENG125611-ENG125702-Blower_1_Backrest_Left-Read_Coding_Pin    No Response From Subnet Component
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold    No Response From Subnet Component
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation    No Response From Subnet Component
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold    No Response From Subnet Component
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation    No Response From Subnet Component
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed    No Response From Subnet Component
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold    No Response From Subnet Component
ENG125612-ENG125702-Blower_1_Backrest_Right-Read_Coding_Pin    No Response From Subnet Component
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold    No Response From Subnet Component
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation    No Response From Subnet Component
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold    No Response From Subnet Component
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation    No Response From Subnet Component
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed    No Response From Subnet Component
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold    No Response From Subnet Component
ENG125609-ENG125702-Blower_1_Cushion_Left-Read_Coding_Pin    No Response From Subnet Component
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold    No Response From Subnet Component
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation    No Response From Subnet Component
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold    No Response From Subnet Component
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage    No Response From Subnet Component
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation    No Response From Subnet Component
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed    No Response From Subnet Component
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold    No Response From Subnet Component
ENG125610-ENG125702-Blower_1_Cushion_Right-Read_Coding_Pin    No Response From Subnet Component
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold    No Response From Subnet Component
ENG126647-ENG98399-debug_light_function-Activation    0
ENG126647-ENG101417-debug_light_function-Adresse    0
ENG126647-ENG126820-debug_light_function-Bitmask    0
ENG126647-ENG126821-debug_light_function-Divisor    0
ENG126647-ENG98827-debug_light_function-Offset    0
ENG126647-ENG126822-debug_light_function-Polaritaet    0
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0    0.00%
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1    50.00%
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2    100.00%
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0    0.00%
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1    50.00%
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2    100.00%
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD    No Response From Subnet Component
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen    No Response From Subnet Component
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD    No Response From Subnet Component
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen    No Response From Subnet Component
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf    No Response From Subnet Component
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN    No Response From Subnet Component
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM    No Response From Subnet Component
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION    No Response From Subnet Component
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK    No Response From Subnet Component
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK    No Response From Subnet Component
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK    No Response From Subnet Component
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK    No Response From Subnet Component
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK    No Response From Subnet Component
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK    No Response From Subnet Component
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK    No Response From Subnet Component
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN    No Response From Subnet Component
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND    No Response From Subnet Component
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB    No Response From Subnet Component
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM    No Response From Subnet Component
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM    No Response From Subnet Component
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK    No Response From Subnet Component
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK    No Response From Subnet Component
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE    No Response From Subnet Component
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1    No Response From Subnet Component
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2    No Response From Subnet Component
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3    No Response From Subnet Component
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4    No Response From Subnet Component
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1    No Response From Subnet Component
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2    No Response From Subnet Component
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3    No Response From Subnet Component
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4    No Response From Subnet Component
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1    No Response From Subnet Component
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2    No Response From Subnet Component
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3    No Response From Subnet Component
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4    No Response From Subnet Component
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH    No Response From Subnet Component
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW    No Response From Subnet Component
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT    No Response From Subnet Component
ENG122925-DWA_Interior_Monitoring_Data_Set_Development    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG122934-erase_error_table    00 00 00
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP    present
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    AFS: BCM-Fernlicht
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    active
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    not installed
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    not installed
ENG141685-Front_wash_function    17
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA    not active
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung    800 ms
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm    active
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf    active
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition    not active
ENG141682-ENG141966-Front_wiper-Frontwischertyp    LIN
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer    not active
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer    0 ms
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren    Deactivating
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay    0 ms
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz    active
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status    not active
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung    active
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant    not active
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube    not active
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus    active
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube    not active
ENG99457-ENG117394-Head area heater-blower_speed    1
ENG99457-ENG98971-Head area heater-Temperature    -2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid    installed
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid    installed
ENG141645-MAS00213-HW_Verbau-Insufficient coolant    installed
ENG141645-MAS00214-HW_Verbau-Brake pad wear    installed
ENG141645-ENG142026-HW_Verbau-Druckklappe    not installed
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv    not active
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung    installed
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor    installed
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube    installed
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung    not installed
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer    not installed
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15    active
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung    not active
ENG126651-ENG115658-Kennlinie Abdimmen-x0    No Response From Subnet Component
ENG126651-ENG101574-Kennlinie Abdimmen-X1    No Response From Subnet Component
ENG126651-ENG115664-Kennlinie Abdimmen-x10    No Response From Subnet Component
ENG126651-ENG99557-Kennlinie Abdimmen-X2    No Response From Subnet Component
ENG126651-ENG102140-Kennlinie Abdimmen-X3    No Response From Subnet Component
ENG126651-ENG102936-Kennlinie Abdimmen-X4    No Response From Subnet Component
ENG126651-ENG103548-Kennlinie Abdimmen-X5    No Response From Subnet Component
ENG126651-ENG113992-Kennlinie Abdimmen-X6    No Response From Subnet Component
ENG126651-ENG115661-Kennlinie Abdimmen-x7    No Response From Subnet Component
ENG126651-ENG115662-Kennlinie Abdimmen-x8    No Response From Subnet Component
ENG126651-ENG115663-Kennlinie Abdimmen-x9    No Response From Subnet Component
ENG126651-ENG115659-Kennlinie Abdimmen-y0    No Response From Subnet Component
ENG126651-ENG99777-Kennlinie Abdimmen-Y1    No Response From Subnet Component
ENG126651-ENG115668-Kennlinie Abdimmen-y10    No Response From Subnet Component
ENG126651-ENG100480-Kennlinie Abdimmen-Y2    No Response From Subnet Component
ENG126651-ENG100773-Kennlinie Abdimmen-Y3    No Response From Subnet Component
ENG126651-ENG100631-Kennlinie Abdimmen-Y4    No Response From Subnet Component
ENG126651-ENG102174-Kennlinie Abdimmen-Y5    No Response From Subnet Component
ENG126651-ENG113993-Kennlinie Abdimmen-Y6    No Response From Subnet Component
ENG126651-ENG115665-Kennlinie Abdimmen-y7    No Response From Subnet Component
ENG126651-ENG115666-Kennlinie Abdimmen-y8    No Response From Subnet Component
ENG126651-ENG115667-Kennlinie Abdimmen-y9    No Response From Subnet Component
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0    -100.00%
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1    -83.00%
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2    -67.00%
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3    -50.00%
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4    -33.00%
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5    -17.00%
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6    0.00%
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7    0
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8    0.00%
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9    0.00%
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0    20.00%
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1    30.00%
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2    41.00%
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3    48.00%
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4    55.00%
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5    58.00%
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6    62.00%
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7    62.00%
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8    62.00%
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9    62.00%
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    127
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    33 - LED-Modul Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15    maximize
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15    maximize
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15    maximize
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15    100
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15    0
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15    0
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15    0
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15    0
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15    0
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15    36 - LED Kleinleistung
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15    Always
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15    Unknown (76)
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15    not active
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15    not active
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15    not active
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15    not active
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15    not active
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15    not active
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15    not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    Abbiegelicht links
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    Abbiegelicht rechts
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    0
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    0
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    not active
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    0
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    0
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    127
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    33 - LED-Modul Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    2B
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    9
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    34 - LED Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    not active
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    2D
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    19
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    34 - LED Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    not active
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    32
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    34 - LED Bremsleuchten
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    Quittierungsfunktion 1
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    100
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    32 - allgemeine LED bis 12W
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    not active
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    100
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    32 - allgemeine LED bis 12W
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    Parking light right
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    not active
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    127
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    2F
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    1C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    9 - allgemeine Glühlampe 27W: auch H15
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    only_if_closed
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    0
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    0
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    not active
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    not active
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    minimize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    27
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    100
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    10
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    Daytime running lamps
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    Blinken links aktiv (beide Phasen)
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    100
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    20 - 4* 5W
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    Footwell lamp
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    3
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    Ambientelicht 1
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    4
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    Ambientelicht 2
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    5
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    Ambientelicht 3
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    6
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    Ambientelicht 4
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    minimize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    27
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    100
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    10
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    Parking light right
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    Daytime running lamps
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    Blinken rechts aktiv (beide Phasen)
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    127
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    0
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    48
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    Daytime running lamps
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    not active
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    127
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    0
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    4C
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    Daytime running lamps
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    Parking light right
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    not active
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    0
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    0
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    0
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    not active
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    not active
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    not active
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    0
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    0
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    0
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    not active
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    not active
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    not active
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck    0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 64 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 64 00 00 00 00 00 00 00 00 00 22 29 00 2C 18 00 64 24 00 20 00 00 00 00 00 00 20 0A 00 29 08 09 64 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 64 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 09 1C 00 2F 1A 00 E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 0B 00 31 19 00 64 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00
ENG141662-Leuchtenkonfiguration_Sonstiges    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR    1-Sensor_LWR
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges    2700 mm
ENG141658-ENG142218-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4    5.00 mm/%
ENG141658-ENG142217-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn    3.00 mm/%
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe    not active
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze    100.00%
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze    0.00%
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz    15%
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe    10.0 s
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1    5.00 mm/%
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2    5.00 mm/%
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1    3.00 mm/%
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2    3.00 mm/%
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante    Verbundlenkerhinterachse
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR    62.00%
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf    0.03 Hz
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung    0
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal    Negative
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1    0 mm
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2    0 mm
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3    0 mm
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4    0 mm
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand    550 mm
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe    680 mm
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle    95.00%
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle    5.00%
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr    255 km/h
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr    100 Hz
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung    0.03 Hz
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte    BCM
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed    Rear
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht    active
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese    0.00%
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart    not active
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad    1000.0 %/s
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht    0.00%
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut    not installed
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR    0.00 s
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1    not active
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2    not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3    not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4    not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5    not active
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6    not active
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ    not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.5
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0    -3.71%
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1    -2.96%
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2    -2.04%
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3    -1.48%
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4    -0.37%
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0    -0.2
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1    -0.1
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2    -0.05
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3    -0.01
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4    0
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband    No Response From Subnet Component
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck    No Response From Subnet Component
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte    No Response From Subnet Component
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben    No Response From Subnet Component
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten    No Response From Subnet Component
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen    No Response From Subnet Component
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1    No Response From Subnet Component
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2    No Response From Subnet Component
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3    No Response From Subnet Component
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation    No Response From Subnet Component
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband    No Response From Subnet Component
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck    No Response From Subnet Component
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte    No Response From Subnet Component
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben    No Response From Subnet Component
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten    No Response From Subnet Component
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen    No Response From Subnet Component
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1    No Response From Subnet Component
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2    No Response From Subnet Component
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3    No Response From Subnet Component
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation    No Response From Subnet Component
ENG122979-ENG141954-Networking-A/C electronics    installed
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet    not installed
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet    installed
ENG122979-ENG141953-Networking-Getriebesteuergeraet    installed
ENG122979-ENG99457-Networking-Head area heater    not installed
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG    not installed
ENG122979-ENG141969-Networking-UGDO    not installed
ENG124714-ENG142044-OCU-DWA_push    not active
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare    not active
ENG124714-OCU-    not installed
ENG124714-ENG142261-OCU-Remote HuF Abbruch    20 km/h
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz    3
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1    80 s
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3    20.0 ms
ENG124714-ENG125657-OCU-Remote_Unlock_Lock    not_active
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I    No Response From Subnet Component
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I    No Response From Subnet Component
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy    No Response From Subnet Component
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy    No Response From Subnet Component
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN    No Response From Subnet Component
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM    No Response From Subnet Component
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION    No Response From Subnet Component
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK    No Response From Subnet Component
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK    No Response From Subnet Component
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK    No Response From Subnet Component
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK    No Response From Subnet Component
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK    No Response From Subnet Component
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK    No Response From Subnet Component
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK    No Response From Subnet Component
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN    No Response From Subnet Component
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND    No Response From Subnet Component
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB    No Response From Subnet Component
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM    No Response From Subnet Component
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM    No Response From Subnet Component
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK    No Response From Subnet Component
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK    No Response From Subnet Component
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE    No Response From Subnet Component
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1    No Response From Subnet Component
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2    No Response From Subnet Component
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3    No Response From Subnet Component
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4    No Response From Subnet Component
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1    No Response From Subnet Component
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2    No Response From Subnet Component
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3    No Response From Subnet Component
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4    No Response From Subnet Component
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1    No Response From Subnet Component
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2    No Response From Subnet Component
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3    No Response From Subnet Component
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4    No Response From Subnet Component
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH    No Response From Subnet Component
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW    No Response From Subnet Component
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT    No Response From Subnet Component
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar    active
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten    4
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung    not active
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    active
ENG98831-ENG126848-Personalization-Personalisierung_aktiv    active
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion    profiles_active
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    active
ENG98831-ENG142030-Personalization-Profil_Variante    Konto (v. 1.x)
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1    active
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2    active
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3    active
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4    not active
ENG141646-MAS01065-Querschnitts_funktionen-Brand    Skoda
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll    active
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung    active
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung    not active
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21    not active
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus    Pin 31
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben    active
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme    not_installed
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem    not active
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment    Right
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side    Left
ENG125614-Reset_Blower_1_Backrest_Left    No Response From Subnet Component
ENG125615-Reset_Blower_1_Backrest_Right    No Response From Subnet Component
ENG125613-Reset_Blower_1_Cushion_Left    No Response From Subnet Component
ENG125616-Reset_Blower_1_Cushion_Right    No Response From Subnet Component
ENG122927-RLS_close_glazing    2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off    120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on    10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off    65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on    140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle    6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high    12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low    6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht    30 s
ENG122929-RLS_LIN_Communication    4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn    200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day    500 lx
ENG122930-RLS_tunel_gateway_recognize    5 s
ENG122935-RLS_Washer_Front    15 s
ENG122926-RLS_wiper_position_parking    15 s
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system    installed
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel    active
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit    1000 ms
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit    1000 ms
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit    0 ms
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit    0 ms
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit    800 ms
ENG141684-SFT271873-Slave_systems_identification-Wiper motor control module    Not available
ENG141684-SFT271874-Slave_systems_identification-Rain/Light Recognition Sensor    Not available
ENG141684-SFT271875-Slave_systems_identification-Light switch    Not available
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module    Not available
ENG141684-SFT271877-Slave_systems_identification-Garage door opener control head    Not available
ENG141684-SFT271894-Slave_systems_identification-Anti-theft alarm system sensor    Not available
ENG141684-SFT271896-Slave_systems_identification-Alarm horn    Not available
ENG141684-SFT271904-Slave_systems_identification-Sunroof control module    Not available
ENG141684-SFT271910-Slave_systems_identification-Roof electronics control module    Not available
ENG141684-SFT271928-Slave_systems_identification-Roof shade control module    Not available
ENG141684-SFT271947-Slave_systems_identification-Humidity sensor: interior    Not available
ENG141684-SFT271966-Slave_systems_identification-Left head area heater    Not available
ENG141684-SFT271967-Slave_systems_identification-Right head area heater    Not available
ENG141684-SFT272065-Slave_systems_identification-Blower 1 for left front backrest    Not available
ENG141684-SFT272067-Slave_systems_identification-Blower 1 for left front seat cushion    Not available
ENG141684-SFT272069-Slave_systems_identification-Blower 1 for right front backrest    Not available
ENG141684-SFT272071-Slave_systems_identification-Blower 1 for right front seat cushion    Not available
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker    SMLS
ENG116588-Sonderfunktionen-    not enabled
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1    not installed
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen    active
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus    by look command via remote control key
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen    active
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung    active
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung    active
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel    not active
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung    active
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt    active
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung    active
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron    active
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0    0.0 lx
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1    8.0 lx
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2    50.0 lx
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3    80.0 lx
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4    100.0 lx
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0    6
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1    6
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2    20
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3    50
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4    100
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0    0.0 lx
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1    8.0 lx
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2    50.0 lx
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3    80.0 lx
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4    100.0 lx
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0    6
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1    6
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2    20
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3    50
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4    100
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0    0 ms
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1    100 ms
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10    1000 ms
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2    200 ms
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3    300 ms
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4    400 ms
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5    500 ms
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6    600 ms
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7    700 ms
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8    800 ms
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9    900 ms
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0    100.00%
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1    78.00%
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10    0.00%
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2    59.00%
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3    44.00%
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4    33.00%
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5    24.00%
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6    17.00%
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7    12.00%
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8    7.00%
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9    3.00%
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM    0.00 s
ENG141663-ENG142236-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM    0.00 s
ENG141663-ENG142238-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM    0.00 s
ENG141663-ENG142239-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM    0.00 s
ENG141663-ENG142237-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM    0.00 s
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung    HMI
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen    0.0 s
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen    0.0 s
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe    not active
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten    not_active
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung    active
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS    0
ENG141663-ENG142235-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM    0.00 s
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert    100%
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl    Fotosensor_Kombi
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung    Always active
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor    0.1
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert    20.00%
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0    0
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1    50
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10    0
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2    100
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3    200
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4    253
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5    0
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6    0
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7    0
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8    0
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9    0
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0    0 lx
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1    50 lx
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10    0 lx
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2    100 lx
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3    200
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4    500
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5    0
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6    0 lx
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7    0 lx
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8    0 lx
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9    0 lx
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0    0 ms
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1    100 ms
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10    1000 ms
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2    200 ms
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3    300 ms
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4    400 ms
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5    500 ms
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6    600 ms
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7    700 ms
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8    800 ms
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9    900 ms
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0    0.00%
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1    3.00%
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10    100.00%
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2    7.00%
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3    12.00%
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4    17.00%
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5    24.00%
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6    33.00%
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7    44.00%
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8    59.00%
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9    78.00%
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0    0 lx
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1    8 lx
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2    50 lx
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3    500 lx
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0    100
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1    100
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2    100
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3    100
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0    0 lx
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1    8 lx
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2    50 lx
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3    510 lx
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0    6
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1    6
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2    100
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3    100
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0    0.00%
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1    6.00%
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2    16.00%
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3    30.00%
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4    60.00%
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5    100.00%
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0    10
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1    10
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2    100
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3    150
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4    220
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5    253
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0    0 lx
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1    8 lx
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2    200 lx
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3    300 lx
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4    500 lx
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0    16
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1    16
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2    100
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3    100
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4    100
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0    0 lx
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1    8 lx
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2    220 lx
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3    300 lx
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4    500 lx
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0    6
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1    6
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2    100
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3    100
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4    100
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0    0
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1    10
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2    50
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3    100
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4    220
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5    253
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0    2.00%
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1    2.00%
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2    6.00%
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3    10.00%
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4    80.00%
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5    100.00%
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0    0 lx
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1    8 lx
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2    50 lx
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3    500 lx
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0    6
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1    6
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2    100
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3    100
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0    0 lx
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1    8 lx
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2    50 lx
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3    500 lx
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0    100
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1    100
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2    100
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3    100
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0    0.00%
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1    50.00%
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2    100.00%
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0    0.00%
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1    50.00%
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2    100.00%
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0    0 lx
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1    200 lx
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2    400 lx
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3    600 lx
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4    800 lx
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5    1020 lx
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0    0
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1    84
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2    166
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3    250
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4    370
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5    500
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0    0 ms
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1    2000 ms
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2    3000 ms
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3    4000 ms
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4    5100 ms
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0    1.00%
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1    5
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2    15
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3    40
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4    100
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen    not active
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen    not active
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen    tilting
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1    not installed
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3    not installed
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo    not installed
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule    LIN
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck    not_installed
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck    active
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv    not active
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb    not active
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close    not installed
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global    active
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen    active
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen    active
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf    not active
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen    not active
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung    nur wenn mind. 1 Raste zu
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden    Always
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit    installed
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach    not active
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung    active
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy    active
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder    active
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung    active
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy    active
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder    active
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal    not active
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba    not active
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau    not installed
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw    0 bit
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute    40
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute    60
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute    30
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB    not active
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern    not active
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein    not active
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein    not active
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt    installed
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster    installed
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion    not active
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung    active
ENG141651-ENG115755-ZV allgemein-Notschließfunktion    active
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung    not active
ENG141651-ENG141957-ZV allgemein-Radio freq.    434.42MHz
ENG141651-ENG141958-ZV allgemein-Tankschloss    Bidirectional
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum    Freigabe_Softtouch
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung    Einzeltuerentriegelung
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion    not installed
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck    active
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln    active
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit    active
ENG141654-ENG116706-ZV Autolock-Autounlock NAR    not active
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock    adjustable
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen    not active
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash    not active
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels    active
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster    via_pin
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung    not active
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen    not active
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste    Yes
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung    Kontaktsteuerung mit Mindestansteuerzeit
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster    0.6 s
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang    No
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel    active
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen    not active
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp    1 or 2 notch rear actuator
ENG141681-IDE02021-ZV Komfort-Comfort closing    active
ENG141681-IDE02022-ZV Komfort-Comfort opening    active
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten    Yes
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen    active
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen    active
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit    600 s
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus    active
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen    active
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen    active
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen    active
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global    active
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer    not active
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar    adjustable
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen    not active
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art    once
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus    not active
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen    active
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen    active
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss    Tuersteuergeraet im Fond verbaut oder keine Fondtuer
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal    nicht invertiert
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite    not installed
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite    not installed
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links    No
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts    No
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter    not installed
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM    Driver side
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR    No
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer    Yes
Elapsed Time: 01:43
langers2k
C?ID=224085
At a guess, you need to change these two values to something lower, for example 75:
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    100
professorchris
C?ID=580099
Response to Langers2k:
Thank you, Langers2k, for your suggestion.
At first glance it looks simple and obvious but, alas, I fear it is more complex (or maybe I want to make it more complex).
In line with true tradition, I think time will tell.
Your suggestion immediately invoked doubt (based on my attempts and experience to date, not a lack of faith in you, this forum and its members. I am a mere baby in the VCDS world), but then I looked at my admap again (I have spent so many hours in translating and studying that map! -I modified my spreadsheet to have both German and English columns. A very worthwhile modification) and it (thanks to your message) triggered a new train of thought:
Although my car has one light tube (per side) for sidelights and DRLs, it has two leuchte channels for (a logical assumption) separate LEDs, i.e. Leuchte 2SL & 3SL for sidelights (standlicht), and Leuchte 4TFL & 5TFL for DRLs (Tag Fahr Licht), driven, respectively, by "LED Tagfahrlichtmodul Signal" and "LED Tagfahrlichtmodul Versorgung", which I automatically take to mean two separate, physical LED driver modules.
And so my sudden, new train of thought is this: Isn’t it strange to have one light tube (per side) illuminated by two separate LEDs (SL and TFL) (not forgetting the amber LED for direction indicators, but that’s an entirely separate subject) with their own separate driver modules (controlled in turn by the BCM).
Maybe, just maybe, there is just one LED driving both sidelight AND the DRL (which makes complete sense), but driven by separate hypothetical, digital, purely software, drivers (that makes less sense if there’s only one LED. In fact it makes no sense!).
The names of the two modules don’t translate into anything glaringly obvious or particularly helpful (“Tagfahrlichtmodul Signal” = DRL module signal, and “Tagfahrlichtmodul Versorgung” = DRL module supply).
(Maybe I am totally misunderstanding the term "module" here)
It is also interesting to note that the two modules’ dimming values are given in different numerical formats, ie. A binary 127 value (equating to 100, or 100%) for the “versorgung” module, but a purely decimal 100 value (again equating to 100, or 100%) for the “signal” module.
Maybe all of this has been discussed in other posts, and is fully understood by others (please feel free to point me in the right direction), in which case I apologise for putting my thoughts, theories, and confusion into what seems to have become a long winded post, but I have searched and read much on this forum (and others) finding little discussion on it. Maybe my car is more complicated than some (unlikely). Maybe I am more complicated than some (very likely). I do definitely have a need to fully understand and I’m sure I’m not alone in this. Perhaps this post will assist others, not just me, in continuing to understand the complexities of modern car electrics and electronics.
It suddenly stands out that, although I have separate Leuchte channels for SL and TFL, the SL channel also contains a function for DRL on channel C, as well as position light, sidelight, and parking light on channels A & B (even tail light gets a mention here, which I find odd), and so perhaps there is an intermingling of the 2 & 3SL and 4 & 5TFL Leuchte sets which isn’t immediately apparent.
In conclusion, Langers2K, as you suggested, I will experiment with the 2 & 3SL dimming settings for channel C (which I totally ignored in favour of the more obvious 4 & 5TFL dimming), and see what happens.
I will report back.
downtime
Finland
C?ID=280813
And it might or might not work. You have led lights and in many newer VAG group cars the light dimming is controlled by the software in the LED module itself. So regardless to what you set the dimming value, it has no impact on the led tube itself.
Only way to find out is experiment. If @langers2k tip does not work, then no way to dim. The flash file is not modifiable, at least not easy.
professorchris
C?ID=580099
Thank you downtime,
The concept of dimming (or more correctly I suppose, power control/current limiting) being in the LED unit itself is an interesting addition to my query.
I wonder how many people have come across this curious problem?
downtime
Finland
C?ID=280813
Yes, that's correct. When the lights are not controlled by BCM but light control module, LCM, then the dimming function is controlled by the light modules themselves.
As you have this adaptation value in BCM set like this :
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module not installed
It means your lights are directly controlled via BCM so the channels posted above and changing their value should do the trick for you :)
langers2k
C?ID=224085
In this instance, my logic is very simple...
I looked at the following channels:
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    27
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    10
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    Daytime running lamps
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    Blinken links aktiv (beide Phasen)
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    27
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    100
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    10
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    Parking light right
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    Daytime running lamps
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    Blinken rechts aktiv (beide Phasen)
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    127
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    Daytime running lamps
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    127
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    Daytime running lamps
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    Parking light right
To me, that suggests that 4/5 are providing power to the LED modules whereas 2/3 are brightness. That would also tally with the LEDs flickering when you started to PWM the power pins :)
Hopefully it works and there is nothing more complex in this instance as Downtime alludes to.
professorchris
C?ID=580099
I have good news,
The leuchte setup perplexes me (that's not the good news).
My electrical and electronics engineering background (with some software included) leads me to interpret it as two separate physical circuits, i.e. one for front DRLs (TFL) and one for front sidelights (SL), but I am totally wrong in my interpretation.
As suggested by langers2k, the SL leuchte does indeed control the TFL leuchte dimming, despite the TFL appearing to be its own independant leuchte set.
And so:
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 100 > 70
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 100 > 70
does dim the 4 & 5TFL leuchte set.
I can clearly see the DRLs dim when changed from 100 to 70, but I can barely see the side by side difference from a distance in daylight. (a setting of 27 gives sidelight-level brighness as expected)
Job done. Thank you both for your help and input.
