2013 Porsche Cayenne coding
alinjdm
Romania
C?ID=582959
Hello, I have an acquaintance with a 2013 Porsche Cayenne that wants some things coded on their car. I know that Porsches are not officially supported but I was wondering if this model can be coded at all. Thanks in advance.
alinjdm
Romania
C?ID=582959
At the moment I can't, tomorrow when I have some spare time from work I will go check out the car.
alinjdm
Romania
C?ID=582959
Ok, so quick update, I tried doing an auto scan but it just reads the VIN and saying "Function not supported by the Gateway" (my dumbass managed to delete the txt of the autoscan) so I guess I need to build an adapter and connect pin 3 to pin 7 and see if it works then.
Jacek
Poland
C?ID=360566
You need to select from the dropdown list as;
Chassis type: 92-VW52 (9P - Porsche Cayenne).
No adapter needed.
Open the RossTech folder, in the Autoscan text document
remove semicolons ( ; ) before Porsche.
The Porsche will now appear in the vehicle drop-down list.
ZF,Lamborghini Huracan NAR (2013 >),00
ZL,Lamborghini Urus (2018 >),00
;9P,Porsche Cayenne,01,02,03,05,06,08,09,11,13,15,16,17,18,19,1C,22,29,32,34,36,37,39,3C,46,47,55,56,57,64,65,68,69,6C,6D,6E,75,76,77
;92,Porsche Cayenne,01,02,03,08,10,15,16,17,18,19,34,36,40,42,44,51,52,53,55,61,62,6D,72
;A2,Porsche Cayenne NAR,01,02,03,08,10,15,16,17,18,19,34,36,40,42,44,51,52,53,55,61,62,6D,72
;97,Porsche Panamera,00
;A7,Porsche Panamera NAR,00
UY,MAN TGE Panel Van (2017 >),00 "
alinjdm
Romania
C?ID=582959
Hmm, I don't have any Porsche option in the dropdown list. Do you mind telling me how to make it show up?
Jacek
Poland
C?ID=360566
alinjdm
Romania
C?ID=582959
Thank you very much!!
alinjdm
Romania
C?ID=582959
Ok, so I managed to get to the car again and used said settings and managed to get an autoscan but when I go to code the car when I go to 09. Central Electronics and enter security access code 20113 it says that the code is incorrect (I want to code the car to start with the Start/Stop system disabled as the button to toggle it on or off was damaged and no longer works).
Saturday,08,June,2024,13:58:18:47655
VCDS Version: 24.5.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WP1ZZZ92ZDLA21202   License Plate:
Chassis Type: 92-N/A (92 - Porsche Cayenne)
Scan: 01 02 03 08 10 15 16 17 18 19 34 36 40 42 44 51 52 53 55 61
          62 6D 72
Address 01: Engine (J623-CRCA)       Labels: None
   Part No SW: 7P5 907 401 D    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---    CVN: B187F94E
   Coding: 2F2A4012A32E03020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P5907401D 001003
   ROD: N/A
   VCID: 353C4D3D15CAD4D2B45-8060
   VINID: 9E006AAAA242A9471108108008868C06A4
No ASAM data for: "EV_ECM30TDI0117P5907401D" (VW52)
14585 - ROD - Unknown Error Code
          - 00 [01101101]
                    Mileage: 221153 km
                    Date: 2024.05.02
                    Time: 11:31:54
10586 - ROD - Unknown Error Code
          - 00 [00100000]
                    Mileage: 221153 km
                    Date: 2024.05.02
                    Time: 11:31:54
Address 02: Auto Trans (J217)       Labels:. 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 749 CM    HW: 0C8 927 749 CM
   Component: AL1000 AISIN  001 2101
   Serial number:                CVN: D46398CC
   Coding: 00B568
   ROD: N/A
   VCID: 0154E9ED1182A87258D-8054
No ASAM data for: "EV_TCMAL991031" (VW37)
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 L    HW: 7P0 907 379 A
   Component: MK25A         H36 0434
   Revision: --------    Serial number: 414320010EC815 Dataset Number:             A001
   Coding: DB7C33690B810563DB7ECC66D05CA0503700
   Shop #: WSC 00256 168 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 46DE3AF1782C4F4A2DF-8012
   Part No SW: 7P5 907 040 AG    HW: 7P5 907 040 AG
   Component: BKE_VORN  21 1620
   Revision: 02013000    Serial number: 00000000002313
   Coding: 0880960900000000
   ASAM Dataset: BKE__ 120007
   ROD: N/A
   VCID: 78A284094258E9BA6F3-802C
   Component: BE_DISKRET  0000 0000
   Subsystem 3 - Part No: 7P5 927 127 CG
011 X008
   Subsystem 6 - Part No: 7P5 927 127 CG
011 X008
No ASAM data for: "BKE__" (VW52)
33537 - ROD - Unknown Error Code
          - 00 [00001000]
                    Fault Frequency: 105
                    Reset counter: 33
                    Mileage: 3584 km
                    Date: 2099.05.01
                    Time: 17:48:54
Address 10: Park/Steer Assist (----)       Labels: None
   Part No SW: 7P5 919 475 C    HW: 7P5 919 475 C
   Component: ParkAssistant H08 0004
   Revision: --------    Serial number: 11931214801535
   Coding: 000002
   ASAM Dataset: ParkAssistant8K 080003
   ROD: N/A
   VCID: 42D626E15404736A017-8016
No ASAM data for: "ParkAssistant8K" (VW52)
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag50Q H05 0025
   Revision: --------    Serial number: 003L0003G4RV Dataset Number: 7P5003p____ 0249
   Coding: 000000000000000000000000000000003051
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41D429ED5102687218D-8014
   Serial number: 3575LRB40531C4LG599$
   Serial number: 3585LRB404P1C4LI2HBR
   Serial number: 3515RRB406318BCIA0F
   Serial number: 3525RRB406118BCI91AW
   Serial number: 3555NRB40124UE20QOU1
   Serial number: 3565NRB40144UE20MHDJ
Address 16: Steering wheel        Labels: None
   Part No SW: 7P5 953 507 EG    HW: 7P5 953 507 EG
   Component: KLSM          011 1100
   Revision: ÿÿÿÿÿÿÿÿ    Serial number: X0001LET000BB  Dataset Number: ÿÿÿÿÿÿÿÿÿÿÿ ÿÿÿÿ
   Coding: 936B03
   ASAM Dataset: E2_KLSM 000034
   ROD: N/A
   VCID: 055CFDFD05AA8452645-8050
No ASAM data for: "E2_KLSM" (VW52)
Address 17: Instruments        Labels: None
   Part No SW: 7P5 920 904 AB    HW: 7P5 920 904 AB
   Component: KIE2 V6_Dÿÿÿÿ 005 4512
   Revision: 00000000    Serial number:         000927
   Coding: 5C038D52BA9100
   ASAM Dataset: Kombiinstrument 000014
   ROD: N/A
   VCID: 77A087354F46E6C2669-8022
No ASAM data for: "Kombiinstrument" (VW52)
40967 - ROD - Unknown Error Code
          - 00 [10001000]
                    Reset counter: 3
                    Mileage: 560643 km
40998 - ROD - Unknown Error Code
          - 00 [10001000]
                    Fault Priority: 8
                    Reset counter: 3
                    Mileage: 560643 km
41030 - ROD - Unknown Error Code
          - 00 [10001000]
                    Reset counter: 3
                    Mileage: 560643 km
41512 - ROD - Unknown Error Code
          - 00 [10001000]
                    Reset counter: 3
                    Mileage: 583681 km
                    Date: 2124.02.11
                    Time: 20:36:13
41591 - ROD - Unknown Error Code
          - 00 [10001000]
                    Reset counter: 3
                    Mileage: 560643 km
Address 19: CAN Gateway        Labels: None
   Part No SW: 7PP 907 530 P    HW: 7PP 907 530 P
   Component: zentr Gateway 220 1042
   Revision: 00000000    Serial number: 2341B565812514 Dataset Number: 00000000000 0000
   Coding: 0011
   ASAM Dataset: CAN/CAN Gateway A4.1
   ROD: N/A
   VCID: 5F90CF95C7B63E820E9-800A
No ASAM data for: "CAN/CAN Gateway" (VW52)
12656659 - ROD - Unknown Error Code
          - 00 [00001000]
                    Fault Frequency: 76
                    Reset counter: 3
                    Mileage: 1040767 km
                    Date: 2080.11.05
                    Time: 21:48:61
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 S    HW: 7P0 907 553 S
   Component: PASM          H01 1700
   Revision: 00000000    Serial number: 00000121530480
   Coding: 42510000
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 47C037F57F265642D69-8012
   Part No SW: 4H0 959 793 P    HW: 4H0 959 793 P
   Component: TSG FA        H02 0302
   Revision: --------    Serial number: 0000031739636
   Coding: 010E022070A04300138C0000
   VCID: 46DE3AF178AC4F4A2DF-8012
                    Reset counter: 76
                    Mileage: 221153 km
                    Date: 2024.05.02
                    Time: 11:32:04
   Part No SW: 4H0 959 792 M    HW: 4H0 959 792 M
   Component: TSG BF        H02 0302
   Revision: --------    Serial number: 0000031767038
   VCID: 42D626E15484736A017-8016
                    Reset counter: 76
                    Mileage: 221153 km
                    Date: 2024.05.02
                    Time: 11:32:04
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1252300369    Dataset Number:             A001
   Coding: 01030100
   ROD: EV_ParkbA7.rod
   VCID: 363E4A3108CCDFCABDF-8062
   Slave 3:
0033 - Dynamic Start Assist Function Not Available
          C10DE 00 [00001000] - -
                    Reset counter: 78
                    Mileage: 221153 km
                    Date: 2024.05.01
                    Time: 11:44:54
                    Voltage: 14.2 V
Address 55: Headlight Range        Labels: None
   Part No SW: 7P5 907 381 B    HW: 7P5 907 381 B
   Component: SWSG_RE 1.2 0900
   Revision: 3476883     Serial number: 12052921007491 Dataset Number: XXXXXXXXXXX 0900
   Coding: 1E840C
   ASAM Dataset: SWSG_RE 020003
   ROD: N/A
   VCID: 3A265E013CD43BAA597-806E
No ASAM data for: "SWSG_RE" (VW52)
   Part No SW: 4H0 959 795 J    HW: 4H0 959 795 J
   Component: TSG HL        H02 0302
   Revision: --------    Serial number: 0000031588304
   Coding: 010E002021A0230013880000
   Component: TSG HR        H02 0302
   Revision: --------    Serial number: 0000031588158
End----------(Elapsed Time: 02:52, VBatt start/end: 12.4V/12.4V)-----------
Hard to say what's going on there since there is no 09 in this scan, probably because the line in the Auto-Scan file doesn't specify 09..
Jacek
Poland
C?ID=360566
In my scan, 09 was not on the list, but in the scan it was (car from 2014);
Address 09: Central electrical unit Label file: None
Element designation SW: 7PP 907 064 HJ HW: 7PP 907 064 HJ
Component: BCM_VORNE D50 2900
Verification: 00000000
Coding: 02000040616D10351C07C115A83E0101010100EC3E0000000003079F
Service code: WSC 00000 000 00000
ASAM dataset: BCM_VORNE 020030
ROD: N/A
VCID: A30665B0AA632A953F-80F6
No ASAM data for: "BCM_VORNE" (VW52)
alinjdm
Romania
C?ID=582959
Indeed, the Auto-Scan file does not specify 09. If I ever get the chance to test another Cayenne I will send another Auto-Scan, the more the merrier. Edit: grammar.
