2014 Q5 TDI - Where to start , getting "Alternator Failure Battery Not Charging" message.
Brianlac
Portsmouth, NH, USA
C?ID=174529 (NRRT)
Recently the front Rear Differential mount failed resulting in the rear differential and drive shaft raising up and hitting the underside of the car. There are two wiring harnesses in this area and I'm concerned that it damaged the wires in one of them since the Alternator Failure began right after this problem. I have run a scan but it has so many errors I don't know where to start and would appreciate any guidance that can be provided.
Here's the latest scan.
Thursday,06,June,2024,10:58:30:30130
VCDS Version: 24.5.0.0 (x64)
VIN: WA1CMAFP5EA078894   License Plate:
Mileage: 251540km-156299mi   Repair Order: 0606241
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62
          69 6C 6D 72 AC
VIN: WA1CMAFP5EA078894   Mileage: 251540km-156299miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 401 J    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0014
   Revision: 58H14---    CVN: 28BDD599B09F27B738D3FF8238D3FF820E1FC39E
   Coding: 2A2A4012053603050000
   Shop #: WSC 62507 003 1048576
   ASAM Dataset: EV_ECM30TDI0118K5907401J 002014
   ROD: EV_ECM30TDI0118K5907401J_002.rod
   VCID: 377DE4958E38362EB2-8062
   VINID: 9D10537515A01554401C820910DD50163A
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [00101111] - -
                    Mileage: 251544 km
                    Date: 2024.06.05
                    Time: 10:36:38
                    Engine RPM: 887.00 /min
                    Normed load value: 25.1 %
                    Coolant temperature: 24 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 11.280 V
                    ACC specified acceleration: 0.000 m/s²
                    ACC control module: received status-Bits 0-7: 6
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_RUNNING
Readiness: 0 0 0 1 1
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H16 1007
   Revision: --H16---    CVN: 65368DFB
   VCID: 4B95A865E2B0A2CEE6-801E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 239D1C03
   Shop #: WSC 33817 000 1048576
   VCID: 11297A0DC81CC81EDC-8044
02214 - Tire Pressure Warning
                    Reset counter: 121
                    Mileage: 248569 km
                    Date: 2024.04.18
                    Time: 17:54:14
                    Hex Value: 0x4600
                    Hex Value: 0x4006
                    Hex Value: 0x1F21
                    Hex Value: 0x1DB7
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
   Component: BCM2 2.0      H14 0650
   Coding: 0DA54040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 071D5455B65886AE02-8052
   Serial number: 0213000403476001
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 157
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:36:33
                    Fault Status: 00101101
                    Reset counter: 157
                    Mileage: 251532 km
                    Date: 2024.05.31
                    Time: 17:51:08
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01090120140141
   Coding: 3621228000
   VCID: 3979E2ADB02C205E44-806C
03269 - Functionality Linited due to Energy Management
                    Reset counter: 118
                    Mileage: 251544 km
                    Date: 2024.06.06
                    Time: 10:48:39
03270 - Ventilation Reduced due to Energy Management
                    Reset counter: 158
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:23:28
                    Bin. Bits:       01
                    Reset counter: 157
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:37:00
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000057872302
   Coding: 26000091863CAFC00000480300003D0D0F1C6608A6090221000008004000030100000034000000
   VCID: 78FF27A9CBA6F9567B-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140104  H11 0050
   Serial number: 90243014131213194218
   Coding: 01DD13
   Serial number: 22115790
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001812130515
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R97VK03
   Serial number: 6F7804E6000000000001
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003GPDB0TW11   Dataset Number: 8R0909602B  0021
   Coding: 303634313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 479D9455FED846AEC2-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R130000FL16
   Serial number: 6334MSME410B13496
   Serial number: 6344MSME410B6C27H
   Serial number: 6352QSME3A3C0F7A.
   Serial number: 6362QSME233D135AI
   Serial number: 63732SME5339507E2
   Serial number: 63832SME573935582
13635840 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
                    Reset counter: 157
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:37:17
          B10B4 00 [00001000] - Function Restriction due to Undervoltage
                    Reset counter: 157
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:36:33
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NAB000R1
   Coding: 000017
   VCID: 489F9769FBC649D6CB-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 A    HW: 8R0 920 982 A
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZD638F61F
   Coding: 8BB622000301D705020000
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z13C19096F
   Coding: 80CF07FF00
   VCID: 4C97AB79EFBEA5F6EF-8018
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 6067092203
   Serial number: 14008002016021200181
02252 - Generator
                    Fault Status: 01101100
                    Fault Frequency: 18
                    Reset counter: 118
                    Mileage: 251510 km
                    Date: 2024.05.30
                    Time: 17:52:24
                    Bin. Bits:    01111
                    Voltage: 11.10 V
                    Count: 6
                    Fault Frequency: 12
                    Reset counter: 158
                    Mileage: 251522 km
                    Date: 2024.05.31
                    Time: 10:08:50
                    Bin. Bits:    10000
                    Voltage: 11.70 V
                    Count: 10
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000086550942
   Coding: 01581B00000000000000
   VCID: 428B8541DDFA638615-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0320841782 Dataset Number: 8R0909535E  0020
   Coding: 010221
   VCID: 3F8D8CB5A6080E6E7A-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0323653016
   Coding: 010221
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000087219444
   Coding: 011D13205E00440004
   VCID: 4FADBC751EA89EEE8A-801A
                    Reset counter: 157
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:37:06
   Part No SW: 8R0 909 144 G    HW: 8R0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0014145597 Dataset Number: 8R0909852H  0021
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3C77FBB9B71E15765F-8068
   Revision: 00002001    Serial number: 0323745203
   Coding: 0126023A20FA709584A0053600040047
   Component: GTO BF  H01 0080
   Serial number: 00000000000000780170
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Reset counter: 158
                    Mileage: 247769 km
                    Date: 2024.04.01
                    Time: 09:37:07
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 158
                    Mileage: 248258 km
                    Date: 2024.04.16
                    Time: 09:36:38
03073 - Rear Lid Closed Sensor 1
                    Reset counter: 148
                    Mileage: 250967 km
                    Date: 2024.05.12
                    Time: 12:53:08
                    Reset counter: 157
                    Mileage: 251532 km
                    Date: 2024.05.31
                    Time: 17:51:08
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000086151287
   VCID: 4E93A17119A297E681-801A
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 00000001418925
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3979E2ADB82C205E44-806C
10554390 - Supply voltage
                    Reset counter: 117
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:36:41
                    Voltage terminal 30: 8.9 V
                    Internal Fault ID: 40
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Revision: AB001007    Serial number: 156AS0E7952020
   Coding: 020007020100000001
   VCID: 244723D927AE4DB607-8070
                    Reset counter: 157
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:37:03
                    Voltage: 8.60 V
03029 - Subwoofer (R157)
                    Fault Status: 00101011
                    Reset counter: 158
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:06:41
                    Voltage: 11.70 V
   Part No SW: 8R1 035 746 E    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0756
   Revision: --------    Serial number: 204AP0E7633801
   Coding: 160200060005A1EF5102AB5E00000403140000000000000000
   Shop #: WSC 43306 001 1048576
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Component: DU7 High  H42 0104
   Serial number: A130D%0E2997638
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001718052
   Component: CD-Database  5571
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000086989866
   Coding: 010C13204000240004
   VCID: 46839951F1D25FA639-8012
                    Reset counter: 157
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:37:06
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000194485962
   Coding: 0200000000000000
   VCID: 3663E9918132CF26A9-8062
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J3XA3R7
   Coding: 1030010
   VCID: 3467D399574EDD3697-8060
                    Reset counter: 157
                    Mileage: 251533 km
                    Date: 2024.05.31
                    Time: 11:36:45
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D71F6BDA4041C7E68-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H53 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000086931562
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 133430250 Dataset Number: 8R0909571D  0014
   ROD: EV_RDCMA00100.rod
   VCID: 2B55C8E5427082CEC6-807E
End-------------------------(Elapsed Time: 04:42)--------------------------
I would start here:
02252 - Generator 012 - Electrical Fault in Circuit
It's a bit interesting that the Gateway has a fault for the generator (alternator) but not the BDM. Usually those are on the same LIN bus. Where is the battery located in this vehicle?
Brianlac
Portsmouth, NH, USA
C?ID=174529 (NRRT)
I would start here:
Its located in the back under the spare tire.
[The battery is] located in the back under the spare tire.
In that case, I wonder if the BDM and the alternator are actually on the same LIN bus or not. You'll need to check a wiring diagram. for your particular vehicle.
Dr Sheldon
Windsor UK
C?ID=334979
02252 - Generator
Fault Frequency: 18
Reset counter: 118
Mileage: 251510 km
Date: 2024.05.30
Time: 17:52:24
Fix that First !!
Majority of those faults are Voltage related so the Alternator is where you need to start !!
  • Agree
TTT
C?ID=547002
I would start with a visual inspection.
Brianlac
Portsmouth, NH, USA
C?ID=174529 (NRRT)
OK, I started looking at the alternator measurement blocks and after starting the alternator shows an electrical generator status of "Not OK". How is this determined? Does this look like a bad Alternator or a wiring problem?
Friday
7​
June
2024​
15:37:15:30130-VCID:4C97AB79EFBEA5F6EF-8018VCDS Version: Release 24.5.0 (x64)Data version: 20240429 DS355.0
8R0 907 468 PGW-BEM 5CAN-M H11 0060
Group A:'014Group B:'015Group C:'026
Generator VoltageDynamic-FieldField CurrentLoadElectricalMechanicalThermalCurrentCurrentTorqueOutput
TIME(specified)SignalResponse TimeTIMEGenerator StatusGenerator StatusGenerator StatusTIME
MarkerSTAMPV%AsSTAMPSTAMPAANmW
0.2​
10.6​
0​
0​
6​
0.34​
OKOKOKOK
0.07​
0​
0​
0​
0​
0.56​
10.6​
0​
0​
6​
0.67​
OKOKOKOK
0.45​
0​
0​
0​
0​
0.94​
10.6​
0​
0​
6​
1.07​
OKOKOKOK
0.8​
0​
0​
0​
0​
1.32​
10.6​
0​
0​
6​
1.46​
OKOKOKOK
1.19​
0​
0​
0​
0​
1.71​
10.6​
0​
0​
6​
1.84​
OKOKOKOK
1.59​
0​
0​
0​
0​
2.11​
10.6​
0​
0​
6​
2.25​
OKOKOKOK
1.98​
0​
0​
0​
0​
2.52​
10.6​
0​
0​
6​
2.64​
OKOKOKOK
2.38​
0​
0​
0​
0​
2.9​
10.6​
0​
0​
6​
3.04​
OKOKOKOK
2.77​
0​
0​
0​
0​
3.28​
10.6​
0​
0​
6​
3.42​
OKOKOKOK
3.16​
0​
0​
0​
0​
3.72​
10.6​
0​
0​
6​
3.84​
OKOKOKOK
3.58​
0​
0​
0​
0​
4.08​
10.6​
0​
0​
6​
4.21​
OKOKOKOK
3.95​
0​
0​
0​
0​
4.46​
10.6​
0​
0​
6​
4.61​
OKOKOKOK
4.33​
0​
0​
0​
0​
4.87​
10.6​
0​
0​
6​
5​
OKOKOKOK
4.74​
0​
0​
0​
0​
5.29​
10.6​
0​
0​
6​
5.42​
OKOKOKOK
5.16​
0​
0​
0​
0​
5.69​
10.6​
0​
0​
6​
5.82​
OKOKOKOK
5.55​
0​
0​
0​
0​
6.07​
13.5​
3.2​
0​
6​
6.21​
OKOKOKOK
5.94​
0​
189​
0​
50​
6.46​
13.5​
12.9​
0​
6​
6.59​
OKOKOKOK
6.34​
0​
163​
0​
50​
6.85​
13.5​
12.9​
0.125​
6​
6.98​
OKOKOKOK
6.73​
0​
81​
0​
50​
7.25​
13.5​
16.1​
0.125​
6​
7.37​
OKOKOKOK
7.11​
0​
40​
0​
50​
7.63​
13.5​
16.1​
0.125​
6​
7.77​
OKOKOKOK
7.5​
0​
23​
0​
50​
8.02​
13.5​
16.1​
0.125​
6​
8.14​
OKOKOKOK
7.89​
0​
13​
0​
50​
8.41​
13.5​
19.4​
0​
6​
8.54​
OKOKOKOK
8.29​
0​
7​
0​
50​
8.81​
13.5​
19.4​
0​
6​
8.93​
OKOKOKOK
8.66​
0​
3​
0​
50​
9.18​
13.6​
25.8​
0.125​
6​
9.32​
OKOKOKOK
9.06​
0​
1​
0​
50​
9.58​
13.6​
25.8​
0.25​
6​
9.7​
OKOKOKOK
9.45​
0​
0​
0​
50​
9.99​
13.6​
29​
0.125​
6​
10.12​
OKOKOKOK
9.86​
0​
0​
0​
50​
10.38​
13.6​
38.7​
0​
6​
10.5​
OKOKOKOK
10.24​
0​
0​
0​
50​
10.76​
13.6​
48.4​
0.25​
6​
10.9​
OKOKOKOK
10.63​
0​
0​
0​
50​
11.16​
13.6​
58.1​
0​
6​
11.28​
OKOKOKOK
11.03​
0​
0​
0​
50​
11.55​
13.6​
64.5​
0.125​
6​
11.67​
OKOKOKOK
11.43​
0​
0​
0​
50​
11.94​
13.6​
87.1​
0.125​
6​
12.07​
OKOKOKOK
11.8​
0​
0​
0​
50​
12.32​
13.6​
87.1​
0.375​
6​
12.47​
OKOKOKOK
12.2​
0​
0​
0​
50​
12.75​
13.7​
87.1​
0​
6​
12.89​
OKOKOKOK
12.61​
0​
0​
0​
50​
13.17​
13.7​
83.9​
0​
6​
13.3​
OKOKOKOK
13.05​
0​
0​
0​
50​
13.57​
13.7​
83.9​
0.25​
6​
13.69​
Not OKOKOKOK
13.42​
0​
0​
0​
50​
13.95​
13.7​
87.1​
0.125​
6​
14.09​
Not OKOKOKOK
13.82​
0​
0​
0​
50​
14.34​
13.7​
87.1​
0.375​
6​
14.46​
Not OKOKOKOK
14.21​
0​
0​
0​
50​
14.76​
13.7​
87.1​
0​
6​
14.87​
Not OKOKOKOK
14.61​
0​
0​
0​
50​
15.15​
13.7​
87.1​
0​
6​
15.27​
Not OKOKOKOK
15​
0​
0​
0​
50​
15.52​
13.7​
87.1​
0.375​
6​
15.66​
Not OKOKOKOK
15.39​
0​
0​
0​
50​
15.91​
13.8​
87.1​
0​
3​
16.04​
Not OKOKOKOK
15.78​
0​
0​
0​
50​
16.3​
13.8​
87.1​
0.25​
3​
16.43​
Not OKOKOKOK
16.18​
0​
0​
0​
50​
16.7​
13.8​
87.1​
0​
3​
16.82​
Not OKOKOKOK
16.56​
0​
0​
0​
50​
17.08​
13.8​
87.1​
0.375​
3​
17.23​
Not OKOKOKOK
16.95​
0​
0​
0​
50​
17.5​
13.8​
87.1​
0​
3​
17.63​
Not OKOKOKOK
17.36​
0​
0​
0​
50​
17.9​
13.8​
87.1​
0​
3​
18.02​
Not OKOKOKOK
17.77​
0​
0​
0​
50​
18.29​
13.8​
87.1​
0.375​
3​
18.42​
Not OKOKOKOK
18.15​
0​
0​
0​
50​
18.72​
13.8​
87.1​
0.125​
3​
18.83​
Not OKOKOKOK
18.56​
0​
0​
0​
50​
19.08​
13.8​
83.9​
0.375​
3​
19.21​
Not OKOKOKOK
18.96​
0​
0​
0​
50​
19.48​
13.9​
83.9​
0.25​
3​
19.6​
Not OKOKOKOK
19.35​
0​
0​
0​
50​
Dr Sheldon
Windsor UK
C?ID=334979
It is Linbus
For sure NOTHING other than an Oscilloscope can see that clearly !!
Dr Sheldon
Windsor UK
C?ID=334979
