how to change navigation speaking language now menu english but speaking germany
Wednesday,05,June,2024,18:34:13:12202
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUGNAF46HN006543 License Plate:
Chassis Type: F4-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 36 42 44 46 52 5F 6C 81 A5 BB BC
CA
VIN: WAUGNAF46HN006543 Mileage: 74116km-46053miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC) Labels:. 06K-907-425-V2.clb
Part No SW: 8W0 906 259 C HW: 06L 907 425
Component: 2.0l R4 TFSI H13 0004
Revision: --H13--- CVN: 13347691
Coding: 0A2500322324010E34080000000000000000000000000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TFS0208W0906259C 001005
ROD: EV_ECM20TFS0208W0906259C.rod
VCID: 41DF42D3810B30A218D-8014
VINID: 9D19577915841987800061440C8B8530E5
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W1 927 155 A HW: 0CK 927 156 S
Component: 0CK 20TFSINAR H06 0003
Revision: --H06--- Serial number: 0000000055 CVN: 776A27CF
ASAM Dataset: EV_TCMDL382021 002023
ROD: EV_TCMDL382021_AU49.rod
VCID: 3E25392FF0F54F5A65F-806A
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP HB1 0572
Serial number: 75117051150364000650
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 E HW: 8W0 907 379 J
Component: ESP9 Plus H06 0593
Dataset Number: 8W0909504VA 0001 CVN: B0FDBA67
Coding: 18AA409910A20A9C15A3489500804292E6259218020850A81200424967A449
Shop #: WSC 47986 001 1048576
ASAM Dataset: EV_ESP9BOSCHAU49X 012014
ROD: EV_ESP9BOSCHAU49X_012.rod
VCID: 47CB5CCBAF2F0E92D69-8012
297728 - Transport Mode Active
U1105 00 [01101000] - -
[Transport_Mode_is_activated]
Mileage: 71749 km
Date: 2024.01.23
Time: 21:54:18
79 00 80 00 C2 24 00 80 00 00
449792 - Databus
U1121 00 [00101000] - Missing Message
[ComScl:_Signal_Group_SG_TSG_FT_02-_Timeout_error]
Mileage: 73691 km
7B 00 82 00 42 00 00 00 00 00
12615680 - FlexRay Databus
U0080 00 [00101000] - Defective
[FlexRay_controller_0_channel_A_no_synchronisation]
Mileage: 72813 km
Date: 2024.03.12
Time: 20:52:58
7C 00 82 00 42 00 00 00 00 00
419328 - TPMS Warning; Front Right Tire
C1057 00 [00101000] - Flat
Mileage: 73982 km
Date: 2024.05.16
Time: 18:55:38
91 00 80 15 88 24 00 00 A0 60
419840 - TPMS Warning; Rear Right Tire
C105B 00 [00101000] - Flat
Mileage: 73982 km
Date: 2024.05.16
Time: 18:55:38
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0052
Coding: 140805885544000D10000100800000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 372B2C0BDFCF7E12A69-8062
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000712249
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0003
Serial number: 12798908000000000001
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: Klima Heck H34 0050
262658 - High Pressure Sensor
B10AE 31 [00001000] - No Signal
Reset counter: 20
Mileage: 72024 km
Date: 2024.02.14
Time: 13:47:20
Outside temperature: 7.00 °C
Engine RPM: 1250 /min
Compressor current: actual value: 0.00 A
Temperature downstream of evaporator: 6.70 °C
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 AC HW: 8W0 907 063 C
Component: BCM1 MLBevo H12 0228
Dataset Number: 8W0909514F 0031
Coding: 80458364457900CD0115871418AC98BB11033D00000000000000000020001A0000550023025605
ASAM Dataset: EV_BCM1BOSCHAU736 015005
ROD: EV_BCM1BOSCHAU736_015.rod
VCID: 7CA1F327A6699D4A0BB-8028
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 151031 043 0813
Serial number: 894353?0401530401761
Coding: 5BC7F7
Component: G397_RLFS H06 0004
Serial number: 61184622
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 N HW: 4M0 941 531 N
Component: E1 - LDS H06 0008
Serial number: 28 09 2015 00118076
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0040
Serial number: 0000009600335Z0CC202
Coding: 350000
Garage door opener control head:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20151009123806 00381
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE105111511910656
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 AN HW: 8W0 947 135
Component: J528-Dachele H13 0082
Serial number: Q00077772
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H15 0010
Serial number: 2615000121500001
196693 - Front Left Center Parking Aid Sensor
B10F8 14 [00001000] - Open or Short to Ground
Fault Frequency: 56
Reset counter: 26
Mileage: 73691 km
Date: 2024.05.01
Time: 12:58:23
average_Voltage_terminals: 14.40 V
Outside air temperature sensor-Outside air temperature on CAN: 28.50 °C
interior_temperature: 35.50 °C
Vehicle speed: 0.00 km/h
196694 - Front Left Center Parking Aid Sensor
B10F8 29 [00001000] - Signal Implausible
Fault Frequency: 23
Reset counter: 27
Mileage: 73691 km
Date: 2024.05.01
Time: 12:59:08
average_Voltage_terminals: 14.50 V
Outside air temperature sensor-Outside air temperature on CAN: 29.50 °C
196695 - Front Left Center Parking Aid Sensor
B10F8 31 [00001000] - No Signal
Reset counter: 25
Mileage: 74046 km
Date: 2024.05.28
Time: 12:38:32
Outside air temperature sensor-Outside air temperature on CAN: 32.50 °C
interior_temperature: 48.00 °C
Vehicle speed: 13.19 km/h
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 A HW: 8W0 959 655 A
Component: Airbag10.44 H64 0086
Serial number: 003N800081AA Dataset Number: 8W0909602R 0001
Coding: BFCCF0C000800000A0000033C24C00000000
Shop #: WSC 00477 128 28888
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005.rod
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705B0012Q01576
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706C0014Q00172
Coding: 80000D
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150003R2DP0C
Subsystem 4 - Part No SW: ----------- HW: 442 062 711 15
Serial number: 3577Y009D1A87822F046
Subsystem 5 - Part No SW: ----------- HW: 442 062 711 15
Serial number: 3587Y00BF1A87824F27I
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 412 15
Serial number: 35177000E294A8183747
Subsystem 7 - Part No SW: ----------- HW: 442 0B1 412 15
Serial number: 352770002294A828B756
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 711 15
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C91C5DC2671DW
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 711 15
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C71C5DC25E36W
1055232 - Databus
[NWD: 0x11E ESP_08 Timeout]
Reset counter: 250
Mileage: 71749 km
Date: 2024.01.23
Time: 21:54:06
1052928 - Databus
[NWD: 0x0FD ESP_21 Timeout]
Reset counter: 250
Mileage: 71749 km
Date: 2024.01.23
Time: 21:54:07
Part No SW: 4N0 907 129 KC HW: 4N0 907 129 KC
Component: Lenks.Modul H03 0009
4198912 - Databus
U1122 00 [00001000] - Implausible Message
[ESP_03 message counter implausible]
Reset counter: 250
Mileage: 71749 km
Date: 2024.01.23
Time: 21:54:06
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 870 A HW: 8W5 920 870 A
Component: MM--T--BENUS- H11 0267
Revision: 0251v1 Serial number: N7EC8491S
Coding: 04EF51C1608400080100ED601800401000000000
Shop #: WSC 12345 128 12345
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 3FDB442BF7FF46526E9-806A
Part No SW: 8W6 907 468 HW: 8W6 907 468
Component: Gateway H11 2079
Revision: 3R050037 Serial number: 3783R001816115 Dataset Number: 8W0909515E 0038
Coding: 0301000100000F4029000000005900104C100007000000000175070E00000000
GVL: 01503C0000000000409C08000002C80010080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 074B9CCBEFAFCE92169-8052
Subsystem 1 - Part No SW: 8W0 951 523 H HW: 8W0 951 523 H
Component: J453 MFL H04 0004
Serial number: 20180504021933 30066
Subsystem 2 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9052
Serial number: 4457218603
8519683 - Energy Management Active
U140B 00 [00001000] - -
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:49:34
EM_vehicle_state: 02 10
Static current shut-off stage: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Part No SW: 4M0 959 760 HW: 4M0 959 760
Component: MEM-FS 008 0015
Serial number: 00000182468714 Dataset Number: 8W0909856A 0004
Coding: 007C1B000000B0010000210101010000000000000000000000000000000000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
VCID: 75B7E6038543CC02745-8020
Part No SW: 8W0 959 593 G HW: 8W0 959 593
Component: TSG FS 005 0052
Serial number: 0000180600970 Dataset Number: 8W0909872C 0022
Coding: 001F1B20DF00108000010082
VCID: 4EC569EF4055DFDA95F-801A
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 235
Mileage: 73691 km
Date: 2000.01.01
Time: 00:00:05
Part No SW: 8W0 909 144 D HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0405
Dataset Number: 8W0909852F 0023
Coding: 49008080008000
ASAM Dataset: EV_EPSZFAU49X 002015
ROD: EV_EPSZFAU49X_002.rod
Part No SW: 8W0 907 064 CC HW: 8W0 907 064 C
Component: BCM2 MLBevo 016 0344
Dataset Number: 8W0909501C 0036
Coding: 013400006F5000806587A0003E00000233004000101127502F0400040B04803F001E0000000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7F5B042BB77F86522E9-802A
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1532705BH
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000034331071
Subsystem 3 - Part No SW: 3AA 962 243 F HW: 3AA 962 243 F
Component: GEB.F.Heckoef H16 0816
Serial number: 94054954
131125 - Remote key 2
B147A 04 [00001001] - Internal System Fault
Fault Frequency: 66
Reset counter: 242
Mileage: 71752 km
Date: 2024.01.23
Time: 23:31:56
Supply voltages-Terminal 30 power supply: 12.310 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.283 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.296 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 4A 12 00 98
key_error_freeze_frame: 11110001 11111111 11111111 11111111
Part No SW: 8W0 959 592 A HW: 8W0 959 592
Component: TSG BFS 005 0050
Serial number: 0000180624603 Dataset Number: 8W0909873C 0022
Coding: 001F1B204E00108000010080
Reset counter: 235
Mileage: 73691 km
Date: 2000.01.01
Time: 00:00:05
Part No SW: 8W0 035 025 G HW: 8W0 035 025
Component: MU-H-LNS-US 051 1438
Serial number: A385A0GB001633 Dataset Number: VCPVIM0000 0018
Coding: 01940101FF0A000053110001041A00102F0001E501700104BE
VCID: 35372603C5C38C02B45-8060
Subsystem 1 - Part No SW: V03 959 802 TT HW: -----------
Component: ECE 2024/2025 --- 0370
Multimedia System 1:
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H31 0160
Serial number: TPO00102011600820130
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 P
Component: ControlUnit_H H22 0206
Serial number: C1000027111500020024
Compact disc data bank:
Component: Gracenote2--- --- 1017
12 Faults Found:
1585 - invalid data record
B2005 00 [00001000] - -
[Control module (data record download) - invalid data record for ASAM/ODX MUX]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
Voltage terminal 30: 11.8 V
1586 - invalid data record
[Control module (data record download) - invalid data record for speed shutoff thresholds]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1587 - invalid data record
[Control module (data record download) - invalid data record for language]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1588 - invalid data record
[Control module (data record download) - invalid data record for visible MMI system languages]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1589 - invalid data record
[Control module (data record download) - invalid data record for power management timer]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1590 - invalid data record
[Control module (data record download) - invalid data record for sound audio parameters]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1592 - invalid data record
[Control module (data record download) - invalid data record for DAB frequency tables]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1595 - invalid data record
[Control module (data record download) - invalid data record for audio management HMI constants]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1655 - invalid data record
[Control module (data record download) - invalid data record for sound announcement audio parameters (optional)]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1656 - invalid data record
[Control module (data record download) - invalid data record for sound cabriolet audio parameters (optional)]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1657 - invalid data record
[Control module (data record download) - invalid data record for sound configuration audio parameters (optional)]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
1603 - invalid data record
[Control module (data record download) - invalid data record for speech signal enhancement - telephone/voice recognition signal processing (SSE)]
Reset counter: 25
Mileage: 74065 km
Date: 2024.05.29
Time: 20:38:28
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0130
Dataset Number: 8W0909460A 0006
Coding: 0294010102002001000040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
ROD: EV_CamSysRVRVCPANAMLBEv_004_AU49.rod
VCID: 72BDDD1FF42DDB3A517-8026
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 E HW: 8W1 713 041 E
Component: GSM-LL H07 0068
Revision: 0L0D5012 Serial number: 20151127000841
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: EV_GSMWaehlZFAU736_AU49.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 A HW: 8W0 907 217
Component: BVS H13 0030
Dataset Number: 8W0909466B 0026
Coding: 0404090100000401022023E0A90000FC90F0C010C020
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
VCID: 3A2D353FECDD637A597-806E
4195330 - Databus
[HC_requirement_not_workable]
Reset counter: 250
Mileage: 71749 km
Date: 2024.01.23
Time: 21:54:07
Control Module temperature: 26 °C
Voltage terminal 15: 12.10 V
1123600 - Predictive Route Data
B1630 02 [00001000] - Signal Failure
Fault Frequency: 20
Reset counter: 27
Mileage: 71892 km
Date: 2024.01.27
Time: 18:23:11
Control Module temperature: 29 °C
Voltage terminal 15: 15.00 V
1123601 - Predictive Route Data
Reset counter: 15
Mileage: 73225 km
Date: 2024.03.28
Time: 20:49:09
Control Module temperature: 27 °C
Voltage terminal 15: 14.70 V
Part No SW: 8W0 959 595 A HW: 8W0 959 595
Component: TSG HFS 005 0050
Serial number: 0000180924036 Dataset Number: 8W0909897C 0022
Coding: 000F1B200000108040000080
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 4ACD65FFBC3DF3FAC97-801E
Component: TSG HBFS 005 0050
Serial number: 0000180920004 Dataset Number: 8W0909896C 0022
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Part No SW: 4M0 907 594 A HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Dataset Number: 8W0909469B 0007
Coding: 208000049100
VCID: 34311B07CEB9950A83B-8060
End----------(Elapsed Time: 01:55, VBatt start/end: 12.4V/12.4V)-----------
