B7 Passat, left rear light has inactive high power LED, what is it and can it be programmed as reverse light?
scoobykids
C?ID=574407
My B7 passat estate (2014 1.6 diesel) had a message on the dash to fix reversing lamp. I looked in back the car and the only thing I saw was this large LED on the left side (the inner light unit on the rear hatch).
https://photos.app.goo.gl/yTSDAm94D5tnrnLe9
https://photos.app.goo.gl/pQhu5byHogEZZDgRA
I removed the unit and found it was built in, non-removable, glued shut assembly. I bought a replacement unit on ebay and installed it.
The LED still didn't work, however the actual incandescent reverse lamp on the outer unit (which I hadn't noticed) did now work.
The dash message now said replace right side reverse lamp. I took it out, checked bulb resistance, reinstalled it, and it worked again. I then replaced the entire original left unit to see if reverse lamps still worked. They did.
*Shrug* maybe the canbus got its knickers in a twist and reset somehow??
Anyway now my question is, what the hell is the big white LED lamp for? Is it a reverse lamp for high-spec cars only? Can it be activated in VCDS?
Update: I just realised, this may actually be the Rear Fog Light, in which case I feel really stupid. But its not working when I turn on fog light either.....
thanks
Westbury, UK
Very difficult to know until you post an Auto-Scan showing how your Passat is equipped and configured
scoobykids
C?ID=574407
Sunday,18,February,2024,13:52:11:53431
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: WVWZZZ3CZF
Mileage: 163260km-101445mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 56
          61 62 72
VIN: WVWZZZ3CZ..  Mileage: 163260km-101445miles
   Part No SW: 03L 906 023 FS    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number: 00000000000000 CVN: 42E04742
   Coding: 00194036032401080000
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ECM16TDI02103L906023FS 003014
   ROD: EV_ECM16TDI02103L906023FS_003.rod
   VCID: 7CA5383C96666C9A73B-8028
   VINID: 9E69EAAAA0D3A96540141243147ADA97B3
   Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
   Component: J104   C2 450M VDD9 0040
   Revision: --H07---    Serial number: 00000008397862
   Coding: 0003495
   Shop #: WSC 05311 000 00001
   VCID: 79AB212895D459B268D-802C
   Part No SW: 3AA 907 044 BT    HW: 3AA 907 044 BT
   Component: Climatronic   H05 0607
   Revision: 00001K02
   Coding: 061100C803
   Shop #: WSC 00015 115 00001
   VCID: 035743C0EB981362321-8056
9473393 - Motor for Right Temperature Flap
          B108D 71 [00001000] - Actuator Stuck
                    Fault Frequency: 19
                    Reset counter: 2
                    Mileage: 162656 km
                    Date: 2024.01.24
                    Time: 17:15:22
9475349 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [00001000] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 162951 km
                    Date: 2024.01.30
                    Time: 18:38:00
9481988 - Air Quality Sensor
          B10AF 04 [00001000] - Internal System Fault
                    Fault Frequency: 96
                    Reset counter: 2
                    Mileage: 162650 km
                    Date: 2024.01.24
                    Time: 14:12:06
9482025 - Air Quality Sensor
          B10AF 29 [00001000] - Signal Implausible
                    Reset counter: 253
                    Mileage: 162730 km
                    Date: 2024.01.26
                    Time: 17:40:14
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 N    HW: 3AA 937 087 N
   Component: BCM PQ47 M    422 0475
   Revision: BA422001
   Coding: 000800000000000000B800805400006403510088426D87606480C7200041
   Shop #: WSC 05311 000 08193
   VCID: 45D39DD8A5ACED525C5-8010
   Subsystem 1 - Part No SW: 3AB 955 419 A    HW: 3AB 955 419 A  Labels: 1KX-955-119.CLB
   Component: WWS471 150714  24  0654
   Coding: 044D9D
   Component: RLS 190814 05  54  0403
   Coding: 024D2A
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28201421101243
   Coding: 108002
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3FDF8F30C7F0B782169-806A
   Component: J234__107 VW10 HI   2518
   Revision: 28020000    Serial number: 003L7PGMV77A
   Coding: 0012343
   VCID: 7CA5383C9AE66C9A73B-8028
   Subsystem 1 - Serial number: 6332MTS633022034
   Subsystem 2 - Serial number: 6342MTS634932114
   Subsystem 3 - Serial number: 6351HTS6LFSK2DKR
   Subsystem 4 - Serial number: 6361HTS6B4VK2DKJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 DA    HW: 5K0 953 569 BA
   Revision: FF010042    Serial number: 20140728201250
   Coding: 118A250000
   VCID: 6B870B60E308FB22EA1-803E
   Component: E221__MFL-TK6  H07 0023
   Coding: E20000
   Part No SW: 3AA 920 871 A    HW: 3AA 920 871 A
   Component: KOMBI         H03 0905
   Coding: 161D01
   Shop #: WSC 05314 115 00001
   VCID: 313BD90801A451F290D-8064
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 250714F1000210
   Coding: 462006
   VCID: 005D4CCCFA0E087A2F3-8054
   Part No SW: 3AA 959 433 E    HW: 3AA 959 433 E
   Component:    IMMO         048 0407
   Revision: 00048000    Serial number: VWZCZ000000000
   VCID: 3B27FB20DF68ABA23A1-806E
   Revision: A1001003    Serial number: 7666541036
   Coding: 020100
   VCID: 2B07CB6023083B22AA1-807E
   Part No SW: 3C8 035 279 R    HW: 3C8 035 279 R
   Component: RNS315-EU   H80 0500
   Serial number: VWZAZ2P0462800
   Coding: 040004110400110000011301
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 3A29FE24DCD292AA217-806E
   Component: EUR_W_V12  0078
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0008943694
   Coding: 0204B7
   Shop #: WSC 05311 115 00001
   VCID: 3533ED18F5CC7DD2CC5-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  005 0503
   Serial number: 00000004119227
   Coding: 010490
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.308 1401
   Revision: 1BH04739    Serial number: 00142060324601
   Coding: 0000258
   VCID: 41DB89C8BD84C17260D-8014
                    Reset counter: 251
                    Mileage: 163111 km
                    Date: 2018.07.05
                    Time: 18:01:59
                    Voltage: 2.20 V
                    Voltage: 10.40 V
                    Voltage: 10.40 V
                        Not Occup.
                        Not Occup.
   Component:    KSG PQ47 ELV 048 0700
   Coding: 0291028052830E76340494157C084F0B605C00
   Component: EZE_2         H55 1653
   Coding: 00000008
   VCID: 6FBF1F70D7900702C69-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0008902683
   Coding: 0204B6
   VCID: 3631EA14E8CA76CAC5F-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  005 0503
   Serial number: 00000004106685
   Coding: 010490
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000223744
   Coding: 0022167
   VCID: 382DE42CEE5E80BAD73-806C
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1653
   Coding: 030F1859
   VCID: 71BB1908C1A411F2D0D-8024
   Component: J367-BDM  H07 0180
   Serial number: 31210I47281491589512
End----(Elapsed Time: 01:31, VBatt start/end: 11.8V/12.0V. VIgn 11.9V)-----
