Support for 5F MIB2 Columbus & Amundsen on MY16 Octavia III
silvera4quattro
Conshohocken, PA USA
C?ID=58593
Thanks MTL. Do you have thinkblue trainer and performance gauges? I'm unsure what (181)-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated is, but I do not think that was active in my car. I'll run that map tonight.
   #42
mtl
Slovenia
C?ID=153305
The car has both: Performance gauges and ecotrainer (as written it is Seat, not VW).
   #44
andyvee
Rossendale, Lancashire, UK
C?ID=159389
Has anyone compiled a reference list of all the VAG TLA's anywhere - for those of us that don't speak German it is a bit hard to decipher some functions - VZE, VZA, UGDO, MKE, AWV, SIA, MFL, BCmE, ENI, VPS, LDW, VZO, LGI etc. - and that was from a quick scan of that Adaptation Map!
   #45
Eric
HC800000
Wait until you see the MLB Evo platform (B9 A4, new Q7) :D I'd be interested too :thumbs:
   #46
mtl
Slovenia
C?ID=153305
I had a short time with my ''patient''. I will be able to do a reference scan of almost identical car sometime next week, so will be able to do a line by line comparison only then. But I have managed to get also Conv. consumers menu back which is: (181)-Car_Function_Adaptations_Gen2-menu_display_BCmE
I suggest that we create a list of channels and connected menus:
(166)-Car_Function_Adaptations_Gen2-menu_display_car_mirror - Mirrors and wipers menu
(181)-Car_Function_Adaptations_Gen2-menu_display_BCmE - Conv. Consumers menu
(186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating - DriveGreen menu
   #47
Here is a channel map of ''virgin'' 5F done with 15.7.3 version (Seat Leon MY2016).
Mti: I've taken your leon admap using Eric's new version 15.7.3 and put it up against the admap that I posted earlier for a MIBII using Version 15.7.1. You can download the results HERE. Hopefully, my spreadsheet will aid in your line-by-line comparision.
Clearly there will be differences between the two because of the different model vehicles, but the variations in adaption channels that you noted earlier are very obvious!! Albeit some of your adaption channels don't appear at all -like (186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating - DriveGreen menu. But I assume that this the same as (186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating.
Cheers
PS: Kudos to the RT team (and especially to the world's best code-cutter) for solving this problem so expeditiously!!
PPS: I agree with Andyvee- a trade-in facility for Hex_CAN cables would be very nice indeed. RT could trial such a scheme, here in the Antipodes first!
mtl
Slovenia
C?ID=153305
Thx for doing quick comparison. There are some differences. If I will have time I will try a few other options, but I am more keen on waiting to get the reference scan of almost identical vehicle, which should pinpoint directly to the differences.
In my list after the dash (-) is my comment on which menu it affects ;). (186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating - DriveGreen menu: I meant with this that channel (186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating affected DriveGreen menu ;).
   #49
The HEX-USB+CAN owing to its older design experiences CAN buffer overflows while reading long adaptation channels from controllers that spit out the information really fast (for instance Car_Function_Adaptations_Gen2). This resulted in false readings for those adaptation channels, which were then rewritten to the controller when the user makes a change.
EDIT: text underlined for reference
Eric: Just to be clear - are you saying that the buffer overflows which resulted in the false readings when "rewritten to the controller when the user makes a change" occurs ONLY to those adaptation channels that the cable user targeted to alter settings? More importantly, can you confirm that the buffer overflows didn't alter the settings of the other adaptation channels that weren't accessed.
Cheers
   #50
Eric
HC800000
Yes, but we need to be clear on what "channel" means in this context. From examples above, I would call "Car_Function_Adaptations_Gen2" the (main) adaptation channel, and "menu_display_user_eco_rating" a subchannel. If you modified an adaptation channel that has lots of subchannels (such as the now infamous "Car_Function_Adaptations_Gen2"), and the HUC overflowed while reading it, chances are the subchannels such as "menu_display_car_mirror" or "menu_display_user_eco_rating" that are later rewritten by VCDS will be incorrect. This is because UDS doesn't support partially writing a given main channel; you have to rewrite the whole thing, even if you only change one bit (such as activated/not activated) out of the 60 bytes it contains.
Yes, only the main channels that were tweaked by the user could possibly be affected. VCDS doesn't rewrite other main channels without the user asking. Reading them does not affect them either.
   #51
silvera4quattro
C?ID=58593
Here's my Channel map, albeit not virgin. This was before I set 181 BCmE back to enabled. Note that I set the following values to enabled:
(183)-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high
;SW:3Q0-035-876   HW:3Q0-035-876 ---  Information Electr.
;Component:MU-S-NS-US    H25 0241	 Coding:027300020000000051220002001808001F0203F401200105C6
;EV_MUStd4CTSAT	1022	EV_MUStd4CTSAT_VW26.rod
;Thursday	3	December	2015	22:25:50:30193
;VCDS Version: Beta 15.7.3 (x64)  Data version: 20151124
;VCID: 71E26B24A0DCEBB68E-8024
(1)-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF
(2)-Activating and deactivating all development messages-MIB_CAN_Messages	OFF
(1)-Audio Management Input Gain Generation 2-TV Tuner	-128
(2)-Audio Management Input Gain Generation 2-Radio (FM)	-128
(3)-Audio Management Input Gain Generation 2-Radio (AM)	-128
(4)-Audio Management Input Gain Generation 2-Digital radio (DAB)	-128
(5)-Audio Management Input Gain Generation 2-Satellite radio	5
(6)-Audio Management Input Gain Generation 2-Tuner_TI	-128
(7)-Audio Management Input Gain Generation 2-Media_AUXIN	-128
(8)-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128
(9)-Audio Management Input Gain Generation 2-Media_CDA	-128
(10)-Audio Management Input Gain Generation 2-Media_DVD	-128
(11)-Audio Management Input Gain Generation 2-Media_MFP	-128
(12)-Audio Management Input Gain Generation 2-Media_BTDevice	-128
(13)-Audio Management Input Gain Generation 2-TA_Tuner_FM	-128
(14)-Audio Management Input Gain Generation 2-Media_Bluray	-128
(15)-Audio Management Input Gain Generation 2-Media_HDMI	-128
(16)-Audio Management Input Gain Generation 2-Tuner_Online	-128
(17)-Audio Management Input Gain Generation 2-Media_Airplay	-128
(18)-Audio Management Input Gain Generation 2-Media_UPNP	-128
(19)-Audio Management Input Gain Generation 2-Media_Cloud	-128
(20)-Audio Management Input Gain Generation 2-Tuner_Personal	-128
(21)-Audio Management Input Gain Generation 2-Tone_Beep	-128
(22)-Audio Management Input Gain Generation 2-Tone_Warning	-128
(23)-Audio Management Input Gain Generation 2-Tone_Touchscreen	-128
(24)-Audio Management Input Gain Generation 2-Tone_Messaging	-128
(25)-Audio Management Input Gain Generation 2-Exbox_DMB	-128
(26)-Audio Management Input Gain Generation 2-Mirrorlink	-128
(27)-Audio Management Input Gain Generation 2-TTS_Nav	-128
(28)-Audio Management Input Gain Generation 2-TTS_SDS	-128
(29)-Audio Management Input Gain Generation 2-Phone_Voice	-128
(30)-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128
(31)-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-3
(32)-Audio Management Input Gain Generation 2-HFP	-128
(33)-Audio Management Input Gain Generation 2-TV_AV_IN	-128
Automatic ring break diagnostic	No automatic start
Awakening ability on optical databus	OFF
Base volume of speech output	50%
Base volume of telephone	50%
Bluetooth	On
Bluetooth: Sniff mode	OFF
CD eject button	Enabled
(1)-Check tone frequency-High note frequency range	4000 Hz
(2)-Check tone frequency-Medium note frequency range	1000 Hz
(3)-Check tone frequency-Low note frequency range	100 Hz
Confirmation of installation change	09 4B
Country identification; country of sale HMI	US
Deactivate production mode	0
Developer mode	not activated
(1)-Electrical test of loudspeakers-Mode	automatic
(2)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz
(3)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	36
(4)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz
(5)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	36
(6)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz
(7)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	36
(8)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz
(9)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	36
(10)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz
(11)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	36
(12)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz
(13)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	36
(14)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz
(15)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	36
(16)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz
(17)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	36
(18)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz
(19)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	36
(20)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz
(21)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	36
(22)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz
(23)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	36
(24)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz
(25)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	36
(26)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz
(27)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	36
(28)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz
(29)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	36
(30)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz
(31)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	36
(32)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz
(33)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	36
Fee-based traffic information (TMC)	1537
Infotainment Recorder	activated
(1)-Installation list; specified installations-ECU coded	Yes
(2)-Installation list; specified installations-ECU coded	No
(3)-Installation list; specified installations-ECU coded	Yes
(4)-Installation list; specified installations-ECU coded	No
(5)-Installation list; specified installations-ECU coded	No
(6)-Installation list; specified installations-ECU coded	No
(7)-Installation list; specified installations-ECU coded	No
(8)-Installation list; specified installations-ECU coded	No
(9)-Installation list; specified installations-ECU coded 2	No
(10)-Installation list; specified installations-ECU coded 2	No
(11)-Installation list; specified installations-ECU coded 2	No
(1)-Interface for external media; activation-Connection 1	activated
(2)-Interface for external media; activation-Connection 2	not activated
(3)-Interface for external media; activation-Connection 3	not activated
(4)-Interface for external media; activation-Connection 4	not activated
(1)-Locked menu contents-FB_TUNER_0	non_blocked
(2)-Locked menu contents-FB_TUNER_1	non_blocked
(3)-Locked menu contents-FB_TUNER_2	non_blocked
(4)-Locked menu contents-FB_TUNER_3	non_blocked
(5)-Locked menu contents-FB_TUNER_4	non_blocked
(6)-Locked menu contents-FB_TUNER_5	non_blocked
(7)-Locked menu contents-FB_TUNER_6	non_blocked
(8)-Locked menu contents-FB_TUNER_7	non_blocked
(9)-Locked menu contents-FB_TUNER_8	non_blocked
(10)-Locked menu contents-FB_TUNER_9	non_blocked
(11)-Locked menu contents-FB_TUNER_10	non_blocked
(12)-Locked menu contents-FB_TUNER_11	non_blocked
(13)-Locked menu contents-FB_TUNER_12	non_blocked
(14)-Locked menu contents-FB_TUNER_13	non_blocked
(15)-Locked menu contents-FB_TUNER_14	non_blocked
(16)-Locked menu contents-FB_TUNER_15	non_blocked
(17)-Locked menu contents-FB_MEDIA_0	non_blocked
(18)-Locked menu contents-FB_MEDIA_1	non_blocked
(19)-Locked menu contents-FB_MEDIA_2	non_blocked
(20)-Locked menu contents-FB_MEDIA_3	non_blocked
(21)-Locked menu contents-FB_MEDIA_4	non_blocked
(22)-Locked menu contents-FB_MEDIA_5	non_blocked
(23)-Locked menu contents-FB_MEDIA_6	non_blocked
(24)-Locked menu contents-FB_MEDIA_7	non_blocked
(25)-Locked menu contents-FB_MEDIA_8	non_blocked
(26)-Locked menu contents-FB_MEDIA_9	non_blocked
(27)-Locked menu contents-FB_MEDIA_10	non_blocked
(28)-Locked menu contents-FB_MEDIA_11	non_blocked
(29)-Locked menu contents-FB_MEDIA_12	non_blocked
(30)-Locked menu contents-FB_MEDIA_13	non_blocked
(31)-Locked menu contents-FB_MEDIA_14	non_blocked
(32)-Locked menu contents-FB_MEDIA_15	non_blocked
(33)-Locked menu contents-FB_MEDIA_16	non_blocked
(34)-Locked menu contents-FB_MEDIA_17	non_blocked
(35)-Locked menu contents-FB_MEDIA_18	non_blocked
(36)-Locked menu contents-FB_MEDIA_19	non_blocked
(37)-Locked menu contents-FB_MEDIA_20	non_blocked
(38)-Locked menu contents-FB_MEDIA_21	non_blocked
(39)-Locked menu contents-FB_MEDIA_22	non_blocked
(40)-Locked menu contents-FB_MEDIA_23	non_blocked
(41)-Locked menu contents-FB_PHONE_0	non_blocked
(42)-Locked menu contents-FB_PHONE_1	non_blocked
(43)-Locked menu contents-FB_PHONE_2	non_blocked
(44)-Locked menu contents-FB_PHONE_3	non_blocked
(45)-Locked menu contents-FB_PHONE_4	non_blocked
(46)-Locked menu contents-FB_PHONE_5	non_blocked
(47)-Locked menu contents-FB_PHONE_6	non_blocked
(48)-Locked menu contents-FB_PHONE_7	non_blocked
(49)-Locked menu contents-FB_PHONE_8	non_blocked
(50)-Locked menu contents-FB_PHONE_9	non_blocked
(51)-Locked menu contents-FB_PHONE_10	non_blocked
(52)-Locked menu contents-FB_PHONE_11	non_blocked
(53)-Locked menu contents-FB_PHONE_12	non_blocked
(54)-Locked menu contents-FB_PHONE_13	non_blocked
(55)-Locked menu contents-FB_PHONE_14	non_blocked
(56)-Locked menu contents-FB_PHONE_15	non_blocked
(57)-Locked menu contents-FB_NAV_0	non_blocked
(58)-Locked menu contents-FB_NAV_1	non_blocked
(59)-Locked menu contents-FB_NAV_2	non_blocked
(60)-Locked menu contents-FB_NAV_3	non_blocked
(61)-Locked menu contents-FB_NAV_4	non_blocked
(62)-Locked menu contents-FB_NAV_5	non_blocked
(63)-Locked menu contents-FB_NAV_6	non_blocked
(64)-Locked menu contents-FB_NAV_7	non_blocked
(65)-Locked menu contents-FB_NAV_8	non_blocked
(66)-Locked menu contents-FB_NAV_9	non_blocked
(67)-Locked menu contents-FB_NAV_10	non_blocked
(68)-Locked menu contents-FB_NAV_11	non_blocked
(69)-Locked menu contents-FB_NAV_12	non_blocked
(70)-Locked menu contents-FB_NAV_13	non_blocked
(71)-Locked menu contents-FB_NAV_14	non_blocked
(72)-Locked menu contents-FB_NAV_15	non_blocked
(73)-Locked menu contents-FB_NAV_16	non_blocked
(74)-Locked menu contents-FB_NAV_17	non_blocked
(75)-Locked menu contents-FB_NAV_18	non_blocked
(76)-Locked menu contents-FB_NAV_19	non_blocked
(77)-Locked menu contents-FB_NAV_20	non_blocked
(78)-Locked menu contents-FB_NAV_21	non_blocked
(79)-Locked menu contents-FB_NAV_22	non_blocked
(80)-Locked menu contents-FB_NAV_23	non_blocked
(81)-Locked menu contents-FB_NAV_24	non_blocked
(82)-Locked menu contents-FB_NAV_25	non_blocked
(83)-Locked menu contents-FB_NAV_26	non_blocked
(84)-Locked menu contents-FB_NAV_27	non_blocked
(85)-Locked menu contents-FB_NAV_28	non_blocked
(86)-Locked menu contents-FB_NAV_29	non_blocked
(87)-Locked menu contents-FB_NAV_30	non_blocked
(88)-Locked menu contents-FB_NAV_31	non_blocked
(89)-Locked menu contents-FB_NAV_32	non_blocked
(90)-Locked menu contents-FB_NAV_33	non_blocked
(91)-Locked menu contents-FB_NAV_34	non_blocked
(92)-Locked menu contents-FB_NAV_35	non_blocked
(93)-Locked menu contents-FB_NAV_36	non_blocked
(94)-Locked menu contents-FB_NAV_37	non_blocked
(95)-Locked menu contents-FB_NAV_38	non_blocked
(96)-Locked menu contents-FB_NAV_39	non_blocked
(97)-Locked menu contents-FB_CAR_0	non_blocked
(98)-Locked menu contents-FB_CAR_1	non_blocked
(99)-Locked menu contents-FB_CAR_2	non_blocked
(100)-Locked menu contents-FB_CAR_3	non_blocked
(101)-Locked menu contents-FB_CAR_4	non_blocked
(102)-Locked menu contents-FB_CAR_5	non_blocked
(103)-Locked menu contents-FB_CAR_6	non_blocked
(104)-Locked menu contents-FB_CAR_7	non_blocked
(105)-Locked menu contents-FB_CAR_8	non_blocked
(106)-Locked menu contents-FB_CAR_9	non_blocked
(107)-Locked menu contents-FB_CAR_10	non_blocked
(108)-Locked menu contents-FB_CAR_11	non_blocked
(109)-Locked menu contents-FB_CAR_12	non_blocked
(110)-Locked menu contents-FB_CAR_13	non_blocked
(111)-Locked menu contents-FB_CAR_14	non_blocked
(112)-Locked menu contents-FB_CAR_15	non_blocked
(113)-Locked menu contents-FB_CAR_16	non_blocked
(114)-Locked menu contents-FB_CAR_17	non_blocked
(115)-Locked menu contents-FB_CAR_18	non_blocked
(116)-Locked menu contents-FB_CAR_19	non_blocked
(117)-Locked menu contents-FB_CAR_20	non_blocked
(118)-Locked menu contents-FB_CAR_21	non_blocked
(119)-Locked menu contents-FB_CAR_22	non_blocked
(120)-Locked menu contents-FB_CAR_23	non_blocked
(121)-Locked menu contents-FB_MISC_0	non_blocked
(122)-Locked menu contents-FB_MISC_1	non_blocked
(123)-Locked menu contents-FB_MISC_2	non_blocked
(124)-Locked menu contents-FB_MISC_3	non_blocked
(125)-Locked menu contents-FB_MISC_4	non_blocked
(126)-Locked menu contents-FB_MISC_5	non_blocked
(127)-Locked menu contents-FB_MISC_6	non_blocked
(128)-Locked menu contents-FB_MISC_7	non_blocked
(129)-Locked menu contents-FB_MISC_8	non_blocked
(130)-Locked menu contents-FB_MISC_9	non_blocked
(131)-Locked menu contents-FB_MISC_10	non_blocked
(132)-Locked menu contents-FB_MISC_11	non_blocked
(133)-Locked menu contents-FB_MISC_12	non_blocked
(134)-Locked menu contents-FB_MISC_13	non_blocked
(135)-Locked menu contents-FB_MISC_14	non_blocked
(136)-Locked menu contents-FB_MISC_15	non_blocked
(137)-Locked menu contents-FB_MISC_16	non_blocked
(138)-Locked menu contents-FB_MISC_17	non_blocked
(139)-Locked menu contents-FB_MISC_18	non_blocked
(140)-Locked menu contents-FB_MISC_19	non_blocked
(141)-Locked menu contents-FB_MISC_20	non_blocked
;Friday	4	December	2015	20:59:15:30193
Bluetooth	On
(142)-Locked menu contents-FB_MISC_21	non_blocked
(143)-Locked menu contents-FB_MISC_22	non_blocked
(144)-Locked menu contents-FB_MISC_23	non_blocked
(145)-Locked menu contents-FB_MISC_24	non_blocked
(146)-Locked menu contents-FB_MISC_25	non_blocked
(147)-Locked menu contents-FB_MISC_26	non_blocked
(148)-Locked menu contents-FB_MISC_27	non_blocked
(149)-Locked menu contents-FB_MISC_28	non_blocked
(150)-Locked menu contents-FB_MISC_29	non_blocked
(151)-Locked menu contents-FB_MISC_30	non_blocked
(152)-Locked menu contents-FB_MISC_31	non_blocked
(153)-Locked menu contents-FB_MISC_32	non_blocked
(154)-Locked menu contents-FB_MISC_33	non_blocked
(155)-Locked menu contents-FB_MISC_34	non_blocked
(156)-Locked menu contents-FB_MISC_35	non_blocked
(157)-Locked menu contents-FB_MISC_36	non_blocked
(158)-Locked menu contents-FB_MISC_37	non_blocked
(159)-Locked menu contents-FB_MISC_38	non_blocked
(160)-Locked menu contents-FB_MISC_39	non_blocked
(161)-Locked menu contents-FB_MISC_40	non_blocked
(162)-Locked menu contents-FB_MISC_41	non_blocked
(163)-Locked menu contents-FB_MISC_42	non_blocked
(164)-Locked menu contents-FB_MISC_43	non_blocked
(165)-Locked menu contents-FB_MISC_44	non_blocked
(166)-Locked menu contents-FB_MISC_45	non_blocked
(167)-Locked menu contents-FB_MISC_46	non_blocked
(168)-Locked menu contents-FB_MISC_47	non_blocked
Menu entries for mobile online services	not activated
Microphone sensitivity	0 dB
(1)-Navigation receiver GNSS configuration-Default	On
(2)-Navigation receiver GNSS configuration-GPS	OFF
(3)-Navigation receiver GNSS configuration-Galileo	OFF
(4)-Navigation receiver GNSS configuration-Glonass	OFF
(5)-Navigation receiver GNSS configuration-Compass	OFF
Number 1 (roaming) for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 1 for Info call	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 1 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 2 for Info call	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 2 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Production mode	00 00 00
Selection of release codes for a SWaP function	FF FF FF FF
Sporadic ring break detection	Visual
Summertime-automatic	manual
Tuner for satellite radio; preparation	7
Wheel circ.	0 mm
Wheel pulse	0
WLAN	On
BAP_Debug_Mode_Release	not_released
Bluetooth_Phonebook_Access_Profile	PBAP
(1)-Car_Function_Adaptations_Gen2-menu_display_ACC	not activated
(2)-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated
(3)-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	not activated
(4)-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated
(5)-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated
(6)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	activated
(7)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated
(8)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high	activated
(9)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated
(10)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated
(11)-Car_Function_Adaptations_Gen2-menu_display_pdc	not activated
(12)-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated
(13)-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	not activated
(14)-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated
(15)-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated
(16)-Car_Function_Adaptations_Gen2-menu_display_awv	not activated
(17)-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated
(18)-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	not activated
(19)-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated
(20)-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated
(21)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	not activated
(22)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated
(23)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high	not activated
(24)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated
(25)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer	not activated
(26)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	not activated
(27)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated
(28)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	not activated
(29)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	not activated
(30)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	not activated
(31)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	activated
(32)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated
(33)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high	activated
(34)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated
(35)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer	not activated
(36)-Car_Function_Adaptations_Gen2-menu_display_windows	activated
(37)-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated
(38)-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	activated
(39)-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated
(40)-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated
(41)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	activated
(42)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated
(43)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high	activated
(44)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated
(45)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated
(46)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated
(47)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated
(48)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated
(49)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated
(50)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated
(51)-Car_Function_Adaptations_Gen2-menu_display_board_computer	activated
(52)-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated
(53)-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high	activated
(54)-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated
(55)-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated
(56)-Car_Function_Adaptations_Gen2-menu_display_rdk	activated
(57)-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated
(58)-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	activated
(59)-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	not activated
(60)-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated
(61)-Car_Function_Adaptations_Gen2-menu_display_wiper	activated
(62)-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated
(63)-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	activated
(64)-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated
(65)-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated
(66)-Car_Function_Adaptations_Gen2-menu_display_sia	activated
(67)-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated
(68)-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	activated
(69)-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated
(70)-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated
(71)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated
(72)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated
(73)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	not activated
(74)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated
(75)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated
(76)-Car_Function_Adaptations_Gen2-menu_display_central_locking	activated
(77)-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated
(78)-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	activated
(79)-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated
(80)-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated
(81)-Car_Function_Adaptations_Gen2-menu_display_compass	not activated
(82)-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated
(83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	not activated
(84)-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated
(85)-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated
(86)-Car_Function_Adaptations_Gen2-menu_display_charisma	activated
(87)-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated
(88)-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	activated
(89)-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated
(90)-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated
(91)-Car_Function_Adaptations_Gen2-menu_display_oil_level	not activated
(92)-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated
(93)-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	not activated
(94)-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated
(95)-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated
(96)-Car_Function_Adaptations_Gen2-menu_display_vin	activated
(97)-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated
(98)-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	activated
(99)-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated
(100)-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated
(101)-Car_Function_Adaptations_Gen2-menu_display_clock	activated
(102)-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated
(103)-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	activated
(104)-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated
(105)-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated
(106)-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated
(107)-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated
(108)-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated
(109)-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated
(110)-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated
(111)-Car_Function_Adaptations_Gen2-menu_display_headup_display	not activated
(112)-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated
(113)-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	not activated
(114)-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated
(115)-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated
(116)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	activated
(117)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated
(118)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high	activated
(119)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated
(120)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated
(121)-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated
(122)-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated
(123)-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated
(124)-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated
(125)-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated
(126)-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated
(127)-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated
(128)-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated
(129)-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated
(130)-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated
(131)-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated
(132)-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated
(133)-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated
(134)-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated
(135)-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated
(136)-Car_Function_Adaptations_Gen2-menu_display_side_view	not activated
(137)-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated
(138)-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	not activated
(139)-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated
(140)-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated
(141)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	not activated
(142)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated
(143)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high	not activated
(144)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated
(145)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer	not activated
(146)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	not activated
(147)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated
(148)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	not activated
(149)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated
(150)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated
(151)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	not activated
(152)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated
(153)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high	not activated
(154)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated
(155)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer	not activated
(156)-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated
(157)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated
(158)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high	not activated
(159)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated
(160)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer	not activated
(161)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	not activated
(162)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated
(163)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	not activated
(164)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated
(165)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated
(166)-Car_Function_Adaptations_Gen2-menu_display_car_mirror	not activated
(167)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated
(168)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	not activated
(169)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated
(170)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated
(171)-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated
(172)-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated
(173)-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated
(174)-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated
(175)-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated
(176)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	not activated
(177)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated
(178)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high	not activated
(179)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated
(180)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer	not activated
(181)-Car_Function_Adaptations_Gen2-menu_display_BCmE	not activated
(182)-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated
(183)-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	not activated
(184)-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated
(185)-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated
(186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	activated
(187)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated
(188)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	activated
(189)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated
(190)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated
(191)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	not activated
(192)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated
(193)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	not activated
(194)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated
(195)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated
(196)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	not activated
(197)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated
(198)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high	not activated
(199)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated
(200)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated
(201)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated
(202)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated
(203)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated
(204)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated
(205)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated
(206)-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated
(207)-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated
(208)-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high	not activated
(209)-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated
(210)-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated
(211)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated
(212)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated
(213)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high	not activated
(214)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated
(215)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer	not activated
(216)-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated
(217)-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated
(218)-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated
(219)-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated
(220)-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated
(221)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated
(222)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated
(223)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated
(224)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated
(225)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated
(226)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated
(227)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated
(228)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated
(229)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated
(230)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated
(231)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated
(232)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated
(233)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated
(234)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated
(235)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated
(236)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated
(237)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated
(238)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated
(239)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated
(240)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated
(241)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated
(242)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated
(243)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated
(244)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated
(245)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated
(246)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated
(247)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated
(248)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated
(249)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated
(250)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated
(251)-Car_Function_Adaptations_Gen2-menu_display_Ecall	not activated
(252)-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated
(253)-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	not activated
(254)-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated
(255)-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated
(256)-Car_Function_Adaptations_Gen2-menu_display_ENI	not activated
(257)-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated
(258)-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	not activated
(259)-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated
(260)-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated
(261)-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated
(262)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated
(263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated
(264)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated
(265)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated
(266)-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated
(267)-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated
(268)-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated
(269)-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated
(270)-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated
(271)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue	not activated
(272)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_clamp_15_off	not activated
(273)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_over_threshold_high	not activated
(274)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_standstill	not activated
(275)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_after_disclaimer	not activated
(276)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	not activated
(277)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated
(278)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	not activated
(279)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated
(280)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated
(1)-Car_Function_List_BAP_Gen2-climatic_master_0x01	activated
(2)-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	Comfort data bus
(3)-Car_Function_List_BAP_Gen2-climatic_slave_0x02	not activated
(4)-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	Comfort data bus
(5)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated
(6)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	Comfort data bus
(7)-Car_Function_List_BAP_Gen2-headup_displ_0x04	not activated
(8)-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	Comfort data bus
(9)-Car_Function_List_BAP_Gen2-ACC_0x05	not activated
(10)-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	Databus extended
(11)-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated
(12)-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	Suspension data bus
(13)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated
(14)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Suspension data bus
(15)-Car_Function_List_BAP_Gen2-interieur_light_0x08	activated
(16)-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	Comfort data bus
(17)-Car_Function_List_BAP_Gen2-exterieur_light_0x09	activated
(18)-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	Comfort data bus
(19)-Car_Function_List_BAP_Gen2-parking_assist_0x0A	not activated
(20)-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15
(21)-Car_Function_List_BAP_Gen2-VPS_0x0B	not activated
(22)-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	Databus Infotainment
(23)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	activated
(24)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	Comfort data bus
(25)-Car_Function_List_BAP_Gen2-central_locking_0x0D	activated
(26)-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	Comfort data bus
(27)-Car_Function_List_BAP_Gen2-mirror_0x0E	activated
(28)-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	Comfort data bus
(29)-Car_Function_List_BAP_Gen2-MFA_0x0F	activated
(30)-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	Comfort data bus
(31)-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated
(32)-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	Comfort data bus
(33)-Car_Function_List_BAP_Gen2-clock_0x11	activated
(34)-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	Comfort data bus
(35)-Car_Function_List_BAP_Gen2-service_interval_display_0x12	activated
(36)-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	Comfort data bus
(37)-Car_Function_List_BAP_Gen2-unit_master_0x13	activated
(38)-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	Comfort data bus
(39)-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated
(40)-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	Terminal 15
(41)-Car_Function_List_BAP_Gen2-compass_0x15	not activated
(42)-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated
(43)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated
(44)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	Comfort data bus
(45)-Car_Function_List_BAP_Gen2-charisma_0x17	activated
(46)-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	Databus Infotainment
(47)-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated
(48)-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated
(49)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	not activated
(50)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	Databus extended
(51)-Car_Function_List_BAP_Gen2-SWA_0x1A	not activated
(52)-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	Databus extended
(53)-Car_Function_List_BAP_Gen2-AWV_0x1B	not activated
(54)-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	Terminal 15
(55)-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated
(56)-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	Databus drivetrain
(57)-Car_Function_List_BAP_Gen2-SideView_0x1E	not activated
(58)-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	not activated
(59)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	not activated
(60)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	Databus drivetrain
(61)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20	not activated
(62)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20_msg_bus	Comfort data bus
(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	not activated
(64)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	Databus extended
(65)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	not activated
(66)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	Databus Infotainment
(67)-Car_Function_List_BAP_Gen2-BCmE_0x23	activated
(68)-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	Databus Infotainment
(69)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated
(70)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated
(71)-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated
(72)-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	Databus drivetrain
(73)-Car_Function_List_BAP_Gen2-Brake_0x26	activated
(74)-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	Suspension data bus
(75)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	not activated
(76)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	Databus Infotainment
(77)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated
(78)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	Comfort data bus
(79)-Car_Function_List_BAP_Gen2-Amplifier_0x2D	not activated
(80)-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	not activated
(81)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated
(82)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	Comfort data bus
(83)-Car_Function_List_BAP_Gen2-Ecall_0x33	activated
(84)-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	Comfort data bus
(85)-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	not activated
(86)-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	Databus Infotainment
(87)-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated
(88)-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	Comfort data bus
(89)-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated
(90)-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	Comfort data bus
(91)-Car_Function_List_BAP_Gen2-ENI_0x37	activated
(92)-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	Comfort data bus
(93)-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated
(94)-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	Databus Infotainment
(95)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated
(96)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	Databus extended
(97)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated
(98)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	Comfort data bus
(99)-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	not activated
(100)-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	Comfort data bus
(1)-Car_Function_List_CAN_Gen2-MFL	Available
(2)-Car_Function_List_CAN_Gen2-MFL_msg_bus	Databus Infotainment
(3)-Car_Function_List_CAN_Gen2-Oil_level	Not available
(4)-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Databus drivetrain
(5)-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Not available
(6)-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Suspension data bus
(7)-Car_Function_List_CAN_Gen2-VIN	Available
(8)-Car_Function_List_CAN_Gen2-VIN_msg_bus	Comfort data bus
(9)-Car_Function_List_CAN_Gen2-Driving_school	Not available
(10)-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Databus Infotainment
(11)-Car_Function_List_CAN_Gen2-Adaptive_key	Not available
(12)-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Comfort data bus
(1)-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0
(2)-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0
(3)-Dimming_Ambient_Illumination_Information_Control_Unit-X2	50
(4)-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	50
(5)-Dimming_Ambient_Illumination_Information_Control_Unit-X3	100
(6)-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	100
(1)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1	0
(2)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1	0
(3)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2	50
(4)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2	50
(5)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3	100
(6)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3	100
(1)-Dimming_Illumination_for_Display_Unit-X1	0
(2)-Dimming_Illumination_for_Display_Unit-Y1	1%
(3)-Dimming_Illumination_for_Display_Unit-X2	10
(4)-Dimming_Illumination_for_Display_Unit-Y2	1%
(5)-Dimming_Illumination_for_Display_Unit-X3	100
(6)-Dimming_Illumination_for_Display_Unit-Y3	8%
(7)-Dimming_Illumination_for_Display_Unit-X4	150
(8)-Dimming_Illumination_for_Display_Unit-Y4	20%
(9)-Dimming_Illumination_for_Display_Unit-X5	220
(10)-Dimming_Illumination_for_Display_Unit-Y5	60%
(11)-Dimming_Illumination_for_Display_Unit-X6	253
(12)-Dimming_Illumination_for_Display_Unit-Y6	100%
Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation	04 01 52 04 52 10 52 40 52 32 00 64 00 3C 00 7C 01 1D 01 50 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 02 00 A8
p_damping_Display	5 ms
p_HMI_Display	13%
(1)-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0
(2)-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0
Startup_Screen_Sticker_HMI	00 01
(1)-Vehicle_configuration-VZAPro	OFF
(2)-Vehicle_configuration-online_POI	OFF
(3)-Vehicle_configuration-online_POI_voice	OFF
(4)-Vehicle_configuration-online_portal_browser_services	OFF
(5)-Vehicle_configuration-online_navigation	OFF
(6)-Vehicle_configuration-online_street_view	OFF
(7)-Vehicle_configuration-WIFI_Hotspot	OFF
(8)-Vehicle_configuration-my_audi	OFF
(9)-Vehicle_configuration-picture_navi	On
(10)-Vehicle_configuration-online_dictation	OFF
(11)-Vehicle_configuration-remote_HMI	OFF
(12)-Vehicle_configuration-advanced_range_display	OFF
(13)-Vehicle_configuration-gracenote_online_coverarts	OFF
(14)-Vehicle_configuration-gracenote_online_other	OFF
(15)-Vehicle_configuration-gracenote_local_coverarts	OFF
(16)-Vehicle_configuration-gracenote_local_other	OFF
(17)-Vehicle_configuration-UPnP	OFF
(18)-Vehicle_configuration-OPS_display_in_dash_board_display_unit	OFF
(19)-Vehicle_configuration-Joker_button_1	Not Present
(20)-Vehicle_configuration-Joker_button_2	Not Present
(21)-Vehicle_configuration-LTE_modul	activated
(22)-Vehicle_configuration-Support_second_phone	On
(23)-Vehicle_configuration-Support_of_threeway_calling	On
(24)-Vehicle_configuration-Dtmf_without_active_call	On
(25)-Vehicle_configuration-Support_for_response_and_hold	OFF
(26)-Vehicle_configuration-Sim_card_mode_switch	Not Present
(27)-Vehicle_configuration-Phone_module_operation_mode	Data & language service active
(28)-Vehicle_configuration-PSD_Protocol_Version	PSD_1.5
(29)-Vehicle_configuration-RVC_video_input	FBAS
(30)-Vehicle_configuration-Station_Logo_DB_Mode	0
(31)-Vehicle_configuration-TPEG_availability	OFF
(32)-Vehicle_configuration-VZO	OFF
(33)-Vehicle_configuration-LGI	OFF
(34)-Vehicle_configuration-ProbeCar_vzo	OFF
(35)-Vehicle_configuration-online_media	OFF
(36)-Vehicle_configuration-ProbeCar_lgi	OFF
(37)-Vehicle_configuration-NMH_stopwatch	OFF
(38)-Vehicle_configuration-Google_GAL	On
(39)-Vehicle_configuration-Apple_DIO	On
(40)-Vehicle_configuration-UOTA	OFF
(41)-Vehicle_configuration-WiFi_Client_HMI	OFF
(42)-Vehicle_configuration-RSE_software_component	activated
(43)-Vehicle_configuration-SDS_Region_Flag	no_region
silvera4quattro
C?ID=58593
This did it for me as well, awesome! 166 is not enabled on my car and enabling it brings a menus which don't apply to options no my car, so I'm leaving that one alone. Got my convenience consumers menu back though, so that's great.
   #53
silvera4quattro: Many thanks for the admap. I now have MIBII information from 3 countries (Australia, EU, USA). Interesting to see how VW set-up the new infotainment units for various parts of the world. Lots of settings the same -711 x channels are the same for all three countries (i.e. 92% of 776 x total channels). Not surprisingly though, the good stuff is in the differences! Not sure why USA gets a bunch of "ECU coded" channels and no one else does! Tables HERE (hope many more folk get inspired to post-up their admaps - so I can thieve them too)
Cheers
mtl: Just checking - was your admap complete? You appear to be missing the 2 x adaptation channels:
Not sure if this means that EU cars don't have these channels (Australia and USA does have these channels), or if your cut-and-paste prematurely truncated the complete admap
Interested in your repsonse
golfi_vend
Tartu, Estonia
C?ID=195131
Skoda Octavia MY2016
;SW:5Q0-035-840-A   HW:5Q0-035-840-A ---  Information Electr.
;Component:MU-S--ER      H24 0241, Coding:03730100FF00000011110001000100002F0200C40120010000
;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW26.rod
;Thursday,26,November,2015,16:48:02:36026
;VCDS Version: Release 15.7.1 (x64)  Data version: 20150904
;VCID: AB164CE0C2890A6658-80FE
(1)-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
(2)-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
(1)-Audio Management Input Gain Generation 2-TV Tuner,-128
(2)-Audio Management Input Gain Generation 2-Radio (FM),-128
(3)-Audio Management Input Gain Generation 2-Radio (AM),-128
(4)-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
(5)-Audio Management Input Gain Generation 2-Satellite radio,-128
(6)-Audio Management Input Gain Generation 2-Tuner_TI,-128
(7)-Audio Management Input Gain Generation 2-Media_AUXIN,-128
(8)-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
(9)-Audio Management Input Gain Generation 2-Media_CDA,-128
(10)-Audio Management Input Gain Generation 2-Media_DVD,-128
(11)-Audio Management Input Gain Generation 2-Media_MFP,-128
(12)-Audio Management Input Gain Generation 2-Media_BTDevice,-128
(13)-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
(14)-Audio Management Input Gain Generation 2-Media_Bluray,-128
(15)-Audio Management Input Gain Generation 2-Media_HDMI,-128
(16)-Audio Management Input Gain Generation 2-Tuner_Online,-128
(17)-Audio Management Input Gain Generation 2-Media_Airplay,-128
(18)-Audio Management Input Gain Generation 2-Media_UPNP,-128
(19)-Audio Management Input Gain Generation 2-Media_Cloud,-128
(20)-Audio Management Input Gain Generation 2-Tuner_Personal,-128
(21)-Audio Management Input Gain Generation 2-Tone_Beep,-128
(22)-Audio Management Input Gain Generation 2-Tone_Warning,-128
(23)-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
(24)-Audio Management Input Gain Generation 2-Tone_Messaging,-128
(25)-Audio Management Input Gain Generation 2-Exbox_DMB,-128
(26)-Audio Management Input Gain Generation 2-Mirrorlink,-128
(27)-Audio Management Input Gain Generation 2-TTS_Nav,-128
(28)-Audio Management Input Gain Generation 2-TTS_SDS,-128
(29)-Audio Management Input Gain Generation 2-Phone_Voice,-128
(30)-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
(31)-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
(32)-Audio Management Input Gain Generation 2-HFP,-128
(33)-Audio Management Input Gain Generation 2-TV_AV_IN,-128
Automatic ring break diagnostic,No automatic start
Awakening ability on optical databus,OFF
Base volume of speech output,50 %
Base volume of telephone,50 %
Bluetooth,On
Bluetooth: Sniff mode,OFF
(1)-Check tone frequency-High note frequency range,4000 Hz
(2)-Check tone frequency-Medium note frequency range,1000 Hz
(3)-Check tone frequency-Low note frequency range,100 Hz
Confirmation of installation change,23 5F
Country identification; country of sale HMI,--
Deactivate production mode,0
Developer mode,not activated
(1)-Electrical test of loudspeakers-Mode,automatic
(2)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
(3)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36
(4)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
(5)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36
(6)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
(7)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36
(8)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
(9)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36
(10)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
(11)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36
(12)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
(13)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36
(14)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
(15)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36
(16)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
(17)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36
(18)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
(19)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36
(20)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
(21)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36
(22)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
(23)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36
(24)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
(25)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36
(26)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
(27)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36
(28)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
(29)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36
(30)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
(31)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36
(32)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
(33)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36
Infotainment Recorder,activated
(1)-Installation list; specified installations-ECU coded,Yes
(2)-Installation list; specified installations-ECU coded,No
(3)-Installation list; specified installations-ECU coded,No
(4)-Installation list; specified installations-ECU coded,No
(5)-Installation list; specified installations-ECU coded,No
(6)-Installation list; specified installations-ECU coded,No
(7)-Installation list; specified installations-ECU coded,No
(8)-Installation list; specified installations-ECU coded,No
(9)-Installation list; specified installations-ECU coded 2,No
(10)-Installation list; specified installations-ECU coded 2,No
(11)-Installation list; specified installations-ECU coded 2,No
(1)-Interface for external media; activation-Connection 1,activated
(2)-Interface for external media; activation-Connection 2,not activated
(3)-Interface for external media; activation-Connection 3,not activated
(4)-Interface for external media; activation-Connection 4,not activated
(1)-Locked menu contents-FB_TUNER_0,non_blocked
(2)-Locked menu contents-FB_TUNER_1,non_blocked
(3)-Locked menu contents-FB_TUNER_2,non_blocked
(4)-Locked menu contents-FB_TUNER_3,non_blocked
(5)-Locked menu contents-FB_TUNER_4,non_blocked
(6)-Locked menu contents-FB_TUNER_5,non_blocked
(7)-Locked menu contents-FB_TUNER_6,non_blocked
(8)-Locked menu contents-FB_TUNER_7,non_blocked
(9)-Locked menu contents-FB_TUNER_8,non_blocked
(10)-Locked menu contents-FB_TUNER_9,non_blocked
(11)-Locked menu contents-FB_TUNER_10,non_blocked
(12)-Locked menu contents-FB_TUNER_11,non_blocked
(13)-Locked menu contents-FB_TUNER_12,non_blocked
(14)-Locked menu contents-FB_TUNER_13,non_blocked
(15)-Locked menu contents-FB_TUNER_14,non_blocked
(16)-Locked menu contents-FB_TUNER_15,non_blocked
(17)-Locked menu contents-FB_MEDIA_0,non_blocked
(18)-Locked menu contents-FB_MEDIA_1,non_blocked
(19)-Locked menu contents-FB_MEDIA_2,non_blocked
(20)-Locked menu contents-FB_MEDIA_3,non_blocked
(21)-Locked menu contents-FB_MEDIA_4,non_blocked
(22)-Locked menu contents-FB_MEDIA_5,non_blocked
(23)-Locked menu contents-FB_MEDIA_6,non_blocked
(24)-Locked menu contents-FB_MEDIA_7,non_blocked
(25)-Locked menu contents-FB_MEDIA_8,non_blocked
(26)-Locked menu contents-FB_MEDIA_9,non_blocked
(27)-Locked menu contents-FB_MEDIA_10,non_blocked
(28)-Locked menu contents-FB_MEDIA_11,non_blocked
(29)-Locked menu contents-FB_MEDIA_12,non_blocked
(30)-Locked menu contents-FB_MEDIA_13,non_blocked
(31)-Locked menu contents-FB_MEDIA_14,non_blocked
(32)-Locked menu contents-FB_MEDIA_15,non_blocked
(33)-Locked menu contents-FB_MEDIA_16,non_blocked
(34)-Locked menu contents-FB_MEDIA_17,non_blocked
(35)-Locked menu contents-FB_MEDIA_18,non_blocked
(36)-Locked menu contents-FB_MEDIA_19,non_blocked
(37)-Locked menu contents-FB_MEDIA_20,non_blocked
(38)-Locked menu contents-FB_MEDIA_21,non_blocked
(39)-Locked menu contents-FB_MEDIA_22,non_blocked
(40)-Locked menu contents-FB_MEDIA_23,non_blocked
(41)-Locked menu contents-FB_PHONE_0,non_blocked
(42)-Locked menu contents-FB_PHONE_1,non_blocked
(43)-Locked menu contents-FB_PHONE_2,non_blocked
(44)-Locked menu contents-FB_PHONE_3,non_blocked
(45)-Locked menu contents-FB_PHONE_4,non_blocked
(46)-Locked menu contents-FB_PHONE_5,non_blocked
(47)-Locked menu contents-FB_PHONE_6,non_blocked
(48)-Locked menu contents-FB_PHONE_7,non_blocked
(49)-Locked menu contents-FB_PHONE_8,non_blocked
(50)-Locked menu contents-FB_PHONE_9,non_blocked
(51)-Locked menu contents-FB_PHONE_10,non_blocked
(52)-Locked menu contents-FB_PHONE_11,non_blocked
(53)-Locked menu contents-FB_PHONE_12,non_blocked
(54)-Locked menu contents-FB_PHONE_13,non_blocked
(55)-Locked menu contents-FB_PHONE_14,non_blocked
(56)-Locked menu contents-FB_PHONE_15,non_blocked
(57)-Locked menu contents-FB_NAV_0,non_blocked
(58)-Locked menu contents-FB_NAV_1,non_blocked
(59)-Locked menu contents-FB_NAV_2,non_blocked
(60)-Locked menu contents-FB_NAV_3,non_blocked
(61)-Locked menu contents-FB_NAV_4,non_blocked
(62)-Locked menu contents-FB_NAV_5,non_blocked
(63)-Locked menu contents-FB_NAV_6,non_blocked
(64)-Locked menu contents-FB_NAV_7,non_blocked
(65)-Locked menu contents-FB_NAV_8,non_blocked
(66)-Locked menu contents-FB_NAV_9,non_blocked
(67)-Locked menu contents-FB_NAV_10,non_blocked
(68)-Locked menu contents-FB_NAV_11,non_blocked
(69)-Locked menu contents-FB_NAV_12,non_blocked
(70)-Locked menu contents-FB_NAV_13,non_blocked
(71)-Locked menu contents-FB_NAV_14,non_blocked
(72)-Locked menu contents-FB_NAV_15,non_blocked
(73)-Locked menu contents-FB_NAV_16,non_blocked
(74)-Locked menu contents-FB_NAV_17,non_blocked
(75)-Locked menu contents-FB_NAV_18,non_blocked
(76)-Locked menu contents-FB_NAV_19,non_blocked
(77)-Locked menu contents-FB_NAV_20,non_blocked
(78)-Locked menu contents-FB_NAV_21,non_blocked
(79)-Locked menu contents-FB_NAV_22,non_blocked
(80)-Locked menu contents-FB_NAV_23,non_blocked
(81)-Locked menu contents-FB_NAV_24,non_blocked
(82)-Locked menu contents-FB_NAV_25,non_blocked
(83)-Locked menu contents-FB_NAV_26,non_blocked
(84)-Locked menu contents-FB_NAV_27,non_blocked
(85)-Locked menu contents-FB_NAV_28,non_blocked
(86)-Locked menu contents-FB_NAV_29,non_blocked
(87)-Locked menu contents-FB_NAV_30,non_blocked
(88)-Locked menu contents-FB_NAV_31,non_blocked
(89)-Locked menu contents-FB_NAV_32,non_blocked
(90)-Locked menu contents-FB_NAV_33,non_blocked
(91)-Locked menu contents-FB_NAV_34,non_blocked
(92)-Locked menu contents-FB_NAV_35,non_blocked
(93)-Locked menu contents-FB_NAV_36,non_blocked
(94)-Locked menu contents-FB_NAV_37,non_blocked
(95)-Locked menu contents-FB_NAV_38,non_blocked
(96)-Locked menu contents-FB_NAV_39,non_blocked
(97)-Locked menu contents-FB_CAR_0,non_blocked
(98)-Locked menu contents-FB_CAR_1,non_blocked
(99)-Locked menu contents-FB_CAR_2,non_blocked
(100)-Locked menu contents-FB_CAR_3,non_blocked
(101)-Locked menu contents-FB_CAR_4,non_blocked
(102)-Locked menu contents-FB_CAR_5,non_blocked
(103)-Locked menu contents-FB_CAR_6,non_blocked
(104)-Locked menu contents-FB_CAR_7,non_blocked
(105)-Locked menu contents-FB_CAR_8,non_blocked
(106)-Locked menu contents-FB_CAR_9,non_blocked
(107)-Locked menu contents-FB_CAR_10,non_blocked
(108)-Locked menu contents-FB_CAR_11,non_blocked
(109)-Locked menu contents-FB_CAR_12,non_blocked
(110)-Locked menu contents-FB_CAR_13,non_blocked
(111)-Locked menu contents-FB_CAR_14,non_blocked
(112)-Locked menu contents-FB_CAR_15,non_blocked
(113)-Locked menu contents-FB_CAR_16,non_blocked
(114)-Locked menu contents-FB_CAR_17,non_blocked
(115)-Locked menu contents-FB_CAR_18,non_blocked
(116)-Locked menu contents-FB_CAR_19,non_blocked
(117)-Locked menu contents-FB_CAR_20,non_blocked
(118)-Locked menu contents-FB_CAR_21,non_blocked
(119)-Locked menu contents-FB_CAR_22,non_blocked
(120)-Locked menu contents-FB_CAR_23,non_blocked
(121)-Locked menu contents-FB_MISC_0,non_blocked
(122)-Locked menu contents-FB_MISC_1,non_blocked
(123)-Locked menu contents-FB_MISC_2,non_blocked
(124)-Locked menu contents-FB_MISC_3,non_blocked
(125)-Locked menu contents-FB_MISC_4,non_blocked
(126)-Locked menu contents-FB_MISC_5,non_blocked
(127)-Locked menu contents-FB_MISC_6,non_blocked
(128)-Locked menu contents-FB_MISC_7,non_blocked
(129)-Locked menu contents-FB_MISC_8,non_blocked
(130)-Locked menu contents-FB_MISC_9,non_blocked
(131)-Locked menu contents-FB_MISC_10,non_blocked
(132)-Locked menu contents-FB_MISC_11,non_blocked
(133)-Locked menu contents-FB_MISC_12,non_blocked
(134)-Locked menu contents-FB_MISC_13,non_blocked
(135)-Locked menu contents-FB_MISC_14,non_blocked
(136)-Locked menu contents-FB_MISC_15,non_blocked
(137)-Locked menu contents-FB_MISC_16,non_blocked
(138)-Locked menu contents-FB_MISC_17,non_blocked
(139)-Locked menu contents-FB_MISC_18,non_blocked
(140)-Locked menu contents-FB_MISC_19,non_blocked
(141)-Locked menu contents-FB_MISC_20,non_blocked
(142)-Locked menu contents-FB_MISC_21,non_blocked
(143)-Locked menu contents-FB_MISC_22,non_blocked
(144)-Locked menu contents-FB_MISC_23,non_blocked
(145)-Locked menu contents-FB_MISC_24,non_blocked
(146)-Locked menu contents-FB_MISC_25,non_blocked
(147)-Locked menu contents-FB_MISC_26,non_blocked
(148)-Locked menu contents-FB_MISC_27,non_blocked
(149)-Locked menu contents-FB_MISC_28,non_blocked
(150)-Locked menu contents-FB_MISC_29,non_blocked
(151)-Locked menu contents-FB_MISC_30,non_blocked
(152)-Locked menu contents-FB_MISC_31,non_blocked
(153)-Locked menu contents-FB_MISC_32,non_blocked
(154)-Locked menu contents-FB_MISC_33,non_blocked
(155)-Locked menu contents-FB_MISC_34,non_blocked
(156)-Locked menu contents-FB_MISC_35,non_blocked
(157)-Locked menu contents-FB_MISC_36,non_blocked
(158)-Locked menu contents-FB_MISC_37,non_blocked
(159)-Locked menu contents-FB_MISC_38,non_blocked
(160)-Locked menu contents-FB_MISC_39,non_blocked
(161)-Locked menu contents-FB_MISC_40,non_blocked
(162)-Locked menu contents-FB_MISC_41,non_blocked
(163)-Locked menu contents-FB_MISC_42,non_blocked
(164)-Locked menu contents-FB_MISC_43,non_blocked
(165)-Locked menu contents-FB_MISC_44,non_blocked
(166)-Locked menu contents-FB_MISC_45,non_blocked
(167)-Locked menu contents-FB_MISC_46,non_blocked
(168)-Locked menu contents-FB_MISC_47,non_blocked
Menu entries for mobile online services,not activated
Microphone sensitivity,0 dB
Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Number 1 for Info call,5E 04 A1 86 80 82 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 1 for roadside assistance,5E 04 A1 96 97 81 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Number 2 for Info call,5E 05 91 73 62 08 28 08 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 2 for roadside assistance,5E 05 91 73 62 79 19 28 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Production mode,00 00 00
Selection of release codes for a SWaP function,FF FF FF FF
Sporadic ring break detection,Visual
Summertime-automatic,Europe
WLAN,On
BAP_Debug_Mode_Release,not_released
Bluetooth_Phonebook_Access_Profile,PBAP
(1)-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated
(2)-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
(3)-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated
(4)-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
(5)-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
(6)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
(7)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
(8)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated
(9)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
(10)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated
(11)-Car_Function_Adaptations_Gen2-menu_display_pdc,activated
(12)-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
(13)-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated
(14)-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
(15)-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
(16)-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
(17)-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
(18)-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated
(19)-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
(20)-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
(21)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated
(22)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated
(23)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated
(24)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
(25)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated
(26)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated
(27)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
(28)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated
(29)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
(30)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
(31)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
(32)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated
(33)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated
(34)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
(35)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated
(36)-Car_Function_Adaptations_Gen2-menu_display_windows,activated
(37)-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
(38)-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated
(39)-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
(40)-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
(41)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated
(42)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
(43)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated
(44)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
(45)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated
(46)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
(47)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
(48)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated
(49)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
(50)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated
(51)-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
(52)-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
(53)-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated
(54)-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
(55)-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
(56)-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
(57)-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
(58)-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated
(59)-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated
(60)-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
(61)-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
(62)-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
(63)-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
(64)-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
(65)-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
(66)-Car_Function_Adaptations_Gen2-menu_display_sia,activated
(67)-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
(68)-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
(69)-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
(70)-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
(71)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated
(72)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
(73)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated
(74)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
(75)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated
(76)-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
(77)-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
(78)-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated
(79)-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
(80)-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
(81)-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
(82)-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
(83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated
(84)-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
(85)-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
(86)-Car_Function_Adaptations_Gen2-menu_display_charisma,activated
(87)-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
(88)-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated
(89)-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
(90)-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
(91)-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated
(92)-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
(93)-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated
(94)-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
(95)-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
(96)-Car_Function_Adaptations_Gen2-menu_display_vin,activated
(97)-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
(98)-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
(99)-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
(100)-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
(101)-Car_Function_Adaptations_Gen2-menu_display_clock,activated
(102)-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
(103)-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
(104)-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
(105)-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
(106)-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
(107)-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
(108)-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,activated
(109)-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
(110)-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
(111)-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
(112)-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
(113)-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated
(114)-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
(115)-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
(116)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
(117)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
(118)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated
(119)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
(120)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated
(121)-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
(122)-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
(123)-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated
(124)-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
(125)-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
(126)-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated
(127)-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
(128)-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,activated
(129)-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
(130)-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
(131)-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
(132)-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
(133)-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,activated
(134)-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
(135)-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
(136)-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
(137)-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
(138)-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,activated
(139)-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
(140)-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
(141)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated
(142)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated
(143)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated
(144)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated
(145)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated
(146)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
(147)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
(148)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated
(149)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
(150)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
(151)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated
(152)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated
(153)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated
(154)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated
(155)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated
(156)-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
(157)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated
(158)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,activated
(159)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated
(160)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated
(161)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated
(162)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
(163)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated
(164)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
(165)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
(166)-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated
(167)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
(168)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated
(169)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
(170)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
(171)-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
(172)-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
(173)-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated
(174)-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
(175)-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
(176)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated
(177)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated
(178)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated
(179)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
(180)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated
(181)-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated
(182)-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
(183)-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated
(184)-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
(185)-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
(186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated
(187)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
(188)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated
(189)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
(190)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
(191)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated
(192)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
(193)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated
(194)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
(195)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
(196)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated
(197)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
(198)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated
(199)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
(200)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated
(201)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
(202)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
(203)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,activated
(204)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
(205)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
(206)-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
(207)-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
(208)-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated
(209)-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
(210)-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated
(211)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
(212)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated
(213)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,activated
(214)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
(215)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated
(216)-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
(217)-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
(218)-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,activated
(219)-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
(220)-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated
(221)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
(222)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
(223)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,activated
(224)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
(225)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated
(226)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
(227)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
(228)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,activated
(229)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
(230)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
(231)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
(232)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
(233)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,activated
(234)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
(235)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
(236)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
(237)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
(238)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated
(239)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
(240)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated
(241)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
(242)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
(243)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,activated
(244)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
(245)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
(246)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
(247)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
(248)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,activated
(249)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
(250)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
(251)-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated
(252)-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
(253)-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated
(254)-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
(255)-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
(256)-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated
(257)-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
(258)-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated
(259)-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
(260)-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
(261)-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated
(262)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated
(263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated
(264)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated
(265)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated
(266)-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
(267)-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
(268)-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
(269)-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
(270)-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
(271)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue,not activated
(272)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_clamp_15_off,not activated
(273)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_over_threshold_high,not activated
(274)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_standstill,not activated
(275)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_after_disclaimer,not activated
(276)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated
(277)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
(278)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated
(279)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
(280)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated
(1)-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated
(2)-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus
(3)-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
(4)-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus
(5)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
(6)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus
(7)-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
(8)-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus
(9)-Car_Function_List_BAP_Gen2-ACC_0x05,not activated
(10)-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended
(11)-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
(12)-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus
(13)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
(14)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus
(15)-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
(16)-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus
(17)-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
(18)-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus
(19)-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
(20)-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
(21)-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated
(22)-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment
(23)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
(24)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus
(25)-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
(26)-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus
(27)-Car_Function_List_BAP_Gen2-mirror_0x0E,activated
(28)-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus
(29)-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
(30)-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus
(31)-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated
(32)-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus
(33)-Car_Function_List_BAP_Gen2-clock_0x11,activated
(34)-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus
(35)-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
(36)-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus
(37)-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
(38)-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus
(39)-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated
(40)-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15
(41)-Car_Function_List_BAP_Gen2-compass_0x15,not activated
(42)-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Databus Infotainment
(43)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
(44)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus
(45)-Car_Function_List_BAP_Gen2-charisma_0x17,activated
(46)-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment
(47)-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
(48)-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9
(49)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated
(50)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended
(51)-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated
(52)-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended
(53)-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
(54)-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15
(55)-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
(56)-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain
(57)-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
(58)-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9
(59)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated
(60)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain
(61)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20,not activated
(62)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20_msg_bus,Comfort data bus
(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated
(64)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended
(65)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated
(66)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment
(67)-Car_Function_List_BAP_Gen2-BCmE_0x23,activated
(68)-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment
(69)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
(70)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus
(71)-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
(72)-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Comfort data bus
(73)-Car_Function_List_BAP_Gen2-Brake_0x26,activated
(74)-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus
(75)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated
(76)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment
(77)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
(78)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus
(79)-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
(80)-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9
(81)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
(82)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus
(83)-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated
(84)-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus
(85)-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
(86)-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,CAB_9
(87)-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
(88)-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Databus Infotainment
(89)-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
(90)-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Terminal 15
(91)-Car_Function_List_BAP_Gen2-ENI_0x37,not activated
(92)-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus
(93)-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
(94)-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment
(95)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
(96)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended
(97)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
(98)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus
(99)-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated
(100)-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Databus extended
(1)-Car_Function_List_CAN_Gen2-MFL,Not available
(2)-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment
(3)-Car_Function_List_CAN_Gen2-Oil_level,Not available
(4)-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain
(5)-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available
(6)-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15
(7)-Car_Function_List_CAN_Gen2-VIN,Available
(8)-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus
(9)-Car_Function_List_CAN_Gen2-Driving_school,Not available
(10)-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available
(11)-Car_Function_List_CAN_Gen2-Adaptive_key,Not available
(12)-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus
(1)-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0
(2)-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0
(3)-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50
(4)-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50
(5)-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100
(6)-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100
(1)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0
(2)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0
(3)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50
(4)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50
(5)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100
(6)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100
(1)-Dimming_Illumination_for_Display_Unit-X1,0
(2)-Dimming_Illumination_for_Display_Unit-Y1,1 %
(3)-Dimming_Illumination_for_Display_Unit-X2,10
(4)-Dimming_Illumination_for_Display_Unit-Y2,1 %
(5)-Dimming_Illumination_for_Display_Unit-X3,100
(6)-Dimming_Illumination_for_Display_Unit-Y3,9 %
(7)-Dimming_Illumination_for_Display_Unit-X4,150
(8)-Dimming_Illumination_for_Display_Unit-Y4,20 %
(9)-Dimming_Illumination_for_Display_Unit-X5,220
(10)-Dimming_Illumination_for_Display_Unit-Y5,60 %
(11)-Dimming_Illumination_for_Display_Unit-X6,253
(12)-Dimming_Illumination_for_Display_Unit-Y6,100 %
Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 96 00 90 01 C8 00 96 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 05
p_damping_Display,5 ms
p_HMI_Display,13 %
(1)-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
(2)-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
Startup_Screen_Sticker_HMI,00 00
(1)-Vehicle_configuration-VZAPro,OFF
(2)-Vehicle_configuration-online_POI,OFF
(3)-Vehicle_configuration-online_POI_voice,OFF
(4)-Vehicle_configuration-online_portal_browser_services,OFF
(5)-Vehicle_configuration-online_navigation,OFF
(6)-Vehicle_configuration-online_street_view,OFF
(7)-Vehicle_configuration-WIFI_Hotspot,OFF
(8)-Vehicle_configuration-my_audi,OFF
(9)-Vehicle_configuration-picture_navi,OFF
(10)-Vehicle_configuration-online_dictation,OFF
(11)-Vehicle_configuration-remote_HMI,OFF
(12)-Vehicle_configuration-advanced_range_display,OFF
(13)-Vehicle_configuration-gracenote_online_coverarts,OFF
(14)-Vehicle_configuration-gracenote_online_other,OFF
(15)-Vehicle_configuration-gracenote_local_coverarts,On
(16)-Vehicle_configuration-gracenote_local_other,On
(17)-Vehicle_configuration-UPnP,On
(18)-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF
(19)-Vehicle_configuration-Joker_button_1,Not Present
(20)-Vehicle_configuration-Joker_button_2,Not Present
(21)-Vehicle_configuration-LTE_modul,activated
(22)-Vehicle_configuration-Support_second_phone,OFF
(23)-Vehicle_configuration-Support_of_threeway_calling,OFF
(24)-Vehicle_configuration-Dtmf_without_active_call,OFF
(25)-Vehicle_configuration-Support_for_response_and_hold,OFF
(26)-Vehicle_configuration-Sim_card_mode_switch,Not Present
(27)-Vehicle_configuration-Phone_module_operation_mode,Data & language service active
(28)-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5
(29)-Vehicle_configuration-RVC_video_input,FBAS
(30)-Vehicle_configuration-Station_Logo_DB_Mode,1
(31)-Vehicle_configuration-TPEG_availability,OFF
(32)-Vehicle_configuration-VZO,OFF
(33)-Vehicle_configuration-LGI,OFF
(34)-Vehicle_configuration-ProbeCar_vzo,OFF
(35)-Vehicle_configuration-online_media,OFF
(36)-Vehicle_configuration-ProbeCar_lgi,OFF
(37)-Vehicle_configuration-NMH_stopwatch,OFF
(38)-Vehicle_configuration-Google_GAL,OFF
(39)-Vehicle_configuration-Apple_DIO,OFF
(40)-Vehicle_configuration-UOTA,OFF
(41)-Vehicle_configuration-WiFi_Client_HMI,OFF
(42)-Vehicle_configuration-RSE_software_component,activated
(43)-Vehicle_configuration-SDS_Region_Flag,no_region
   #55
andyvee
Rossendale, Lancashire, UK
C?ID=159389
Well I wonder if this is a coincidence, but after I posted the info from the VCP forum on here on the fix, my VCP subscription has magically expired and I need to purchase a 1 year subscription. I have had the VCP interface for 22 months and suddenly I need an annual subscription ..............
   #56
SBC Auto
C?ID=238403
Hmmmm........ Bummer!. Don't like the way they won't even let you look round their forum unless registered. Won't get my money if they don't play nice. Have you contacted Mati for an explanation?
Separate note, 15.7.3 seems to work for me, now it is just finding the things to try and unpick.
I do get messages that I have not had before "out of range" sometimes when I try to do a second/third adaption change. Come out of the controller, go back in again and the adaption takes fine. Only tried a bit of reparation on 5f so far so not sure if it does the same on other controllers.
Well done all for getting to the bottom of it
+1 for a part/ex for a HEX-NET
   #57
andyvee
C?ID=159389
Not contacted Mati directly yet, started a couple of threads on there to see if anyone else needs to buy a subscription since the release of VCP 5.0.1
Glad you are all getting the menus back :)
Anyway, I won't need a trade in program as Uwe will send me one for free :) hint hint
   #58
mtl
Slovenia
C?ID=153305
Cheers
I have checked and it is complete. Those two channels were not read.
An off topic question regarding HEX-NET: getting ad. channel map on MQB from module 9 can take almost half an hour with HEX-USB+CAN. Would it be with HEX-NET faster and if yes, how much faster.
   #60
SBC Auto
C?ID=238403
I have been able to put the Mirrors, Green Menu, and Conv Consumers back using 15.7.3Beta
I am now trying to unpick what else the previous version may have done. Looking through the 5f I still see many adaptions "over_threshold_high" activated on Items not fitted without the basic function set to "activated"
(121)-Car_Function_Adaptations_Gen2-menu_display_hybrid not activated
(122)-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off not activated
(123)-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high activated
(124)-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill not activated
(125)-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer not activated
(126)-Car_Function_Adaptations_Gen2-menu_display_ugdo not activated
(127)-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off not activated
(128)-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high activated
(129)-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill not activated
(130)-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer not activated
(131)-Car_Function_Adaptations_Gen2-menu_display_night_vision not activated
(132)-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off not activated
(133)-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high activated
(134)-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill not activated
(135)-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer not activated
(136)-Car_Function_Adaptations_Gen2-menu_display_side_view not activated
(137)-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off not activated
(138)-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high activated
The car has none of these functions (AFAIK!). Questions
Is this normal?, a change made by the early software?, or the latest not reading these adaptions?
Is this an issue left like it is? or is it best to set them back to "not activated" to match the basic function?
EDIT: Looking harder at the other maps I see others are the same! just seems strange to me
Reactions: mtl
