Support for 5F MIB2 Columbus & Amundsen on MY16 Octavia III
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Looks to me like your chances to reproduce this on the current A6/A7 facelift models are good...
Adresse 5F: Informationselek. I (J794)
   Teilenummer SW: 4G1 035 044 A    HW: 4G1 035 044
   Bauteil: MU-H-LN-EU    H33 0073
   Seriennummer: A277I0E7506XXX
   Codierung: 017503010000000013110002000A00102F000CE5F1700100DF
   Betriebsnr.: WSC 02391 785 00200
   ASAM Datensatz: EV_MUHig4CGen2HBAS 001001
...likewise for Q7 (4M) and A4 (8W).
Andy
Sector 7G
HC424490
Neat, looks like we got this from a US customer with a 2016 S6:
   Part No SW: 4G1 035 025     HW: 4G1 035 025
   Component: MU-H-LNS-US   040 0143
   Serial number: A278F0FB016229
   Coding: 017551020000000013220002041A00102F0007E5F1700104FE
   Shop #: WSC 02391 785 00200
   VCID: 5BB54C6A529DA8E668-800E
   #23
garyp
C?ID=227280
I have a MY16 Golf GTE with MIB2 CMS, happy to send you's any info from it where needed?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Did you guys look at the 2016 US GLI? Should be a MIB2 Standard...
   Part No SW: 5C0 035 200     HW: 5C0 035 200
   Component: MU-S-S-US     H22 0245
   Coding: 02630100AA00000011220001001808001F0100D40020010002
   Shop #: WSC 00066 790 00148
andyvee
Rossendale, Lancashire, UK
C?ID=159389
Uwe, Andy, Dana, Sebastian
It looks like Mati (VCP) has fixed this - I am pretty sure you don't have VCP forum accounts so the below link won't work for you, so I have pasted a copy of the fix if it means anything to you and helps you out :)
https://vcp-forum.de/viewtopic.php?f=6&t=1258&p=8326#p8310
Hi guys, been a while, but there has been progress...
I did a teamviewer session with Mati tonight, seems like the VCDS adaptations I've made were triggering different bits from the code...
Mati was able to restore the default coding values in channels 2876 and 2877 in 5F
my value 2876 = 040505050505050505040505050505050404040505040405000000000000000000000000000000000000000000000000000000000000000000000000
should be 040505050505050505040505050505050404040505040405040404040404040404050404050505050404040404040404040400000000000000000000
my value 2877 = 00010000000C100D010119090101010101010101180800080000000000000000000000000000000000000000000000000000000000000000000000000C000000
should be 00010000000C100D010119090101010101010101180800083C0D0D1900043C04000C08090000110900000000003C0000000000003C08180000080C000C000000
I've got my assistance settings back and working (but no Greendrive yet, it's possible it needs some time/driving around and will appear tomorrow)
   #26
Thanks Andy :) The quoted info should be helpful when we resume normal hours on Monday.
   #27
Dana: Good morning . I don't want to sound pushy, but any chance of an update on this issue. I've been getting lots of requests to modify MIBII units, but I have been reticent to proceed until more is known about these problems. I suspect that a fix soon is too ambitious, but has RT been able to ascertain the scope of the problem (does it only impact adaptation channel tweaks and not coding changes - for example)
Any comment would be welcomed.
   #28
Eric
HC800000
Don, I'm still in the process of trying to reproduce this somehow. I've moved from Andy's EV_MUStd4CPASE to Helen's EV_MUHig6C3HBAS. This one has a 60 byte adaptation channel much like in AndyVee's very helpful post, however the latter part is already zeroed out even though everyone swears they didn't touch her 5F. Next step is to write some non-zero stuff in that later part with ODIS and see if VCDS nulls it out somehow (which doesn't happen on Andy's 40-some byte channels, so my early theory of a 24-byte limit in VCDS was wrong).
If you have very good access to one of the affected units and you're willing to risk breaking it, I can come up with a test plan that will be more detailed than maps, and assuming nothing VCDS does while reading creates the issue, we should be able to rewrite it to factory specs after you reproduce the issue. Otherwise I would steer clear of those units until we have a fix.
We don't like to post "updates" on an issue that's being worked on, much less time estimates, until we have an actual fix; but since you've asked, that's where we are now. This is pretty high up on the priority list, and would obviously go much faster if we had local access to a unit that's actually affected and someone's willing to let us break. That $60k+ 2016 A6 at the dealer doesn't fully qualify ;)
   #29
Eric: Many thanks for the reply and for breaching normal RT protocol to provide this update. I (as I am sure will others) await further developments with eager anticipation. Alas no luck convincing anyone down here to allow their MIBII to be a test unit for the fix investigation - understandable, I guess.
PS: I will make further attempts on VWW forum to find you a test unit.
silvera4quattro
Conshohocken, PA USA
C?ID=58593
I've got a 2016 NAR GTI Autobahn with Navi and MIB II. I tried enabling the performance gauges using adaptation and lost the Think Blue Trainer and Convenience consumer menus under CAR. I got Think Blue back finally after messing around, but the other is still missing.
No label files for my infotainment system or 09 central elec. exist right now. Is there any way I can help out the Ross Tech team? I'm local as well, in case you needed to check out anything on my car.
   #31
kreativ
Hidden
C?ID=108852
any support for Polo 6C MIB2 with Discover Media?
   Part No SW: 3Q0 035 864     HW: 3Q0 035 864
   Component: MU-S-N-ER     H04 0105
   Serial number: VWZAZ2P4526728
   Coding: 02620001BE00000011110001000808001F0100D401200100C6
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_SK35.rod
   VCID: 6ED8D663B1564D4825-803B
   Media Player Position 1:
   Subsystem 1 - Part No SW: 6C0 919 603 A    HW: 6C0 919 603 A
   Component: ABTm_Std2_Nav  H41 1015
   Serial number: VWZ8Z9PH2004JW
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 3G0 919 866 E    HW: -----------
   Component: ECE 2015  --- 0335
   #32
I suggest you don't play with it just yet.
Eric
HC800000
Here are "Beta" executables that should become/be part of Release 15.7.3 shortly:
http://download.ross-tech.com/VCDS/download/F730/VCDS-B15-7-3-x64.zip
http://download.ross-tech.com/VCDS/download/F730/VCDS-B15-7-3-x86.zip
If you don't know whether you have x86 or x64, or how to decompress a zip, it's probably best you wait for the full 15.7.3 release package :)
We were indeed able to reproduce the issue on Helen's car. Only the HEX+CAN is affected, micro-CAN and HEX-NET work fine (which didn't help when trying to reproduce the issue, since we prefer to use the faster HEX-NET internally these days :) ). The HEX-USB+CAN owing to its older design experiences CAN buffer overflows while reading long adaptation channels from controllers that spit out the information really fast (for instance Car_Function_Adaptations_Gen2). This resulted in false readings for those adaptation channels, which were then rewritten to the controller when the user makes a change.
The fix is two-fold. First, we're now making sure that if a buffer overflow is detected, the message is deemed non-valid. Should this happen, you would see something like this instead of values that appear correct but do not reflect what's actually in the car. Second, there's a software workaround to ensure the HUC has time to receive those messages on the MIB units.
Now, what we'd like to see from you: if you have a unit that's already affected, try and re-enable the portions you lost when tweaking those adaptation channels, and confirm that you can get them working again. If you have a MIB2 that's not been affected, you may want to make a map of it with 15.7.3 so that others with a similar unit who lost functions while tweaking can refer to it to re-enable the disabled functions. Wait until affected users have confirmed the fix is working before you modify your own unit :)
   #35
silvera4quattro
C?ID=58593
Eric: Just to confirm I want to replace the Beta exe file with the one currently in C:\Ross-Tech\VCDS? I'm actually renaming the .exe to .old so I can revert back, but same idea.
Just wanted to make sure that was clear. I'll give this a try tonight if I can and post back the results.
   #36
Eric
HC800000
The opposite, but I think you have the right idea. What you want to do is rename vcds.exe currently in your folder to vcds.old, and then drop the vcds.exe from the beta .zip in the same folder.
silvera4quattro
C?ID=58593
Ten four, that's actually what I meant and I wrote it bass ackwards. Will report back soon!
   #38
silvera4quattro
C?ID=58593
Well, no errors and when I made a change in an adaptation channel, it was read correctly right away with the Beta exe.
I still can't find which function/channel controls the Convenience Consumers menu and I don't wanna mess with things any more. The Think Blue menu was under Driver_eco_rating. I was ready to start a controller channel map, but I need to recharge my battery and I hope to try tomorrow.
   #39
mtl
Slovenia
C?ID=153305
I will try to do channel map from a ''virgin'' untouched car today and upload it here. This should help and serve as benchmark.
On my car these functions were lost (in brackets if I have managed to get them back):
·ASR/ESP system deactivation
·options under Mirrors and wipers menu (Synchronous adjustment, Lower while reversing, Fold in when parked) (solved by activating(166)-Car_Function_Adaptations_Gen2-menu_display_car_mirror and
(168)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high)
·Drive Green menu under View menu (I've managed to get it back also by activating: (186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating)
·speed limit display on Navigation
Does anyone have suggestion which setting is for ASR/ESP deactivation and speed limit display on Navigation?
   #40
mtl
Slovenia
C?ID=153305
Here is a channel map of ''virgin'' 5F done with 15.7.3 version (Seat Leon MY2016).
	SW:5QA-035-846   HW:5QA-035-846 ---  Information Electr.
	Component:MU-S-N-ER     H24 0241, Coding:04730001FF0A000011110001000808002F0201840120010046
	EV_MUStd6C3TSAT,001015,EV_MUStd6C3TSAT_SE37.rod
	Friday,04,December,2015,10:09:44:46154
	VCDS Version: Beta 15.7.3 (x64)  Data version: 20151124
(1)-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
(2)-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
(1)-Audio Management Input Gain Generation 2-TV Tuner,-128
(2)-Audio Management Input Gain Generation 2-Radio (FM),-128
(3)-Audio Management Input Gain Generation 2-Radio (AM),-128
(4)-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
(5)-Audio Management Input Gain Generation 2-Satellite radio,-128
(6)-Audio Management Input Gain Generation 2-Tuner_TI,-128
(7)-Audio Management Input Gain Generation 2-Media_AUXIN,-128
(8)-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
(9)-Audio Management Input Gain Generation 2-Media_CDA,-128
(10)-Audio Management Input Gain Generation 2-Media_DVD,-128
(11)-Audio Management Input Gain Generation 2-Media_MFP,-128
(12)-Audio Management Input Gain Generation 2-Media_BTDevice,-128
(13)-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
(14)-Audio Management Input Gain Generation 2-Media_Bluray,-128
(15)-Audio Management Input Gain Generation 2-Media_HDMI,-128
(16)-Audio Management Input Gain Generation 2-Tuner_Online,-128
(17)-Audio Management Input Gain Generation 2-Media_Airplay,-128
(18)-Audio Management Input Gain Generation 2-Media_UPNP,-128
(19)-Audio Management Input Gain Generation 2-Media_Cloud,-128
(20)-Audio Management Input Gain Generation 2-Tuner_Personal,-128
(21)-Audio Management Input Gain Generation 2-Tone_Beep,-128
(22)-Audio Management Input Gain Generation 2-Tone_Warning,-128
(23)-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
(24)-Audio Management Input Gain Generation 2-Tone_Messaging,-128
(25)-Audio Management Input Gain Generation 2-Exbox_DMB,-128
(26)-Audio Management Input Gain Generation 2-Mirrorlink,-128
(27)-Audio Management Input Gain Generation 2-TTS_Nav,-128
(28)-Audio Management Input Gain Generation 2-TTS_SDS,-128
(29)-Audio Management Input Gain Generation 2-Phone_Voice,-128
(30)-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
(31)-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
(32)-Audio Management Input Gain Generation 2-HFP,-128
(33)-Audio Management Input Gain Generation 2-TV_AV_IN,-128
Base volume of speech output,50 %
Base volume of telephone,50 %
Bluetooth,On
Bluetooth: Sniff mode,On
CD eject button,Enabled
(1)-Check tone frequency-High note frequency range,4000 Hz
(2)-Check tone frequency-Medium note frequency range,1000 Hz
(3)-Check tone frequency-Low note frequency range,100 Hz
Confirmation of installation change,3C 91
Country identification	 country of sale HMI,--
Deactivate production mode,0
Developer mode,not activated
(1)-Electrical test of loudspeakers-Mode,automatic
(2)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
(3)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36
(4)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
(5)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36
(6)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
(7)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36
(8)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
(9)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36
(10)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
(11)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36
(12)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
(13)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36
(14)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
(15)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36
(16)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
(17)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36
(18)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
(19)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36
(20)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
(21)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36
(22)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
(23)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36
(24)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
(25)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36
(26)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
(27)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36
(28)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
(29)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36
(30)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
(31)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36
(32)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
(33)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36
Fee-based traffic information (TMC),0
Infotainment Recorder,activated
(1)-Interface for external media	 activation-Connection 1,activated
(2)-Interface for external media	 activation-Connection 2,not activated
(3)-Interface for external media	 activation-Connection 3,not activated
(4)-Interface for external media	 activation-Connection 4,not activated
(1)-Locked menu contents-FB_TUNER_0,non_blocked
(2)-Locked menu contents-FB_TUNER_1,non_blocked
(3)-Locked menu contents-FB_TUNER_2,non_blocked
(4)-Locked menu contents-FB_TUNER_3,non_blocked
(5)-Locked menu contents-FB_TUNER_4,non_blocked
(6)-Locked menu contents-FB_TUNER_5,non_blocked
(7)-Locked menu contents-FB_TUNER_6,non_blocked
(8)-Locked menu contents-FB_TUNER_7,non_blocked
(9)-Locked menu contents-FB_TUNER_8,non_blocked
(10)-Locked menu contents-FB_TUNER_9,non_blocked
(11)-Locked menu contents-FB_TUNER_10,non_blocked
(12)-Locked menu contents-FB_TUNER_11,non_blocked
(13)-Locked menu contents-FB_TUNER_12,non_blocked
(14)-Locked menu contents-FB_TUNER_13,non_blocked
(15)-Locked menu contents-FB_TUNER_14,non_blocked
(16)-Locked menu contents-FB_TUNER_15,non_blocked
(17)-Locked menu contents-FB_MEDIA_0,non_blocked
(18)-Locked menu contents-FB_MEDIA_1,non_blocked
(19)-Locked menu contents-FB_MEDIA_2,non_blocked
(20)-Locked menu contents-FB_MEDIA_3,non_blocked
(21)-Locked menu contents-FB_MEDIA_4,non_blocked
(22)-Locked menu contents-FB_MEDIA_5,non_blocked
(23)-Locked menu contents-FB_MEDIA_6,non_blocked
(24)-Locked menu contents-FB_MEDIA_7,non_blocked
(25)-Locked menu contents-FB_MEDIA_8,non_blocked
(26)-Locked menu contents-FB_MEDIA_9,non_blocked
(27)-Locked menu contents-FB_MEDIA_10,non_blocked
(28)-Locked menu contents-FB_MEDIA_11,non_blocked
(29)-Locked menu contents-FB_MEDIA_12,non_blocked
(30)-Locked menu contents-FB_MEDIA_13,non_blocked
(31)-Locked menu contents-FB_MEDIA_14,non_blocked
(32)-Locked menu contents-FB_MEDIA_15,non_blocked
(33)-Locked menu contents-FB_MEDIA_16,non_blocked
(34)-Locked menu contents-FB_MEDIA_17,non_blocked
(35)-Locked menu contents-FB_MEDIA_18,non_blocked
(36)-Locked menu contents-FB_MEDIA_19,non_blocked
(37)-Locked menu contents-FB_MEDIA_20,non_blocked
(38)-Locked menu contents-FB_MEDIA_21,non_blocked
(39)-Locked menu contents-FB_MEDIA_22,non_blocked
(40)-Locked menu contents-FB_MEDIA_23,non_blocked
(41)-Locked menu contents-FB_PHONE_0,non_blocked
(42)-Locked menu contents-FB_PHONE_1,non_blocked
(43)-Locked menu contents-FB_PHONE_2,non_blocked
(44)-Locked menu contents-FB_PHONE_3,non_blocked
(45)-Locked menu contents-FB_PHONE_4,non_blocked
(46)-Locked menu contents-FB_PHONE_5,non_blocked
(47)-Locked menu contents-FB_PHONE_6,non_blocked
(48)-Locked menu contents-FB_PHONE_7,non_blocked
(49)-Locked menu contents-FB_PHONE_8,non_blocked
(50)-Locked menu contents-FB_PHONE_9,non_blocked
(51)-Locked menu contents-FB_PHONE_10,non_blocked
(52)-Locked menu contents-FB_PHONE_11,non_blocked
(53)-Locked menu contents-FB_PHONE_12,non_blocked
(54)-Locked menu contents-FB_PHONE_13,non_blocked
(55)-Locked menu contents-FB_PHONE_14,non_blocked
(56)-Locked menu contents-FB_PHONE_15,non_blocked
(57)-Locked menu contents-FB_NAV_0,non_blocked
(58)-Locked menu contents-FB_NAV_1,non_blocked
(59)-Locked menu contents-FB_NAV_2,non_blocked
(60)-Locked menu contents-FB_NAV_3,non_blocked
(61)-Locked menu contents-FB_NAV_4,non_blocked
(62)-Locked menu contents-FB_NAV_5,non_blocked
(63)-Locked menu contents-FB_NAV_6,non_blocked
(64)-Locked menu contents-FB_NAV_7,non_blocked
(65)-Locked menu contents-FB_NAV_8,non_blocked
(66)-Locked menu contents-FB_NAV_9,non_blocked
(67)-Locked menu contents-FB_NAV_10,non_blocked
(68)-Locked menu contents-FB_NAV_11,non_blocked
(69)-Locked menu contents-FB_NAV_12,non_blocked
(70)-Locked menu contents-FB_NAV_13,non_blocked
(71)-Locked menu contents-FB_NAV_14,non_blocked
(72)-Locked menu contents-FB_NAV_15,non_blocked
(73)-Locked menu contents-FB_NAV_16,non_blocked
(74)-Locked menu contents-FB_NAV_17,non_blocked
(75)-Locked menu contents-FB_NAV_18,non_blocked
(76)-Locked menu contents-FB_NAV_19,non_blocked
(77)-Locked menu contents-FB_NAV_20,non_blocked
(78)-Locked menu contents-FB_NAV_21,non_blocked
(79)-Locked menu contents-FB_NAV_22,non_blocked
(80)-Locked menu contents-FB_NAV_23,non_blocked
(81)-Locked menu contents-FB_NAV_24,non_blocked
(82)-Locked menu contents-FB_NAV_25,non_blocked
(83)-Locked menu contents-FB_NAV_26,non_blocked
(84)-Locked menu contents-FB_NAV_27,non_blocked
(85)-Locked menu contents-FB_NAV_28,non_blocked
(86)-Locked menu contents-FB_NAV_29,non_blocked
(87)-Locked menu contents-FB_NAV_30,non_blocked
(88)-Locked menu contents-FB_NAV_31,non_blocked
(89)-Locked menu contents-FB_NAV_32,non_blocked
(90)-Locked menu contents-FB_NAV_33,non_blocked
(91)-Locked menu contents-FB_NAV_34,non_blocked
(92)-Locked menu contents-FB_NAV_35,non_blocked
(93)-Locked menu contents-FB_NAV_36,non_blocked
(94)-Locked menu contents-FB_NAV_37,non_blocked
(95)-Locked menu contents-FB_NAV_38,non_blocked
(96)-Locked menu contents-FB_NAV_39,non_blocked
(97)-Locked menu contents-FB_CAR_0,non_blocked
(98)-Locked menu contents-FB_CAR_1,non_blocked
(99)-Locked menu contents-FB_CAR_2,non_blocked
(100)-Locked menu contents-FB_CAR_3,non_blocked
(101)-Locked menu contents-FB_CAR_4,non_blocked
(102)-Locked menu contents-FB_CAR_5,non_blocked
(103)-Locked menu contents-FB_CAR_6,non_blocked
(104)-Locked menu contents-FB_CAR_7,non_blocked
(105)-Locked menu contents-FB_CAR_8,non_blocked
(106)-Locked menu contents-FB_CAR_9,non_blocked
(107)-Locked menu contents-FB_CAR_10,non_blocked
(108)-Locked menu contents-FB_CAR_11,non_blocked
(109)-Locked menu contents-FB_CAR_12,non_blocked
(110)-Locked menu contents-FB_CAR_13,non_blocked
(111)-Locked menu contents-FB_CAR_14,non_blocked
(112)-Locked menu contents-FB_CAR_15,non_blocked
(113)-Locked menu contents-FB_CAR_16,non_blocked
(114)-Locked menu contents-FB_CAR_17,non_blocked
(115)-Locked menu contents-FB_CAR_18,non_blocked
(116)-Locked menu contents-FB_CAR_19,non_blocked
(117)-Locked menu contents-FB_CAR_20,non_blocked
(118)-Locked menu contents-FB_CAR_21,non_blocked
(119)-Locked menu contents-FB_CAR_22,non_blocked
(120)-Locked menu contents-FB_CAR_23,non_blocked
(121)-Locked menu contents-FB_MISC_0,non_blocked
(122)-Locked menu contents-FB_MISC_1,non_blocked
(123)-Locked menu contents-FB_MISC_2,non_blocked
(124)-Locked menu contents-FB_MISC_3,non_blocked
(125)-Locked menu contents-FB_MISC_4,non_blocked
(126)-Locked menu contents-FB_MISC_5,non_blocked
(127)-Locked menu contents-FB_MISC_6,non_blocked
(128)-Locked menu contents-FB_MISC_7,non_blocked
(129)-Locked menu contents-FB_MISC_8,non_blocked
(130)-Locked menu contents-FB_MISC_9,non_blocked
(131)-Locked menu contents-FB_MISC_10,non_blocked
(132)-Locked menu contents-FB_MISC_11,non_blocked
(133)-Locked menu contents-FB_MISC_12,non_blocked
(134)-Locked menu contents-FB_MISC_13,non_blocked
(135)-Locked menu contents-FB_MISC_14,non_blocked
(136)-Locked menu contents-FB_MISC_15,non_blocked
(137)-Locked menu contents-FB_MISC_16,non_blocked
(138)-Locked menu contents-FB_MISC_17,non_blocked
(139)-Locked menu contents-FB_MISC_18,non_blocked
(140)-Locked menu contents-FB_MISC_19,non_blocked
(141)-Locked menu contents-FB_MISC_20,non_blocked
(142)-Locked menu contents-FB_MISC_21,non_blocked
(143)-Locked menu contents-FB_MISC_22,non_blocked
(144)-Locked menu contents-FB_MISC_23,non_blocked
(145)-Locked menu contents-FB_MISC_24,non_blocked
(146)-Locked menu contents-FB_MISC_25,non_blocked
(147)-Locked menu contents-FB_MISC_26,non_blocked
(148)-Locked menu contents-FB_MISC_27,non_blocked
(149)-Locked menu contents-FB_MISC_28,non_blocked
(150)-Locked menu contents-FB_MISC_29,non_blocked
(151)-Locked menu contents-FB_MISC_30,non_blocked
(152)-Locked menu contents-FB_MISC_31,non_blocked
(153)-Locked menu contents-FB_MISC_32,non_blocked
(154)-Locked menu contents-FB_MISC_33,non_blocked
(155)-Locked menu contents-FB_MISC_34,non_blocked
(156)-Locked menu contents-FB_MISC_35,non_blocked
(157)-Locked menu contents-FB_MISC_36,non_blocked
(158)-Locked menu contents-FB_MISC_37,non_blocked
(159)-Locked menu contents-FB_MISC_38,non_blocked
(160)-Locked menu contents-FB_MISC_39,non_blocked
(161)-Locked menu contents-FB_MISC_40,non_blocked
(162)-Locked menu contents-FB_MISC_41,non_blocked
(163)-Locked menu contents-FB_MISC_42,non_blocked
(164)-Locked menu contents-FB_MISC_43,non_blocked
(165)-Locked menu contents-FB_MISC_44,non_blocked
(166)-Locked menu contents-FB_MISC_45,non_blocked
(167)-Locked menu contents-FB_MISC_46,non_blocked
(168)-Locked menu contents-FB_MISC_47,non_blocked
Menu entries for mobile online services,not activated
Microphone sensitivity,0 dB
(1)-Navigation receiver GNSS configuration-Default,On
(2)-Navigation receiver GNSS configuration-GPS,OFF
(3)-Navigation receiver GNSS configuration-Galileo,OFF
(4)-Navigation receiver GNSS configuration-Glonass,OFF
(5)-Navigation receiver GNSS configuration-Compass,OFF
Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Production mode,00 00 00
Selection of release codes for a SWaP function,FF FF FF FF
Summertime-automatic,Europe
Wheel circ.,0 mm
Wheel pulse,0
WLAN,On
BAP_Debug_Mode_Release,not_released
Bluetooth_Phonebook_Access_Profile,PBAP
(1)-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated
(2)-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
(3)-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated
(4)-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
(5)-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
(6)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
(7)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
(8)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated
(9)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
(10)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated
(11)-Car_Function_Adaptations_Gen2-menu_display_pdc,not activated
(12)-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
(13)-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated
(14)-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
(15)-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
(16)-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
(17)-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
(18)-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated
(19)-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
(20)-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
(21)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated
(22)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated
(23)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated
(24)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
(25)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated
(26)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated
(27)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
(28)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated
(29)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
(30)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
(31)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
(32)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated
(33)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated
(34)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
(35)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated
(36)-Car_Function_Adaptations_Gen2-menu_display_windows,activated
(37)-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
(38)-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated
(39)-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
(40)-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
(41)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated
(42)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
(43)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated
(44)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
(45)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated
(46)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
(47)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
(48)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated
(49)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
(50)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated
(51)-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
(52)-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
(53)-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated
(54)-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
(55)-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
(56)-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
(57)-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
(58)-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated
(59)-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated
(60)-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
(61)-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
(62)-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
(63)-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
(64)-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
(65)-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
(66)-Car_Function_Adaptations_Gen2-menu_display_sia,activated
(67)-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
(68)-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
(69)-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
(70)-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
(71)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated
(72)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
(73)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated
(74)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
(75)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated
(76)-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
(77)-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
(78)-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated
(79)-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
(80)-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
(81)-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
(82)-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
(83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated
(84)-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
(85)-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
(86)-Car_Function_Adaptations_Gen2-menu_display_charisma,activated
(87)-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
(88)-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated
(89)-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
(90)-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
(91)-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated
(92)-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
(93)-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated
(94)-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
(95)-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
(96)-Car_Function_Adaptations_Gen2-menu_display_vin,activated
(97)-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
(98)-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
(99)-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
(100)-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
(101)-Car_Function_Adaptations_Gen2-menu_display_clock,activated
(102)-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
(103)-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
(104)-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
(105)-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
(106)-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
(107)-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
(108)-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated
(109)-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
(110)-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
(111)-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
(112)-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
(113)-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated
(114)-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
(115)-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
(116)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
(117)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
(118)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated
(119)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
(120)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated
(121)-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
(122)-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
(123)-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated
(124)-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
(125)-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
(126)-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated
(127)-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
(128)-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated
(129)-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
(130)-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
(131)-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
(132)-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
(133)-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated
(134)-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
(135)-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
(136)-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
(137)-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
(138)-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated
(139)-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
(140)-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
(141)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated
(142)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated
(143)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated
(144)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated
(145)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated
(146)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
(147)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
(148)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated
(149)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
(150)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
(151)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated
(152)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated
(153)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated
(154)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated
(155)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated
(156)-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
(157)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated
(158)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated
(159)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated
(160)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated
(161)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated
(162)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
(163)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated
(164)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
(165)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
(166)-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated
(167)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
(168)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated
(169)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
(170)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
(171)-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
(172)-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
(173)-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated
(174)-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
(175)-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
(176)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated
(177)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated
(178)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated
(179)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
(180)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated
(181)-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated
(182)-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
(183)-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated
(184)-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
(185)-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
(186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated
(187)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
(188)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated
(189)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
(190)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
(191)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated
(192)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
(193)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated
(194)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
(195)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
(196)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated
(197)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
(198)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated
(199)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
(200)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated
(201)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
(202)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
(203)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated
(204)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
(205)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
(206)-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
(207)-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
(208)-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated
(209)-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
(210)-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated
(211)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
(212)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated
(213)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated
(214)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
(215)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated
(216)-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
(217)-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
(218)-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated
(219)-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
(220)-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated
(221)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
(222)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
(223)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated
(224)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
(225)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated
(226)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
(227)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
(228)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated
(229)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
(230)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
(231)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
(232)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
(233)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated
(234)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
(235)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
(236)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
(237)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
(238)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated
(239)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
(240)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated
(241)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
(242)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
(243)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated
(244)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
(245)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
(246)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
(247)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
(248)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated
(249)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
(250)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
(251)-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated
(252)-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
(253)-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated
(254)-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
(255)-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
(256)-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated
(257)-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
(258)-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated
(259)-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
(260)-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
(261)-Car_Function_Adaptations_Gen2-menu_display_SportHMI,activated
(262)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated
(263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,activated
(264)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated
(265)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated
(266)-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
(267)-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
(268)-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
(269)-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
(270)-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
(271)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue,not activated
(272)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_clamp_15_off,not activated
(273)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_over_threshold_high,not activated
(274)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_standstill,not activated
(275)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_after_disclaimer,not activated
(276)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated
(277)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
(278)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated
(279)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
(280)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated
(1)-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated
(2)-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus
(3)-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
(4)-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus
(5)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
(6)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus
(7)-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
(8)-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus
(9)-Car_Function_List_BAP_Gen2-ACC_0x05,not activated
(10)-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Comfort data bus
(11)-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
(12)-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Comfort data bus
(13)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
(14)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus
(15)-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
(16)-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus
(17)-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
(18)-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus
(19)-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
(20)-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
(21)-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated
(22)-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Comfort data bus
(23)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
(24)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus
(25)-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
(26)-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus
(27)-Car_Function_List_BAP_Gen2-mirror_0x0E,activated
(28)-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus
(29)-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
(30)-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus
(31)-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated
(32)-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus
(33)-Car_Function_List_BAP_Gen2-clock_0x11,activated
(34)-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus
(35)-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
(36)-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus
(37)-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
(38)-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus
(39)-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated
(40)-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Comfort data bus
(41)-Car_Function_List_BAP_Gen2-compass_0x15,not activated
(42)-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Comfort data bus
(43)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
(44)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus
(45)-Car_Function_List_BAP_Gen2-charisma_0x17,activated
(46)-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment
(47)-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
(48)-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,Comfort data bus
(49)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated
(50)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended
(51)-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated
(52)-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Comfort data bus
(53)-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
(54)-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Comfort data bus
(55)-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
(56)-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Comfort data bus
(57)-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
(58)-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,Comfort data bus
(59)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated
(60)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus
(61)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20,not activated
(62)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20_msg_bus,Comfort data bus
(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated
(64)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Comfort data bus
(65)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated
(66)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus
(67)-Car_Function_List_BAP_Gen2-BCmE_0x23,activated
(68)-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment
(69)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
(70)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus
(71)-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
(72)-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Comfort data bus
(73)-Car_Function_List_BAP_Gen2-Brake_0x26,activated
(74)-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus
(75)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated
(76)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment
(77)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
(78)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus
(79)-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
(80)-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus
(81)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
(82)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus
(83)-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated
(84)-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus
(85)-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
(86)-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus
(87)-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
(88)-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus
(89)-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
(90)-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus
(91)-Car_Function_List_BAP_Gen2-ENI_0x37,not activated
(92)-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus
(93)-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
(94)-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus
(95)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
(96)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Comfort data bus
(97)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
(98)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus
(99)-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated
(100)-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus
(1)-Car_Function_List_CAN_Gen2-MFL,Available
(2)-Car_Function_List_CAN_Gen2-MFL_msg_bus,Terminal 15
(3)-Car_Function_List_CAN_Gen2-Oil_level,Not available
(4)-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Comfort data bus
(5)-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available
(6)-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus
(7)-Car_Function_List_CAN_Gen2-VIN,Available
(8)-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus
(9)-Car_Function_List_CAN_Gen2-Driving_school,Not available
(10)-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Comfort data bus
(11)-Car_Function_List_CAN_Gen2-Adaptive_key,Not available
(12)-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus
(1)-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0
(2)-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0
(3)-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50
(4)-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50
(5)-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100
(6)-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100
(1)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0
(2)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0
(3)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50
(4)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50
(5)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100
(6)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100
(1)-Dimming_Illumination_for_Display_Unit-X1,0
(2)-Dimming_Illumination_for_Display_Unit-Y1,2 %
(3)-Dimming_Illumination_for_Display_Unit-X2,10
(4)-Dimming_Illumination_for_Display_Unit-Y2,2 %
(5)-Dimming_Illumination_for_Display_Unit-X3,100
(6)-Dimming_Illumination_for_Display_Unit-Y3,11 %
(7)-Dimming_Illumination_for_Display_Unit-X4,150
(8)-Dimming_Illumination_for_Display_Unit-Y4,25 %
(9)-Dimming_Illumination_for_Display_Unit-X5,220
(10)-Dimming_Illumination_for_Display_Unit-Y5,70 %
(11)-Dimming_Illumination_for_Display_Unit-X6,253
(12)-Dimming_Illumination_for_Display_Unit-Y6,100 %
Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 90 01 5E 01 2C 01 2C 01 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CA
p_damping_Display,5 ms
p_HMI_Display,13 %
(1)-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
(2)-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
Startup_Screen_Sticker_HMI,01 00
(1)-Vehicle_configuration-VZAPro,OFF
(2)-Vehicle_configuration-online_POI,OFF
(3)-Vehicle_configuration-online_POI_voice,OFF
(4)-Vehicle_configuration-online_portal_browser_services,OFF
(5)-Vehicle_configuration-online_navigation,OFF
(6)-Vehicle_configuration-online_street_view,OFF
(7)-Vehicle_configuration-WIFI_Hotspot,OFF
(8)-Vehicle_configuration-my_audi,OFF
(9)-Vehicle_configuration-picture_navi,On
(10)-Vehicle_configuration-online_dictation,OFF
(11)-Vehicle_configuration-remote_HMI,OFF
(12)-Vehicle_configuration-advanced_range_display,OFF
(13)-Vehicle_configuration-gracenote_online_coverarts,OFF
(14)-Vehicle_configuration-gracenote_online_other,OFF
(15)-Vehicle_configuration-gracenote_local_coverarts,OFF
(16)-Vehicle_configuration-gracenote_local_other,OFF
(17)-Vehicle_configuration-UPnP,OFF
(18)-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF
(19)-Vehicle_configuration-Joker_button_1,Not Present
(20)-Vehicle_configuration-Joker_button_2,Not Present
(21)-Vehicle_configuration-LTE_modul,activated
(22)-Vehicle_configuration-Support_second_phone,OFF
(23)-Vehicle_configuration-Support_of_threeway_calling,OFF
(24)-Vehicle_configuration-Dtmf_without_active_call,OFF
(25)-Vehicle_configuration-Support_for_response_and_hold,OFF
(26)-Vehicle_configuration-Sim_card_mode_switch,Not Present
(27)-Vehicle_configuration-Phone_module_operation_mode,Data & language service active
(28)-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5
(29)-Vehicle_configuration-RVC_video_input,FBAS
(30)-Vehicle_configuration-Station_Logo_DB_Mode,1
(31)-Vehicle_configuration-TPEG_availability,OFF
(32)-Vehicle_configuration-VZO,OFF
(33)-Vehicle_configuration-LGI,OFF
(34)-Vehicle_configuration-ProbeCar,OFF
(35)-Vehicle_configuration-online_media,OFF
(36)-Vehicle_configuration-ProbeCar_lgi,OFF
(37)-Vehicle_configuration-NMH_stopwatch,OFF
(38)-Vehicle_configuration-Google_GAL,OFF
(39)-Vehicle_configuration-Apple_DIO,OFF
