Caddy 2008, aux. heater fault code, unable to clear
LN-TAL
Norway
C?ID=13729
Hi,
would appreciate the security code to module 18 to clear the codes:
Saturday,17,October,2015,15:54:37:62006
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WV1ZZZ2KZ8XXXXXXX   License Plate:
Mileage: 93360km-58011mi   Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 46 52 69
VIN: WV1ZZZ2KZ8X022439   Mileage: 93360km-58011miles
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 PF    HW: 03G 906 021 AB
   Component: R4 1,9L EDC  000SG  1331
   Revision: --H07---    Serial number: VWX7Z0G63N319R
   Coding: 0000071
   Shop #: WSC 00660 218 182365
   VCID: 72E175E96D5D17AE5B-8026
   Revision: 00H11001
   Coding: 0021206
   Shop #: WSC 35110 377 00154
   VCID: 73EF70ED12471EA650-8026
   Part No SW: 1K0 820 047 HC    HW: 1K0 820 047 HC
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6CDD6B914F79C15E91-8038
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000007294280
   Coding: 0888CF030004100047000000000000000009FB075C000100000000000000
   Shop #: WSC 35110 377 08192
   VCID: 6FE77C9D7E6F3A46B4-803A
   Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 040707 021  0501
   Coding: 00038805
   Shop #: WSC 35110
                    Fault Status: 01101100
                    Reset counter: 92
                    Mileage: 93361 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.60 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 1E AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD0EWUJI
   Coding: 0012613
   VCID: 7DFB56D5240358D636-8028
   Part No SW: 1K0 953 549 BB    HW: 1K0 953 549 BB
   Component: Lenks‰ulenmodul 636 0070
   Coding: 0000002
   Part No SW: 2K0 920 844 A    HW: 2K0 920 844 A
   Revision: V0002000    Serial number: VWX7Z0G63N319R
   Coding: 0016101
   Shop #: WSC 80093 222 69422
   VCID: 29535285800B14762A-807C
   Part No: 1K0 815 071 T
   Component: Zuheizer        050 2504
   Revision: 00050000    Serial number: 09009839000000
   Coding: 0000011
   Shop #: WSC 80093 222 71269
   VCID: 366989F941B54B8EB7-8062
01407 - Flame Extinguished
            000 -  -  - Intermittent
                    Reset counter: 130
                    Mileage: 81269 km
                        Start
                    Temperature: 73.0∞C
                    Temperature: 72.0∞C
                    Voltage: 14.53 V
01406 - No Flame
            000 -  -
                    Reset counter: 98
                    Mileage: 81290 km
                        Start
                    Temperature: 29.0∞C
                    Temperature: 24.0∞C
                    Voltage: 14.60 V
00664 - Fuel gauge
                    Reset counter: 134
                    Mileage: 81362 km
02251 - Heater Unit Locked
            000 -  -
                    Reset counter: 98
                    Mileage: 81417 km
   Revision:   H07 01    Serial number: 050707F2001694
   Coding: A9801F460008027400
   VCID: 3065BFE1A3D165BEED-8064
                    Reset counter: 132
                    Mileage: 93361 km
                    Time: 00:10:59
   Component: IMMO            VDD 1212
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1205
   Coding: 0000048
   VCID: 387587C14BA1BDFEA5-806C
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Coding: 80890C087F2D8405484A036010C0
   VCID: 00052F2153F1353E5D-8054
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000048
   VCID: 397382C570ABA4F65A-806C
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 D    HW: 1K0 907 383 B
   Component: Anhaenger     H15 0070
   Revision: 3A002001    Serial number: 00000105367466
   Coding: 0100000200000000
   VCID: 2E59A19979E5734EFF-807A
                    Fault Status: 01100010
                    Reset counter: 92
                    Mileage: 93361 km
End-------------------------(Elapsed Time: 01:22)--------------------------
NEtech
Denmark
C?ID=56995
No Secure code!
Adaptation channel.
And assume you know it is locked for a reason.
rucklet
Sweden
C?ID=14863
My experience: the fault code about fuel level is not really a fault code, it's more an information to the driver that he or she needs to refuel because the heater won't start with too low fuel level. The fault code about flame is possibly because of this or too many short trips driving, it's not necessarily something wrong.
To release the heater put a 1 in adaption channel 43.
