'Evening all,
I'm trying to correct the estimated range 'til empty as it is quite far off on my '18 A6. It will estimate ~535 miles 'til empty upon topping up with fuel, but the actual range is in the 3xx's. I have tried adjusting a fuel consumption but it's bottom limit is 85%, and I saw no change in the DTE (distance 'til empty) upon refueling the following three tanks.
I will post the Auto-Scan and follow-up with a reply of the instruments controller map
Sunday,26,May,2024,22:27:03:19414
VCDS Version: 24.5.0.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: WAUH3BFC8JN098266 License Plate: PVL8289
Mileage: 40231km-24998mi Repair Order: After Cleared
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 3C 42 44 46 52 53 55
5F 62 6C 6D 72 82 8F 90 47
VIN: WAUH3BFC8JN098266 Mileage: 40231km-24998miles
Address 01: Engine (J623-CREH) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G2 907 551 C HW: 4H2 907 551 F
Component: 3.0l V6 TFSI H10 0001
Revision: --H10--- CVN: 8CA5C053
Coding: 0A2A00340526010D3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G2907551C 001002
ROD: EV_ECM30TFS021_AU57.rod
VCID: 2B086E9783818D32D21-807E
VINID: 9D19580D259321A7802480861809D03C49
Readiness: 1110 1101
Part No SW: 4G0 927 158 AM HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H22 1004
Revision: --H22--- CVN: 6296D1FF
VCID: 79A484DF395DEFA210D-802C
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 44A7964122E569821B00
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 41D42C3F110D776218D-8014
Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR
Component: BCM2 2.0 H61 0825
Coding: 0DA86F4E000000000000
VCID: 0052E93B5A07BE6A573-8054
Serial number: 3218000031456014
Part No SW: 4G0 820 043 CE HW: 4G0 820 043 CE
Serial number: 06021800041725
Coding: 6601317A590000
VCID: 649AC5ABAEDF024AD3B-8030
Part No SW: 4H0 907 063 GM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0368
Revision: 2102003S Serial number: 00001916061102
Coding: 01050091043C9FE081004884A0003800CF9CD208A60802258000080471101502006000240B0000
VCID: 79A484DF39DDEFA210D-802C
Component: WWS57X 180128 H38 0080
Serial number: 180208141226
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21230248X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AN HW: 4G0 941 531 AN
Component: E1 - LDS H07 0044
Serial number: 12 02 2018 00001028
Component: USHL4.2 H30 0030
Serial number: 00000000095Z03BDA8A5
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0304281572
Coding: 853000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA130814000044554145
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 8620D61900PAG0MUFU03
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H66 0098
Revision: -------- Serial number: 003G0004UX44 Dataset Number: 4G0909602N 0002
Coding: 303331343135303335304A55304C34473053
VCID: 343A75EB5EBFD2CA83B-8060
Serial number: 6940000Y180001PWFU0-
Serial number: 3575HRB401C5DK0CG8B5
Serial number: 3585HRB401E5DLTME0D/
Serial number: 3515JRB40635CFN4BP29
Serial number: 3525JRB405L5A8NUIO7C
Serial number: 3554VRB405D5DNA8F82K
Serial number: 3564VRB40595CFN848S-
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560RBG0005E
Coding: 000034
VCID: 3B285ED773611DB2421-806E
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 04 01 2018 C0003013
Part No SW: 4G8 920 987 T HW: 4G8 920 987 T
Component: TBenUsa H17 0225
Revision: 18001312 Serial number: 658150218592030
Coding: 0BEF09040B41D705020000
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 4AC60B132C3BB43AC97-801E
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 K HW: 4G8 907 468
Component: J533--Gateway H15 0110
Revision: -------- Serial number: 00000002907381 Dataset Number: 4G0909515M 0026
Coding: C0CD073010
GVL: FD81C84CDC23680D00040000
ASAM Dataset: EV_GatewPkoUDS 002011
VCID: 40D2293B1A077E6A173-8014
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 2002596804
Voltage stabilizer:
Serial number: 171207000000000007DE
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 27021800040653
Coding: 20
VCID: 3D2C50CF6DF513827C5-8068
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000293680862
Coding: C0581B008F006001000001010101102030303232203232
VCID: 382241DB425736AAAF3-806C
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA72121S80 Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 333876F75BB1D5F29A1-8066
Component: SWA Master H08 0070
Serial number: 0472922685 Dataset Number: 4G0909535C 0010
Coding: 040211
VCID: 392444DF79DD2FA250D-806C
Component: SWA Slave H08 0070
Serial number: 0472986366
Coding: 040211
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F17015E00628002000012
VCID: 47C032273FA94952D69-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H55 0202
Revision: 00000002 Serial number: 0000514170 Dataset Number: 4G0909852L 0038
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A265BD37CDB24BA597-806E
Revision: 00002001 Serial number: 0472953952
Coding: 0106063A00FA718580B0088402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000428855
Subsystem 2 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H04 0005
Serial number: 0000FST001Z0Q2S00000
Coding: 101F02
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00043210837
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 66020408
Component: TSG BF H03 0511
Coding: 011F17015E00628002000002
VCID: 46DE3F2338A3505A2DF-8012
Part No SW: 4H0 907 801 N HW: 4H0 907 801 M
Component: EPB-4 H01 0020
Revision: -------- Serial number: 00000002448145 Dataset Number: 4G0909522G 0001
ASAM Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
Component: MxB-ECU 001 0100
Revision: -------- Serial number: -------------- Dataset Number: 4G0909865D 0019
Coding: 04FA021122200400
Coding: E01E00
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 G HW: 4G1 035 025 C
Component: MU-H-LNS-US 054 0980
Serial number: A741B0JS020351 Dataset Number: 4G1909545K 0046
Coding: 017501020000000013220002041A00102F0006E5F17001047E
VCID: 221683B3F44B4C7A617-8076
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Multimedia System 1:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY809WRB
Serial number: 90349RBQ0006W
Compact disc data bank:
Component: Gracenote2--- --- 3012
Component: TSG HL H03 0511
Coding: 010F17004000628002000002
VCID: 49C4341F29BDBF22C0D-801C
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0380
Revision: 11001001 Serial number: 82330JG0476079
Coding: 0211000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
VCID: 2F307A87B799F112FE9-807A
9617993 - Proximity Camera
B145C 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 142
Mileage: 40231 km
Date: 2024.05.26
Time: 22:23:15
Voltage terminal 30: 11.7 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4G5 959 107 C HW: 4G5 959 107 A
Component: HDSG-Modul H02 0049
Revision: 13002003 Serial number: 038802199 Dataset Number: 4G1909541C 0003
Coding: 111104C120
ASAM Dataset: EV_HDSGAu571 001022
ROD: EV_HDSGAu571_AU57.rod
VCID: 323673F3A4ABDCFA917-8066
Component: TSG HR H03 0511
Address 82: Head Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 M HW: 4G0 919 604 M
Component: HeadUpDisplay H10 0306
Coding: A20000
ASAM Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7_AU57.rod
VCID: 353C48EF55C5CBC2B45-8060
Component: RGS-VL H16 0080
Dataset Number: 4G0909614C 0001
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 31347CFFA1ADE7E2E8D-8064
Component: RGS-VR H16 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G5 035 223 E HW: 4G5 035 223
Component: MIB2_amp_P H03 0440
Serial number: 00000000144621 Dataset Number: 4G1909510Q 0013
Coding: 0175010A018AF02A5A0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
VCID: 241A85ABEE5F424A13B-8070
End----(Elapsed Time: 02:22, VBatt start/end: 12.0V/11.8V. VIgn 11.9V)-----
