AUDI A2 unable to connect to ECU but can connect to HVAC etc
Quantumtokoloshi
Basingstoke, UK
C?ID=491918
I am trying to read a DTC, but I am not able to connect to the Engine ECU, via hex used the autoscan and direct to the control module but no module found, I am able to connect to the HVAC module okay. My Foxwell OBD scanner also does not connect. I have seen mention of baud rate being an issue on some A2 ECUs, can anyone offer advice?
Thanks.
Dr Sheldon
Windsor UK
C?ID=334979
Post an Autoscan FIRST !!
Quantumtokoloshi
Basingstoke, UK
C?ID=491918
Here is the Autoscan.
,26,May,2024,10:49:59:41118
Chassis Type: 8Z - Audi A2 (2000 > 2005)
Scan: 01 02 03 08 15 16 17 18 37 45 46 56 57 75 76 77
Address 03: ABS Brakes        Labels:
   VCID: 55F789660C1B5F42545-4800
No Faults Found
   Part No: 8Z2 820 043
   Component: A2-KLIMAVOLLAUTOMAT 0406
   VCID: 75B7E9E6ECDB3F42745-24D2
00818 - Sensor for Evaporator Outlet Temperature (G263)
            30-00 - Open or Short to Plus
Address 15: Airbags        Labels: None
   VCID: 55F789660C1B5F42545-4E20
No Faults Found
Address 46: Central Conv.        Labels:
   VCID: 55F789660C0B5F42545-47E4
   Note: Excessive Comm Errors
End----(Elapsed Time: 04:32, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
That looks like some kind of interference on the K-line (the single wire diagnostic bus in that car).
What works in this car and what doesn't?
Does this car have any aftermarket equipment? E.g. an aftermarket radio, or perhaps a GPS tracking device?
Quantumtokoloshi
Basingstoke, UK
C?ID=491918
It does have an aftermarket radio, should I try it with the radio disconnected?
Thanks, that did the trick.
Post a new scan please.
Then find the K-Line coming from the car to the radio and make sure it isn't connected to anything on the radio.
