stcroix1
- May 19, 2024
- 3
- 0
- Tennessee, USA
- C?ID=542952 (NRRT)
I'm trying to reset Inspection code but I get this message and I cannot proceed.
WSC 06385 Importer 790 Equipment 00016 was rejected by the control module The command will probably fail. Please change the values.
Thursday,23,May,2024,20:24:22:50778
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUBEGFFXK1016781 License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 08 09 13 15 17 19 22 42 44 52 5F 6C BB BC
VIN: WAUBEGFFXK1016781 Mileage: 99871km-62056miles
Address 01: Engine (J623-DHHA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 Q HW: 06K 907 425 J
Component: R4 2.0l TFS H13 0007
Revision: --H13--- CVN: C6C47AFD
Coding: 0A2500124426010F2000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259Q 001008
ROD: EV_ECM20TFS0205G0906259Q.rod
VCID: 3C21276736E7C24A4BB-8068
VINID: 9D1952557596A1B0400461C804EAA3BB15
38649 - EVAP Purge System
P00FE 00 [01100000] - Line Restricted / Blocked
Part No SW: 0GC 300 013 M HW: 0GC 927 711 H
Component: GSG DQ381 H06 2402
Revision: 00H06V07 CVN: D78AB11A
ROD: EV_TCMDQ381061.rod
VCID: 2E051D2FF09B20DAF5F-807A
No subsystems:
Part No SW: 5Q0 614 517 FG HW: 5Q0 614 517 BR
Component: ESC H82 0191
Revision: 00000000 Serial number: 62658000000005
Coding: 13FF6B9250212272897E0B08A0C469C8D60A4491D00596741241505492084A0B0000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 7BA3E47B73690572021-802E
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 39
Mileage: 99093 km
Date: 2024.05.14
Time: 19:31:58
Part No SW: 8V0 820 043 AF HW: 8V0 820 043 AF
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001687811
Coding: 03000014010000001000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
VCID: 76B5F54F484B581A7DF-8022
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 2F80975900PAG0MUFU03
65544 - Button(s) or Switch(es) in Operating Device
B1312 07 [00001000] - Mechanical Failure
Fault Frequency: 66
Mileage: 90498 km
Date: 2024.01.03
Time: 21:36:21
Voltage terminal 30: 14.4 V
Outside temperature: 16 °C
Pressing a button-Defrost: Not operated
Pressing a button-Recirculating air: Not operated
Pressing a button-Rear window defogger: Not operated
Pressing a button-AC: Not operated
Pressing a button-Left heated seat: Not operated
Pressing a button-Right heated seat: Not operated
Pressing a button-OFF: Not operated
Pressing a button-AUTO: Not operated
Pressing a button-Footwell air distribution: Not operated
Pressing a button-Upper body vent air distribution: Not operated
Pressing a button-Air distribution up: Not operated
Pressing a button-Left head area heater: Not operated
Pressing a button-Right head area heater: Not operated
Part No SW: 5Q0 937 085 BS HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H38 0273
Serial number: 00001830900663 Dataset Number: 8V0909514AB 0025
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 0B43B4BB23C935F2321-805E
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 181013 043 0585
Serial number: 181023231932
Coding: 0A47F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21698744X81A955547A0
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 04 09 2018 20001547
Serial number: 00000000000045680082
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H04 0005
Serial number: 0000FST00271MMI00000
Coding: 101F00
Steering Column Switch:
Subsystem 6 - Part No SW: 82A 953 521 AC HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000016111820240965
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 5Q0 907 572 J
Dataset Number: 8V1909863AD 0003
Coding: B500000111F78428949C815500302400000000000000000004
VCID: 44D15F874E17BA8A33B-8010
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR0ALDS1 Dataset Number: 8V0909602R 0002
VCID: 47CB488B7F219192D69-8012
Left seat belt tensioner:
Component: BeltPretRevFL H37 0350
Serial number: 34230167A01111820109
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H37 0350
Serial number: 34230168A05111831166
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 C HW: 5C6 959 339 C
Component: BF-Gewichtss. H10 0047
Serial number: 694000000000001SK8C2
Coding: 303435
Subsystem 4 - Part No SW: ----------- HW: 480 001 311 18
Serial number: 35700000000E76F0653S
Subsystem 5 - Part No SW: ----------- HW: 480 001 311 18
Serial number: 35800000000F76F0653U
Subsystem 6 - Part No SW: ----------- HW: 480 401 311 18
Component: SideSensor_Dr 003 6149
Serial number: 35100019D2C6D4B6E5AT
Subsystem 7 - Part No SW: ----------- HW: 480 401 311 18
Component: SideSensor_Pr 003 6149
Serial number: 35200019F2C6D4B1828G
Subsystem 8 - Part No SW: ----------- HW: 480 400 611 18
Component: FrontSensor_D 004 6149
Serial number: 3550001062BF5A91A243
Subsystem 9 - Part No SW: ----------- HW: 480 400 611 18
Component: FrontSensor_P 004 6149
Serial number: 3560001062BF5A9211C3
Part No SW: 8V0 920 840 HW: 8V0 920 840
Component: KOMBI H21 2603
Coding: 0BF418092380CF050280A8001800000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
VCID: 75B7F243554D5302745-8020
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[BAP_Audio_0x31 keine Kommunikation]
Fault Frequency: 17
Reset counter: 25
Mileage: 93526 km
Date: 2024.02.27
Time: 15:24:29
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 04111810520516 Dataset Number: 8V0909515R 0101
Coding: 030100043F0859005B00004C180B00000001010000000000000000000000
GVL: 01C03C0000000000400C80000002C80000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E85DD2F301B60DAB5F-803A
Generator:
Component: 0-01-0d-01-04
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0004
Serial number: 20181107204128 22637
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 758860029118103002B0
66565 - Diagnostic Databus
U1202 00 [00001000] - Malfunction
[Bus defekt CAN-Diagnose]
Reset counter: 29
Mileage: 98859 km
Date: 2024.05.12
Time: 16:59:37
Terminal 30 power supply: 13.2 V
Terminal 15: On
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00028.08.18 Dataset Number: v1260x015G0 0000
Coding: 0001
VCID: 4CC177A7664772CAFBB-8018
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RK21462A Dataset Number: 8V0909872N 0060
Coding: 00100B204000008000000002
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Dataset Number: 8V0909852AA 0001
Coding: 011F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B1CF475E374A0A43B-8020
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RK116001 Dataset Number: 8V0909873N 0060
Coding: 001003204000008000000002
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 43D35C9B4B19BDB20A1-8016
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGS2.clb
Part No SW: 8V1 035 652 D HW: 8V1 035 652
Component: MU-HS-S-US 050 0185
Serial number: Dataset Number: 8V1909545N 0027
Coding: 01730100FF0A000011220001061A00002F002DC401F001040A
ROD: EV_MUHigScl6C3DELP.rod
VCID: 38293B7702DFEE6AAF3-806C
Multimedia System 1:
Subsystem 1 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y0EUYH
Subsystem 2 - Part No SW: 8V0 919 614 BQ HW: 8V0 919 614 BQ
Component: ControlUnit_B H50 0106
Serial number: ALJAL128021900060332
Reset counter: 242
Mileage: 73378 km
Date: 2023.01.11
Time: 08:50:04
Voltage terminal 30: 13.3 V
Satellite radio tuner status-Antenna current: 137 mA
Satellite radio tuner status-Reception quality: weak_signal
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 05
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 05
Component: RVC Compact H15 0231
Dataset Number: 8V0909460E 0005
Coding: 0273010100002001000040
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW41.rod
VCID: 392F3E7339D5F76250D-806C
Part No SW: 8W1 959 395 D HW: 8W1 959 395 D
Component: TSG HFS003 0187
Serial number: YE007RIP22592 Dataset Number: 8V0909897J 0059
Coding: 000003204000008000000002
ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
Component: TSG HBFS003 0187
Serial number: YE007RIP23625 Dataset Number: 8V0909896J 0059
ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
End----------(Elapsed Time: 01:27, VBatt start/end: 12.2V/12.2V)-----------
