HI,
When trying to access ABS module I get the error below. Is my interface "HEX+CAN" not compatible with this car?
Any other way of retracting the parking brake?
"A vehicle identification number (VIN) is requierd to propely load data for UDS modules. However VCDS is not able to retrieve one at this time. VCDS can attempt geussing your vechlie´s platform based on part numbers instead, however the loaded data may not correctly match your control module. We suggest the following insted: "Close controller, run an autoscan, then connect again. ""
Tried doing this but did not help.
After pressing "yes" i get a message saying:
"Unsupported vechile. Please upgrade to a current ross tech-interface."
Based on what i have found my interface should be able to enter ABS-brakes on my vehicle. Have I been misinformed on these other websites?
Thursday,23,May,2024,12:47:32:26847
VCDS Version: 24.5.0.0 (x64)
VIN: WVWZZZAUZGW814713 License Plate: YCG426
Mileage: 123242km-76579mi Repair Order:
Chassis Type: AU-VW37 (5QE)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 23 42 44 51 52 55 5F 69
75 8C A9 C6
VIN: WVWZZZAUZGW814713 Mileage: 123242km-76579miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CUKB) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AG HW: 04E 907 309 F
Component: R4 1.4l TFSI H22 1726
Revision: X3H22--- CVN: 686016F4
Coding: 011D001A647405082000
ASAM Dataset: EV_ECM14TFS01104E906023AG 005005
ROD: EV_ECM14TFS01104E906023AF_005.rod
VCID: 65C1C7F7640919BED0-8030
VINID: 9E69EAAAA465A979C80441C10CF5069E38
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [00100000] - -
Mileage: 117753 km
Date: 2024.01.19
Time: 16:20:43
Engine RPM: 0.00 /min
Coolant temperature: 7 C
Intake air temperature: 10 C
Voltage terminal 30: 12.020 V
Unlearning counter according OBD: 25
Part No SW: 0DD 300 045 K HW: 0DD 927 770 B
Component: GSG DQ400E H31 1120
Revision: 00031033 Serial number: TFK01602130044 CVN: AA3CCFD5
Shop #: WSC 40206 222 00000
ROD: EV_TCMDQ400021.rod
VCID: 2F6D65DF767593EEEA-807A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 907 379 AK HW: 5Q0 907 379 H
Component: ESC H31 0809
Revision: 00000000 Serial number: 63445000000043 CVN: 689BA4B6
Coding: 01FA40A138213170037E060141C62980021C8CC0608294F3F8A15078C202
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_001.rod
VCID: 0501E7778449F9BE70-8050
16401 - Tire Pressure Warning
C102D 00 [10101111] - -
Fault Frequency: 32
Mileage: 122786 km
Date: 2024.05.17
Time: 20:48:05
Part No SW: 5GE 907 044 AE HW: 5GE 907 044 AE
Component: Climatronic H02 1104
Revision: 00001K07 Dataset Number: 0000
Coding: 00021004200101010005000000101002
ASAM Dataset: EV_ACClimaBHBVW37X 005134
VCID: 7F0D759FE695A36E3A-802A
Subsystem 3 - Part No SW: 12E 963 231 F HW: 12E 963 231 F
Component: J848 HV-PTC H09 0206
Serial number: LM160563003807000045
Air quality sensor:
A/C compressor sub:
H02
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061604404746 Dataset Number: V03935234Q0001
Coding: 00021A46C35102F36BEC5000001C07281400000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 0407FA738F73C0B667-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160128 043 0551
Serial number: 160209165042
Component: RLHS 037 0059
Serial number: S3Y16M02D24H15M15S27
Coding: 90A8DD
204546 - Remote key 2
B147A 18 [00001001] - Current Too Low
Reset counter: 189
Mileage: 122345 km
Date: 2024.05.07
Time: 11:52:55
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: OFF
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.4 V
Outside temperature: 15.0 C
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391604906209 Dataset Number: V03935233NV 0001
Coding: 0071151111
VCID: 4385396FCAFD078E1E-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 04021603210427 Dataset Number: 5g0114v____ 1027
Coding: 001C1B00FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 3A7B448BBD3746464D-806E
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR01WT00 Dataset Number: V03935211YW 0001
Coding: 98CCC000002000005C0000CF004800000065
VCID: 50AF06230B8BEC1693-8004
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34169667B25021640366
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34169668B23021641211
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 002 16
Serial number: 35700000000CF459691X
Subsystem 4 - Part No SW: ----------- HW: 480 002 602 16
Serial number: 35800000000664EC591U
Subsystem 5 - Part No SW: ----------- HW: 480 401 902 16
Serial number: 3510002C71F3538240C/
Subsystem 6 - Part No SW: ----------- HW: 480 401 902 16
Serial number: 3520002BB1F35382E38A
Subsystem 7 - Part No SW: ----------- HW: 480 401 902 16
Serial number: 3550002BD1F1FF3560AO
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160211501638
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F8D359FA615636E7A-806A
617752 - Selector Lever Park Position Lock Switch
B1162 29 [00001000] - Signal Implausible
Fault Frequency: 11
Reset counter: 230
Mileage: 117753 km
Date: 2024.01.20
Time: 10:23:44
Ubat 30 Voltage: 15.00 V
Ignition State: On
Terminal 15: 14.20 V
A/D #1: 0.00 %
A/D #2: 0.00 %
A/D #3: 0.00 %
Part No SW: 5G1 920 754 A HW: 5G1 920 754 A
Component: KOMBI 302 6420
Coding: 072D1B082FC0000801886A111600000000000000
VCID: 29598BC74891FDDE34-807C
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [00001000] - -
Mileage: 117454 km
Date: 2024.01.14
Time: 11:31:21
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 F HW: 5Q0 963 272 F
Component: STH-MQB 007 0072
Coding: 13C1
VCID: 39795B87B8314D5E44-806C
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001340356
0040 - Shutdown by Battery Management Module
B1381 00 [00001000] - -
Reset counter: 210
Mileage: 118516 km
Date: 2024.02.07
Time: 16:20:15
Parking heater: operating condition: Control mode
99
Coolant temperature of parking heater: 54 C
Coolant temperature: -6 C
Engine running status: not detected
Fuel level: 41 l
Heating performance: 5000 W
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 E HW: 5QE 907 530 A
Component: GW MQB EV 312 3245
Revision: -------- Serial number: 10021610801422 Dataset Number: 5G0067V____ 2407
Coding: 020100172EF16400FB00527C5C1F00000001050100010000000300000000
GVL: 01543C1000000008D00C90008004C81800000000000000000000000000000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 489F2E43F3DB24D6CB-801C
Subsystem 1 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160000211420106055
Coding: 2DFFFF
Subsystem 2 - Part No SW: 5QE 915 181 HW: 5QE 915 181
Component: J367-BDMHella H04 8050
Serial number: 4290128703
8526357 - No Function Support for HV to LV while standing; HV SOC
P30F4 00 [00001000] - -
Fault Frequency: 18
Reset counter: 210
Mileage: 117587 km
Date: 2024.01.15
Time: 14:37:09
Terminal 30 power supply: 13.8 V
Terminal 15: OFF
Address 23: Brake Booster (J539) Labels:| 5QE-909-059.clb
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430010697
Coding: 02720100331900020002060500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_003_VW37.rod
VCID: 4FAD055F16B5F3EE8A-801A
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861050216124126
154624 - Implausible Data Received from Engine Control Module
U0401 00 [00101000] - -
Mileage: 119642 km
Date: 2024.03.24
Time: 16:06:35
Component: TSG FS 020 0041
Serial number: 200116EAG09151 Dataset Number: 5G0222v____ 0068
Coding: 003F0720D000048000001000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009064370
Coding: 110000
B1487 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 238
Mileage: 123200 km
Date: 2024.05.21
Time: 10:44:10
65593 - Switch for Central Locking
B122D 29 [00001000] - Signal Implausible
Reset counter: 221
Mileage: 120612 km
Date: 2024.04.08
Time: 16:58:54
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Dataset Number: V03935226XC 0001
Coding: C102
VCID: 44873A73CFF300B627-8010
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 D HW: 5G0 907 080 D
Component: VW370P3815010 H07 4492
Revision: 00H07000 CVN: 3A7DD219
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM09550115G0907080D 001018
ROD: EV_DMCM09550115G0907080D.rod
VCID: 285F8EC3539BC4D62B-807C
Component: TSG BFS 020 0041
Serial number: 220116EAK02971 Dataset Number: 5G0157v____ 0064
Coding: 003F0120DE00048000801000
VCID: 428B3C6BD5E70E8615-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009096754
Coding: 090000
Reset counter: 238
Mileage: 123211 km
Date: 2024.05.21
Time: 15:23:03
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: -------------- Dataset Number: V03935194PF 0001
Coding: 029A000001010000
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: 75E197B7D4A9E93E60-8020
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 J HW: 3G0 035 043
Component: MU-H-N-EU H50 0343
Serial number: A683B0GB020850 Dataset Number: V03935223SB 0001
Coding: 02730001FF0000005111000100080A001F0209D401200100DF
VCID: 234599EF2ABD278E7E-8076
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU304Z21
Subsystem 2 - Part No SW: V03 959 800 QN HW: -----------
Component: ECE 2016 --- 0134
Compact disc data bank:
Component: Gracenote2 --- 1012
1553 - Function Restriction
B200D F0 [00001000] - due to Internal Communcations Error
Reset counter: 202
Mileage: 118435 km
Date: 2024.02.02
Time: 15:17:14
Voltage terminal 30: 13.5 V
Part No SW: 5Q0 907 383 H HW: 5Q0 907 383 C
Component: Anhaenger H21 0203
Revision: 8B001003 Serial number: 0393804251 Dataset Number: V03935214RG 0001
Coding: 0100000202000000
VCID: 3C774293B70378765F-8068
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 012 0715
Dataset Number: V03935222LG 0001
Coding: 0273900110829A0100F800000000
ROD: EV_OCULowMQB_VW32.rod
Address 8C: HV Battery (J840) Labels: None
Part No SW: 5Q0 915 182 C HW: 5Q0 915 182 C
Component: BECM H05 0752
Serial number: TB090016 Dataset Number: 0001 CVN: AD56AFEABE0FD826B72DDBABB72DDBABB72DDBABB72DDBABB72DDBABB72DDBAB
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006037
ROD: EV_BECM09620115Q0915182.rod
VCID: 336569AF9A5DB70E8E-8066
Battery interrupt switch:
Subsystem 1 - Part No SW: 5Q0 915 250 D HW: 5Q0 915 250 D
Component: BJB H27 0240
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D1 H14 0472
Serial number: V013C15B2730060
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D2 H14 0472
Serial number: V013C15B2730790
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D3 H14 0472
Serial number: V013C15B2730057
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D4 H14 0472
Serial number: V013C15B2730058
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D5 H14 0472
Serial number: V013C15B2730064
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D6 H14 0472
Serial number: V013C15B2730059
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D7 H14 0472
Serial number: V013C15B2730061
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D8 H14 0472
Serial number: V013C15B2730062
Part No SW: 5G0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0017
Serial number: 160126200108
VCID: 2E5378DB717F9AE6E1-807A
0005 - Incorrect Vehicle Type
U10D9 00 [00001000] - -
Reset counter: 209
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AA HW: 5QE 915 682 AA
Component: OBC KOSTAL H61 3018
Revision: -------- Serial number: 1402160BC000IR Dataset Number: V03935224LX 0001
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
VCID: 0C17D253A72388F62F-8058
14746880 - LED Module for Charging Socket A
P31C9 00 [00001001] - Electrical Malfunction
Fault Frequency: 103
Reset counter: 198
Mileage: 117448 km
Date: 2024.01.13
Time: 16:09:33
End-------------------------(Elapsed Time: 05:52)--------------------------
