Terribly sorry did not know where to post this. Purchased 2015 GTI and performed autoscan after initial break-in period. Car has not reached first service interval but son brought it to dealer near his college for issues unrelated to scan(difficulty shifting). Car presently has around 3K miles but is not in area to rescan. VW dealer there states that there are no error codes when they scanned the car and that they use different numbers to describe codes? Is this just someone taking advantage of 21 year old and is he getting the run-a-round? All we did was scan the car nothing else. Was waiting for first service to address codes that came with car.
Code
[Friday,28,August,2015,19:11:58:21746
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: 3VW5T7AU3FM104573
Mileage: 2057km-1278mi Repair Order: 8/28/15
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75 A9
VIN: 3VW5T7AU3FM104573 Mileage: 2057km-1278miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CXCA) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0006
Revision: --H13---
Coding: 091900122424002F1000
Shop #: WSC 00066 790 00221
ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C5708CC475FC541E27-8079
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 51435000000816
Coding: 01FA6BA134200970007C020781C62980D62C9000408194B400430050C009
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 479D5760FEF90619EF5-8012
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0366800877
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A7B3E94BD0B6BF160B-806F
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000000000000000000
ROD: EV_ACManueBHBVW37X_SE37.rod
VCID: 46835A64F9F31F11143-8013
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Revision: -------- Serial number: 86581706152041
Coding: 001108464041826969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00208
ROD: EV_BCMBOSCH_VW37.rod
VCID: 4A9B6E54EDEBFB71F0B-801F
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119
Component: WWS 150419 043 0581
Serial number: 150617163451
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S3Y15M04D16H07M44S52
Coding: 90A8DD
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03694813370303150608
Coding: 181803
329480 - Unknown Error Code
B1806 F0 [008] - Unknown Error Elaboration
Reset counter: 71
Mileage: 34 km
Date: 2011.02.25
Time: 00:29:18
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM029JBJ
VCID: 51A9793800BDC8A9B11-8004
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150003027G0D
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 001 105 15
Serial number: 35700000000CC3101416
Subsystem 3 - Part No SW: ----------- HW: 480 001 105 15
Serial number: 35800000000D6880741K
Subsystem 4 - Part No SW: ----------- HW: 480 402 204 15
Serial number: 35100029B1A91E7091B8
Subsystem 5 - Part No SW: ----------- HW: 480 402 204 15
Serial number: 3520002C31A8786253E5
Subsystem 6 - Part No SW: ----------- HW: 480 402 404 15
Serial number: 3550002B91A8785112B3
Subsystem 7 - Part No SW: ----------- HW: 480 402 404 15
Component: FrontSensor_P 001 6149
Serial number: 3560002B71A8785550B8
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150504500246
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 0407806C8F4FED014A7-8051
Part No SW: 5G1 920 856 HW: 5G1 920 856
Component: KOMBI 342 4270
Coding: 0BAD09122180CF0502086A001000000000000000
ROD: EV_DashBoardVDDMQBAB_VW37.rod
VCID: 6BD5CBD082D10279ABD-803E
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:18
U1110 00 [008] - -
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:19
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:18
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 14051510001566
Coding: 0101000820085900EF000028080F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
ROD: EV_GatewConti_VW37.rod
VCID: 71E9D9B8A0FDE8A9911-8024
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H10 0101
Serial number: 29150001095780075222
Coding: 30FFFF
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:17
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000110560003
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 346710AC9F6F9D81BA7-8061
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 2005150605011W
Coding: 003E13200000040000000000
VCID: 408F4C7CDBD731212EF-8015
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001327692
Coding: 011000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 377D27A08E1976999F5-8062
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 2805150605027U
VCID: 3F8D4F80A6294ED9575-806A
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001237386
Coding: 091000
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0655
Serial number: V7B01206150391
Coding: 027300000000000021220002001800001F0203340100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64C7A0EC6F0F4D01EA7-8031
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9RS501T58
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Shop #: WSC 00066 790 00323
ROD: EV_OCULowMQB.rod
VCID: 43854370CAC12A3933D-8016
0022 - Databus
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:21
0036 - Databus
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:18
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150423200190
0006 - Actuator for Structural Accoustics
P193A 00 [009] - Open Circuit
Fault Frequency: 12
Reset counter: 33
Mileage: 180 km
Date: 2015.08.19
Time: 16:08:26
End-------------------------(Elapsed Time: 03:36)--------------------------]Code
Code
Revision: --H13---
Coding: 030C0C
Revision: 00001K01
Slave 1:
Slave 2:
Coding: 90A8DD
Coding: 181803
Reset counter: 71
Mileage: 34 km
Date: 2011.02.25
Time: 00:29:18
Coding: 303131
Coding: 0400
U1110 00 [008] - -
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:18
U1110 00 [008] - -
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:19
U1110 00 [008] - -
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:18
Coding: 30FFFF
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:17
Coding: 011000
Coding: 8102
Coding: 091000
0022 - Databus
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:21
0036 - Databus
Reset counter: 73
Mileage: 166 km
Date: 2015.08.19
Time: 12:40:18
Fault Frequency: 12
Reset counter: 33
Mileage: 180 km
Date: 2015.08.19
Time: 16:08:26
