VW Caddy MK3 and MFSW from Golf Mk5
bert682
Ireland
C?ID=580016
Good morning!
Very new to VCDS and coding however not unfamiliar with the process involved, suspect my failings are interoperability of bits and sadly a cross check on the Wiki still has me stuck;
I am trying to add Cruise Control to my MK3 VW Caddy with Indicator Stalk along with a MFSW from a Golf MK5 and have the log output beblow;
Thursday,16,May,2024,15:58:47:47896
VIN: WV1ZZZ2KZBX223902   License Plate:
Chassis Type: 2K-VN35 (7N0)
VIN: WV1ZZZ2KZBX223902   Mileage: 344030km-213770miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 DB    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number: 00000000000000 CVN: D0EF36E6
   Coding: 00114014032500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023DB 003011
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 698FAA1309F253C2E0D-803C
   VINID: 9E606AAAA09BA92A02083240083D1CB9BD
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Revision: 00H31001
   Coding: 633C400D092403FDC61402E4901BC081300000
   Shop #: WSC 35110 377 00154
   VCID: 75B7F66355CA8722745-8020
   Part No SW: 7N0 907 426 F    HW: 7N0 907 426 F
   Component: AC Manuell    H15 0101
   Revision: 00010001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW32.rod
   VCID: 372B3C6B0FC63532A69-8062
9481748 - High Pressure Sensor
          B10AE 14 [00001000] - Open or Short to Ground
                    Reset counter: 136
                    Mileage: 343822 km
                    Date: 2024.05.16
                    Time: 19:32:00
          B10AB F0 [00001001] - Too Low
                    Reset counter: 97
                    Mileage: 343955 km
                    Date: 2024.05.16
                    Time: 20:32:38
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 401A581A8025186B08800082900000644301728852028060648000000040
   VCID: 72BDCD7F24A4901A517-8026
   Subsystem 1 - Part No: 1T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 05101  26  0512
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 96
                    Mileage: 343949 km
                    Date: 2018.10.07
                    Time: 00:56:01
                    Voltage: 13.15 V
                    Reset counter: 97
                    Mileage: 343955 km
                    Date: 2018.10.07
                    Time: 04:04:11
                    Voltage: 12.10 V
                    Reset counter: 100
                    Mileage: 343991 km
                    Date: 2018.10.07
                    Time: 17:41:28
                    Voltage: 12.30 V
                    Reset counter: 96
                    Mileage: 343949 km
                    Date: 2018.10.07
                    Time: 00:55:38
                    Voltage: 14.35 V
                    Reset counter: 96
                    Mileage: 343949 km
                    Date: 2018.10.07
                    Time: 00:55:38
                    Voltage: 14.35 V
   Component: VW10Airbag00U H06 0013
   Revision: --------    Serial number: 003HL001UZ6R Dataset Number: 2KC003v____ 0221
   Coding: 000000000000000000000000000000003055
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3537366315CAC722B45-8060
   Revision: --------    Serial number:  90422KCO0002X Dataset Number: 5K0953507AH D005
   Coding: 008A160000
   Shop #: WSC 00028 028 00025
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B5F16F484C8C3A7DF-8022
267264 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2024.05.16
                    Time: 01:08:20
365080 - Controls in Steering Wheel
          U108E 00 [00001001] - No Communications
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2024.05.16
                    Time: 01:08:20
   Part No SW: 2K0 920 965 A    HW: 2K0 920 965 A
   Component: KOMBI         H04 0404
   Coding: 480000
   VCID: 2D071E03FD9A8FE2CC5-8078
1416448 - Oil Level Thermal Sensor
          B1041 29 [00001000] - Signal Implausible
                    Reset counter: 137
                    Mileage: 343950 km
                    Date: 2024.05.16
                    Time: 01:02:26
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 290910F2002012
   Coding: E9801F0600020200007401
   VCID: 6D87DE03319A4FE28C5-8038
                    Reset counter: 139
                    Mileage: 343955 km
                    Date: 2018.10.07
                    Time: 17:58:37
   Component: IMMO          H04 0404
   ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
   VCID: 6A8DD51F0CF458DAE97-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 48C94F977EB84ACADF3-801C
00913 - Window Regulator Switch; Front Right Driver (E81)
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 140    3001
   Revision: 00H17000
   VCID: 313F0273ED22EB02E8D-8064
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 47CB4CAB73A645B2D69-8012
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5814
   Revision: --------    Serial number: VWZZZ4H6290655
   Coding: 16000440040005
   Shop #: WSC 127395 840 08317
   VCID: 46D541AF78AC5CBA2DF-8012
9 Faults Found:
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.07
                    Time: 01:18:40
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.07
                    Time: 01:18:40
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.07
                    Time: 01:18:40
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.07
                    Time: 01:18:40
00856 - Radio Antenna
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.07
                    Time: 01:18:38
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.07
                    Time: 01:19:60
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.07
                    Time: 01:19:60
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.07
                    Time: 01:19:60
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.07
                    Time: 01:19:60
End----------(Elapsed Time: 00:52, VBatt start/end: 14.2V/14.1V)-----------
I believe I have the Cruise Control coded in correctly however ive got nothing on my steering wheel, no horn and no buttons work along with the errors;
My best guess is that the Mk5 wheel is too old (LIN 1.3) to work with my newer instrument controls (LIN 2.0) however I have not been able to confirm this. Would I have better success with a MK6 steering wheel?
Interesting is that I get the same error (267264) when I put my original wheel back in so maybe that is a red herring?
Many thanks for any advice.
Rob
bert682
Ireland
C?ID=580016
Use G6 Steering wheel Type, then you have sucess
Thank you, suspected this but appreciate the help.
Ill get one ordered!
2kaa52
Ceska Republica, Praha
C?ID=319193
Regarding Cruise, did you coded 01 engine and 16 steering column ECU to Cruise Control activ ?
bert682
Ireland
C?ID=580016
I believe so, not tested it on the road yet, will do that today. I followed the video below;
bert682
Ireland
C?ID=580016
Managed to pop on a Mk6 Steering wheel and got the left side controls and horn working however I now have an airbag fault. The wheel is from a breaker so I suppose its possible the airbag is bad?
Friday,17,May,2024,11:49:18:47896
Mileage: 344030km-213770mi   Repair Order:
6082 - Steering Column Control Module
          U0212 00 [00100000] - No Communications
                    Mileage: 344039 km
                    Date: 2024.05.17
                    Time: 05:22:53
                    Engine RPM: 0.00 /min
                    Coolant temperature: 38  C
                    Intake air temperature: 21  C
                    Voltage terminal 30: 12.762 V
                    Driver intention torque-TQI_DRIV_SUB: 0.00 Nm
                    Control Module temperature-TECU: 17  C
   Revision: 00H31001
   Revision: 00010001
   Coding: 0000000002
                    Reset counter: 136
                    Mileage: 343822 km
                    Date: 2024.05.17
                    Time: 19:32:00
                    Reset counter: 97
                    Mileage: 343955 km
                    Date: 2024.05.17
                    Time: 20:32:38
   Revision: BB011001
   Coding: 009795
                    Reset counter: 96
                    Mileage: 343949 km
                    Date: 2018.10.08
                    Time: 00:56:01
                    Voltage: 13.15 V
                    Reset counter: 97
                    Mileage: 343955 km
                    Date: 2018.10.08
                    Time: 04:04:11
                    Voltage: 12.10 V
                    Reset counter: 100
                    Mileage: 343991 km
                    Date: 2018.10.08
                    Time: 17:41:28
                    Voltage: 12.30 V
                    Reset counter: 96
                    Mileage: 343949 km
                    Date: 2018.10.08
                    Time: 00:55:38
                    Voltage: 14.35 V
                    Reset counter: 96
                    Mileage: 343949 km
                    Date: 2018.10.08
                    Time: 00:55:38
                    Voltage: 14.35 V
          B1000 1B [10001000] - Resistance Too High
                    Mileage: 344039 km
                    Date: 2024.05.17
                    Time: 18:14:18
   Coding: 008A160000
   Serial number: 30000000000000335235
   Coding: E20000
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2024.05.17
                    Time: 21:13:36
   Coding: 480000
                    Reset counter: 137
                    Mileage: 343950 km
                    Date: 2024.05.17
                    Time: 01:02:26
   Coding: 0000560
   Revision: 00H17000
   Coding: 0000560
9 Faults Found:
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.08
                    Time: 01:18:40
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.08
                    Time: 01:18:40
                    Fault Status: 00111011
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.08
                    Time: 01:18:40
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.08
                    Time: 01:18:40
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.08
                    Time: 01:18:38
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.08
                    Time: 01:19:60
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.08
                    Time: 01:19:60
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.08
                    Time: 01:19:60
                    Reset counter: 103
                    Mileage: 344039 km
                    Date: 2018.10.08
                    Time: 01:19:60
End----------(Elapsed Time: 00:53, VBatt start/end: 12.5V/12.5V)-----------
bert682
Ireland
C?ID=580016
Not sure whats suddenly made it behave but after a short drive the airbag error has cleared, seems to be working now as expected!
