AFS seat alhambra
vioelectric
Romania
C?ID=11248
Hi. I've replaced the left headligh on a 2014 seat alhambra and I can't code the new headlight. When i tried to recode with same code VCDS gives error 10 general error. Do i need any security acces code before? Any advice is welcome. Thank you.
Wednesday,14,October,2015,15:37:48:42648
VCDS Version: 15.7.0.1
Data version: 20150729
Workshop Code: 111 17000 123456
VIN: VSSZZZ7NZEV   License Plate:
Mileage: 64560km-40115mi   Repair Order:
Chassis Type: 7N (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 25 2E 42 44 46 4C 52 53 55
          56 61 62 72 77
VIN: VSSZZZ7NZEV   Mileage: 64560km-40115miles
Address 01: Engine (J623-CFFE)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 KT    HW: 03L 906 018 M
   Component: R4 2,0L EDC   H28 4246
   Revision: 44H28---    Serial number:
   Coding: 0019001A042401080000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01103L906018KT 003009
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: 860989CE3981350EEC-80D2
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [167] - Intermittent
                    Mileage: 64567 km
                    Date: 2015.10.14
                    Time: 04:33:41
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 P    HW: 7N0 614 109 P
   Component: J104   C3 450M VDB9 0030
   Revision: --H07---    Serial number: 00000007658145
   Coding: 0019067
   Shop #: WSC 00020 790 00000
   VCID: BA712D3EF5F981EED8-80EE
   Part No SW: 7N0 907 044 Q    HW: 7N0 907 044 Q
   Component: Clima-Sharan  H02 0404
   Revision: 00001K02
   Coding: 021000C549
   ROD: EV_ClimaAutoSharaBasis_VW36.rod
   VCID: BE79212E21D1ADCEE4-80EA
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20131127000000141993
   Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
   Component: BCM PQ35 M    122 0173
   Revision: BC122001
   Coding: 60180A3B89251AC4408800C81400896443559388626D29626484C72000C1
   VCID: C28155DE5D29C92E80-8096
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    131127  033 0044
   Coding: 004DBD
   Component: RLFS  024 0042
   Coding: 0228DD
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 185
                    Mileage: 64567 km
                    Date: 2015.10.14
                    Time: 04:36:56
                    Voltage: 11.75 V
                    Reset counter: 185
                    Mileage: 64567 km
                    Date: 2015.10.14
                    Time: 04:36:56
                    Voltage: 11.75 V
Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28231333401160
   Coding: 108002
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: B973323238FF8AF6D1-80EC
   Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
   Component: VW10Airbag00N H12 0014
   Serial number: 003LGPQVG67M
   Coding: 00304E
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: BF875C2A26DBA4C6EF-80EA
   Serial number: 3493ETS60F1BB01199D
   Serial number: 3503ETS6013160D19DDJ
   Serial number: 3513ETS608EC401199DV
   Serial number: 3523ETS60F1620D19DDY
   Serial number: 35540TS603BD5F7129DU
   Part No SW: 5K0 953 501 CR    HW: 5K0 953 569 AL
   Revision: FF010042    Serial number: 20131203100678
   Coding: 118A240000
   VCID: FCFDEB26774D7FDE8A-80A8
   Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0103
   Coding: E20000
   Part No SW: 7N5 920 870 J    HW: 7N5 920 870 J
   Coding: 141F01
   Part No: 7N0 963 271 E
   Component: Zuheizer        051 2940
   Revision: 00051000    Serial number: 09024297000000
   Coding: 0000041
   VCID: B669390EC1E1658E3C-80E2
   Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1642
   Revision:   H58       Serial number: 301113F1000408
   Coding: 468202
   VCID: FAF1ED3E757941EE98-80AE
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 7N0 857 511 P    HW: 8P0 857 511 C
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 0201816B74745D545420363E01
   VCID: C0855FD65325DB3E96-8094
   VCID: EAD1DD7E0DD9F16E68-80BE
Address 2E: Media Player 3
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 G    HW: 7N0 959 793 G
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000083313154
   Coding: 011107209000411011
   VCID: C68949CE7101F50EAC-8092
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.324 1401
   Revision: 1BH04739    Serial number: 00133230004201
   Coding: 0000258
   VCID: C1835AD2982FD23699-8094
Address 4C: Tire Pressure II
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 G    HW: 7N0 959 792 G
   Component: TSG BF        H03 0553
   Revision:             Serial number: 0000082645492
   Coding: 011105209E00411011
   VCID: C58B4EC24C07FE16A5-8090
   Revision:   H19       Serial number: 00000001679461
   Coding: 0024167
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 068200000B000000
   Shop #: WSC 00020 999 39850
   ROD: EV_HeadlRegulVWAFSPt_SE36.rod
   VCID: B777340A0EEB9C8627-80E2
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0001
   Coding: 3B0000
          U1014 00 [137] - -
                    Reset counter: 185
                    Mileage: 64567 km
                    Date: 2015.10.14
                    Time: 04:37:16
5276145 - Power Output Module for Left Headlamp
          C1081 F1 [137] - Incorrectly Coded
                    Reset counter: 185
                    Mileage: 64567 km
                    Date: 2015.10.14
                    Time: 04:37:16
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  042 0082
   Revision: 00000001    Serial number: VWZ1Z2N3726650
   Coding: 01000400040024
   VCID: B36F001A129370A61B-80E6
   Component: Batt.regelung H58 1642
   Coding: 030F7859
   VCID: F1E3CA12280F02B629-80A4
   Component: J367-BDM  H07 0180
02252 - Generator
                    Reset counter: 185
                    Mileage: 64567 km
                    Date: 2015.10.14
                    Time: 04:34:41
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794 G    HW: 7N0 959 794 G
   Component: TSG HL        H04 0553
   Revision:             Serial number: 0000083743682
   Coding: 010005200000411001
   VCID: C79744CA760BEC0657-8092
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Component: TSG HR        H04 0553
   Revision:             Serial number: 0000082777157
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665522078
   Coding: 0A00030080010110
   ROD: EV_UHVUMI.rod
   VCID: AE59116EF1B15D4E74-80FA
End-------------------------(Elapsed Time: 03:48)--------------------------
AIB Wolfgang
please recode the Headlight Aim Control "55" , this will also recode the subsystems :cool::thumbs:
vioelectric
Romania
C?ID=11248
Yes I did that. Recode adress 55 with 068200000B000000 but I have error 10 general error.
