Audi Q7, engine Cannot crank
PPP
Sketchy
Cambodia
C?ID=242293
Dear mate,
I got a car in for injector #4 replacement, once I replaced new #4 and engine can start and run as normal, I am followed the procedure by carried out the injector adaptation by putting the injector code in for #4 but it failed several times, then I started the engine and run normal, then it started to get vibration and die out. Once I turn the ignition off and on then the car cannot crank any more and I cannot communicate with ECU either.
VIN: WA1CM74L59D032053
I notice the following when engine cannot crank
1- Temperature gauge does not move.
2- Front cooling fan running in full speed when ignition on.
3- VCDS cannot communicate with ECM.
I have no idea what going on as I think adaptation would not damage the ECM, anyone experience with this issue, please share and advise.
Thursday,15,October,2015,18:39:57:52357
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x86
VCDS Version: 15.7.1.0
Data version: 20150904
Mileage: 162500km-100972mi   Repair Order:
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 28 34 36 37 3C 42
          46 47 4F 52 55 56 62 65 67 6C 6D 6F 72 76 77
   Mileage: 162500km-100972miles
01-Engine -- Status: Cannot be reached 1100
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 FD    HW: 09D 927 750 FD
   Component: AL 750 6A           1474
   Revision: 00H78000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 75E1DCA11C0DB3967E-8020
Address 03: ABS Brakes        Labels: 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0103569
   VCID: 2959C0D18035A7762A-807C
                    Reset counter: 53
                    Mileage: 162466 km
                    Date: 2015.10.12
                    Time: 16:44:04
                    Count: 7168
                    Count: 65
                    Count: 128
                    Count: 35840
            000 -  -
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:00:31
                    Count: 128
                    Count: 8961
                    Count: 297
                    Count: 43776
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:45
                    Count: 8257
                    Count: 8194
                    Count: 46336
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601242501
   Coding: 0000135
   Shop #: WSC 42508 444 96599
   VCID: 2541CCE1EC2D83160E-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0040
7 Faults Found:
00192 - Rear Left Door Handle Touch Sensor (G417)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 252
                    Mileage: 161134 km
                    Date: 2015.09.19
                    Time: 17:00:19
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 250
                    Mileage: 161134 km
                    Date: 2015.09.19
                    Time: 17:00:19
                    Fault Status: 01111011
                    Reset counter: 252
                    Mileage: 161424 km
                    Date: 2015.09.22
                    Time: 07:18:17
02764 - Access/Start Authorization Switch (E408)
                    Mileage: 161677 km
                    Date: 2015.10.03
                    Time: 18:00:50
00230 - Transmission Park Selector Switch (F305)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 15
                    Mileage: 162252 km
                    Date: 2015.10.12
                    Time: 13:17:27
00190 - Driver's Door Handle Touch Sensor (G415)
                    Fault Status: 00111011
                    Reset counter: 53
                    Mileage: 162470 km
                    Date: 2015.10.12
                    Time: 16:55:40
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Fault Status: 00101001
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:09:38
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.lbl
   Part No SW: 4L0 910 732 R    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 354KZ087546307
   Coding: 0002003
   VCID: 387F15954B9F0EFEA5-806C
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000001226889
   Subsystem 3 - Serial number: 0114.11.080000000100010324ÿ
   Subsystem 4 - Serial number: 010324ÿ
02244 - Button in Control Head is Stuck
            000 -  -  - Intermittent
                    Reset counter: 44
                    Mileage: 161679 km
                    Date: 2015.10.03
                    Time: 18:02:26
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      011
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 N
   Component: KLIMABETAETIGUNGH07 0040
   Revision: 00---014    Serial number: 00000000193448
   Coding: 0131126
   VCID: 2345D2F9E2197D2660-8076
00003 - Control Module
                    Fault Status: 00100011
                    Mileage: 142505 km
                    Date: 2014.07.09
                    Time: 18:02:52
                    Temperature: 29.0°C
                    Fault Status: 01101000
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:10:13
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H22 0320
   Coding: 0012123
   VCID: 346721A557F7EA9E89-8060
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H16 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 15
                    Mileage: 151264 km
                    Date: 2015.03.22
                    Time: 15:48:00
                    Reset counter: 15
                    Mileage: 150648 km
                    Date: 2015.03.16
                    Time: 09:16:00
                    Reset counter: 15
                    Mileage: 150648 km
                    Date: 2015.03.16
                    Time: 09:16:00
01494 - Bulb for Parking Lamps; Left (M1)
                    Reset counter: 15
                    Mileage: 150648 km
                    Date: 2015.03.16
                    Time: 09:13:00
01498 - Bulb for Parking Lamps; Right (M3)
                    Reset counter: 15
                    Mileage: 150648 km
                    Date: 2015.03.16
                    Time: 09:13:00
   Part No SW: 4L0 910 110 B    HW: 4L0 035 110
   Component: MP3-Changer     H46 0390
   Revision: 00046004    Serial number: AUZ5ZBH8682635
   VCID: 1E33E30DC97B50CE4F-804A
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR
   Revision: 00000000    Serial number: AUZ4Z7H0470051
   Coding: 0000100
   VCID: 316928B1A8E5DFB6E2-8064
            000 -  -
                    Reset counter: 222
                    Mileage: 150417 km
                    Date: 2014.11.24
                    Time: 23:07:58
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09706T
   Coding: 0014131
   VCID: 2B553AD98AC9B566D8-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME141624261
   Subsystem 3 - Serial number: 6342QSME0112371E5
   Subsystem 4 - Serial number: 6352QSME2C16160EJ
   Subsystem 5 - Serial number: 6362QSME2C165326F
   Subsystem 6 - Serial number: 63734SME48113012L
   Subsystem 7 - Serial number: 63834SME3C102018T
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90055083090003
   Coding: 0002142
   VCID: 275DC6E9962191063C-8072
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels: 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 981 Q    HW: 4L0 920 981 Q
   Component: KOMBIINSTR.   H06 0135
   Revision: 00000000    Serial number: AFD039KC8
   Coding: 8B9664040101CF05020201
   VCID: 3E73038DA9BB30CE6F-806A
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:46
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 G    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0024
   Revision: 4MA80022    Serial number: 2200M08A068294
   Coding: 000303
   VCID: 336522B992F9EDA690-8066
   Component: J367-BDM  H07 0107
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:13:28
                    Bin. Bits:    00111
                    Voltage: 11.90 V
                    Count: 7
                    Bin. Bits:     1000
                    Time: 0.00 s
Address 1E: Media Player 2 (R199)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B553AD94AC9B566D8-807E
   Part No SW: 4L0 910 158     HW: 4L0 919 158 C
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---009    Serial number: 00000030116618
   Coding: 0000006
   VCID: 68DF85D55BBF5E7EF5-803C
                    Fault Frequency: 21
                    Mileage: 138807 km
                    Date: 2014.05.12
                    Time: 09:02:41
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 6
                    Mileage: 142505 km
                    Date: 2014.07.09
                    Time: 18:02:58
Address 34: Level Control        Labels: None
   Part No SW: 4L0 910 553 F    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7750
   Revision: --H03001    Serial number: 15.1528-0113.2
   Coding: 0015510
   Shop #: WSC 08254 001 1048576
   VCID: 2D5134C1B4DDBB56C6-8078
01577 - Turn-Off due to Over-Temp
                    Fault Status: 00100001
                    Fault Frequency: 185
                    Reset counter: 53
                    Mileage: 156513 km
                    Date: 2015.05.31
                    Time: 22:00:18
                    Error Code: 68
                    Reset counter: 53
                    Error Code: 13
                    Fault Status: 11100100
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:12:40
                    Error Code: 112
                    Fault Status: 11101101
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:16:45
                    Error Code: 98
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001001182722
   Coding: 00581B00000011110000
   VCID: 316928B168E5DFB6E2-8064
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H52 1100
   Revision: 00000000    Serial number: 313JX087544871
   Shop #: WSC 25807 444 68113
                    Reset counter: 27
                    Mileage: 160860 km
                    Date: 2015.09.15
                    Time: 09:07:14
                    Hex Value: 0x55F7
                    Hex Value: 0xDFC2
                    Hex Value: 0x009D
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0020
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0000001
   VCID: 2E5333CDB9DBC04EFF-807A
   Component: J0770_SWA_Slave_H01 0020
   Subsystem 3 - Serial number: 5F09.11.0800H010003C910059ÿ
   Subsystem 4 - Serial number: 910059ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 144
                    Mileage: 157740 km
                    Date: 2015.07.06
                    Time: 10:08:30
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000100500380
   Coding: 010D57205E40440004
   VCID: 46836B6DF16B680E27-8012
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 39
                    Mileage: 159434 km
                    Date: 2015.08.27
                    Time: 16:45:46
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H08 0060
   Revision: 0060 ---    Serial number: 01159404700000
   Coding: 3438621
   VCID: 336522B952F9EDA690-8066
                    Fault Frequency: 15
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:46
Address 47: Sound System        Labels: None
   Part No SW: 4L0 910 466 A    HW: 4L0 035 466
   Component: BO_Q7           H10 0820
   Revision: 04S00000    Serial number: 00306080002123
   Coding: 0000122
   Subsystem 1 - Part No: 4L0 910 465 A
   Component: BO_Q7_SLAVE     H41 0780
   Subsystem 2 - Serial number: 00204080002244
   Subsystem 3 - Serial number: 0202.04.080000000100032044ÿ
   Subsystem 4 - Serial number: 032044ÿ
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000049363
   Coding: 0012001
   VCID: 5EB3A30D89FB10CE0F-800A
                    Fault Frequency: 35
                    Reset counter: 15
                    Mileage: 162504 km
                    Date: 2015.10.15
                    Time: 18:09:00
                    Voltage: 12.600 V
                    Temperature: 36.0°C
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000100468668
   VCID: 45816C61CC6D63162E-8010
                    Reset counter: 15
                    Mileage: 160214 km
                    Date: 2015.09.09
                    Time: 08:48:09
   Part No: 8P0 907 357 H
   Coding: 0000008
   VCID: 3F8D7E896EB139C664-806A
                    Reset counter: 0
                    Mileage: 162504 km
                    Date: 2015.10.15
                    Time: 18:09:45
   Part No SW: 4E0 910 541 T    HW: 4E0 035 542
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 304KZ087629904
   Coding: 0000002
                    Reset counter: 55
                    Mileage: 147404 km
                    Date: 2014.09.27
                    Time: 10:35:26
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000100508214
   Coding: 010C57204040230004
   VCID: 43857279C2595D2600-8016
                    Fault Frequency: 66
                    Reset counter: 15
                    Mileage: 159432 km
                    Date: 2015.08.27
                    Time: 10:01:52
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000900081662
   Coding: 0062424
   VCID: 224BD7FDFD03742E6B-8076
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:16:48
                    (no units): 0.0
                    Voltage: 12.30 V
                    (no units): 27.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
02214 - Tire Pressure Warning
                    Fault Frequency: 253
                    Reset counter: 55
                    (no units): 0.0
                    Temperature: 40.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000811100115
   Shop #: WSC 12336 024 394758
   Revision: --H03---    Serial number: 525PA8-J8X43QB
   Coding: 1021001
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:16:44
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H28 0290
   Revision: --H28001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7F9C54F47725E91-8038
   Subsystem 3 - Serial number: RD21.11.08--H28001001A0287ÿ
   Subsystem 4 - Serial number: 1A0287ÿ
02242 - Rear Lid Lock Button in Luggage Compartment (E406)
                    Fault Frequency: 9
                    Reset counter: 55
                    Mileage: 158934 km
                    Date: 2015.08.09
                    Time: 18:30:37
Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003859340-----
   Coding: 0003595
   VCID: 2643CBED912B880E07-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE16_SKB09H10 0200
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE16_SKB09H10 0200
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE16_SKB09H10 0200
02961 - Lamp in Bumper; Rear Right
                    Fault Status: 01101001
                    Fault Frequency: 8
                    Reset counter: 239
                    Mileage: 157886 km
                    Date: 2015.07.17
                    Time: 20:52:01
                    Bin. Bits:  000 001
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000100508215
   Part No SW: 4F0 910 283 K    HW: 4F0 919 283 K
   Component: Parkhilfe 8-Kan H12 0100
   Revision: 00H12000    Serial number: 69820829007978
   Coding: 0221346
   VCID: 2C5739C58FC7B25ED1-8078
01625 - Front Parking Aid Warning Chime (H22)
                    Reset counter: 238
                    Mileage: 160458 km
                    Date: 2015.09.11
                    Time: 15:08:32
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005068636
   Coding: 0010900
   VCID: 285FC5D59B3F9E7E35-807C
End-------------------------(Elapsed Time: 04:17)--------------------------
Thursday,15,October,2015,18:46:03:52357
Chassis Type: 4F0
Address 01: Engine
   Coding: 0000504
   Revision: 00H30001
   Coding: 0103569
                    Reset counter: 53
                    Mileage: 162466 km
                    Date: 2015.10.12
                    Time: 16:44:04
                    Count: 7168
                    Count: 65
                    Count: 128
                    Count: 35840
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:45
                    Count: 8257
                    Count: 8194
                    Count: 46336
            000 -  -
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:00:31
                    Count: 128
                    Count: 8961
                    Count: 297
                    Count: 43776
   Coding: 0000135
7 Faults Found:
                    Reset counter: 252
                    Mileage: 161134 km
                    Date: 2015.09.19
                    Time: 17:00:19
                    Reset counter: 250
                    Mileage: 161134 km
                    Date: 2015.09.19
                    Time: 17:00:19
                    Reset counter: 252
                    Mileage: 161424 km
                    Date: 2015.09.22
                    Time: 07:18:17
                    Mileage: 161677 km
                    Date: 2015.10.03
                    Time: 18:00:50
                    Reset counter: 15
                    Mileage: 162252 km
                    Date: 2015.10.12
                    Time: 13:17:27
                    Reset counter: 53
                    Mileage: 162470 km
                    Date: 2015.10.12
                    Time: 16:55:40
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:09:38
   Coding: 0002003
                    Reset counter: 44
                    Mileage: 161679 km
                    Date: 2015.10.03
                    Time: 18:02:26
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      011
   Coding: 0131126
                    Mileage: 142505 km
                    Date: 2014.07.09
                    Time: 18:02:52
                    Temperature: 29.0°C
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:10:13
   Coding: 0012123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 15
                    Mileage: 151264 km
                    Date: 2015.03.22
                    Time: 15:48:00
                    Reset counter: 15
                    Mileage: 150648 km
                    Date: 2015.03.16
                    Time: 09:16:00
                    Reset counter: 15
                    Mileage: 150648 km
                    Date: 2015.03.16
                    Time: 09:16:00
                    Reset counter: 15
                    Mileage: 150648 km
                    Date: 2015.03.16
                    Time: 09:13:00
                    Reset counter: 15
                    Mileage: 150648 km
                    Date: 2015.03.16
                    Time: 09:13:00
   Component: SDAR SIRIUS     H07 0160
   Coding: 0000100
            000 -  -
                    Reset counter: 222
                    Mileage: 150417 km
                    Date: 2014.11.24
                    Time: 23:07:58
   Coding: 0014131
   Coding: 0002142
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:46
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:46
   Coding: 000303
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:13:28
                    Bin. Bits:    00111
                    Voltage: 11.90 V
                    Count: 7
                    Bin. Bits:     1000
                    Time: 0.00 s
   Revision: 00000000
   Coding: 0000006
                    Fault Frequency: 21
                    Mileage: 138807 km
                    Date: 2014.05.12
                    Time: 09:02:41
                    Reset counter: 6
                    Mileage: 142505 km
                    Date: 2014.07.09
                    Time: 18:02:58
   Coding: 0015510
                    Reset counter: 53
                    Mileage: 156513 km
                    Date: 2015.05.31
                    Time: 22:00:18
                    Error Code: 68
                    Reset counter: 53
                    Error Code: 13
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:12:40
                    Error Code: 112
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:16:45
                    Error Code: 98
                    Reset counter: 27
                    Mileage: 160860 km
                    Date: 2015.09.15
                    Time: 09:07:14
                    Hex Value: 0x55F7
                    Hex Value: 0xDFC2
                    Hex Value: 0x009D
   Coding: 0000001
            014 - Defective
                    Reset counter: 144
                    Mileage: 157740 km
                    Date: 2015.07.06
                    Time: 10:08:30
                    Reset counter: 39
                    Mileage: 159434 km
                    Date: 2015.08.27
                    Time: 16:45:46
   Coding: 3438621
                    Fault Frequency: 15
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:46
   Coding: 0000122
   Coding: 0012001
                    Fault Frequency: 35
                    Reset counter: 15
                    Mileage: 162504 km
                    Date: 2015.10.15
                    Time: 18:09:00
                    Voltage: 12.600 V
                    Temperature: 36.0°C
                    Reset counter: 15
                    Mileage: 160214 km
                    Date: 2015.09.09
                    Time: 08:48:09
   Coding: 0000008
                    Reset counter: 0
                    Mileage: 162504 km
                    Date: 2015.10.15
                    Time: 18:09:45
   Coding: 0000002
                    Reset counter: 55
                    Mileage: 147404 km
                    Date: 2014.09.27
                    Time: 10:35:26
                    Fault Frequency: 66
                    Reset counter: 15
                    Mileage: 159432 km
                    Date: 2015.08.27
                    Time: 10:01:52
   Coding: 0062424
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:16:48
                    (no units): 0.0
                    Voltage: 12.30 V
                    (no units): 27.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 55
                    (no units): 0.0
                    Temperature: 40.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 1021001
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:16:44
                        Reverse OFF
                    Count: 3
                    Fault Frequency: 9
                    Reset counter: 55
                    Mileage: 158934 km
                    Date: 2015.08.09
                    Time: 18:30:37
   Coding: 0003595
                    Fault Frequency: 8
                    Reset counter: 239
                    Mileage: 157886 km
                    Date: 2015.07.17
                    Time: 20:52:01
                    Bin. Bits:  000 001
   Coding: 0221346
                    Reset counter: 238
                    Mileage: 160458 km
                    Date: 2015.09.11
                    Time: 15:08:32
   Coding: 0010900
End-------------------------(Elapsed Time: 04:18)--------------------------
PPP
Sketchy
Cambodia
C?ID=242293
Dear Jack,
We already checked those and confirm ok. Strange thing is it was started then vibrate then die out. Could not crank again. It was just only involved with injector #4 failure adaptation only.
ECU is clearly off-line. Even the Gateway says, "01-Engine -- Status: Cannot be reached".
Do you have a scan from when the ECU was still communicating so people can see what kind of ECU this is?
Look in your Scans sub-folder. VCDS saves scans there whether you tell it to or not.
Gone But Not Forgotten
Address 01: Engine
Okay when the ecu is offline....... it can't report the coding string of the config through the gateway to authorize the starter.
How does Jack know this you might ask?
Jack disables modules to see how they affect other modules.
Jack does this so he can document how other modules will react and writes his own repair information.
It should be noted that, this is done by Jack for experimental purposes never being driven on public roads, and is done to determine when or how it may affect an emissions device, or how a device operates.
PPP
Sketchy
Cambodia
C?ID=242293
Dear Jack,
Are there ways we can get it started and wake up ECU online again?
Yes...........
First see if you can talk to it directly by making a hookup of the CAN HIGH/LOW.
Before you do this......... make sure all grounds and power supplies are functional to the ECU in the car.
Please advise if you get direct COM?
PPP
Sketchy
Cambodia
C?ID=242293
Hi,
We have rework on all the connect and all the fuses, it is coincident that the fuse was at the edge which somehow flew off and make the ECU lost communication to the rest. WE have fitted the new fuse and another symptom raised.
This point of time, the engine is running but it s vibration, at this point there is no DTC on injector 4 but (P0606 - 012 - Processor Fault) shown and cannot be erased. I have checked also that in Ross-Tech it is recon to replace ECU???
What we have checked:
1- Replaced the old inject back to the car and code to original injector number.
2- Cleared DTC and re-read but the same DTC is coming back. (Pls see attached detail).
3- Read real time on all injector, 1,2,3 but 4,5,6 is only shown 4 injectors only, which strange. (pls see attached detail).
4- The starting seem to be too long crank to start.
5- No power when driving.
Saturday,17,October,2015,09:39:12:52357
VIN: WA1CM74L59D032053   License Plate: 2AF_7766
Chassis Type: 4L (4F0)
VIN: WA1CM74L59D032053   Mileage: 162500km-100972miles
Address 01: Engine (CAT)       Labels: 059-907-401-CAT1.clb
   Part No SW: 4L0 910 401 Q    HW: 4L0 907 401 B
   Component: 3.0TDI EDC17G000AG  0100
   Revision: 31H01---    Serial number:
   Coding: 0121002A190F0168
   Shop #: WSC 83840 553 616489
   VCID: 306F2DB5A3EFD6BEED-8064
001542 - Internal Control Module
               P0606 - 012 - Processor Fault - MIL ON
                    Fault Status: 11101100
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:16:03
                    RPM: 1008 /min
                    Voltage: 13.68 V
                    Temperature: 35.1∞C
                    Pressure: 662.2 bar
                    (no units): 4.0
                    (no units): 4.0
                    Bin. Bits: 00110110
005277 - Transfer Pump for Reductant
               P149D - 000 - Open Circuit - Intermittent
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:16:36
                    RPM: 987 /min
                    Voltage: 13.60 V
                    Load: 88.2 %
                    Temperature: 19.8∞C
                        0.0 bar
                    Temperature: 29.7∞C
                    Voltage: 2.160 V
Readiness: 1 1 0 0 1
   Coding: 0000504
00777 - Accelerator Position Sensor (G79)
   Revision: 00H30001
   Coding: 0103569
                    Reset counter: 53
                    Mileage: 162466 km
                    Date: 2015.10.12
                    Time: 16:44:04
                    Count: 7168
                    Count: 65
                    Count: 128
                    Count: 35840
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:45
                    Count: 8257
                    Count: 8194
                    Count: 46336
            000 -  -
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:00:31
                    Count: 128
                    Count: 8961
                    Count: 297
                    Count: 43776
   Coding: 0000135
7 Faults Found:
                    Reset counter: 252
                    Mileage: 161134 km
                    Date: 2015.09.19
                    Time: 17:00:19
                    Reset counter: 250
                    Mileage: 161134 km
                    Date: 2015.09.19
                    Time: 17:00:19
                    Reset counter: 252
                    Mileage: 161424 km
                    Date: 2015.09.22
                    Time: 07:18:17
                    Mileage: 161677 km
                    Date: 2015.10.03
                    Time: 18:00:50
                    Fault Status: 00101010
                    Reset counter: 55
                    Mileage: 162252 km
                    Date: 2015.10.12
                    Time: 13:17:27
                    Reset counter: 53
                    Mileage: 162470 km
                    Date: 2015.10.12
                    Time: 16:55:40
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:09:38
   Coding: 0002003
   Subsystem 3 - Serial number: 0114.11.080000000100010324ˇ
   Subsystem 4 - Serial number: 010324ˇ
                    Reset counter: 55
                    Mileage: 161679 km
                    Date: 2015.10.03
                    Time: 18:02:26
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      011
   Coding: 0131126
                    Mileage: 142505 km
                    Date: 2014.07.09
                    Time: 18:02:52
                    Temperature: 29.0∞C
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:10:13
01273 - Fresh Air Blower (V2)
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:13:23
                    Temperature: 32.0∞C
                    (no units): 184.0
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:01:51
                    Temperature: 54.0∞C
                    Temperature: 34.0∞C
                    Temperature: -55.0∞C
                    RPM: 6000 /min
                    Absolute Pres.: 9.4 bar
                    Current: 0.000 A
                    Temperature: 33.0∞C
   Coding: 0012123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 15
                    Mileage: 162504 km
                    Date: 2008.08.13
                    Time: 00:26:00
                    Reset counter: 15
                    Mileage: 162504 km
                    Date: 2008.08.13
                    Time: 00:23:00
                    Reset counter: 15
                    Mileage: 162504 km
                    Date: 2008.08.13
                    Time: 00:23:00
                    Reset counter: 15
                    Mileage: 162504 km
                    Date: 2008.08.13
                    Time: 00:26:00
                    Reset counter: 15
                    Mileage: 162504 km
                    Date: 2008.08.13
                    Time: 00:26:00
   Coding: 0000100
            000 -  -
                    Reset counter: 222
                    Mileage: 150417 km
                    Date: 2014.11.24
                    Time: 23:07:58
   Coding: 0014131
   Coding: 0002142
00886 - Turn Signal Switch (E2)
                    Fault Status: 00101110
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 14:03:12
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:46
   Coding: 000303
   Revision: 00000000
   Coding: 0000006
                    Fault Frequency: 21
                    Mileage: 138807 km
                    Date: 2014.05.12
                    Time: 09:02:41
                    Reset counter: 6
                    Mileage: 142505 km
                    Date: 2014.07.09
                    Time: 18:02:58
   Coding: 0015510
                    Reset counter: 53
                    Mileage: 156513 km
                    Date: 2015.05.31
                    Time: 22:00:18
                    Error Code: 68
                    Reset counter: 53
                    Error Code: 13
                    Fault Frequency: 12
                    Reset counter: 168
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:12:40
                    Error Code: 112
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:17:04
                    Error Code: 98
                    Reset counter: 27
                    Mileage: 160860 km
                    Date: 2015.09.15
                    Time: 09:07:14
                    Hex Value: 0x55F7
                    Hex Value: 0xDFC2
                    Hex Value: 0x009D
   Coding: 0000001
   Subsystem 3 - Serial number: 5F09.11.0800H010003C910059ˇ
   Subsystem 4 - Serial number: 910059ˇ
            014 - Defective
                    Reset counter: 144
                    Mileage: 157740 km
                    Date: 2015.07.06
                    Time: 10:08:30
                    Reset counter: 39
                    Mileage: 159434 km
                    Date: 2015.08.27
                    Time: 16:45:46
   Coding: 3438621
                    Fault Frequency: 31
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2015.10.15
                    Time: 18:09:46
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 15:08:21
   Coding: 0000122
   Subsystem 3 - Serial number: 0202.04.080000000100032044ˇ
   Subsystem 4 - Serial number: 032044ˇ
   Coding: 0012001
                    Fault Frequency: 64
                    Reset counter: 55
                    Mileage: 162504 km
                    Date: 2015.10.15
                    Time: 18:09:00
                    Voltage: 12.600 V
                    Temperature: 36.0∞C
                    Reset counter: 55
                    Mileage: 162504 km
                    Date: 2008.08.13
                    Time: 14:45:00
                    Voltage: 12.200 V
                    Temperature: 20.0∞C
                    Fault Frequency: 9
                    Reset counter: 15
                    Mileage: 160214 km
                    Date: 2015.09.09
                    Time: 08:48:09
   Coding: 0000008
                    Fault Frequency: 0
                    Mileage: 162504 km
                    Date: 2015.10.15
                    Time: 18:09:45
   Coding: 0000002
                    Reset counter: 55
                    Mileage: 147404 km
                    Date: 2014.09.27
                    Time: 10:35:26
                    Fault Frequency: 72
                    Reset counter: 15
                    Mileage: 159432 km
                    Date: 2015.08.27
                    Time: 10:01:52
   Coding: 0062424
                    Reset counter: 55
                    (no units): 0.0
                    Temperature: 40.0∞C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 1021001
                    Reset counter: 15
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 00:17:02
                        Reverse OFF
                    Count: 3
   Subsystem 3 - Serial number: RD21.11.08--H28001001A0287ˇ
   Subsystem 4 - Serial number: 1A0287ˇ
                    Fault Frequency: 9
                    Reset counter: 55
                    Mileage: 158934 km
                    Date: 2015.08.09
                    Time: 18:30:37
   Coding: 0003595
                    Fault Frequency: 8
                    Reset counter: 239
                    Mileage: 157886 km
                    Date: 2015.07.17
                    Time: 20:52:01
                    Bin. Bits:  000 001
                    Reset counter: 55
                    Mileage: 162506 km
                    Date: 2008.08.13
                    Time: 14:45:39
   Coding: 0221346
                    Reset counter: 238
                    Mileage: 160458 km
                    Date: 2015.09.11
                    Time: 15:08:32
   Coding: 0010900
End-------------------------(Elapsed Time: 04:12)--------------------------
Saturday,17,October,2015,15:21:36:52357
Mileage:    Repair Order: Data injection #1-#3
                Address 01: Engine  (4L0 910 401 Q)
15:19:24 Group 013: Idle Stabilization Cyl. 1-3 (Injection Quantity Deviation)
  -5.27 mg/str  Injection Quantity Deviation Cyl. 1
  -5.27 mg/str  Injection Quantity Deviation Cyl. 2
  -5.27 mg/str  Injection Quantity Deviation Cyl. 3
Saturday,17,October,2015,15:23:31:52357
Mileage:    Repair Order: Data injection #4_#6
15:21:44 Group 014: Idle Stabilization Cyl. 4-6 (Injection Quantity Deviation)
  5.22 mg/str  Injection Quantity Deviation Cyl. 4
Saturday,17,October,2015,15:17:24:52357
15:14:10 Group 004: Main Injection
  798 /min  Engine Speed (G28)
  3.0 ∞ATDC  Injection Start (specified)
  0.76 ms  Injection Duration (specified)
  473.0 bar  High Fuel Pressure (actual)
PPP
Sketchy
Cambodia
C?ID=242293
Hi,
Anyone have any idea?
Send me ecu for replacement after verifying the unit fault stays the same after swapping an injector location to double check work and not before verifying the harness back to ecu.
PPP
Sketchy
Cambodia
C?ID=242293
Dear Jack,
The car owner just back from abroad and he mentioned if it is possible to save time by buying another ECU from you rather send to and back.
What part #?
It is always best to send the unit to me to observe, and extract possible lost data, for a data transfer, or build.
PPP
Sketchy
Cambodia
C?ID=242293
Dear Jack,
Please give me your address and so I can post you this ECU.
C/o jack shapiro
european parts emporium
1001 state route 17k
montgomery new york 12549 usa
PPP
Sketchy
Cambodia
C?ID=242293
Ok, I am posting via FedEx to you now.
Welder75
Canada
C?ID=261654
Blaa blah blaa
Hope Jack gets it going for you
