Wednesday,01,July,2015,14:07:18:53737
VCDS Version: 15.6.1.0 (x64)
Data version: 20150612
Workshop Code: 122 12345 011111
VIN: WV2ZZZ2KZCX License Plate:
Chassis Type: 2K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 52 55 56 77
A5
VIN: WV2ZZZ2KZCX Mileage: 67410km-41886miles
Address 01: Engine (J623-CAYD) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PC HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 0869
Revision: --H43--- Serial number: 00000000000000
Coding: 00114036032400080000
Shop #: WSC 12345 122 11111
ASAM Dataset: EV_ECM16TDI02103L906023PC 003002
ROD: EV_ECM16TDI02103L906023DB.rod
VCID: 76E3C036C916D48FD3-8022
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 423C400D092303FA420B02E7901DC041310DF0
Shop #: WSC 11112 555 12345
VCID: 7BF5D102FA3489E7AC-802E
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BF HW: 5K0 907 044 BF
Component: Climatronic H14 0606
Revision: 00003001
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 70EFF62EAB72FABF09-8024
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AC HW: 5K0 937 087 AC
Component: BCM PQ35 H+ 122 0174
Revision: BF122001
Coding: 411A0A38E825D36B08880088C40009E803757408727D8160E48440040049
VCID: 76E3C036C116D48FD3-8022
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 19011 26 0512
Coding: 0097B5
Component: RLS 060612 05 54 0403
Coding: 0730ED
Subsystem 3 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 K HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0031
Revision: -------- Serial number: 56261221500198
Coding: 348001
ASAM Dataset: EV_EPHVA2C000000000 002011
ROD: EV_EPHVA2C000000000_SE36.rod
VCID: 438569E2CA443127A4-8016
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag01P H06 0013
Revision: -------- Serial number: 003HN006Y052
Coding: 000000000000000000000000000000003150
Shop #: WSC 35110 790 50316
ROD: EV_AirbaVW10BPAVN750_SE12.rod
VCID: 336539229AE481A734-8066
Serial number: 3495RRB40570VC0I6H5J
Serial number: 3505RRB404R0V8BO8OQU
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Revision: -------- Serial number: 90440KK7001MR
Coding: 1082140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 72EBFC26A57EC8AFFF-8026
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0110332
Coding: 820000
Part No SW: 5N0 920 883 A HW: 5N0 920 883 A
Component: KOMBI H05 0505
Coding: 181E01
ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
VCID: 326B3C2665FE88AF3F-8066
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General checksum failure
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 130114F1002029
Coding: 357402
VCID: 7CF7D21EFF3A8EDFA5-8028
Component: IMMO H05 0505
VCID: 6ADBE4468DAE006F47-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7665894085
Coding: 010100
VCID: 2B5521424AD4D9677C-807E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H23 6270
Revision: AB001001 Serial number: VWZ6Z7P9232467
Coding: 0C000440000000AD2013
VCID: 3D711F1AA4A047D7D2-8068
Component: EU West V12 8195
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2109
Coding: 0000114
VCID: 489F7ECE3B62127F71-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 140 3305
Revision: 00H22000
Shop #: WSC 35110 377 08192
VCID: 377D0D32469C6D8708-8062
Address 4C: Tire Pressure II
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000114
VCID: 479D7DF2367C1D0778-8012
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 091600104F000200
ROD: EV_HeadlRegulVWAFSPt_SE36.rod
VCID: 377D0D328E9C6D8708-8062
Subsystem 1 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A
Component: LeiMo links H06 0007
Coding: 3D0000
Subsystem 2 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A
Component: LeiMo rechts H06 0007
Coding: 3D0000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660915910
Coding: 0E00000100010110
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 2643D0765936E40FA3-8072
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3AA-980-654.clb
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H09 0300
Serial number: 0195243920
Coding: 010102000102020E0200040001000000
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
VCID: 39790B0AB8887BF7FE-806C
End-------------------------(Elapsed Time: 03:12)--------------------------
