Resolved A6 3.0 tfsi Ecu problem
Resolved
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
Hi all,
can somebody help me with what is happening with the ecu? The car runs but limited to under 1500 rpm and I can feel thumping sensation from under the body, firstly slow but later the thumping becomes faster. Feel somewhat like the transmission changing gear roughly even while I'm idling. I don't know whether I am describing it correctly but that what I felt from inside the car. The ESP TPMS warnings came up as well.
Thank you in advance.
Monday,13,May,2024,10:41:18:34670
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUZZZ4G9BN031310 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031310 Mileage: 238957km-148480miles
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CGWB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 HW: 4H0 907 551
Component: 3.0l V6 TFSI H05 0007
Revision: --H05--- CVN: C8FC4A11
Coding: 0A250034052701020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551 002010
ROD: EV_ECM30TFS0214G0907551_002.rod
VCID: 6695B5FFE8EFBBDACDF-8032
VINID: 9D196AAAA1172527800C10C1005A6DBEFC
10 Faults Found:
6347 - Control Module Malfunction - Lambda Sensing Circuit
P1385 00 [00100111] - -
Mileage: 238954 km
Date: 2024.05.13
Time: 10:02:51
Engine RPM: 1247.00 /min
Normed load value: 43.1 %
Vehicle speed: 27 km/h
Coolant temperature: 73 °C
Intake air temperature: 33 °C
Voltage terminal 30: 12.796 V
Engine speed: actual: 992 /min
MAF_ENVD: 70.81176 mg/stroke
Coolant temperature (unfiltered): 90.00 °C
Engine: operating status: PUC
T_AST_ENVD: 128.50 s
STATE_LS_ENVD[1]: 4
6349 - Control Module Malfunction - Lambda Sensing Circuit
Mileage: 238954 km
Date: 2024.05.13
Time: 10:02:51
STATE_LS_ENVD[2]: 4
6162 - Internal Control Module
P0603 00 [00100111] - Non-Volatile Memory Error
Mileage: 238957 km
Date: 2024.05.13
Time: 10:34:20
Engine RPM: 971.00 /min
Vehicle speed: 35 km/h
Coolant temperature: 90 °C
Intake air temperature: 55 °C
Voltage terminal 30: 13.507 V
Coolant temperature (unfiltered): 90.75 °C
Battery voltage: 13.507813 V
Vehicle speed: actual: 35 km/h
6163 - Internal Control Module
P1604 00 [00100111] - Output Driver IC Error
Mileage: 238957 km
Date: 2024.05.13
Time: 10:34:20
6546 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P0135 00 [00100111] - Malfunction
Mileage: 238954 km
Date: 2024.05.13
Time: 10:04:10
Engine RPM: 1064.00 /min
Normed load value: 18.8 %
Vehicle speed: 15 km/h
Coolant temperature: 78 °C
Intake air temperature: 35 °C
Voltage terminal 30: 12.898 V
Coolant temperature (unfiltered): 93.00 °C
Battery voltage: 13.609375 V
STATE_LS_ENVD[1]: 8
6547 - Oxygen (Lambda) Sensor Heater Circuit: B2 S1
P1197 00 [00100111] - Electrical Malfunction
Mileage: 238955 km
Date: 2024.05.13
Time: 10:04:56
Engine RPM: 1328.00 /min
Vehicle speed: 29 km/h
Coolant temperature: 80 °C
Voltage terminal 30: 13.710 V
Engine speed: actual: 1280 /min
MAF_ENVD: 337.71764 mg/stroke
Engine: operating status: PL
STATE_LS_ENVD[2]: 8
6277 - Injector: Cylinder 5 (N83)
P0205 00 [00100110] - Circuit Malfunction
Mileage: 238957 km
Date: 2024.05.13
Time: 10:34:20
Engine RPM: 1038.00 /min
Vehicle speed: 34 km/h
Engine speed: actual: 800 /min
MAF_ENVD: 212.43529 mg/stroke
Engine: operating status: IS
Vehicle speed: actual: 4 km/h
7098 - Supply Voltage for Fuel Injector Group C
P2153 00 [00100110] - Short to GND
Mileage: 238957 km
Date: 2024.05.13
Time: 10:35:34
Engine RPM: 811.00 /min
Normed load value: 23.9 %
Vehicle speed: 4 km/h
Coolant temperature: 93 °C
Voltage terminal 30: 13.609 V
6161 - Internal Control Module
Mileage: 238957 km
Date: 2024.05.13
Time: 10:34:20
Engine RPM: 996.00 /min
10981 - Camshaft Position Sensor (G163)
P0346 00 [00100110] - Implausible Signal
Mileage: 238957 km
Date: 2024.05.13
Time: 10:35:16
Engine RPM: 1042.00 /min
Vehicle speed: 45 km/h
Intake air temperature: 54 °C
Engine speed: actual: 1024 /min
MAF_ENVD: 76.25882 mg/stroke
ENVD_CAM_IN_2: 1
Vehicle speed: actual: 45 km/h
Part No SW: 4G0 927 156 M HW: 0B5 927 156 F
Component: 0B5 30TFSIRdW H10 0024
Revision: --H10--- Serial number: 0000000785 CVN: 0000744E
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 363525BFF8CF0B5ABDF-8062
10617 - Valve for Transmission Fluid Cooler
P2753 00 [00101111] - Open Circuit
Mileage: 238826 km
Date: 2024.05.09
Time: 11:12:46
Engine RPM: 1255 /min
Transmission input speed: 1255 /min
Transmission output speed: 224 /min
Engine torque: -16 Nm
ATF temperature: 68 °C
Accelerator pedal position: 0.0 %
Clutch status: Kupplung 1 kann Moment übertragen
Voltage terminal 30: 14.100 V
Transmission oil cooler valve: Open
ATF temperature: 69 °C
8448 - Implausible Data Received from Engine Control Module
U0401 00 [00100111] - -
Mileage: 238957 km
Date: 2024.05.13
Time: 10:34:21
Engine RPM: 1050 /min
Transmission input speed: 1050 /min
Transmission output speed: 252 /min
Engine torque: -36 Nm
ATF temperature: 74 °C
Clutch status: Kupplung 2 kann Moment übertragen
Voltage terminal 30: 13.000 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.971 V
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 HW: 4G0 907 379
Component: ESP PREMIUM H08 0190
Coding: 44A687002265E100DB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
VCID: 6E85CDDFC01F739AB5F-803A
0674 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[ComScl_PDU_LH_EPS_02_Timeout]
Reset counter: 177
Mileage: 238921 km
Date: 2024.05.11
Time: 10:50:48
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 06
Bit Info 4: 1F
F-Path: 00
F-Type: DA
Uz: B4
0469 - Function Restricted due to Missing Message(s)
[ComScl_PDU_LH_EPS_03_Timeout]
Reset counter: 177
Mileage: 238921 km
Date: 2024.05.11
Time: 10:50:48
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 06
Bit Info 4: 1F
F-Path: 00
F-Type: DB
Uz: B4
0787 - Function Restriction due to Implausible Message(s)
U1112 00 [10001001] - -
[SCL_MO_Motormomente_Invalid]
Reset counter: 138
Mileage: 238957 km
Date: 2024.05.13
Time: 10:34:20
VzRef: 22
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: EA
Uz: B3
Part No SW: 4H0 907 064 AP HW: 4H0 907 064 AP
Component: BCM2 2.0 H24 0217
Coding: 05B82F00000000000000
VCID: 77ABE8BBBFC53252669-8022
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000097450009
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0056
Serial number: 06051100040574
Coding: 6621007824
ASAM Dataset: EV_AirCondiComfoUDS 002029
VCID: 270BF8FB2F6562D2369-8072
0379 - Supply Voltage Terminal 30 for Coolant Pump
B11D5 01 [00001001] - Electrical Failure
Fault Frequency: 12
Reset counter: 137
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:11
Voltage terminal 30: 14.04 V
Outside temperature: 42.0 °C
Inside temperature: 25.57 °C
Part No SW: 4H0 907 063 N HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0092
Revision: 20012002 Serial number: 00000001044197
Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100
VCID: 33331CABEB3D1E729A1-8066
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels:
1KX-955-119.CLB
Component: WWS57X 110404 H35 0051
Serial number: 110407090850
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels:
8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11418017
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 22 04 2011 00000235
Component: AQ_Hum_Sensor H02 0002
Serial number: 5228C6A5000000000001
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 122
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 J HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0032
Revision: 11001001 Serial number: 55901107004778
Coding: 300306
Shop #: WSC 00097 210 98728
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 392F2E83C9D1E42250D-806C
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG002BRPH Dataset Number: 4G0909602G
0009
Coding: 30323436313330303631554A305234473053
Serial number: 3575HRB404T0HM766GDR
Serial number: 3585HRB405H0H0LUC8R2
Serial number: 3515JRB405D0H4DU9P4N
Serial number: 3525JRB405F0G944N0G$
Serial number: 3554VRB40630GR36HOS5
Serial number: 3564VRB405D0GR36IHD.
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110505000939
Coding: 000034
VCID: 303913A71A2B256AE73-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Part No SW: 4G8 920 981 A HW: 4G8 920 981 A
Component: TBenGb H34 0312
Revision: 19100074 Serial number: 658020411593026
Coding: 33A709000B012600010000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 313F16A311A12C62E8D-8064
16776978 - Function Restricted due to Missing Message(s)
[LH_EPS_01 keine Kommunikation]
Reset counter: 177
Mileage: 238921 km
Date: 2024.05.11
Time: 10:50:48
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000141378
Coding: 00CD073000
GVL: FDA1E848DEE2600D00
ROD: EV_GatewUDS_AU57.rod
VCID: 303913A71AAB256AE73-8064
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650387009
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11130001538021200181
4906 - Power Steering Control Module
U101D 00 [00001000] - No Communication
Reset counter: 177
Mileage: 238921 km
Date: 2024.05.11
Time: 10:50:47
Voltage terminal 30: 13.6 V
Voltage terminal 15: 13.8 V
Control Module temperature: 62 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0056
Serial number: 06051100040012
Coding: 02
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
VCID: 2F3B10DB07953A92FE9-807A
0026 - Motor for Rear Left Upper Body Vent
B10D3 21 [00001001] - Signal Amplitude Too Low
Fault Frequency: 19
Reset counter: 138
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:11
Voltage terminal 30: 14.19 V
Left Rear Upper Body Vent Motor-Act.val.: 10980
Left Rear Upper Body Vent Motor-Target value: 10980
Left Rear Upper Body Vent Motor-Stop open: 11400
Left Rear Upper Body Vent Motor-Stop closed: 10000
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00000006129999
Coding: 00781B0000006001000001010101102030303232203232
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200UA850
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D070AD30D994882CC5-8078
Part No SW: 4G8 959 793 C HW: 4G8 959 793 A
Component: TSG FA H04 0210
Coding: 011F16205E01628002080002
Shop #: WSC 02312 785 00200
VCID: 40D94367AA8BB5EA173-8014
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Frequency: 18
Reset counter: 178
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:08
Fault Status: 00100111
Fault Frequency: 29
Reset counter: 178
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:08
02116 - Mirror Adjusting Motor
Fault Frequency: 49
Reset counter: 178
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:08
Fault Status: 01100111
Fault Frequency: 26
Reset counter: 138
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:08
02117 - Motor for Mirror Folding
Fault Frequency: 51
Reset counter: 178
Fault Frequency: 34
Reset counter: 138
Part No SW: 4G0 909 144 L HW: 4G0 909 144 F
Component: RCEPS H32 0010
Revision: 00001000 Serial number: 0001043439
Coding: 101000010100
Shop #: WSC 00078 790 12345
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D19AF14A7177A917-8066
1052420 - Internal Control Module Memory Check Sum Error
B2000 49 [10001001] - Internal Electronic Failure
[Unplausibler Signalverlauf Motortemperatursensor (zu hoher
Temperaturgradient)]
Mileage: 236702 km
Date: 2024.02.29
Time: 02:49:36
Write only channel
Revision: 00002001 Serial number: 0149428872
Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
014 - Defective
Fault Status: 01101110
Reset counter: 122
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:12
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
VCID: 3FDB409BD775CA126E9-806A
Reset counter: 164
Mileage: 238562 km
Date: 2024.05.03
Time: 16:51:12
Reset counter: 164
Mileage: 238562 km
Date: 2024.05.03
Time: 16:51:12
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000070722
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D01CF3C775FBA297-807E
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Reset counter: 138
Mileage: 238957 km
Date: 2024.05.13
Time: 10:34:20
Voltage terminal 30: 14.1 V
Internal Fault ID: 188
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: Dynamic
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 110502-0004-033
Coding: 0000020000020000
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
266752 - Control module not coded
U1013 00 [10001001] - -
[Steuergeraet nicht codiert]
Reset counter: 122
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:11
530180 - Local Data Bus
U10BA 00 [10001001] - No Communication
Fault Frequency: 30
Reset counter: 138
Mileage: 238481 km
Date: 2024.05.02
Time: 15:08:11
Part No SW: 4G0 035 056 A HW: 4G0 035 056
Component: Radio U STD H52 0050
Revision: AB001007 Serial number: 051EY0B7516476
Coding: 010003020100000001
VCID: 1F1BE01B77B5AA124E9-804A
Part No SW: 4G0 035 670 B HW: 4G0 035 670
Component: H-BNT-EU H46 0239
Revision: -------- Serial number: 428EX0B7514227
Coding: 050101000003E1EF45108B3E000000030000010000000000
VCID: 221DE9EF44C787FA617-8076
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300QPJ1
Subsystem 3 - Part No SW: 4G2 919 612 L HW: 4G2 919 612 L
Component: E380 BDT C7 H08 0120
Serial number: 90349KDT0007U
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F14204001628002080002
VCID: 42DD496FA487A7FA017-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J14F0S1
Coding: 1020004
VCID: 2517F2F359E970C2045-8070
Component: TSG HR H03 0210
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Revision: -------- Serial number: 262130025421000 Dataset Number: 4G0909547A
0023
Coding: 64040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 6597B2F315E9B0C2C45-8030
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Dataset Number: 4G0909614A 0010
Coding: 00060000031F030000030800424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FBBD0DBC7157A92BE9-803A
12583955 - Function Restriction due to Implausible Message(s)
U1112 00 [00001000] - -
Reset counter: 177
Mileage: 238924 km
Date: 2024.05.11
Time: 10:59:22
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
Dataset Number: 4G0909615A 0010
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B9D3A7DA2B656AA73-8024
Reset counter: 177
Mileage: 238924 km
Date: 2024.05.11
Time: 10:59:22
End----------(Elapsed Time: 02:15, VBatt start/end: 14.2V/14.3V)-----------
Based on the fault codes in that ECU, it's terminally ill. Is there any back-story here? Flooded? Hit by lightning? Jumper cables reverse-connected?
coconutaudi
C?ID=345326
No flood, reverse jumper cable. Not sure about lighting. One thing was noticeable that is the lambda circuits always had intermittent malfunction but the lambda fault codes always erasable. Maybe its too old? 14 years old car.
Ziddywerks
Northern NJ USA
C?ID=208579
ECM reflash or replace is the only option.
coconutaudi
C?ID=345326
After you kind people helped me confirmed that the problem was definitely with the ECU, my mechanic sent it out to the ECU guys for repair and true enough there were two burnt spots on the circuit board. They were able to replaced the burnt components but unfortunately I don't know what they were specifically. I think the must be related to the injector circuit as stated in the DTCs. The car is running good again. I was lucky to be able to get the ecu fixed. Thanks guys.
