2015 Q5 08-Auto HVAC not redirecting
Mrclopec
Nipomo, CA
C?ID=149231
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01190920141164
Coding: 3621228080
Shop #: WSC 06335 000 00000
VCID: 77FDC0B9C6CD2C87C9-8023
Checked 8k-08.lbl and the AQ control module should initiate a redirect but it doesnt.
VCDS 15.7.1 Dataversion 20150904
AIB Wolfgang
I think there is something wrong with the installation.
Labels: None ! And no redirecting fail.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The above scan was NOT done with 15.7.1, feel free to post a fresh and complete scan...
... Or VCDS was somewhat confused.
Christopher, are you running VCDS in a VM? ;)
Mrclopec
Nipomo, CA
C?ID=149231
Holy Cow! Okay, so here I go with breaking cardinal rule #1 and not posting an Autoscan. Alright! Behind the shed with me!
1. Yes Uwe, I am on a VM. Parallels 10.0.1 with Win7.
2. It is true that that little excerpt I posted above was not from a current, today, right now, Autoscan. I was in a hurry, sorry. I merely posted it to show which HVAC module I was referring to.
2. 08-Auto HVAC is not redirecting.
Thursday,15,October,2015,08:33:41:00104
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(Parallels)
VCDS Version 15.7.1.0
Data version: 20150904
VIN: WA1WMBFP6FAXXXXXX   License Plate: XXXXXXX
Mileage: 22280km-13844mi   Repair Order:
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 36 3C 42 44 46 47 52
          53 56 5C 5F 62 69 6C 6D 72 AC
VIN: WA1WMBFP6FAXXXXXX   Mileage: 22280km-13844miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CPNB)       Labels: 059-907-401-V2.clb
   Part No SW: 8K5 907 401 S    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0001
   Revision: 58H14---
   Coding: 2A2A4012057603050000
   Shop #: WSC 55440 001 1048576
   ASAM Dataset: EV_ECM30TDI0118K5907401S 001003
   ROD: EV_ECM30TDI0118K5907401S.rod
   VCID: 408F6B65DB83AB3E1D-8015
8812 - Cylinder 2 Internal Pressure Sensor
          P13D1 00 [047] - Short to Plus
                    Fault Frequency: 9
                    Mileage: 21507 km
                    Date: 2015.09.11
                    Time: 14:44:45
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H19 1003
   Revision: --H19---
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 4B954C49E2C57866F8-801F
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 23AD1C03
   VCID: 11299E21C86912B6C2-8045
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0DA54040000000000000
   VCID: 081FB345BB33537E15-805D
   Coding: 3621228080
   VCID: 77FDC0B9C6CD2C866C-8023
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000893404802
   Coding: 26000091867CAFF21100488300003D0D4F9CE708A6090221000008004000010200040034000000
   VCID: 7AFBD98DF5DF31EE13-802F
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140827  H12 0050
   Coding: 01DD13
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0100
   Coding: 008157
   VCID: 377D00B9864DEC86AC-8063
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED12HYXB
   Coding: 303334313432383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4C974F55E7CB7F5EF1-8019
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R140000GX4R
   Serial number: 6334MSME480E2C00D
   Serial number: 6344MSME4879646DV
   Serial number: 6352QSME5C460456J
   Serial number: 6362QSME4747316EO
   Serial number: 63732SME40443466U
   Serial number: 63832SME64424D44+
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NIG000A4
   Coding: 0000FF
   VCID: 44876775C79BB71E39-8011
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 B    HW: 8R0 920 982 B
   Component: KOMBIINSTR.   H35 0564
   Revision: 00400000    Serial number: ZDC27399F
   Coding: 8BBF22006F01D705020000
   VCID: 3A7B198DB55FF1EE53-806F
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z149050B6E
   Coding: 80CF07FF00
   VCID: 4C974F55EFCB7F5EF1-8019
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 020100
   VCID: 39790681B059FAF65A-806D
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02019164747464545425363E00
   Shop #: WSC 06325 000 00000
   VCID: 7CF7DF95FFEB0FDE01-8029
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000114744385
   Coding: 01581B00000000000000
   VCID: 428B616DDD8FB92E0B-8017
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0346139735
   Coding: 010221
   VCID: 3F8D6899A67DD4C664-806B
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000116313843
   Coding: 011D13215E00440004
   VCID: 4FAD58591EDD444694-801B
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0030925634
   Coding: 010001010001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X.rod
   Revision: 00002001    Serial number: 0347056755
   Coding: 0126063A20FA709584A0053600040047
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813034061406
   VCID: 2D5122D174115656C6-8079
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000117929946
   VCID: 4E93455D19D74D4E9F-801B
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 30000000264223
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7B198DBD5FF1EE53-806F
   Revision: AB001007    Serial number: 156I20E8065591
   Coding: 020007010000000001
   VCID: 2447C7F527DB971E19-8071
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600213910000FA
   Coding: 0132104
   VCID: 377D00B9464DEC86AC-8063
   Part No SW: 8R1 035 746 F    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0812
   Revision: --------    Serial number: 204I10E7679622
   Coding: 160200060005E9EF7D02AF5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  5950
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000117821679
   Coding: 010C13204000240004
   VCID: 46837D7DF1A7850E27-8013
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00008200724693
   Coding: 0200000000000000
   VCID: 36630DBD8147158EB7-8063
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J47A2YG
   Coding: 1031010
   VCID: 346737B5573B079E89-8061
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D711291A471C6D676-8069
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 142460205
   ROD: EV_RDCMA00100.rod
   VCID: 2D5122D17C115656C6-8079
End-------------------------(Elapsed Time: 04:50)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The redirect data exists, but the file it should redirect to doesn't. This is - at this point - intentional, as the file in question hasn't been created just yet.
Mrclopec
Nipomo, CA
C?ID=149231
Completely makes sense. Having a Label file intentionally redirect to a non existent file was just making my mind throw an error code. Thank you for the clarification.
That happens at times when new files are being worked on, or when someone has already developed a file in another language like German or Danish, but there's no English version yet.
Hi Christopher,
Those KLIMA 3 ZONEN modules are pretty common in B8s so please let us know if you were looking for something specific.
Internal ref: FS#762
Mrclopec
Nipomo, CA
C?ID=149231
Will do, Dana. Thank you. :-)
