ABS annoying
caliche1275
Columbia
C?ID=160533
Hi,
Friends have a problem with the ABS system Audi brand me the wheel sensors
respectively, check wiring remplace, the scan ist.
:thanks::confused:
AUTO-SCAN
VCDS Version: Release 15.7.1 Running on Windows 7 x86
Data version: 20150904
Friday,13,March,2015,15:37:18:49232
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72 77
VIN: WAUZZZ8P09A066362   Mileage: 69810km-43377miles
Address 01: Engine (CDA)       Labels: 06J-907-115-CDA.clb
   Part No SW: 8P7 907 115 E    HW: 8P0 907 115 Q
   Component: 1.8l R4/4V TFSI     0020
   Revision: AAH03---    Serial number: AUX7Z0H9FNT03M
   Coding: 0103001024070060
   Shop #: WSC 06314 000 00000
   VCID: 3B7516777AA5F0E648-806E
8 Faults Found:
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 29
                    Mileage: 69446 km
                    Date: 2015.10.02
                    Time: 16:26:22
                    RPM: 1073 /min
                    Load: 23.1 %
                    Temperature: 99.0°C
                    Temperature: 60.0°C
                    Absolute Pres.: 740.0 mbar
                    Voltage: 13.208 V
006469 - Control Module 1 for Cooling Fan
               P1945 - 000 - Output Short Circuit - Intermittent
                    Mileage: 69734 km
                    Date: 2015.10.11
                    Time: 23:25:15
                    RPM: 765 /min
                    Load: 12.2 %
                    Temperature: 102.0°C
                    Temperature: 53.0°C
                    Voltage: 13.208 V
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow - Intermittent
                    Mileage: 69771 km
                    Date: 2015.10.12
                    Time: 19:40:47
                    RPM: 752 /min
                    Load: 13.3 %
                    Temperature: 92.0°C
                    Temperature: 37.0°C
                    Voltage: 13.335 V
               U1017 - 015 -  - Intermittent
                    Fault Status: 00101111
                    Fault Frequency: 14
                    Mileage: 69535 km
                    Date: 2015.10.10
                    Time: 15:25:45
                    RPM: 1698 /min
                    Load: 51.0 %
                    Speed: 51.0 km/h
                    Temperature: 90.0°C
                    Temperature: 26.0°C
                    Voltage: 13.970 V
               U1017 - 007 -  - Intermittent
                    Fault Status: 00100111
                    Mileage: 69723 km
                    Date: 2015.10.11
                    Time: 22:59:00
                    RPM: 1263 /min
                    Load: 11.4 %
                    Speed: 21.0 km/h
                    Temperature: 77.0°C
                    Temperature: 44.0°C
                    Voltage: 13.716 V
006480 - Radiator Fan (V7)
               P1950 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 69734 km
                    Date: 2015.10.11
                    Time: 23:32:38
                    RPM: 760 /min
                    Load: 11.4 %
                    Temperature: 103.0°C
                    Temperature: 63.0°C
                    Voltage: 13.208 V
000564 - Boost Pressure Regulation
               P0234 - 000 - Limit Exceeded (Overboost Condition)
                    Mileage: 69801 km
                    Date: 2015.10.14
                    Time: 11:49:46
                    RPM: 3729 /min
                    Load: 100.0 %
                    Speed: 64.0 km/h
                    Temperature: 90.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 730.0 mbar
                    Voltage: 13.716 V
004688 - Fuel Level too Low
               P1250 - 000 -
                    Mileage: 69801 km
                    Date: 2015.10.14
                    Time: 11:49:47
                    RPM: 4017 /min
                    Load: 63.1 %
                    Speed: 69.0 km/h
                    Temperature: 90.0°C
                    Temperature: 25.0°C
                    Voltage: 13.716 V
Readiness: 0010 0000
   Part No SW: 0AM 300 045 A    HW: 0AM 927 769 D
   Component: GSG DSG AG7     402 0605
   Revision:    40024    Serial number: 00001004090284
   Shop #: WSC 04940 001 00001
   VCID: 2B5526378AC56066D8-807E
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 114240120A280000880E02EA501B0041B900
   VCID: 75E1C04FDC0166967E-8020
                    Fault Status: 00100011
                    Reset counter: 50
                    Mileage: 69614 km
                    Date: 2015.10.11
                    Time: 11:20:14
                    Count: 17472
                    Count: 32768
                    Count: 12800
                    Count: 75
                    Count: 49188
                    Count: 63458
                    Count: 65280
                    Count: 1536
                    Reset counter: 50
                    Mileage: 69535 km
                    Date: 2015.10.10
                    Time: 15:25:44
                    Count: 1088
                    Count: 32768
                    Count: 4608
                    Count: 49
                    Count: 50994
                    Count: 258
                    Fault Frequency: 11
                    Reset counter: 15
                    Mileage: 69467 km
                    Date: 2015.10.08
                    Time: 05:38:07
                    Count: 16448
                    Count: 12800
                    Count: 73
                    Count: 51519
                    Count: 255
                    Count: 1024
   Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
   Component: KlimavollautomatH09 0100
   Revision: 000679      Serial number: 8P0820043BG
   VCID: 72EBFB536D6F71AE5B-8026
Address 09: Cent. Elect.        Labels: 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000009056315
   Coding: E18E1F8190141380EF00000A0000000000094E056406040364A000000000
   Shop #: WSC 06314 000 08192
   VCID: 489F79BB3B73AB7ED5-801C
   Subsystem 1 - Part No: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 06314
   Coding: 00150573
   Shop #: WSC 06314
Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 303142383038303031314A55304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 49997CBFE8795276CA-801C
   Serial number: 3572DRB400007E6110FU
   Serial number: 3582DRB400007E64A1D%
   Serial number: 35128RB400004639BFD-
   Serial number: 35228RB40000463963EL
   Serial number: 35547RB40000472EE1AW
   Serial number: 35647RB40000472E152G
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0014112
   VCID: 4189649F18499A3612-8014
   Component: E0221           H02 0030
   Part No SW: 8P0 920 931 T    HW: 8P0 920 931 T
   Component: KOMBIINSTR. VDO H18 0830
   Revision: D0H18006    Serial number: 2249H006023855
   Coding: 0000128
   Shop #: WSC 13107 210 10234
   VCID: 44876D8B075B8F1E39-8010
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400
   Coding: ED817F06100602002102
   VCID: 377D0A47468DD486AC-8062
   Revision: D0H18006    Serial number: AUX7Z0H9FNT03M
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000148
   VCID: 43856E970255882600-8016
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 233    2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A5B2333853F796E23-807E
                    Fault Status: 00101101
                    Fault Frequency: 25
                    Reset counter: 65
                    Mileage: 69806 km
                    Date: 2015.10.14
                    Time: 11:57:21
                    Voltage: 13.75 V
                        DU
                    Temperature: 42.0°C
                    RPM: 1229 /min
                    Speed: 46.0 km/h
                    Speed: 47.0 km/h
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 J
   Component:    KSG          H11 0080
   Coding: 1980200002186D0985054C8FC677
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H04 0020
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674803019340
   VCID: 3561004F5C812696BE-8060
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000148
   Part No: 8P0 907 357 J
   Component: Dynamische LWR  H01 0020
   Coding: 0000013
                    Reset counter: 55
                    Mileage: 69464 km
                    Date: 2015.10.08
                    Time: 05:38:10
Address 56: Radio        Labels: None
   Part No SW: 8P0 035 195 N    HW: 8P0 035 195 N
   Component: R Symphony2+    H05 0270
   Revision: 00H05000    Serial number: AUZ1Z4H7183681
   Coding: 0730212
   VCID: 3D71186F64B1FED676-8068
00857 - CD Changer Unit (R41)
                    Reset counter: 56
                    Mileage: 69812 km
                    Date: 2015.10.14
                    Time: 15:15:29
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000144
   VCID: 428B6B931D4F812E0B-8016
   Part No SW: 8P0 862 335 S    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0550
   Revision: 00000000    Serial number: 00000005047274
   Coding: 0001295
   VCID: 468377833167BD0E27-8012
End-------------------------(Elapsed Time: 02:17)--------------------------
