- Feb 20, 2015
- 11
- 2
- Peterborough, UK
- C?ID=236259
Hi, guys this is my first post here on the forum, I am looking for some advice on an issue with an intermittent fault 28823 No communications with airbag control module (U0151) code that has appeared ever since my local VW dealership changed my complete engine, cat converter, pre-cat down pipe, fuel injectors, pre & post cat lambda sensors, fuel filter (these were changed because the dealer used the wrong oil grade in my engine and seriously ?#?#?# it up!). The fault code has appeared under the engine module and no other fault codes in any other module are present. It appears to be intermittent and my initial thoughts are a connection issue?
First the auto-scan data:-
Tuesday,13,October,2015,14:17:12:64326
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVWZZZ1KZ8Wxxxxxx License Plate:
Mileage: 54950km-34144mi Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ8W169542 Mileage: 54950km-34144miles
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 AS HW: 03C 906 024 AS
Component: MARELLI 4HV 0917
Revision: --H06--- Serial number: VWX7Z0GN3N68QU
Coding: 0004071
Shop #: WSC 00000 028 00001
VCID: 6FC3201D7E664A46B4-803A
28823 - No Communications with Airbag Control Module
U0151 - 000 - - Intermittent
Fault Status: 00110000
Reset counter: 23
Mileage: 54501 km
Date: 2000.01.01
Time: 15:14:48
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0019073
Shop #: WSC 01279 785 00200
VCID: 73CB2C6D124E6EA650-8026
Part No SW: 1K0 820 047 HB HW: 1K0 820 047 HB
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
VCID: 6BFB340D4A7EB66698-803E
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007667786
Coding: 008D0F2700041500471400001400000000087B075C000100000000000000
Shop #: WSC 00000 785 00200
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 081107 021 0501
Coding: 00038805
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1KT2Y6
Coding: 0013112
Shop #: WSC 01269 785 00200
VCID: 3D5FCA55648AE8D676-8068
Subsystem 1 - Serial number: 6332MSME297438127
Subsystem 2 - Serial number: 6342MSME333577459
Subsystem 3 - Serial number: 6352QSME44797733L
Subsystem 4 - Serial number: 6362QSME3D731617J
Part No SW: 1K0 953 549 BB HW: 1K0 953 549 BB
Component: Lenksäulenmodul 636 0070
Coding: 0000002
Part No SW: 1K0 920 954 K HW: 1K0 920 954 K
Revision: V0002000 Serial number: VWX7Z0GN3N68QU
Coding: 0003403
Shop #: WSC 00225 210 99164
VCID: 3449EF7157C0299E89-8060
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K077258301
Coding: E9801F060002020003
VCID: 3041E361A3D815BEED-8064
Component: IMMO VDD 1212
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1204
Coding: 0000564
VCID: 3851DB414BA8CDFEA5-806C
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.067 H08 1901
VCID: 364DD57941BC3B8EB7-8062
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 80C802087F2D8405485B038010CC
Shop #: WSC 00225 210 91070
VCID: 002173A153F8453E5D-8054
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000564
VCID: 3957DE4570A2D4F65A-806C
Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
Component: Radio BVX 037 0048
Revision: 00037000 Serial number: VWZ1Z2G6326202
Coding: 0020400
VCID: 68F14B015B889D7EF5-803C
End-------------------------(Elapsed Time: 00:59)--------------------------
