Flat Battery Causing Issues
Righteouness
Australia
C?ID=434582
Hey all,
BKD TDI MK5 Jetta here.
I recently had a flat battery due to a potential parasitic drain. After recharging battery and changing fuses, it's created some other issues that I may have done during my multi-meter testing. None of these items were touched either except for the battery.
After jump starting the car to drive back home and charge overnight, I had the engine light appear. This is mainly to three new issues: 012547 - Motor for Intake Manifold Flap (V157),
01314 - Engine Control Module (did my multi-meter do this?) and 28775 - No Communication with Gear Selector Module as listed below. I changed fuses for everything and the problems persist. I went for a short drive and experienced no issues. Do I need to keep driving to get rid of these issues perhaps for the computer to relearn after disconnecting the battery?
Wednesday,08,May,2024,15:04:39:52175
VCDS Version: 24.5.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVWZZZ1KZ8M038523   License Plate:
Mileage: 331910km-206239mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76
VIN: WVWZZZ1KZ8M038523   Mileage: 331910km-206239miles
15-Airbags -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 021 PP    HW: 03G 906 021 AN
   Component: R4 2,0L EDC G000AG  1264
   Revision: --H07---    Serial number: VWX7Z0G724M0YP
   Coding: 0000078
   Shop #: WSC 00066 000 00000
   VCID: FCAA1E8AFAE75B1A8BB-80A8
   VINID: 9E69EAAAA05BA887400C81420C509461FC
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 122
                    Mileage: 327479 km
                    Time: 13:31:30
                    RPM: 1050 /min
                    Load: 23.9 %
                    Voltage: 13.83 V
                    Bin. Bits: 00101000
                    Temperature: 88.2�C
                    Duty Cycle: 67.6 %
               P3103 - 000 - Malfunction - Intermittent
                    Voltage: 5.85 V
                    Bin. Bits: 11001010
                    Torque: 0.0 Nm
                    Torque: 0.0 Nm
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 044 F    HW: 02E 927 770 AD
   Component: GSG DSG         082 1402
   Revision: 04808020    Serial number: 00000902060147
   Shop #: WSC 04940 001 00001
   VCID: 9862221AEE9F973A0F3-80CC
            U0103 - 000 -  - Intermittent
                    Fault Frequency: 255
                    Mileage: 331913 km
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Revision: 00H11001
   Coding: 0006786
   VCID: F3B835B6D7B91462DA1-80A6
   Part No SW: 1K0 907 044 BR    HW: 1K0 907 044 BR
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: F8A2029ACEDF773AEF3-80AC
   Revision: 00H54000    Serial number: 00000000710502
   Coding: E7030E2700041500C70000000F00000000095D0364000100000000000000
   Shop #: WSC 00066 123 12345
   VCID: F1B43FBEADA5267228D-80A4
   Component: Wischer 220807 020  0501
   Coding: 00040853
   Shop #: WSC 00066
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     170707 020  0105
   Coding: 00471077
   Shop #: WSC 00066
00156 - Control Circuit for Windshield Washer Pump
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 206
                    Mileage: 331913 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.50 V
00924 - Relay for Headlamp Cleaning System (J39)
                    Reset counter: 206
                    Mileage: 331913 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
                    Reset counter: 246
                    Mileage: 331913 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.65 V
                    Reset counter: 246
                    Mileage: 331913 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.65 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 245
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.15 V
   Component: 2T AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1CTE4N
   Coding: 0012884
   VCID: BD2CD38EA17D9212FC5-80E8
   Subsystem 1 - Serial number: 6332MSME155804262
   Subsystem 2 - Serial number: 6342MSME155A3C58L
   Subsystem 3 - Serial number: 6351HSME0F3611799
   Subsystem 4 - Serial number: 6361HSME0F161D08C
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012021
   VCID: 81546F7E9D0536F2D8D-80D4
   Part No SW: 1K0 920 874 B    HW: 1K0 920 874 B
   Component: KOMBIINSTRUMENT 3HL 1216
   Revision: V0002000    Serial number: VWX7Z0G724M0YP
   Coding: 0023103
   Shop #: WSC 13671 002 1048576
   VCID: AC0AEECA4A070B9A5BB-80F8
                    Fault Frequency: 25
                    Reset counter: 245
                    Mileage: 331871 km
                    Time: 19:56:03
                    Reset counter: 245
                    Mileage: 331871 km
                    Time: 20:05:10
                    Reset counter: 246
                    Mileage: 331913 km
                    Time: 00:11:25
   Revision:   H07 01    Serial number: 150707F1001552
   Coding: ED817F0E0002021003
   VCID: B032FABA662F6F7A673-80E4
                    Fault Status: 00110100
                    Reset counter: 246
                    Mileage: 331913 km
                    Time: 00:33:58
                    Reset counter: 246
                    Mileage: 331913 km
                    Time: 00:11:26
                    Reset counter: 246
                    Mileage: 331913 km
                    Time: 00:11:29
                    Reset counter: 245
   Component: IMMO            3HL 1216
01176 - Key
                    Mileage: 330021 km
                    Time: 16:42:42
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1126
   Revision: 11006001    Serial number: 00000527768723
   Coding: 0000692
   Shop #: WSC 00046 412 00000
   VCID: BC2ADE8ABA679B1ACBB-80E8
                    Reset counter: 245
                    Mileage: 331871 km
                    Fault Status: 01100101
                    Fault Frequency: 27
                    Reset counter: 206
                    Mileage: 327113 km
00096 - Drivers Door Central Locking (Safe) Motor (V161)
                    Fault Status: 00101100
                    Reset counter: 246
                    Fault Status: 00111000
                    Fault Frequency: 51
                    Reset counter: 246
                    Mileage: 327181 km
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: B63ECCA2844B414A3DF-80E2
   Coding: 80910A0001064C7F2D0284056008DF0380FC00
   VCID: 83586576871924E2CA1-80D6
                    Fault Status: 00110010
                    Reset counter: 245
                    Mileage: 331871 km
                    Time: 19:11:57
00830 - Convertible Top Control Module (J256)
                    Reset counter: 206
                    Mileage: 331913 km
                    Time: 22:36:19
                    Reset counter: 246
                    Mileage: 331913 km
                    Time: 00:11:29
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1134
   Revision: 31008001    Serial number: 00000023078517
   Coding: 0000948
                    Reset counter: 245
                    Mileage: 331871 km
00097 - Front Passengers Central Locking (Safe) Motor (V162)
                    Reset counter: 246
                    Fault Frequency: 180
                    Reset counter: 246
                    Mileage: 327145 km
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: F4BA36AAD2B7135AC3B-80A0
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AD    HW: 1K0 035 186 AD
   Component: Radio BVX       035 0047
   Revision: 00035000    Serial number: VWZ1Z2G6300293
   Coding: 0040400
   VCID: E88252DA9E7FE7BA7F3-80BC
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000002031871
   Coding: 0000144
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000002027530
   Coding: 0000144
   VCID: BE2ED482AC7B890AE5F-80EA
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 12 Einparkhilfe     0101
   VCID: AD0CE3CE711D02924C5-80F8
End----------(Elapsed Time: 01:50, VBatt start/end: 12.2V/12.3V)-----------
Most of these faults are intermittent. Having a slew of such faults is not unusual when the battery goes flat. Please clear them and set's see what comes back.
Righteouness
Australia
C?ID=434582
I had to manually clear codes in each module for it to properly clear. No issues except for the door latches in both passenger and driver side that may be causing battery drainage. Cheap Chinese knock-offs... do I try Amazon for the door lock latches or are they the same garbage?
Righteouness
Australia
C?ID=434582
most likely same "garbage". Try to find used genuine (ebay?). Unfortuneatley, that has it's
own set of risks as well.
Well that's a hiccup and a half. Maybe I'll have to treat the car like an iPhone and have to recharge it every now and then, lol...
Righteouness
Australia
C?ID=434582
I had a wiper motor go bad. I replaced it with a genuine part (same part number) from used a MK6 Golf to a MK5 Jetta. It worked for 2 weeks and then it stopped working again. Is this a CAN-bus issue? I changed fuses and nothing worked. The window wiper pumps work but nothing. Changed headlight settings and nothing.
What's the OBD say?
Righteouness
Australia
C?ID=434582
What's the OBD say?
I haven’t scanned it yet but after some research, I have a huge suspicion that the BCM has partly failed. My convenience system is having some issues. My rain sensor stop working at first. Then my wipers later. My rear taillight is flickering and sometimes my driver side window doesn’t AUTO down/up even after resetting it. Now my wipers don’t work and my battery parasitic drain is pointing me to the BCM as others have experienced this issue before. I don’t know any other issue to resolve since the battery is in good condition (2.5 years old) with lots of highway driving and the wiper motor was replaced and stopped working some time later. This will be my last option before throwing it to the wreckers.
Righteouness
Australia
C?ID=434582
What's the OBD say?
If you were meaning to scan it with OBD 11, then I haven’t because I don’t own one. The scan I originally posted above was from VCDS for the issue at hand.
Neither actually.... it was just another way of asking what's the scan tell you....
ODB = On Board Diagnostic
So I was saying, why are you guessing instead of using the capabilities and diagnostics available to you?
Also, see @Uwe 's GIF
Righteouness
Australia
C?ID=434582
I see. So far, I’ve replaced the fuse and that didn’t help. I replaced the wiper motor and that worked for a week. The comfort features are intermittently working which leads me to the module that controls the comfort features in the BCM. There apparently is no relay for the wiper motor. A faulty BCM can also display parasitic battery drain. What other options am I missing? Because it’s left me guessing at this point.
Righteouness
Australia
C?ID=434582
Is anyone kind enough to assist me with swapping my current BCM coding into the new one? Anything is appreciated. I’m running out of options.
Westbury, UK
Please post an Auto-Scan made after you cleared all the intermittent faults so we can see what faults are "real" and help you - rather than us jumping to assumptions about the BCM.
Righteouness
Australia
C?ID=434582
I’ll have to do so after driving the car back as I needed to drop it off as my friends place during the rainy week.
Righteouness
Australia
C?ID=434582
Hi all,
I found some time to get the car back and auto-scan it. Just a recap. I installed a used window wiper motor and it failed after a week of use. I replaced the fuses with no success. Here's an auto-scan of the car:
Thursday,29,August,2024,18:39:49:52175
VCDS Version: 24.7.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WVWZZZ1KZ8M038523   License Plate: JETTA
Mileage: 337250km-209557mi   Repair Order:
VIN: WVWZZZ1KZ8M038523   Mileage: 337250km-209557miles
   Coding: 0000078
   VCID: FCAA1E8AFAE75B1A83B-80A8
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Fault Status: 01110000
                    Mileage: 333584 km
                    Time: 08:52:20
                    RPM: 882 /min
                    Voltage: 13.30 V
                    Bin. Bits: 00101011
                    Temperature: 8.1�C
                    Bin. Bits: 10110000
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -  - Intermittent
                    Mileage: 336954 km
                    Time: 09:58:18
                    RPM: 798 /min
                    Voltage: 14.14 V
                    Bin. Bits: 00101000
                    Temperature: 83.7�C
                    (no units): 0.0
005685 - Powertrain Data Bus
               P1635 - 000 - Missing Message from A/C Controller - Intermittent
                    Mileage: 336980 km
                    Time: 11:08:39
                    Voltage: 12.31 V
                    Bin. Bits: 00101000
                    Bin. Bits: 00000000
                    (no units): 16.0
                    Fault Frequency: 16
                    Mileage: 336990 km
                    Time: 18:02:23
                    RPM: 798 /min
                    Voltage: 13.91 V
                    Bin. Bits: 00101011
                    Temperature: 81.0�C
                    Duty Cycle: 9.7 %
   VCID: 9862221AEE9F973A073-80CC
   Revision: 00H11001
   Coding: 0006786
   VCID: F3B835B6D7B91462D21-80A6
   VCID: F8A2029ACEDF773AE73-80AC
   VCID: F1B43FBEADA5267220D-80A4
   Coding: 00471077
   Shop #: WSC 00066
   Subsystem 3 - Component: Fehler Lin-Slave 01
                    Reset counter: 99
                    Mileage: 337257 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
02071 - Local Databus
                    Reset counter: 99
                    Mileage: 337257 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
                    Reset counter: 99
                    Mileage: 337257 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
                    Reset counter: 99
                    Mileage: 337257 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
   Coding: 0012884
   VCID: BD2CD38EA17D9212F45-80E8
   Coding: 0012021
   VCID: 81546F7E9D0536F2D0D-80D4
   Coding: 0023103
   VCID: AC0AEECA4A070B9A53B-80F8
   VCID: B032FABA662F6F7A6F3-80E4
   Coding: 0000692
   VCID: BC2ADE8ABA679B1AC3B-80E8
   VCID: B63ECCA2844B414A35F-80E2
   VCID: 83586576871924E2C21-80D6
   Coding: 0000948
   Coding: 0000003
   VCID: F4BA36AAD2B7135ACBB-80A0
   Coding: 0040400
   VCID: E88252DA9E7FE7BA773-80BC
   Coding: 0000144
   Coding: 0000144
   VCID: BE2ED482AC7B890AEDF-80EA
   VCID: AD0CE3CE711D0292445-80F8
End----------(Elapsed Time: 01:50, VBatt start/end: 12.1V/12.1V)-----------
Righteouness
Australia
C?ID=434582
Which part of that are you struggling with? :confused:
I don't know how the window wipers would correlate to the Engine Control Module. Wouldn't the Body Control Module be the culprit? Happy for correction.
Where do you see the fault in Engine Control Module?
Hi all,
Rich (BB code):
   Coding: 00471077
   Shop #: WSC 00066
                    Reset counter: 99
                    Mileage: 337257 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
