MKV Jetta TDI LED Tail Coding
dconofrey
C?ID=178747
Hi all,
I could use some coding expertise. I've installed and wired the Chinese-made Hella LED tail lights with rear fog. Now I'm trying to achieve two things: turn off cold diagnostics for the now-defunct left reverse light and (more significantly) stop the outer rings of the tails from illuminating amber when I use the brakes. The outer rings do blink amber when the hazards or turn signals are used, but also when the brakes are used. I'd like the amber to be for blinkers only which, as I understand, is the correct, full-on "amber club" mode of operation.
Here is the CECM section of my current coding (ignore the license plate bulb warning - it needs replacing):
   Part No SW: 5K0 937 085 L    HW: 5K0 937 085 L
   Component: BCM PQ35 B++  111 0135
   Revision: BI111001
   Coding: 2D200B3F902F3EE4800A00042B00000401000086510085605C8020000000
   Shop #: WSC 00066 123 12345
   VCID: 3C59D568BF869DDE41-8068
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 14081  21  0512
   Coding: 009795
                    Fault Status: 00101010
                    Fault Frequency: 120
                    Reset counter: 211
                    Mileage: 75777 km
                    Date: 2015.06.03
                    Time: 07:37:47
                    Voltage: 13.90 V
                    Fault Status: 01101010
                    Reset counter: 190
                    Mileage: 82099 km
                    Date: 2015.10.11
                    Time: 00:15:01
                    Voltage: 11.75 V
Let me know if there's more you need to see and if there are any questions I can answer.
Many thanks for your time & effort!
dco
dconofrey
C?ID=178747
Wow, strange! Went I went back into the coding, it was as listed in the link you posted, not as listed in the VCDS log I pasted. Anyway, even with bytes 9-13 correctly set at 0A 00 00 0F 00, the amber-while-braking problem persists.
Revision: BI111001
Coding: 2D200B3F902F3EE4800A00000F00000401000082510085605C8020000000
Coding: 009795
Reset counter: 211
Mileage: 75777 km
Date: 2015.06.04
Time: 07:37:47
Voltage: 13.90 V
Reset counter: 190
Mileage: 82099 km
Date: 2015.10.12
Time: 00:15:01
Voltage: 11.75 V
01800 - Light Switch (E1)
Reset counter: 233
Mileage: 82099 km
Date: 2015.10.12
Time: 01:19:03
Term 15 Off
Voltage: 12.40 V
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Did you read whole post ?
There is coding for rear fog light as well.
dconofrey
C?ID=178747
Yup. So is the implication that correct coding of the rear fog will correct the amber-while-braking issue?
In trying to run down the checklist of coding changes, I've noticed that the bytes & bits I'm instructed to change for rear fog activation in no way correspond to mention of a rear fog option in VCDS. For instance, I have to set BYTE 03, BITS 1 & 2 both to 1 for rear fog operation (per the instructions), but that corresponds to sunroof comfort opening/closing on my controller:
https://www.icloud.com/sharedalbum/#B07GRMtznG9E9Jn
Jetta 97
C?ID=81680
Your car is Mk5 with only BCM , address-09.
The link I post is not good for your car, it is for car with BCM and CCM.
Sorry but I do not have solution for this .
dconofrey
C?ID=178747
No worries, I appreciate you trying. :)
