Skoda Octavia 2 2008 fault code 01271
Bashers
C?ID=41592
I have had Ross-Tech for some years now but have not used it to it full, having relied on much younger chaps to sort out my technical things. I currently have a Skoda where there is no heat coming into the cabin, an auto scan has revealed a fault code of P01271, Positioning motor for temperature flap ( V68 ). It seems a pretty easy job to change the motor, but I do not know how to initiate basic settings on the new unit, so it works?
Any advise is welcome
Bashers
DrPeter
16.4905° S, 151.7375° W
Hi,
Also there is no such thing as a P01271 code.... the 'P' is for powertrain.. the code you have is a 01271
- This code is on the Ross-Tech wiki page, and agreed, an Auto-Scan does help us to see the details of the fault code and vehicle.
01271 - Positioning Motor for Temperature Flap (V68)
Thanks,
drpeter
Bashers
C?ID=41592
Please find my auto scan ( hopefully )
Bashers
Tuesday,13,October,2015,12:32:05:47277
VCDS Version: 15.7.0.1
Data version: 20150729
VIN: TMBCB21Z482201349   License Plate: P60JWR
Mileage: 41920km-26047mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBCB21Z482201349   Mileage: 41920km-26047miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 EB    HW: Hardware No
   Component: MED9.5.10        00 0144
   Revision: 66H09---    Serial number: SKZ7Z0H4966459
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 67D62DA156D57906F7-8032
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
   Component: MABS MK70M          0104
   Revision: 00H32001
   Coding: 0016641
   Shop #: WSC 73430 790 08192
   VCID: 76E870E5017F908E7C-8022
   Part No SW: 1Z0 820 047 K    HW: 1Z0 820 047 K
   Component: Climatic PQ35   140 0909
   Revision: 00140009    Serial number: 00000000000000
   VCID: 3B7EA1D17ADD0DE643-806E
            000 -  -
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000005819269
   Coding: 008C0F030004140043110D000000000000087B075C000000000000000000
   VCID: 32608CF5AD97CCAE90-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 200608 022  0601
   Coding: 00055223
   Shop #: WSC 73430
                    Fault Status: 00101100
                    Reset counter: 111
                    Mileage: 41895 km
                    Voltage: 11.95 V
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1WS0BZ
   Coding: 0020788
   VCID: 3D7AAFC964C903D67D-8068
   Subsystem 1 - Serial number: 6332MSME3B3527215
   Subsystem 2 - Serial number: 6342MSME3B353528C
   Part No SW: 1K0 953 549 CA    HW: 1K0 953 549 CA
   Coding: 0000012
   VCID: 73EE49F1120D85A65B-8026
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1Z0 920 912 B    HW: 1Z0 920 912 B
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610057    Serial number: SKZ7Z0H4966459
   Coding: 0003401
   Shop #: WSC 23007 067 57207
   VCID: 346C8AED5783C29E82-8060
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K086100B81
   Coding: E9807F0E0002021303
   VCID: 356AB7E95CF9DB96B5-8060
   Component: IMMO            VD1 1610
   Part No SW: 1T0 959 701 H    HW: 1T0 959 701 H
   Component: Tuer-SG         006 1204
   Coding: 0000756
   VCID: 3C7CA2CD7FD30ADE4A-8068
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 67     2301
   Revision: 00H15000
   VCID: 2A5094958547846E28-807E
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 81801A085283007F3F04850540085F96907CA0
   VCID: 030E193142ADB5264B-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
   Part No SW: 1T0 959 702 H    HW: 1T0 959 702 H
   Coding: 0000756
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       020 0041
   Revision: 00020000    Serial number: SKZ7Z3H0097092
   Coding: 0000402
   VCID: 2E589885B9AFE84EF4-807A
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 3776BDE146F52986A7-8062
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012550
   VCID: 336E89F1528DC5A69B-8066
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End-------------------------(Elapsed Time: 01:57)--------------------------
Hello Ian,
I reply to your email I wouldn't expect a successful Basic Settings calibration until the repairs that caused the DTC are completed but VCDS should offer the following from a pull-down menu when you are connected to that controller: Potentiometer & Flap Alignment
Selecting that operation would enter group number 001 at which point you would click [Go!] followed by [ON/OFF/Next]. This page applies to the Golf based Climatic system in that vehicle: VW Golf (1K) Climatic
Because you have a temp concern in addition to a DTC I would locate, remove and inspect the V68 motor. If the linkage and plastic gears are OK you may want to try Output Tests per that Wiki page before moving on to wiring and resistance testing.
Bashers
C?ID=41592
Dana hi,
Thanks very much for that, I will be replacing the position motor, so needed to be able to basic set the unit. I am not going to mess about with the old one as there isn't a peep out of it when powered and the DTC returns instantly, just needed to be sure the VW Golf ( 1K ) Climatic procedure applied to the Octavia 2 as well.
Thanks again
Bashers
