Audi A8 ESP fault
Cbolton78
C?ID=219577
So I tried to clear the fault and it comes back right away. The car seems to run great. It does have a wondering idle when it is in park or I am at a stop light. It doesn't do this all the time. I have replaced the Mass Air meter today. Because I had it on hand. This didn't fix anything. Last time I had and ESP fault it was the brake pedal switch.
Here is my latest log.
Monday,12,October,2015,10:24:26:63033
VCDS Version: 15.7.1.0
Data version: 20150904
VIN: WAULV94E98N000907   License Plate: 378-GWN
Mileage: 201460km-125181mi   Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 34 36 37 38 42
          46 47 4F 52 53 55 56 61 62 67 72 77
VIN: WAULV94E98N000907   Mileage: 201460km-125181miles
38-Roof Electronics -- Status: OK 0000
Address 01: Engine        Labels: 079-907-560-BVJ.clb
   Part No SW: 4E1 910 560 D    HW: 4E1 907 560
   Component: 4.2l V8/4V          0010
   Revision: 71H21---    Serial number: AUX3Z0G7528356
   Coding: 01060009190F0120
   Shop #: WSC 02313 785 00200
   VCID: 2345F614E223C12660-8076
000257 - Mass Air Flow Sensor (G70)
               P0101 - 004 - Implausible Signal - MIL ON
                    Fault Status: 11100100
                    Mileage: 201250 km
                    Date: 2015.10.10
                    Time: 19:23:11
                    RPM: 1821 /min
                    Load: 47.8 %
                    Speed: 100.0 km/h
                    Temperature: 98.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
               P1653 - 008 -
                    Fault Status: 01101000
                    Fault Frequency: 16
                    Mileage: 201250 km
                    Date: 2015.10.10
                    Time: 19:23:12
                    RPM: 1812 /min
                    Load: 53.7 %
                    Speed: 100.0 km/h
                    Temperature: 98.0°C
                    Temperature: 29.0°C
                    Voltage: 14.097 V
   Part No SW: 4E1 910 156 C    HW: 09L 927 156 A
   Component: AG6 09L 4,2lFSI USA 0030
   Revision: --H01---    Serial number:        4362464
   Coding: 0000002
006231 - Load Signal
               P1857 - 001 - Error Message from ECU
                    Fault Status: 01100001
                    Mileage: 201468 km
                    Date: 2015.10.11
                    Time: 18:30:22
                    (no units): 30.0
                    (no units): 24.0
                    Temperature: 70.0°C
                    T.B. Angle: 0.0°
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 J    HW: 4E0 614 517 BQ
   Component: ESP 5.7 allrad  H49 0540
   Coding: 0008597
   Shop #: WSC 02313 000 00000
   VCID: 2A5B1B308509106E23-807E
18265 - Load Signal
            P1857 - 000 - Error Message from ECU
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 907 181 B
   Component:     FBS AUDID3  H12 0200
   Revision: 02005112    Serial number: AUX3Z0G7528356
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58BF91F8EBE552FE45-800C
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4071520
   VCID: 2447F508E72DC61E19-8070
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 732 B    HW: 4E0 035 729
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 346HS077543009
   Coding: 0000003
   VCID: 2149FC1CF83FD33672-8074
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000044213
   Subsystem 3 - Serial number: 0113.08.070000000100010048ÿ
   Subsystem 4 - Serial number: 010048ÿ
                    Reset counter: 148
                    Mileage: 201468 km
                    Date: 2015.10.12
                    Time: 10:14:18
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000129065
   Coding: 0037121
   VCID: 1C37CDE8DF5DFEDEA1-8048
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 S    HW: 4E0 907 279 S
   Component: ILM Fahrer      H16 0240
   Coding: 0143123
   VCID: 387F31784BA5B2FEA5-806C
   Subsystem 1 - Part No: 4E1 910 113 C
   Component: Wischer WWS D3  H60 0420
   Coding: 00000037
   Shop #: WSC 02313
   Component: REGENLICHTSENSORH04 0002
   Coding: 00139548
   Shop #: WSC 02313
Address 0E: Media Player 1 (R192)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0700
   Revision: 00000000
   VCID: 275DE204561B2D063C-8072
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7G0130555
   Coding: 0000100
   VCID: 2F6D0A24BEEB7546F4-807A
            000 -  -
                    Reset counter: 148
                    Mileage: 201468 km
                    Date: 2015.10.11
                    Time: 18:30:30
Address 15: Airbags        Labels: None
   Part No SW: 4E0 910 655 F    HW: 4E0 959 655 L
   Component:    Airbag 9.41  H01 4230
   Revision: 91H01423    Serial number: 003CV000065E
   Coding: 0532707
   VCID: 2959E43C800F1B762A-807C
   Subsystem 1 - Part No: 4E0 910 339 C
   Component: BF-Gewichtsens. H02 0040
   Subsystem 2 - Serial number: 00XZN
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†63328RB402D3F860Pÿ†63
   Subsystem 5 - Serial number: 3F860Pÿ†63428RB402D3F861Rÿ†63
   Subsystem 6 - Serial number: 3F861Rÿ†63528RB402D3F807Sÿ†63
   Subsystem 7 - Serial number: 3F807Sÿ†63628RB402D3F381Qÿ†63
   Subsystem 8 - Serial number: 3F381Qÿ†63729RB4028F9837Zÿ†63
   Subsystem 9 - Serial number: F9837Zÿ†63829RB4028F9864-ÿ
   Subsystem 10 - Serial number: F9864-ÿ
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549 A    HW: 4E0 953 549 C
   Component: J0527               0410
   Revision: 00H04000    Serial number: 90025071910036
   Coding: 0012141
   VCID: 2643EF009111340E07-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 K    HW: 4E0 920 951 K
   Component: KOMBIINSTR. VDO H84 0620
   Revision: D02         Serial number: AUDID3G7000080
   Coding: 0032283
   Shop #: WSC 54593 001 104857
   VCID: 2D51102CB4E70756C6-8078
Address 19: CAN Gateway
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0350
   Revision: 00046006    Serial number: AUZ5ZBG3458972
   VCID: 183FD1F82B6592FE85-804C
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 L    HW: 4E0 907 553 H
   Component: LUFTFDR.-CDC    H07 6340
   Coding: 0015510
   VCID: 2C571D288FFD0E5ED1-8078
   Component: Sitzmemory FS  H02  0010
   Coding: 4071522
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H50 1100
   Revision: 00000000    Serial number: 395HP077503402
   Shop #: WSC 23312 444 54552
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H05 0090
   Serial number: 00000716400033
   Coding: 0003461
   VCID: 1D31C0ECC447F7D656-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 801 F
   Component: Türsteuer.FS BRM005 0180
   Coding: 0032364
   VCID: 204FF918F335DA3E7D-8074
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 E    HW: 4E0 907 289 E
   Component: Komfortgeraet   H10 0010
   Revision: 00100010    Serial number:  W040708240078
   Coding: 0048142
   VCID: 2B551E348AF30966D8-807E
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
   Component: DSP-High D3     H03 0120
   Revision: PROD_01     Serial number: 00000000002128
   Coding: 0000026
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 D
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000000979
   Coding: 0010111
   VCID: 1E33C7E0C941ECCE4F-804A
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H04 0050
   Subsystem 2 - Serial number: 0253440T1BD805
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 802 F
   Component: Türsteuer.BF BRM005 0180
   Coding: 0032364
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
   Component: EPB  A4EC0230   H03 0230
   Revision: --H03---
   Coding: 0000922
   Shop #: WSC 23312 444 11180
Address 55: Headlight Range
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 396H 077578231
   Coding: 0000002
   VCID: 2E531720B9E17C4EFF-807A
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000011026
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  0708180243
   Coding: 344530393135313035412056413030373038313830323433
   Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0032364
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000707240347
   Shop #: WSC 12336 024 394758
   VCID: 3467054857CD569E89-8060
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0032364
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005005057
   Coding: 0010900
   VCID: 2541E80CEC173F160E-8070
End-------------------------(Elapsed Time: 03:30)--------------------------
Colter
Agree, the ESP fault is due to to the ECU being unhappy with the MAF.
Cbolton78
C?ID=219577
Thanks for the quick response!
So the traction control light and check engine light are now off. It took some driving around I guess for the computer to learn the new MAF.
I had bought the new MAF because there had been some earlier indication of it having a problem. After replacing it, it seems to have a little more umph too.
Can I ask what in the log tells you that it is exactly the MAF? I mean besides the fault code. My experience so far is that one system is usually being problematic for another system. Hences MAF house causing an ESP fault. Just trying to see what you are seeing.
Thanks,
Colter
Gone But Not Forgotten
Well the MAF when faulty generally causes such lean codes, so can an air leak and a fuel starvation issue.
