- Feb 27, 2015
- 68
- 64
- Central FL
- C?ID=148074
I have a customer with a 2012 TDI jetta with an 02E DSG, just over 100k. Last week she was out of town and got stuck in an area that was experiencing flooding. According to the owner the car was driven through water that was just over the bottom of the doors. The car was driven home, over 1,000 miles, and began to make a metallic noise while idling the following day. I looked the car over today and the noise is coming from the bell housing area. The noise is quite loud and seems to go away when you bring the RPMs up. The car seems to drive and shift fine. The 18149 code appeared at the approximate date and time the car was driven through the water. I cleared the code and it returned after a short drive around the block.
It sounds like the clutch is making the noise. I can pinpoint the sound when the car is running on the lift with the splash pan off. It sounds like it is dead center between engine and trans. If it is a mechanical issue with the clutch getting water damage through the bell housing would that cause the clutch pressure adaptation issue? I am going to drain the transmission tomorrow and see if there was water intrusion and see if I can reset the clutch adaptations. Any thoughts? I haven't see an issue like this before.
j.
j.
Chassis Type: AJ (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VWLL7AJ1CM037691 Mileage: 165950km-103116miles
Part No SW: 03L 906 019 HH HW: 03L 907 309 AA
Component: R4 2,0L EDC G000AG 8180
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 78F5F0A90BA2FEFE65-802C
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2705
Revision: 05351113 Serial number: 00001107120836
VCID: 1737D31526FC11868C-8042
18149 - Clutch Pressure Adaptation
P1741 - 002 - Limit Reached
Fault Status: 01100010
Fault Frequency: 255
Reset counter: 2
Mileage: 164639 km
Date: 2015.10.04
Time: 12:07:09
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: B14B400C492500018D1102ED921A0042A70000
VCID: 7BFFEFA5FA94D5E608-802E
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000529379
VCID: 6FE7CBF57EECB946B4-803A
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0251
Revision: B2066001 Serial number: 04371236110352
Coding: 7B994B1808AB0B0000382000240884C50082502E60000000300000000000
VCID: 2F670BF57E6CF946F4-807A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTM01LAM
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 346D04999F4ADA9E89-8060
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100006RM80W
Coding: 303241
Serial number: 3572MSME30010161ZZZ5
Serial number: 3582MSME0B556361ZZZV
Serial number: 3516KSME1B1C2312ZZZM
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME40082412ZZZB
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME07631B12ZZZP
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME2D551B12ZZZZ
9445892 - Seat occupied recognition control module
B1022 04 [137] - Internal System Fault
Mileage: 163475 km
Date: 2015.10.02
Time: 08:53:52
Part No SW: 5C6 920 951 A HW: 5C6 920 951 A
Component: KOMBI H04 0604
Coding: 270A01
Shop #: WSC 00066 000 00119
VCID: 2953E5ED488897762A-807C
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0251
Revision: B2066001
Coding: 102200
VCID: 70E5C889A3D2A6BEAD-8024
Component: IMMO H04 0604
VCID: 6AD1DAE18D0E5C6EE3-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660435378
VCID: 2953E5ED408897762A-807C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 346D0499574ADA9E89-8060
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 164 C HW: 1K0 035 164 C
Component: LOW NAR SDARS H02 0004
Revision: -----03S Serial number: VWZ4Z6L3189310
Coding: 01000400020006
VCID: 2241F2C13DBE442E6B-8076
Reset counter: 22
Mileage: 148844 km
Date: 2015.05.16
Time: 00:43:07
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660486879
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 356B399D9430C396BE-8060
