Cruise Control not working, 2006 Jetta TDI Manual
Jesus Is Lord
C?ID=201863
I have been trying to diagnose the cruise control on a 2006 Jetta TDI.
All of the switches work in VCDS.
The brake and clutch switch also work.
The running lights are all working and so are the brake lights.
I checked the cruise in VCDS on our two other cars. The cruise does work on these cars.
2005 Passat TDI
2004 Jetta Wagon TDI
This is the only thing that I found was in Cruise Control Switch Monitoring.
With the car on (engine off) and the cruise switched on, this is what our two other cars were.
00000001
This is what the 2006 Jetta TDI was.
10000001
Here is what VCDS says
xxxxxxx1-Stuck ON
xxxxxx1x-Pressed OFF
xxxxx1xx-Decelerate (-)
xxxx1xxx-Accelerate (+)
xxx1xxxx-Set (SET)
xx1xxxxx-Resume (RESET)
1xxxxxxx-Stuck ON (Hardware)
The only codes are Airbag codes.
What does "Stuck ON (Hardware)" mean?
I read that someone fixed a similar problem by replacing the accelerator pedal.
Does that have anything to do with cruise control?
I can get an Auto Scan if you need it.
Gone But Not Forgotten
Please post the auto-scan......even God knows to post an auto-scan in the Church of RT.
Have you verified that cruise is activated with VCDS?
Stuck on hardware of what?
Jesus Is Lord
C?ID=201863
I posted the wrong auto scan. So I am deleting it and posting the right one.
Monday,12,October,2015,11:01:44:15611
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 15.7.1.0
Data version: 20150904
VIN: 3VWST71KX6M670389   License Plate:
Mileage: 210130km-130568mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST71KX6M670389   Mileage: 210130km-130568miles
15-Airbags -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H01---    Serial number: VWZ7Z0E2546716
   Coding: 0050071
   Shop #: WSC 00066 000 00000
   VCID: 63C5506BA269432620-8036
005686 - Powertrain Data Bus
               P1636 - 000 - Missing Message from Airbag Controller
                    Fault Frequency: 22
                    Mileage: 210129 km
                    Time: 18:20:26
                    RPM: 798 /min
                    Voltage: 14.21 V
                    Bin. Bits: 00001000
                    Torque: 141.5 Nm
                    Torque: 0.0 Nm
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0021122
   VCID: 408FBFE713BF383E1D-8014
   Part No: 1K0 820 047 DL
   Component: Climatic PQ35   090 0505
   VCID: 71E92A236895E1B6A2-8024
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000146052
   Coding: 14018E234004180000140000001400000008730B5C
   Shop #: WSC 00066 123 12345
   VCID: 2A5BFD4F85C3D26E23-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 00066
                    Reset counter: 117
                    Mileage: 210132 km
                    Voltage: 14.05 V
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E2032900
   VCID: 2B55F84B8A39CB66D8-807E
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 231
                    Mileage: 51436 km
                    Time: 03:19:29
02788 - Internal Communications Error
            000 -  -  - Intermittent
                    Fault Frequency: 25
                    Reset counter: 157
                    Mileage: 210130 km
                    Time: 19:50:59
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
Address 15: Airbags        Labels: None
   VCID: 55A17EB3FC3DAD965E-8000
No Faults Found
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000021
   VCID: 78FF17070BEFB0FE65-802C
   Part No: 1K0 920 952 D
   Component: KOMBIINSTRUMENT 3HL 1212
   Coding: 0023203
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001057068CE3
   Coding: 3D3F0B60071002
                    Reset counter: 157
                    Mileage: 210129 km
                    Time: 18:20:27
   Component: IMMO            3HL 1212
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 3663D93F417B868EB7-8062
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 326BE52FAD139AAE9B-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AF
   Coding: 137803281B09050F880F048051A0
   VCID: 74E723371787D49E49-8020
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 377DD43B46717F86AC-8062
   Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
   Component: Radio DE2       011 0014
   Revision: 00011000    Serial number: VWZ4Z7E2037916
   Coding: 0040402
   VCID: 204F1F67F3FF183E7D-8074
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 3169EA23A815A1B6E2-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D51F653B42DC556C6-8078
00361 - Heater Element for Auxiliary Heater (Z35)
End-------------------------(Elapsed Time: 01:56)--------------------------
Jesus Is Lord
C?ID=201863
The cruise is activated.
I checked and activated it again just to make sure.
Jesus Is Lord
C?ID=201863
I would consider that CCS Switched On but those bits weren't standardized so I had to exclude ????XXXX in the charts on this page:
Checking Cruise Control using Measuring Values
This isn't from that label file but I have a German clip example:
006,4,Schalterstellung,,Siehe Labeldatei
; xxxxxxx? = Gerastet EIN
; xxxxxx?x = Getastet AUS
; xxxxx?xx = Verzögern (-)
; xxxx?xxx = Beschleunigen (+)
; xxx?xxxx = Setzen (SET)
; xx?xxxxx = Wiederaufnahme (RESET)
; ?xxxxxxx = Gerastet EIN (Hardware)
Gerastet EIN (Hardware) should mean locked on hardware in my opinion.
P.S. Did you check MVB 006.2 for Clutch, brake and similar feedback in addition to checking the #16 controller for switch info yet? Clicking [Add to Log] will save that data to a log so you can paste it here.
Jesus Is Lord
C?ID=201863
I did check mvb 006 and #16 steering, everything looked good.
Here is a log.
Monday,12,October,2015,17:54:23:15611
Address 16: Steering wheel (1K0 953 549 AH)
17:54:22 Group 004: Cruise-Cntrol-System
ON Main Switch
Not Oper. CCS-Set
Not Oper.
N/A
Monday,12,October,2015,17:54:41:15611
17:54:40 Group 004: Cruise-Cntrol-System
ON Main Switch
Not Oper. CCS-Set
Not Oper.
N/A
Monday,12,October,2015,17:55:13:15611
17:55:12 Group 004: Cruise-Cntrol-System
ON Main Switch
Activated CCS-Set
Resume
N/A
Monday,12,October,2015,17:57:25:15611
Address 01: Engine (03G 906 016 AB)
17:57:24 Group 006: Cruise Control System (CCS)
0.0 km/h Vehicle Speed (actual)
00101100 Cruise Control Pedal Monitoring
0.0 % Accel. Pedal Pos. Sensor 1 (G79)
10000001 Cruise Control Switch Monitoring
Monday,12,October,2015,17:57:40:15611
17:57:38 Group 006: Cruise Control System (CCS)
00101000 Cruise Control Pedal Monitoring
Jesus Is Lord
C?ID=201863
If the airbag light is on, will the ECU shut the cruise off?
Jesus Is Lord
C?ID=201863
Is there anything else I can check?
AIB Wolfgang
"If the airbag light is on, will the ECU shut the cruise off?"
As Jack answered
No, never heard about it. Don't think so. But :cool:
This entry shows an activated clutch pedal and that means CCS off
Ja Ja .......Switch stuck broken/bad wire track ........or foot on pedal ..........:thumbs:
I wondered the same with the Airbag issue but I don't know if that would cause inoperative CCS.
Either way, 15 isn't communicating and several modules in the car are complaining about No Signal/Communication so that should be diagnosed at some point.
Jesus Is Lord
C?ID=201863
I did see that clutch pedal switch.
If you turn the car on without starting and don't touch the clutch it will read that way.
As soon as you push the clutch in once, it will read correctly. I am guessing that it reads that way because it is a hall effect sensor.
Jesus Is Lord
C?ID=201863
The drivers door harness was replaced by the previous owner. The trunk and fuel door do not work. Can that have anything to do with cruise control?
AIB Wolfgang
Ok. I think that sensor will be the issue. Ignition on, pedal not moved "0". Ever.
Than after pushing the pedal, may be half way; switching to "1".
That's the way it works.
Jesus Is Lord
C?ID=201863
As soon as you start the car it works perfect. How would I know for sure that that is the problem?
Jesus Is Lord
C?ID=201863
Also the car starts perfect and there is only one sensor.
