1389 Function Restricted due to insufficient Voltage (U1400) FAULT_VBAT_BUSMON_LOW
grittysoup
C?ID=362815
I have a 2019 VW crafter.
Over the last week or so I have been getting repeated:
U1400 FAULT_VBAT_BUSMON_LOW
I think this gives the description, although my '1389' is different to the belows '31896'.
The battery went flat, it was jumped then drove the vehicle - for around 4 hours, I then removed and charged the battery (as it was still completely flat), and put in a different but temporary battery and drove for a few hours on that, I did not setup this temporary battery using VCDS, as I put back the original battery shortly afterwards, I received the error code on several occassions during this whole time ... has the system got confused ? and should I carry out any procedures with VCDS ... or will it just sort itself out over the next few weeks.
Here is the specific error:
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[FAULT_VBAT_BUSMON_LOW]
Reset counter: 153
Mileage: 106825 km
Date: 2023.12.24
Time: 17:16:05
Voltage terminal 15: 9.6 V
Control Module temperature: 10 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: -0.50 m/s²
Adaptive distance regulation: status: ACC_reversible_error
Full scan here:
Thursday,18,April,2024,10:47:13:43490
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
VIN: xxxxxxxxxxxxxxxxxxxxxxxxxxxx   License Plate:
Mileage: 106831km-66381mi   Repair Order:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 03 08 09 13 15 17 19 42 44 52 5F 69 BB BC
VIN: WV1ZZZSYZK9066163   Mileage: 106831km-66381miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DASB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 BD    HW: 04L 907 445 C
   Component: R4 2.0l TDI   H01 6412
   Revision: 23201001
   Coding: 001940106004010800000000000000000000000000000000
   Shop #: WSC 01924 004 1048576
   ASAM Dataset: EV_ECM20TDI03004L906056BD 005004
   ROD: EV_ECM20TDI03004L906056BD_005.rod
   VCID: 70B9D1DAFA298DAADF3-8024
   VINID: 9E606AAAA8E9A9B2401860460CB882505D
31150 - Reductant
          P20E8 00 [01100100] - Pressure too Low
                    Mileage: 106826 km
                    Date: 2023.12.24
                    Time: 17:19:15
                    Engine RPM: 1017.00 /min
                    Normed load value: 40.0 %
                    Vehicle speed: 3 km/h
                    Coolant temperature: 56 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.796 V
                    Outside temperature sensor 1: B1: raw value: 8.5 °C
                    Reducing agent pump module relative press.: calculated: 554 mbar
                    Reducing agent fill level sensor: act. value: 104 mm
                    Sensor for reducing agent tank temperature: temperature: 9.3 °C
                    Reducing agent system pressurization release conditions-Engine running: Condition not met
                    Reducing agent system pressurization release conditions-Press. enabled: Condition not met
                    Reducing agent system pressurization release conditions-Heat. strategy: enable: Condition not met
                    Reducing agent system pressurization release conditions-Depressurized min. time below limit: Condition not met
                    Reducing agent system pressurization release conditions-Catalyst temp.reached: Condition not met
                    Reducing agent system pressurization release conditions-Release due to jammed valve needle: Condition not met
                    Reducing agent system pressurization release conditions-Rinse function finished: Condition not met
                    Reducing agent system pressurization release conditions-Initial filling completed: Condition not met
                    Reducing agent system pressurization release conditions-Release via inducement: Condition not met
                    Reducing agent system pressurization release conditions: 767
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2N0 907 379 D    HW: 2N0 907 379 C
   Component: ESC_base      H02 0860
   Serial number: 08512985190427
   Coding: 25A884774843B688A448216612466D063DF120B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701030
   ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
   VCID: 372B2AC6DFC71A92DE9-8062
Address 08: Auto HVAC (J65)       Labels:* Redir Fail!
   Part No SW: 7C0 907 184 N    HW: 7C0 907 184 N
   Component: Heizung       H01 0401
   Coding: A03110000800030001000800500101000000000000000000000000000000
   Shop #: WSC 00069 790 00035
   ASAM Dataset: EV_AirCondiBHTCVN54X 003020
   ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
   VCID: 353720CEC5CBE882CC5-8060
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H42 0273
   Serial number: 01002031900192 Dataset Number: V03935325WQ 0001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7DA7F8EEBD7BF0C2445-8028
   Steering Column Switch:
   Subsystem 1 - Part No SW: 5Q1 953 521 AK    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100180320190C102341
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Dataset Number: V03935287GA 0001
   Coding: 2A00400900EF8448949C814D00308500000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 42DD4B1284054F3A797-8016
                    Reset counter: 153
                    Mileage: 106825 km
                    Date: 2023.12.24
                    Time: 17:16:05
   Part No SW: 3Q0 959 655 CL    HW: 3Q0 959 655 CL
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z1P8REUT0 Dataset Number: V03935296YM 0001
   Coding: 800080000000000040000000008800000065
   ROD: EV_AirbaVW21TS6VW48X_VN54.rod
   VCID: 0A4DA332FCB5D77A717-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 801 403 19
   Component: FrontSensor_D  305 0109
   Serial number: 35500EE581218000000N
   Subsystem 2 - Part No SW: -----------    HW: 454 801 403 19
   Component: FrontSensor_P  305 0109
   Serial number: 35600C04912180000008
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7C0 920 941 B    HW: 7C0 920 941 B
   Component: KOMBI         211 2700
   Coding: 27A411002000260001882A010400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 2517F08E756B98027C5-8070
   Serial number: 11041910803751 Dataset Number: V03935295SX 0001
   Coding: 030000044F05730000000000000E00010001070000000000000000000000
   GVL: 01403C0000000000C00C80000000480000000000000000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 6E85CFA2E01D9B5ACDF-803A
   Generator:
   Component: 0-01-13-01-04
   Subsystem 2 - Part No SW: 2N0 915 181     HW: 2N0 915 181
   Serial number: 75884902001904300650
   Part No SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
   Component: TSG FS        006 0246
   Serial number: 0000374144985  Dataset Number: V03935290UP 0001
   Coding: 00300B200101020100001000
   Shop #: WSC 00069 790 00038
   ROD: EV_DCU2DriveSideMAXHCONT_SE38.rod
   VCID: 46D55702A82D731A55F-8012
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 2N0 909 143 G    HW: 2N0 909 143 C
   Component: EPS_MQB_ZFLS  701 7031
   Dataset Number: V03935288DQ 0001
   Coding: 0107
   Shop #: WSC 00069 790 00020
   ASAM Dataset: EV_SteerAssisMNB 002009
   ROD: EV_SteerAssisMNB.rod
   VCID: 313F14DE31A3C4A290D-8064
   Part No SW: 5Q4 959 392 F    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0246
   Serial number: 0000373992815  Dataset Number: V03935290US 0001
   ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
   VCID: 45D7500E952B78025C5-8010
   Part No SW: 2E0 035 130     HW: 2E0 035 130
   Component: MU-G--EU      611 0242
   Serial number: VWZGZ1W5633168 Dataset Number: V03935301TS 0001
   Coding: 064500002800000000110001010002002F0000040000010000
   ASAM Dataset: EV_MUGlb4CHBAS 001001
   ROD: EV_MUGlb4CHBAS.rod
   VCID: 53F37E566B7FD6B2C21-8006
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: ConWysTrailer H14 0137
   Serial number: 00000181563668
   Coding: 0100000200000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 392F2CFEE9D30CE228D-806C
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 00:51, VBatt start/end: 14.7V/14.7V)-----------
If the battery was still completely flat after driving for four hours, either that battery is completely shot and should be handed over for recycling, or there's something wrong with the charging system in this vehicle.
Spacewalker
Poland
C?ID=159607
with some reason radar only see 9.6V
all other see proper voltage
go to radar MB and check voltage in reall data
grittysoup
C?ID=362815
When I got the Vehicle back, the battery was removed and charged - then placed back in the vehicle after a few days of driving (on another temp battery), it has been operating fine for the last week or so with plenty of starts.
From what I can tell the battery was only flat for a week or two, why it didn't initially charge at all on the 3/4 hour journey back I'm not sure.
Excuse my ignorance ... do I find this under 'Advanced Measuring Blocks ? and is it groups 017, 018, 019 and 020, and I'm looking for a charge load/current/voltage ?
grittysoup
C?ID=362815
OK, cleared the DTCs and have done some trips in the last week, the Fault does not seem to have re-appeared.
I will presume swapping out the batteries for a few days, without changing any settings - upset the battery management system, but now with the original battery back in for the last week or so - it has sorted itself out.
