audi a5 3.0tdi v6 fault code ? P1610
TD&MCK Car Sales
C?ID=160148
Hi, got a bit of a strange one ! car is a 2008 audi A5 3.0 tdi v6, was sat in the car whilst it was idling and all of a sudden it just cut out and flashed something up in the clocks about the alternator ? so put booster pack on and tried to start but it would not crank, plugged vagcom in and did a scan and it first it said no communication with engine control module, took battery off for an hour, scanned again and it had a big list of faults ! cleared them all but the engine one remains, P1610 checksum error ? car is cranking now but will not start and keeps coming up with loads of faults, heater plug glow light is flashing, esp error etc, can anyone shed any light on P1610 ?? is it a fried ecu ? could alternator have caused that ? please help !! glenn
first scan
Monday,12,October,2015,13:12:12:17628
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Dealer/Shop Name: TDMCK Car Sales
VIN: WAUZZZ8TX8A023465   License Plate: AUDI A5 1
Mileage: 155600km-96685mi   Repair Order:
Chassis Type: 8T (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 77
VIN: WAUZZZ8TX8A023465   Mileage: 155600km-96685miles
Address 01: Engine (J623-CAPA)       Labels: 059-907-401-V1.clb
   Part No SW: 8K0 907 401 F    HW: 8K0 907 401
   Component: 3.0TDI EDC17  H01 0002
   Revision: --H01---
   Coding: 0114002C180F0118
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30LTDIA5 A02002
   ROD: EV_ECM30LTDIA5.rod
   VCID: 2E594FE17153994EFF-807A
4698 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:32:59
4699 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:32:59
5095 - Internal Control Module
          P1610 00 [167] - Memory Check Sum Error
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:20:48
7945 - Internal Control Module
          P1603 00 [039] - Failed Self-Test
                    Mileage: 155606 km
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 L    HW: 8K0 907 379 L
   Component: ESP8 quattro  H03 0170
   Coding: 1B0500
   VCID: 42810B51DDCB0D2E0B-8016
                    Fault Status: 01101000
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:32:49
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0009
                    Hex Value: 0x809A
                    Hex Value: 0x00FF
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:32:49
                    Hex Value: 0x0000
                    Hex Value: 0x2282
                    Hex Value: 0x0013
                    Hex Value: 0x0298
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
   Component: BCM2.01       H38 0251
   Revision: 00003002
   Coding: 031000
   VCID: 39736CBDB01D4EF65A-806C
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H35 0052
   Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
   Component: ELVAUDIB8  H35 0039
   Part No SW: 8T2 820 043 M    HW: 8T2 820 043 M
   Component: KLIMA 3 ZONEN H05 0120
   Revision: D0000000    Serial number: 0121.11.070384
   Coding: 36060000
   VCID: 3C7D75A9BF2F7BDE41-8068
00457 - Control Module for Network (J519)
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:38:00
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:38:00
                    Temperature: 11.0°C
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:38:00
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H21 0252
   Revision: 04021001    Serial number: 00000000049151
   Coding: 260050914014AF010009000000005D5D001D038800010141000000
   VCID: 2F6752E57E599046F4-807A
   Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 061107  H11 0040
   Coding: 00FD11
   Component: RLS  H04 0002
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:38:00
            014 - Defective
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:38:00
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330733400359
   VCID: 387569B98B1757FEA5-806C
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD121C8O
   Coding: 30323433363030303030554A305238543053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 3C7D75A9B72F7BDE41-8068
   Serial number: 6334MSME2832232FA
   Serial number: 6344MSME283606469
   Serial number: 6352QSME47443957K
   Serial number: 6362QSME4507233DF
   Serial number: 63732SME464C3D413
   Serial number: 63832SME4427445B+
   Component: Lenks.Modul   H10 0012
   Revision: J5------    Serial number: 90315GKL0001O
   Coding: 000016
   VCID: 3D7B78ADA43572D676-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 981 B    HW: 8T0 920 981 B
   Component: KOMBIINSTR.   H26 0214
   Revision: 00000000    Serial number: 71Y16DT97
   Coding: 2F05010002002600010000
   VCID: 3B7F76B5BA217CE648-806E
   Part No SW: 8T0 907 468 D    HW: 8T0 907 468 D
   Component: GW-BEM 5CAN   H04 0084
   Revision: GA801030    Serial number: 3000G07A14814F
   Coding: 000003
   Shop #: WSC 00899 210 89303
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 173
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:16:48
                    Reset counter: 173
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:24:36
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 A    HW: 8K0 959 793 A
   Component: TSG FA        H09 0146
   Revision:             Serial number: bg
   Coding: 0110022240012201
   VCID: 3E797FA1A93369CE6F-806A
   Revision: 00003002    Serial number: 0107196337
   Coding: 011B068200390440002000
   Component: DWA-Sensor  H02 0030
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:24:31
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:24:49
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 J    HW: 8T0 035 223
   Component: DSP STD       H07 0210
   Revision: S1700000
   Coding: 0203010102
   VCID: 356B608D9C05AA96BE-8060
   Part No SW: 8K0 959 792 A    HW: 8K0 959 792 A
   Component: TSG BF        H09 0146
   Revision:             Serial number: ‡d
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0040
   Revision: 00000003    Serial number: 00000000032746
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 01:08:09
                    Voltage: 11.00 V
                    Count: 56
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 00101101
                    Reset counter: 173
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:46:06
                    Voltage: 10.60 V
                    Count: 58
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No: 8K0 907 357 A
   Coding: 0000002
   VCID: 336F5E955271B4A690-8066
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 B    HW: 8T2 035 186 B
   Component: Concert3      H11 0130
   Revision: 00000511    Serial number: AUZ5Z6G1007451
   Coding: 0002008201048D00035B070000
   VCID: 37776A8586095886AC-8062
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
   Part No SW: 8T0 862 335 B    HW: 8T0 862 335 B
   Component: FSE_255x BT     H26 0350
   Revision: 00000000    Serial number: 00000005028521
   Coding: 0010320
   VCID: 39736CBD701D4EF65A-806C
End-------------------------(Elapsed Time: 02:45)--------------------------
then cleared all faults and did another scan
Monday,12,October,2015,13:24:50:17628
VIN: WAUZZZ8TX8A023465   License Plate: LEE AUDI A5
   Revision: --H01---
          U1017 00 [039] - -
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:37:03
          U1017 00 [039] - -
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:37:03
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:37:01
   Coding: 1B0500
   Revision: 00003002
   Coding: 031000
   Coding: 36060000
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:37:01
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:37:01
                    Temperature: 12.0°C
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:37:01
   Coding: 00FD11
   Coding: 02532C
            014 - Defective
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:37:00
            014 - Defective
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:37:00
   Revision: --------    Serial number: 90315GKL0001O
   Coding: 000016
   Coding: 000003
   Revision: S1700000
   Coding: 0203010102
   Coding: 0000002
   Component: Display
   Coding: 0010320
End-------------------------(Elapsed Time: 02:42)--------------------------
TD&MCK Car Sales
C?ID=160148
If I try and start it again it brings all the first lot of fault codes back up !!!
Gone But Not Forgotten
U1017 00 [039] - -
Mileage: 155606 km
Date: 2007.08.01
Time: 00:32:59
U1017 00 [039] - -
Mileage: 155606 km
Date: 2007.08.01
Time: 00:32:59
Mileage: 155606 km
Date: 2007.08.01
Time: 00:20:48
Mileage: 155606 km
When it rains it pours twice...........thank you for that post............ especially the first two!
Sounds like weak battery and charging issues.......or maybe bad BDM/gateway.
Lets recode all modules with defaults and verify battery levels + alternator output.
TD&MCK Car Sales
C?ID=160148
Can you point me in the right direction for doing that ??
Each module .........please enter recoding with your VCDS tester prior setup in config screen first with a tester #, WSC, and importer #
Then observe the change of these #s you created in your modules after recoding.
Engine example..... 0x01-07-0114002C180F0118 ( same data with new WSC # )
Shop #: WSC 06325 000 00000 <<<<<<<<<<<< These will now change with your new #s you created.
All other modules same thing........
Ref how to do the other tests consult the repair manual here.
http://www.erwin.audi.com/
TD&MCK Car Sales
C?ID=160148
Thanks for the reply but I'm still non The wiser Sorry ! If you could detail it a bit simpler for a beginner I would much appreciate it ? Thank you
TD&MCK Car Sales
C?ID=160148
Keeps flashing up in clocks, "alternator fault, battery is not being charged"
Why would it say this even though engine is not running ?? Car will not crank now and radiator fans keep coming on !!!
TD&MCK Car Sales
C?ID=160148
anyone help please ?? do you think I need a new engine ecu ??
TD&MCK Car Sales
C?ID=160148
Just worried if the alternator could of fried the ecu, don't want to get a new ecu then the alternator does any damage to it ?
Yup that is advised you verify it.
Line conditioners are always a good idea....... properly wired.
Hi Glenn,
Although that engine controller sounds like it is faulty I wanted to clarify Jack's prior suggestion. The coding and shop info was:
You would Select > 01-Engine > Coding > and paste the same value back into the New coding line. Change the all zero Importer and Equipment numbers to something else (such as 321 | 54321) and click Do it!
Doing so would refresh the coding and the new scan info would look more like:
Shop #: WSC 06325 321 54321
TD&MCK Car Sales
C?ID=160148
Hi Glenn,
Thanks for the reply dana, I have sent the ecu away to be tested and repaired if possible (fingers crossed) just hoping if I do get it repaired whatever caused it to go wont happen again ! I had no battery or alternator warning issues prior to it happening ?
only thing I have found if anyone can help is a blown 40amp fuse in the trunk fusebox and I don't know what it is for ! doesn't mention it at all in the handbooks, it is a larger fuse than the standard fuses and with it being 40amp im pretty sure it is for something important ??
thanks again
TD&MCK Car Sales
C?ID=160148
Ecu company have been on to me and said the ECU has been spiked and the pcb is beyond repair ! great, that's all I needed to hear, They are now trying to source me a second hand unit to transfer my data over too ?? but they said the ecu in mine is quite a hard one to get !! don't suppose any of you guys can help with sourcing one ??? its a EDC17CP04 ?? Bosch part no 0281 014 725
many thanks
CP04 is a bitch.....
You might want to go new if coding didn't help default this.
Do you happen to have a picture of the mystery blown 40amp fuse in the trunk? If so this thread explains how to upload a picture and post it here: How To Post Pictures
No mystery Dana .........it is for the rear defrost heater extra fuse box H
Separate fuses on fuse holder F -SF-
Item Current Flow Diagram designation Nominal value Function/component Terminal
H - Heated rear window fuse -S41- 40 A - Heated rear window relay -J9- 30
In the repair manual........
TD&MCK Car Sales
C?ID=160148
Brilliant, thanks for the help jack, I did post a picture in another thread Dana but with Jack's help I've got the culprit now, pretty sure the fuse blown for the heated rear window is not connected to the ECU spike, I had the battery tested today and its breaking down under load, so new battery ordered, just stuck now trying to source a engine ECU, seen some for sale in Poland with same part numbers but then got the hassle of swapping data over for immobilizer etc
If you find the controller used for same part # send it to me and we can transfer the needed data if interested.
TD&MCK Car Sales
C?ID=160148
Brand New ECU fitted and coded today... Car Starts but wont stay running
Monday,26,October,2015,14:42:56:17628
VIN: WAUZZZ8TX8A023465   License Plate: NJZ7001
Mileage: 155600km-96685mi   Repair Order: 26/10/15
   Component: 3.0TDI EDC17  H08 0008
   Revision: --H08---
   Shop #: WSC 18207 000 1048576
   ASAM Dataset: EV_ECM30LTDIA5 A02008
7 Faults Found:
          U1017 00 [039] - -
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:19:50
          U1017 00 [039] - -
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:19:50
4984 - Glowplug for Cylinder 1 (Q10)
          P161A 00 [101] - Open Circuit
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:33:48
4985 - Glowplug for Cylinder 2 (Q11)
          P161B 00 [101] - Open Circuit
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:33:48
4986 - Glowplug for Cylinder 3 (Q12)
          P161C 00 [101] - Open Circuit
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:33:48
5417 - Glowplug for Cylinder 5 (Q15)
          P161E 00 [101] - Open Circuit
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:33:48
5418 - Glowplug for Cylinder 6 (Q15)
          P161F 00 [101] - Open Circuit
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:33:48
   Coding: 1B0500
   Shop #: WSC 06325 123 12345
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:19:48
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0009
                    Hex Value: 0x8094
                    Hex Value: 0x00FF
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:33:32
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0013
                    Hex Value: 0x0295
                    Hex Value: 0x00FF
   Revision: 00003002
   Coding: 031000
   Coding: 36060000
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:18:55
                    Temperature: 13.0°C
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:18:55
   Coding: 00FD11
   Coding: 02532C
            014 - Defective
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:18:00
            014 - Defective
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:18:00
   Coding: 000016
   Coding: 000003
   Revision: S1700000
   Coding: 0203010102
                    Reset counter: 133
                    Mileage: 155606 km
                    Date: 2007.08.07
                    Time: 00:19:48
                    Voltage: 12.10 V
                    Count: 56
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Coding: 0000002
   Component: Display
   Coding: 0010320
