Intake Air Regulating Flap
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
I have this problem in this car, after starting the engine and drive the car to 4okm\h ,the accelerator pedal become just like no more power to press. remove your leg and press again it will drive normally, every time and at every shift ( the first - second - third -fourth - fifth also )
so any help it will be appreciated ;
and how can I solve the fault at the engine
Regards
________________________________
Monday,12,October,2015,03:33:16:25282
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 15.7.1.0
Data version: 20150904
VIN: WVWZZZ1KZAP014600   License Plate:
Mileage: 136930km-85084mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 14 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAP014600   Mileage: 136930km-85084miles
Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
   Part No SW: 03C 906 027 F    HW: 03C 906 027 F
   Component: MED17.5.5       G   4008
   Revision: LAH07---    Serial number:
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 244D88D2E7B93D1E19-8070
004261 - Position Sensor for Intake Air Regulating Flap
               P10A5 - 000 - Signal too High - Intermittent
                    Mileage: 136932 km
                    Date: 2010.03.04
                    Time: 12:03:20
                    Temperature: 91.0°C
                    Temperature: 56.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.192 V
004260 - Intake Air Regulating Flap
               P10A4 - 000 - Mechanical Malfunction
                    Mileage: 136933 km
                    Date: 2010.03.04
                    Time: 13:22:30
                    RPM: 1292 /min
                    Load: 9.8 %
                    Temperature: 66.0°C
                    Temperature: 44.0°C
                    Voltage: 12.065 V
Readiness: 0110 0001
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 143B600D092300FE281106E4901900403000
   Shop #: WSC 00070 726 179402
   VCID: 7EF99ABAE995B7CE2F-802A
   Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
   Component: Climatronic   H14 0608
   Revision: 00003001
   Coding: 0000000000
   Shop #: WSC 00028 028 00023
   ASAM Dataset: EV_Climatronic A01001
   VCID: 6DDBADF6BCF33C5686-8038
9470997 - Temperature Sensor for Right Footwell Vent
          B1084 15 [009] - Open or Short to Plus
                    Reset counter: 244
                    Mileage: 134370 km
                    Date: 2015.08.15
                    Time: 12:30:23
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0537
   Revision: 00103 AC
   Coding: 40180A3A90251AC040080080100081E443010088524D8960648000200000
   VCID: 30657482634191BEED-8064
   Component: Wischer 04060  21  0501
   Coding: 009795
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 08060902140001
   Coding: 000180
   VCID: 27579FDE568FD6063C-8072
Address 15: Airbags
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           055 0111
   Coding: 0000532
   VCID: 78F58CA20BB189FE65-802C
   Subsystem 1 - Part No: 3C8 959 537 B
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
   Part No SW: 5K0 920 870 D    HW: 5K0 920 870 D
   Component: KOMBI         H05 0206
   Coding: 170B00
   VCID: 2E596AFA7175874EFF-807A
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 080609F2000036
   Coding: E9887F06000202000002
   VCID: 66C9D2DA51050F0EC7-8032
   Component: IMMO          H05 0206
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2123
   Coding: 0000180
   VCID: 336F7B8E5257AAA690-8066
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 174    2901
   Revision: 00H15000
   VCID: 2F6777FEBE7F8E46F4-807A
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Coding: 0000180
   VCID: 346D78925759AD9E89-8060
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
   Component: Radio RCD510  051 0207
   Revision: 00000001    Serial number: VWZ1Z3L8066435
   Coding: 05000400040005
   VCID: 234F8BCE22B73A2660-8076
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 00028 028 1012545
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 356B45965C23B496BE-8060
End-------------------------(Elapsed Time: 01:49)--------------------------
Gone But Not Forgotten
Voltage issue check charging system.
Correct intake flap error and check for carbon build up in intake.
Jack picked up on:
RPM: 1292 /min
Load: 9.8 %
Temperature: 66.0°C
Temperature: 44.0°C
Voltage: 12.065 V
The first DTC was 0 RPM so it wasn't running but 1,292 RPM @ 12.065 V is suspicious. I would make sure the battery, main fuse panel, wiring to/from and the alternator itself are functioning properly.
