2013 Tiguan Cluster Problem
benghanbari
Australia
C?ID=250241
Hi,
Can someone help me to reset my cluster? Auto scan attached.
Thank
Sunday,11,October,2015,10:46:28:23801
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVGZZZ5NZDW072782   License Plate:
Mileage: 16320km-10140mi   Repair Order:
Chassis Type: 5N (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 52 53 56 61
          62 72 77
VIN: WVGZZZ5NZDW072782   Mileage: 16320km-10140miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 FQ    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H28 4573
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00250032042701080000
   ASAM Dataset: EV_ECM20TDI01103L906018FQ 003011
   ROD: EV_ECM20TDI01103L906018FQ_VW36.rod
   VCID: 7EF3B636E1AB8CCE2F-802A
4815 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [167] - -
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:23:25
14413 - Implausible Data Received from ABS Control Module
          U0415 00 [039] - -
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:23:21
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:23:21
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [167] - -
                    Mileage: 16329 km
                    Date: 2015.10.11
                    Time: 00:00:31
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BH 300 011 S    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H07 1806
   Revision: 00H07V01
   ROD: EV_TCMDQ500021_SE36.rod
   VCID: 326B5206657398AE9B-8066
   Part No SW: 5N0 614 109 BC    HW: 5N0 614 109 BC
   Component: J104   C6 450M V4BF 0011
   Revision: --H07---    Serial number: 00000006566726
   Coding: 0010000
   VCID: 6DD1817A74CD075686-8038
7 Faults Found:
            000 -  -
                    Speed: 252.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 0.00 V
                    Bin. Bits: 00000000
                    Count: 216
                    Hex Value: 0x0000
03201 - Adaptation Overboost
   Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010002003
   VCID: 79F9A52AF885ABF61A-802C
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 46180A3B802518C0408800C0340081644B51AA88436D81606480C7000041
   VCID: 3E737636A92B4CCE6F-806A
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 14011  013 0204
   Coding: 009795
   Component: RLS 110113 05  54  0403
   Coding: 02304D
                    Reset counter: 231
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:50
                    Voltage: 14.05 V
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56231301606916
   Coding: 049303
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000_SE36.rod
   VCID: 448704DECFC7261E39-8010
13637393 - Databus
                    Reset counter: 191
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:24
13637392 - Databus
                    Reset counter: 191
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:24
13637395 - Databus
                    Reset counter: 191
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:24
13637396 - Databus
                    Reset counter: 191
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:28
13637397 - Databus
                    Fault Frequency: 9
                    Reset counter: 191
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:28
   Component: J234__20B VW10 HI   2118
   Revision: 25018000    Serial number: 003L7P0M3ZZM
   Coding: 0012354
   VCID: 7CF7BC3E3FB79EDE01-8028
   Subsystem 1 - Serial number: 6332MTS688510073
   Subsystem 2 - Serial number: 6342MTS647090073
   Subsystem 3 - Serial number: 6351HTS6TP48JBKJ
   Subsystem 4 - Serial number: 6361HTS61CU7JBKR
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90422MA70002J
   Coding: 1882140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 76E3AE16C99BC48E77-8022
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0430508
   Coding: 820000
   Part No SW: 5N0 920 873 C    HW: 5N0 920 873 C
   Coding: 711F00
   VCID: 336557029A6991A690-8066
8 Faults Found:
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 231
                    Mileage: 16328 km
                    Date: 2015.10.11
                    Time: 17:49:09
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 231
                    Mileage: 16328 km
                    Date: 2015.10.11
                    Time: 18:21:33
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 39
                    Reset counter: 63
                    Mileage: 16328 km
                    Date: 2015.10.11
                    Time: 18:23:19
12658688 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 231
                    Mileage: 16328 km
                    Date: 2015.10.11
                    Time: 18:21:33
12671232 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 16328 km
                    Date: 2015.10.11
                    Time: 18:42:15
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 231
                    Mileage: 16328 km
                    Date: 2015.10.11
                    Time: 18:21:37
13635840 - Supply voltage
                    Mileage: 16328 km
                    Date: 2015.10.11
                    Time: 18:43:32
13654544 - Databus
                    Fault Frequency: 8
                    Reset counter: 231
                    Mileage: 16328 km
                    Date: 2015.10.11
                    Time: 17:51:16
   Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
   Component: J533  Gateway H53 1634
   Revision:   H53       Serial number: 130113F1000968
   Coding: 356003
   VCID: 75E1A91ADC9DCF967E-8020
                    Reset counter: 231
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:35:17
01304 - Radio
                    Reset counter: 231
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:30:20
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: 4D9121FAD48DE756E6-8018
00625 - Vehicle Speed Signal
                    Reset counter: 138
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:23
   VCID: 6ADB8A668D23106EE3-803E
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [009] -  -
9456681 - Key
          B104C 29 [009] - Implausible Signal
                    Mileage: 16329 km
                    Date: 2015.10.11
                    Time: 00:03:43
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664008761
   Coding: 010100
   VCID: 2A5B4A6645A3D06E23-807E
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0504
   Revision: 13110009    Serial number: 0006199512
   Coding: 0202BC
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 387F602E830F72FEA5-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C
   Component: J389__TSG-HR  008 1504
   Serial number: 00000007500871
   Coding: 000090
   Part No: 5N0 909 144 P
   Component: EPS_ZFLS Kl. 202    3305
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   VCID: 3E737636692B4CCE6F-806A
                    Fault Status: 11100101
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:23
                    Battery Volts: 11.7 V
                        DD
                    Temperature: 24.0°C
                    Count: 3
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
                    Fault Status: 11101101
                    Reset counter: 191
                    Mileage: 16329 km
                    Date: 2015.10.11
                    Time: 00:00:38
                    Voltage: 11.63 V
                        DD
                    Temperature: 24.0°C
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0504
   Revision: 15110009    Serial number: 0006195742
   Coding: 0202BC
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3979652AB8056BF65A-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C
   Component: J388__TSG-HL  008 1504
   Serial number: 00000007506671
   Coding: 000090
   Revision:   H19       Serial number: 00000000697498
   Coding: 0010000
   VCID: 36636E16411B848EB7-8062
            000 -  -
                    Fault Status: 01110000
                    Reset counter: 191
                    Mileage: 16329 km
                    Date: 2015.10.11
                    Time: 00:03:44
                    Voltage: 9.00 V
                    Count: 98
                    Hex Value: 0x12C3
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 -  -
                    Reset counter: 191
                    Mileage: 16329 km
                    Date: 2015.10.11
                    Time: 00:03:44
                    Voltage: 9.00 V
                    Count: 41
                    Hex Value: 0x12C3
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Status: 01110101
                    Reset counter: 191
                    Mileage: 16329 km
                    Date: 2015.10.11
                    Time: 00:03:44
                    Voltage: 9.00 V
                    Count: 99
                    Hex Value: 0x12C3
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Status: 01111101
                    Reset counter: 191
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:24
                    Voltage: 11.60 V
                    Count: 69
                    Speed: 8.0 km/h
                    Hex Value: 0x1253
                    Hex Value: 0x0004
                    Hex Value: 0x1010
02845 - Function Display in Instrument Cluster (!)
                    Fault Status: 00101010
                    Reset counter: 231
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:35:13
                    Voltage: 11.70 V
                    Count: 77
                    Hex Value: 0x0853
                    Hex Value: 0x0088
                    Hex Value: 0x1010
Address 56: Radio
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
   Component: Batt.regelung H53 1634
   Coding: 230F1859
   VCID: 71E99D0AA8F5E3B6A2-8024
   Component: J367-BDM  H07 0180
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007664100636
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
          B104F 13 [009] - Short to GND
                    Reset counter: 191
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:23
          B104E 13 [009] - Short to GND
                    Reset counter: 191
                    Mileage: 122155 km
                    Date: 2016.12.04
                    Time: 00:17:23
End-------------------------(Elapsed Time: 03:11)--------------------------
AIB Wolfgang
Hello
Think there is too little input to help.
First, be sure to have a good battery voltage. Stabilized battery charger. (Battery Volts: 11.7 V Voltage: 9.00 V in different ECU's).
Second, Databus Instrument Cluster 004 - No Signal/Communication > wiring, connection problem between "17" + "19" + other modules.
Third, Mileage: 16329 km + Mileage: 122155 km in different modules, what's happenend?
Any replacement or retrofit?
benghanbari
Australia
C?ID=250241
Hi,
Thanks for your respond.
I have bought second hand cluster my original done 122155 km and one I bought is 16329km my original cluster was 5N0920 873A and one I bought is 5N0920 873C.
golfi_vend
Tartu, Estonia
C?ID=195131
It's not possible with VCDS to adapt cluster to another car. At least not so new cluster.
Hello Ben,
We received your email however this vehicle uses Immo 4C which is not supported with VCDS as golfi_vend mentioned:
http://wiki.ross-tech.com/wiki/index.php/Immobilizer#Immobilizer_Generation_4
The ABS and Parking Brake coding values are lost (which isn't uncommon when the VIN is missing or incorrect) so you can reconfigure those controllers based on the original Auto-Scan after the Immo problem is sorted. This page should be helpful at that time:
http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Brake_Electronics
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
This why I always tell everyone to ask and check things before you do on your own.
Now even if you put old cluster back you will have problem with ABS Coding and most likely you will need to go to dealer to recover it.
Yeah Marin, the original coding may be lost but we did include a \Scans (C:\Ross-Tech\VCDS\Scans) folder in 15.7 that saves scans even when the user doesn't [Save]. That won't help if a scan wasn't completed in the first place ... but it has saved the day on a few MK60EC1 coding strings so far :-)
Jetta 97
C?ID=81680
He is lucky he did save original Coding , here , he made one more thread:
http://forums.ross-tech.com/showthread.php?4302-2013-Tiguan-Cluster-Problem
To OP,
You need to adopt ABS sensors:
benghanbari
Australia
C?ID=250241
Thanks,
Almost all gone except G85 the hand brakes don’t go off so I can move the car? Any suggestion?
