Touareg 7P - MMI / Infotainment problem
Cruelworld
C?ID=255222
All,
I have an issue with my infotainment RNS-850. The issue is that the display is not functioning. I have checked fuses, wiring between display and main unit for continuity etc. I have voltage at the screen unit and it will switch on and play the radio etc. The radio station and nav is also displayed in the cluster screen.
I have had the screen working when first had the car but after a faulty battery and the car trying to start the screen was flickering ON/OFF with the low voltage etc. Im suspecting a voltage spike has blown something ??
VCDS scan below any help appreciated.
Friday,09,October,2015,16:09:17:41103
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVGZZZ7PZCD011785   License Plate:
Mileage: 13232km-8221mi   Repair Order:
Chassis Type: 7P (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 72
VIN: WVGZZZ7PZCD011785   Mileage: 13232km-8221miles
Address 01: Engine (J623-CRCA)       Labels: 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---
   Coding: 292A4012232601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001003
   ROD: EV_ECM30TDI0117P0907311C.rod
   VCID: 326B4D13658FEEAE9B-8066
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 AG    HW: 0C8 927 750 AG
   Component: AL1000 AISIN  001 1933
   Coding: 001568
   ROD: EV_TCMAL991031_VW52.rod
   VCID: 71E9821FA00995B6A2-8024
Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 419410010EC010
   Coding: 5B6B13C309252554DAFBC89B90D7A4507700
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A01000.rod
   VCID: 458106CFC40169162E-8010
   Slave 1:
   Part No SW: 4H0 907 064 BL    HW: 4H0 907 064 BL
   Component: BCM2 2.0      H31 0330
   Coding: 01B60000000000000000
   VCID: 74E78B0BD71BA09E49-8020
   Subsystem 1 - Part No SW: 7P6 959 754 AA    HW: 7P6 959 754 AA
   Component: FBSTOUAREGIDG  H05 0051
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
   Part No SW: 7P6 907 040 BA    HW: 7P6 907 040 BA
   Component: Klima 2 Zonen H20 1203
   Coding: B626000890
   VCID: 74E78B0BDF1BA09E49-8020
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000000999747
   Coding: 26001011D1345F010021000300005D0C431D470807010341000000020000
   VCID: 6BD590778A257F6698-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    110708  31  0020
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431     HW: 7P6 941 431
   Component: E1 - LDS  H04 0031
Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28291117884891
   Coding: 108501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 428B1DD3D52F5E2E0B-8016
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag02P H05 0023
   Revision: --------    Serial number: 003JX003GT7O
   Coding: 000000000000000000000000000000003250
   ROD: EV_AirbaVW10BPAVW526.rod
   VCID: 408F17DBDB234C3E1D-8014
   Serial number: 3575LRB40650JR9K6P5X
   Serial number: 3585LRB405P0JE3C6PV9
   Serial number: 3515RRB40610KOIAKOD4
   Serial number: 3525RRB40610KOIAEHCY
   Serial number: 3555NRB404T6N1H8GG8$
   Serial number: 3565NRB40630K4DIKOH.
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372LJ2000EB
   Coding: 000034
   VCID: 387F7F3B8BF304FEA5-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 981     HW: 7P6 920 981
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658040313592038
   Coding: 332731002A002600010004
   Shop #: WSC 00682 210 99182
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 7AFBA533FD7FD6EE13-802E
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000211827
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 387F7F3B83F304FEA5-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650900596
   Voltage stabilizer:
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000118147031
   Coding: 011D0620D001451005080002
   VCID: 44871BCBC73B501E39-8010
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0152168471
   Coding: 011B162228B8008083200424000000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000118171965
   Coding: 011D0620D001451005080000
   VCID: 3B756037BAC52FE648-806E
Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A11719002CA
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3663710389E7F28EB7-8062
   Slave 3:
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 018E00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CF7A32BF74BE8DE01-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Part No SW: 4G0 035 061 C    HW: 4G0 035 061
   Component: Radio U DAB   H52 0083
   Revision: AB001007    Serial number: 109G10B7529368
   Coding: 010105020100000003
   VCID: 1D318EAF041141D656-8048
   Part No SW: 7P6 035 670 A    HW: 7P6 035 670 A
   Component: H-BNT-EU      H45 0318
   Revision: --------    Serial number: 478G50B7558083
   Coding: 010101060040C1ED01000B0E00000003F0040101
   VCID: 336548179295E7A690-8066
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H25 0045
   Subsystem 3 - Part No: 8R0 060 961
   Component: CD-Database  1886
02071 - Local Databus
                    Fault Status: 01101100
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.17
                    Time: 22:09:21
                    Voltage: 12.10 V
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.17
                    Time: 22:09:20
                    Voltage: 12.10 V
                    Fault Status: 01101000
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.17
                    Time: 22:09:20
                    Voltage: 12.10 V
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000118495147
   Coding: 011C06200001251005080000
   VCID: 3A7B6533B5FF16EE53-806E
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000118461804
End-------------------------(Elapsed Time: 04:14)--------------------------
Mrclopec
Nipomo, CA
C?ID=149231
Congrats on fixing your slip ring. Nice to see the system almost fault free :-)
As for your MMI...Do you get different errors under the following scenarios:
1. 20 pin cable plugged in and video cable unplugged
2. 20 pin cable unplugged and video cable unplugged
3. 20 pin cable plugged in and video cable plugged in
4. 20 pin cable unplugged and video cable plugged in
Just trying to rule out which cable/device may be the culprit.
Cruelworld
C?ID=255222
Hi Mrclopec,
I have ran the 4 different scenarios and see the following results for your information, your thoughts ??
NONE CONNECTED
Saturday,10,October,2015,18:33:24:41103
                Address 5F: Information Electr.       Labels: 4E0-035-6xx-5F.clb
Control Module Part Number: 7P6 035 670 A    HW: 7P6 035 670 A
  Component and/or Version: H-BNT-EU      H45 0318
           Software Coding: 010101060040C1ED01000B0E00000003F0040101
            Work Shop Code: WSC 31414 790 00001
00658 - Control Head
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:44:03
                    Voltage: 12.00 V
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:44:02
                    Voltage: 12.00 V
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:44:01
                    Voltage: 12.00 V
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:44:01
                    Voltage: 12.00 V
5 PIN CONNECTED ONLY
Saturday,10,October,2015,18:30:12:41103
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:40:41
                    Voltage: 12.00 V
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:40:41
                    Voltage: 12.00 V
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:40:41
                    Voltage: 12.00 V
20 PIN CONNECTED ONLY
Saturday,10,October,2015,18:32:05:41103
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:42:35
                    Voltage: 12.00 V
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:42:34
                    Voltage: 12.00 V
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:42:34
                    Voltage: 12.00 V
BOTH 5 AND 20 PIN CONNECTED
Saturday,10,October,2015,18:35:08:41103
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:45:47
                    Voltage: 12.00 V
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:45:46
                    Voltage: 12.00 V
                    Reset counter: 126
                    Mileage: 13232 km
                    Date: 2015.06.19
                    Time: 00:45:46
                    Voltage: 12.00 V
Mrclopec
Nipomo, CA
C?ID=149231
5pin connector seems fine. "Information Display and Control Head (Front) (J685)" exists in all situations (meaning they aren't talking to the Info Elec. Control Mod) and "Local Databus" fault only shows up when the 20 pin connector is connected (meaning there is a communications disruption in the databus wires between the two). There should be 7 wires coming out of the 20 pin connector on the back of the display. Pin 15 (Or/Br) and Pin 16 (Or/Bl) are databus wires that go directly to the Info. Elect. Control Module. Check Continuity on those wires between the connectors on each end. If the wires are fine, then the problem is either in the display, or the unit in the glove box and you will be swapping them out for new ones to test.
