Audi A4/S4/RS4 (8K/FL) 2008+ USED Brake module
bobbik
Poland
C?ID=50728
While i tried to change totally scraped Abs Pump,{"new" with same part no} i get stucked here:
Friday,09,October,2015,19:31:03:22340
VCDS Version: 15.7.1.0
Data version: 20150904
VIN: WAUZZZ8K89N071287   License Plate:
Mileage: 206920km-128574mi   Repair Order: slepy
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 18 19 42 46 52 53 55 56 62 69 72
VIN: WAUZZZ8K89N071287   Mileage: 206920km-128574miles
Address 01: Engine (J623-CAHA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MR    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H01 5485
   Revision: 11H01---
   Coding: 0104002C18172920
   Shop #: WSC 40862 222 62375
   ASAM Dataset: EV_ECM20TDI03L906022MR A01007
   ROD: EV_ECM20TDI03L906022JT.rod
   VCID: 8103C7E5105ECE36D2-80D4
          U1113 00 [047] - -
                    Fault Frequency: 155
                    Mileage: 205924 km
                    Date: 2012.09.23
                    Time: 12:57:21
          U1113 00 [047] - -
                    Mileage: 205924 km
                    Date: 2012.09.23
                    Time: 12:57:21
5182 - Particulate Trap Bank 1
          P2002 00 [236] - Efficiency Below Threshold
                    Fault Frequency: 27
                    Mileage: 205941 km
                    Date: 2012.09.23
                    Time: 18:26:34
4901 - Engine Mount Solenoid Valves (N144/N145)
          P1588 00 [044] - Open Circuit
                    Fault Frequency: 151
                    Mileage: 205924 km
                    Date: 2012.09.23
                    Time: 13:03:04
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AG    HW: 8K0 907 379 AG
   Component: ESP8 front    H04 0240
   Coding: 030500
   Shop #: WSC 02391 823 56573
   VCID: FEF9BC1969A0B1CEAF-80AA
            000 -  -
                    Reset counter: 104
                    Mileage: 206920 km
                    Date: 2012.10.08
                    Time: 13:22:56
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0014
                    Hex Value: 0x0398
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H80 0145
   Coding: 030100
   Shop #: WSC 02399 823 56573
   VCID: B0655221E37497BE6D-80E4
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: J764 ELV MLB  H36 0042
   Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
   Component: KLIMA 1 ZONE  H06 0150
   Revision: A1000000    Serial number: 01200320090516
   Coding: 34080000
   VCID: F0E5922123F4D7BE2D-80A4
00457 - Control Module for Network (J519)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 6
                    Mileage: 197294 km
                    Date: 2012.07.20
                    Time: 16:10:50
                    Fault Status: 01101000
                    Reset counter: 6
                    Mileage: 197294 km
                    Date: 2012.07.20
                    Time: 16:10:50
                    Temperature: 33.0°C
   Component: BCM1 1.0      H26 0253
   Revision: 05026001    Serial number: 00000000347112
   Coding: 2600D0914034AF000001000300001D0D0F1C230800010101000000
   Component: WWS 031111  H07 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
9 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101100
                    Reset counter: 241
                    Mileage: 1048574 km
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2014.12.12
                    Time: 21:28:00
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2014.12.12
                    Time: 21:29:00
                    Reset counter: 241
                    Mileage: 1048574 km
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2014.12.12
                    Time: 21:28:00
                    Reset counter: 35
                    Mileage: 1048574 km
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2008.07.04
                    Time: 02:34:00
03205 - Control Circuit / Actuator for Left Low-Beam Shutter
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2014.12.12
                    Time: 21:28:00
03206 - Control Circuit / Actuator for Right Low-Beam Shutter
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2014.12.12
                    Time: 21:28:00
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1F2BZL
   Coding: 30343435363030303030554A304C384B3053
   Shop #: WSC 02135 785 00200
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: BC7D7611373C63DEC1-80E8
   Serial number: 6334MSME453610585
   Serial number: 6344MSME4520503B4
   Serial number: 6352QSME1422521C6
   Serial number: 6362QSME021C4D0CM
   Serial number: 63732SME6E102D14/
   Serial number: 63832SME085F0506$
9442816 - Front Passenger's Airbag Disabled Indicator Lamp
             B1016 00 [137] -  -
                    Mileage: 206920 km
                    Date: 2012.10.08
                    Time: 13:08:19
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372JJ5000UW
   Coding: 000015
   Shop #: WSC 00100 259 122823
   VCID: BD7B7B1524266AD6F6-80E8
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 930 C    HW: 8K0 920 930 C
   Component: KOMBIINSTR.   H18 0224
   Revision: 00200000    Serial number: 9E2140W39
   Coding: 0F04080002000008010000
   VCID: AD5B4B55F446FA5646-80F8
            000 -  -
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2008.05.27
                    Time: 05:44:19
Address 18: Aux. Heat (J364)       Labels: 8R0-265-105.clb
   Part No SW: 8R0 265 105 A    HW: 8R0 265 105 A
   Component: Standheizung  H11 0110
   Revision: 12001001    Serial number: 20090304031115
   Coding: 5D0000
   VCID: AE594C59F940814E7F-80FA
02251 - Heater Unit Locked
            000 -  -
                    Fault Status: 01110000
                    Mileage: 195234 km
                    Date: 2014.12.12
                    Time: 21:28:52
                    Temperature: 69.0°C
                    Temperature: 77.0°C
                    Voltage: 12.70 V
                    Error Code: 10
                    Temperature: 6.0°C
                    RPM: 874 /min
                        Yes
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G093188148
   Coding: 000303
   VCID: CB9F25CD6A92D46678-809E
   Component: J367-BDM  H06 0160
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008684342
   Coding: 011C02204000410001
   VCID: C18307E558DE0E3692-8094
                    Fault Status: 00101100
                    Reset counter: 122
                    Mileage: 186635 km
                    Date: 2013.12.30
                    Time: 10:07:30
02123 - Door Warning Light / Entry Light
                    Reset counter: 242
                    Mileage: 195234 km
                    Date: 2008.05.27
                    Time: 01:28:41
   Revision: 00002001    Serial number: 0117605909
   Coding: 011A062000390040002001
02739 - Bulb for Tail/Brake Light; Right
                    Fault Frequency: 18
                    Reset counter: 144
                    Mileage: 198317 km
                    Date: 2012.07.25
                    Time: 11:30:13
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Reset counter: 111
                    Mileage: 198832 km
                    Date: 2012.07.27
                    Time: 14:13:10
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008704987
   VCID: C08502E153D4073E9D-8094
                    Reset counter: 122
                    Mileage: 195239 km
                    Date: 2008.05.30
                    Time: 05:51:37
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000334628
   VCID: B36F5D2D1262ACA610-80E6
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 02145 785 00200
   VCID: F7F7A93D869A8086EC-80A2
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 145
                    Mileage: 191335 km
                    Date: 2014.07.15
                    Time: 21:39:30
                    Fault Status: 11101010
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2014.12.12
                    Time: 21:28:54
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2014.12.12
                    Time: 21:28:54
                    Reset counter: 241
                    Mileage: 195234 km
                    Date: 2008.05.27
                    Time: 00:05:50
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
   Component: Concert3      H02 0310
   Revision: 00000005    Serial number: AUZ5Z6I1194840
   Coding: 05000480040105000559070000
   VCID: C48D0EF147CC1B1EB9-8090
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000104553448
   Coding: 010002204000210001
   Shop #: WSC 06325 000 00000
   VCID: C28108E95DD8152E8B-8096
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 B    HW: 8K0 907 383 B
   Component: Anhaenger     H08 0080
   Revision: 1A002002    Serial number: 00000117583604
   Coding: 0100000000000000
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100878801
   Coding: 010C02204000210001
End-------------------------(Elapsed Time: 02:42)--------------------------
We may be able to assist but this should be in the Car Repair Support sub-forum now that you are registered for support. If I can't move it I'll ask one of the guys to do so.
bobbik
Poland
C?ID=50728
Thanks for quick reply. I posted it while i wasn't verified yet. I'll try and report.
bobbik
Poland
C?ID=50728
Works fine, thanks again. But TPMS light is still on, which unit have i to recode?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Mind posting a fresh Auto-Scan? The coding I gave you has TPMS disabled, though it is entirely possible that the previous coding has to do with the current malfunction message. In a fresh scan I would look for DTCs in 03 & 17, if they are both clean - try clearing codes in 03, 17 and 19 (even if there are currently no DTCs stored). Otherwise we'll need to look for a TPMS reset procedure similar to the one on most Continental ESP systems...
bobbik
Poland
C?ID=50728
Sadly this car is total mess, made of few different scrap parts. And it seems like there never wasn't TPMS ,anyway there is no TPMS reset button. So far customer took the car with light on, but he'll back if i call him to make new Auto-scan.
Thanks for the update. Please make sure the VIN that VCDS read matches the windshield, sticker in the trunk and/or B-Pillar label. We obtain the PR codes using the VIN shown in the VCDS Auto-Scan so we just want to make sure the value Sebastian came up with matches the actual car.
bobbik
Poland
C?ID=50728
I think dashboard (with buttons etc) and ABS unit was replaced, rest of modules are original
