Tis' the season.... for non-functioning AC - '14 Touareg TDI
RAGE!!!
As some of you may recall, I was whining late last year about lower than desired AC output, but due to the inexplicable CP events that I have seen during the last 5 years of owning the vehicle, I was distracted, and didn't for a second expect a problem, so no diagnostics took place.
(see previous discussion - Component Protection - Potential Controller Software\Firmware issue )
Now that we are finally getting some warmth in my neck of the woods, it's evident that there's a more substantial issue with the system.
Bottom line is, my AC compressor doesn't kick in.
Autoscan
Wednesday,10,April,2024,19:02:35:38535
VCDS Version: 23.11.0.0
VIN: WVGEP9BPXED013866   License Plate: TOUAREG
Mileage: 203339km-126348mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          62 65 69 6C 6D 72
VIN: WVGEP9BPXED013866   Mileage: 203339km-126348miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
   Component: 3.0TDI FSA    H21 0011
   Revision: 56H21---    CVN: E7FCBDE438D3FF82755A21130E1FC39E
   Coding: 292A4012233600050000
   Shop #: WSC 93288 999 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
   ROD: EV_ECM30TDI0117P0907401K.rod
   VCID: B777000D0EDB8329B2-80E2
   VINID: 9E65D58094A0A1550004320618BB2177C4
22838 - Particulate Filter (Bank 1)
          P226D 00 [11101101] - Damaged or Substrate Missing
                    Mileage: 202475 km
                    Date: 2024.04.01
                    Time: 06:54:32
                    Engine RPM: 1554.50 /min
                    Normed load value: 78.4 %
                    Vehicle speed: 78 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 4 °C
                    Voltage terminal 30: 14.760 V
                    Engine status: COENG_RUNNING
29012 - Particulate Filter (Bank 1)
                    Mileage: 202475 km
                    Date: 2024.04.01
                    Time: 06:54:32
                    Particle filter: soot mass measured: 8.45 g
                    Particle filter: soot mass calculated: 9.51 g
                    Particle sensor: soot volume in exhaust: 0.14 mg/m³
                    Particle sensor: exhaust temperature: 274.3 °C
                    Particle sensor: cleaning deviation reaction time: 0.120
Readiness: 1 2 0 0 0
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 CF    HW: 0C8 927 750 CF
   Component: AL1000 AISIN  002 3376
   Serial number:                CVN: 187C4FCF
   Coding: 00B168
   Shop #: WSC 47391 001 104857
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002_VW52.rod
   VCID: F2E1F1192539260145-80A6
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 408840010EC818 Dataset Number: 7P0012v____ 0001
   Coding: 5B7613C349252556DAFCC89992D8A4407300
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: CA9149F96D290EC1DD-809E
   Part No SW: 4H0 907 064 FK    HW: 4H0 907 064 EK
   Component: BCM2 2.0      H36 0551
   Coding: 0D860000000000000000
   Shop #: WSC 63086 001 1048576
   VCID: F7F7C00D465B432972-80A2
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 0213000390009010
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: B686000A80
   VCID: 850BBAC504B721B970-80D0
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001883690
   Coding: 26001012D63C5D010020180780005D0C431C660882010261800000020000
   VCID: ECDDEF610F1DF0F18F-80B8
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    140423  033 0021
   Serial number: 90243400140508230309
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20317072
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002005140341
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RB6ZK03
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA108664000005784112
   Coding: 010300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28231413800002
   Coding: 318501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: C38F64DD4A03DF891E-8096
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag02B H10 0043
   Revision: --------    Serial number: 003NK00015FO Dataset Number: 7P6003V____ 1547
   Coding: 000000000000000000000000000000003242
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R143040JLC8
   Serial number: 3575LRB40572B5M689OA
   Serial number: 3585LRB401C50OF8B941
   Serial number: 3517ARB40652KQAOP8G
   Serial number: 3527ARB40652KQAOOPLH
   Serial number: 3557BRB401C50QDH8SAL
   Serial number: 3567BRB401C50QLON3L
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 01335NEE000P2
   Coding: 000C15
   VCID: B87503310BC58C51BB-80EC
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0047512 TRW 20140421
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 882 M    HW: 7P6 920 882 M
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658210514592010
   Coding: 0B3733012B000008020004
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526.rod
   VCID: C79770CD7E3BF3A9C2-8092
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001394142 Dataset Number: 7P6067v____ 0040
   Coding: 000103AD00
   GVL: FB4F40455D7F000000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: BF87682D26EBBB697A-80EA
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 41128155225701197223
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000099669702
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: B46D370117AD683197-80E0
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000102810077
   Coding: 011D17205E00453005080000
   VCID: FAF1D93975495E410D-80AE
   Revision: 00002001    Serial number: 0335488971
   Coding: 0186163A68B9509580A00620210A08000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 1361424141
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO29327928
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO29447628
   Coding: 191100
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93222408
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811003178507
   VCID: F5EBCA055C57313960-80A0
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000102860422
   VCID: C89573F17B25FCD1CB-809C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1451300316    Dataset Number:             A001
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: B6690D0909D17A21A9-80E2
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0010
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: FCFDDF21777D60711F-80A8
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Revision: AB001007    Serial number: 156E.0E8010399
   Coding: 020007010000000001
   VCID: A44DC741A74DF8B107-80F0
   Part No SW: 7P6 035 664 F    HW: 7P6 035 664 A
   Component: H-BN-NA       H40 0821
   Revision: --------    Serial number: 273ET0EB001901
   Coding: 020200050040E1EF41022B0E00000003F00001030000000000
   VCID: BB7F1C3D3AF3A74956-80EE
   Subsystem 1 - Part No: 7P6 060 884 J
   Component: NAR 2017/2018  1602
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H27 0045
   Serial number: VWZ8Z9PA3007YZ
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  5950
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000103045387
   Coding: 011817200000253005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 K    HW: 7P6 907 273 K
   Component: RDKBERU25     H09 0009
   Serial number: 10000000130690 Dataset Number: 7P6096v____ 0022
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: C48D67C14F0DD8B127-8090
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H11 0110
   Revision: 5A001001    Serial number: 00008200376188
   Coding: 020D000000000000
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8J442396
   Coding: 0130001
   VCID: B777000DC6DB8329B2-80E2
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 131400152 Dataset Number: 7P6959107C  D045
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000102895888
End-------------------------(Elapsed Time: 05:53)--------------------------
Idling, AC on - Rad fan not ramping up, compressor not turning on, AC output not cold.... controller thinks all is good... no faults, no codes, no cooling! :banghead:
Wednesday,10,April,2024,19:25:02:38535
VIN: WVGEP9BPXED013866   License Plate: AC_ON
                Address 08: Auto HVAC  (7P6 907 040 BR)
19:24:50
  IDE00021-ENG98502   Engine RPM-Data 758 /min
  IDE00198-ENG98502   Refrigerant pressure-Data 6.7 bar
  IDE00380-ENG98502   Coolant fan 1: activation-Data 20.0 %
  IDE00965-ENG98502   Compressor shut-off condition-Data Compressor active: no shut-off condition is present
  IDE00966-ENG98502   Compressor current: actual value-Data 796 mA
  IDE00973-ENG98502   Outside temperature-Data 17.00 °C
  IDE00977-ENG98502   Right front vent temperature-Data 23.10 °C
  IDE00982-ENG98502   Temperature downstream of evaporator-Data 24.20 °C
  IDE00983-ENG98502   Inside temperature-Data 28.60 °C
  IDE01239-ENG98502   Operating hours of air conditioning-Data 3986 H
  IDE01471-ENG98502   Moisture sensor in fresh air intake duct: temperature-Data 164.60 °C
  IDE01473-ENG98502   Refrigerant pressure sensor: status-Data OK
Same conditions as above, but AC off - not changes in pressure or fan speed, etc.
Wednesday,10,April,2024,19:25:34:38535
VIN:    License Plate: AC_OFF
19:25:18
  IDE00021-ENG98502   Engine RPM-Data 757 /min
  IDE00198-ENG98502   Refrigerant pressure-Data 5.7 bar
  IDE00965-ENG98502   Compressor shut-off condition-Data AC button off
  IDE00966-ENG98502   Compressor current: actual value-Data 0 mA
  IDE00973-ENG98502   Outside temperature-Data 16.50 °C
  IDE00977-ENG98502   Right front vent temperature-Data 23.50 °C
  IDE00982-ENG98502   Temperature downstream of evaporator-Data 24.30 °C
I'm not liking this IDE01471 value, but I have to try to figure out what sensor is providing it....
Wednesday,10,April,2024,19:28:37:38535
19:28:29
  IDE00198-ENG98502   Refrigerant pressure-Data 6.4 bar
  IDE00966-ENG98502   Compressor current: actual value-Data 664 mA
  IDE00971-ENG98502   Coolant fan activation: specified value-Data 8.3 %
  IDE00977-ENG98502   Right front vent temperature-Data 23.70 °C
  IDE00982-ENG98502   Temperature downstream of evaporator-Data 24.50 °C
  IDE00983-ENG98502   Inside temperature-Data 28.80 °C
I have also physically checked with my hand on the compressor when the AC button is cycled on and off that it doesn't engage.
Right now, my speculation is that the N280 valve in the compressor is stuck.... this is based on the compressor not kicking in, the pressure not dropping, the evaporator temp not changing, and obviously the AC output not being any colder than ambient temps.
Output test was ran and passed on the rad coolant fan, so that's not an issue.
Output test of the compressor activation was refused by the controller.
I'm done poking around this for tonight, so if anyone wants to throw out some ideas, I'm eager to read them.
Also went for a short drive yesterday while logging a few things, but still no joy....
Huh.... so apparently, while "going to school" regarding modern automotive A/C repair/maintenance/procedures, there appears to be some "drier" filter in these condensers.... :eek:
Need to do some digging around, to try to figure out what kind of a "life expectancy" these have....
open-uri20170126-7343-yfaq3a.
TTT
C?ID=547002
Lifetime if system is never opened.
Dryers were there since AC was invented and noah apprentice carpenter.
So they are only a thing once a component is replaced?
TTT
C?ID=547002
Once the system is opened. Moisture comes in and saturates the silica or whatever is inside them. If filter gets blocked, it becomes very cold.
Does this value seem crazy to anyone else?
The only humidity sensor I can think of is the one at the base of the inside rear view mirror that's combined with the rain sensor..... I need to do some digging here.
Superficially, yes. But at one point Dana posted a map from Boris (her 2017 VR6 T'reg, since traded away) and....
IDE01471-ENG98502,Moisture sensor in fresh air intake duct: temperature-Data,164.60, °C
So I suspect that's a "fake" sensor reading.
Yeah, IDE01471-ENG98502 looks like bogus data (i.e. no sensor installed) to me.
It sounds like the compressor (or the N280 inside it) is faulty but I agree with this:
Most obstructions would present as an increase in high side pressure after compressor activation, reduction on the low side gauge, cold air may (or may not) start to blow and then the pressures would equalize followed by ambient air temps at the vents.
However, in some instance severe restrictions at the receiver/dryer or in-line orifice tube can act like a faulty compressor. After you have evacuated the system and applied a vacuum you find a section of line cold and sweating (wet from condensation) after 15 - 20 minutes. That type of behavior is not right at all but it happens when the recovery equipment was unable to get all of the refrigerant out due to the restriction.
I would not obsess over restriction possibility that as long as there wasn't ever any leak stop installed and the oil doesn't show signs of metal when you have it evacuated but it is a good idea to replace the dryer any time the system is opened up for compressor replacement. Since 7P0 898 191 was Dropped: 1 Jul 2014 and the Supersession is 7P0 898 191 A my guess is they had problems with those.
It's so weird that the compressor doesn't turn on, but the controller also refuses to run an output test on it..... This really makes it seem like there's some measurement or reading that causes the controller to block things.from happening.
Since there isn't an active compressor shut-down I think the old-school light bulb test may be best. I used the Bosch connector fuel injector Noid light for this but the same can be done using a standard light bulb. Peter makes reference to that here and most 168 / 194 bulbs can be modified to slip into those connectors.
Speaking of Output Tests, the next version of VCDS has an entirely re-worked SOT function for UDS protocol modules. For that reason you may want to wait a day or two and then grab the latest Release from this location so you can repeat testing:
Thanks @Dana
I've been trying to find an opportunity to get to the N280 connector to put a meter on it, but its in a super awkward placement and I really don't want to pull the PS pump just to gain access to it. I may have to rip the wheel and wheel liner off in an attempt to access it from the wheel wheel opening since access from above is super limited.
Had a burst of motivation last night as the weather was decent, so I started crawling all over the engine bay for a bit.... got some picks out and struggled to attempt to unlock the N280 connector "by feel"... managed to get it off.
Checked signal with a meter... yup... gets power when A/C is activated.
I couldn't get sufficient access to check resistance on the N280, and hitting the contact pins blindly with the meter leads didn't work so well :banghead:
Checked again with VCDS... yup... it threw codes as I disconnected it and messed around with it.
   Coding: 004DBD
   Coding: 025223
   Coding: 010300
01232 - A/C Compressor Regulator Valve (N280)
                    Fault Status: 00101100
                    Reset counter: 37
                    Mileage: 204669 km
                    Date: 2024.04.30
                    Time: 19:30:00
Reconnected, cleared codes, did some logs....
N280
A/C
Now, my new theory is that the N280 is actually stuck or it gets jammed while attempting to open.... this is based on the log that shows pressure barely building and compressor torque changing very little....
What's really awesome about all this is the fact that I am forced to deal with VW clowns now, as I don't have an A/C service station or the required equipment to properly evacuate and recharge the system.... I've already called a few local dealers trying to get them to quote me an evacuation and recharge, but they all refuse, and want me to pay them to diagnose the system prior to anything else.... so this means, I'm going to give them $200 just so that they can tell me that I need a new compressor (when I'm almost certain that I just need a new N280 which they don't sell, but I can source online). Even if I neglect the $200 gift to the dealer, I'm still in a pickle as I need the system evacuated so I can take off the PS pump in order to get sufficient access to the N280 valve to remove it out of the compressor, swap it out, then return to the same clowns to have the system recharged after more than likely having to pay another diagnostic fee first..... or I can just say "shut up and take my money" and let them replace the complete compressor at 10x the actual repair cost. :banghead:
  • Informative
Oh yeah.... forgot to add this bit of "supporting" info as well
12:46:06
  IDE00021-ENG98502   Engine RPM-Data 805 /min
  IDE00025   Coolant temperature 54.70 °C
  IDE00198-ENG98502   Refrigerant pressure-Data 5.2 bar
  IDE00966-ENG98502   Compressor current: actual value-Data 600 mA
  IDE00967-ENG98502   Compressor current: specified value-Data 599 mA
  IDE00971-ENG98502   Coolant fan activation: specified value-Data 5.3 %
  IDE00973-ENG98502   Outside temperature-Data 13.00 °C
  IDE00982-ENG98502   Temperature downstream of evaporator-Data 20.50 °C
  IDE00983-ENG98502   Inside temperature-Data 28.50 °C
  IDE01288-ENG98502   Compressor power restriction-Data Refrigerant pressure
So the way I'm interpreting IDE01288 is that the controller is not allowing the compressor to turn on due to not sensing enough refrigerant present... which also coincides with my theory that the N280 isn't opening up to allow said refrigerant to flow through the compressor, etc.
So running a search has resulted in me finding a comparable block map from the past.... I believe this also supports all the blabbing I've been doing above, but please feel free to correct me.
My Values(source) Working A/C Values
IDE00021-ENG98502,Engine RPM-Data,756, /min
IDE00025,Coolant temperature,63.00, °C
IDE00198-ENG98502,Refrigerant pressure-Data,6.2, bar
IDE00380-ENG98502,Coolant fan 1: activation-Data,30.0, %
IDE00966-ENG98502,Compressor current: actual value-Data,328, mA
IDE00967-ENG98502,Compressor current: specified value-Data,333, mA
IDE00971-ENG98502,Coolant fan activation: specified value-Data,25.0, %
IDE00973-ENG98502,Outside temperature-Data,14.00, °C
IDE00982-ENG98502,Temperature downstream of evaporator-Data,6.60, °C
IDE00983-ENG98502,Inside temperature-Data,20.50, °C
IDE01288-ENG98502,Compressor power restriction-Data,no limitation,
IDE01473-ENG98502,Refrigerant pressure sensor: status-Data,OK,
Why? Pretty much any reasonably equipped independent repair shop should have that, and it's not like they have to be knowledgeable about VWs or T'regs; the A/C system, particularly the refrigerant part of it isn't all that special.
I guess you do have a good point.... I had called 3 other shops that were actually known to be capable of a wide range of repairs, only to find out that none have A/C service stations....
I agree with Uwe and did some clicking around for independent shops in your area. I like the look of the google reviews on a family owned shop called: C S Automotive
I would try to find a place like that to do the evacuation. Since you don't want the system open for longer than necessary I would source the new N280 and have it on hand before having the system evacuated. That may allow you to have it discharged early in the day, return home for parts swapping and perhaps return the same day before the business closes so they can put it under vacuum and then recharge it.
Oh, Canada! :D
Thanks for the suggestions. I've already located a shop that's on my "drive home" so I will stop by to check it out and talk to them today.
I think I'm going to roll the dice and simply pay for an evacuation\flush\recharge before I buy the new N280. I know it's risky, but I'm really trying to avoid driving the egg, even for short distances with the system evacuated as in my mind, this would also mean a loss of lubricity......
Interestingly enough, I need to really get in there to clearly see where the N280 is located on my compressor.... looking up the Denso part number that I believe I have, it appears that the N280 might be on the side of the compressor and may (I hope) be possibly removed while the compressor is still bolted up in there (I'm worried the frame rail will be right next to it)
Will follow up with updates.
