Audi A4 estate MJ 2024 ->
vwflappie
C?ID=970
Last Friday (5 april 2024) i had a brand new Audi A4 etstate 8W (5 KM) , after connecting VCDS and made a gateway installation list, and saw all modules.
The only module i could connect was 19-gateway...
Unfortunaly i had no time to try to make a scan or any other info. Also it was a customer car, and is no longer available for testing.
(I have immideatly tried an other car (2019 VW Tiguan) which worked perfectly)
Is this a known problem?
AINils
Germany (AIB)
C?ID=56975
Know issue is SFD2, which "hide" all controller except Gateway.
first of all you have to "open" SFD2" and then to deactivate diagnsotic filter in Gateway. After it you can read all controller.
But actually VCDS can't unlock SFD, it need some time.
  • Agree
vwflappie
C?ID=970
Thank you... that explains.
We have a GRP/ Odis/ GEKO account, and i dit unlock SFD from the gateway. (had to switch off the transport mode), which worked perfectly with VCDS (SFD and transport modus). :)
Diagnostic filter is in adaptation?
SFD end SFD2 is the same?
That's my understanding. Unlock Gateway via SFD first, then turn off Diagnostic Filters in Adaptation.
vwflappie
C?ID=970
Thanx, will try on the next oppertunity.. en will report back.
vwflappie
C?ID=970
Have tried it, unlocked SFD (Succes)
in adaptation --> IDE13756-Diagnosis Filter: Activation
From active --> not active
i get: Request Sequence error
NEtech
Denmark
C?ID=56995
Do you use Beta 24.6.0 ?
GTPprix
Metro Detroit, USA
C?ID=588547
I feel like rather than making another post this is probably the best place for my question as it dovetails into OP's situation as I'm in the same boat. I am admittedly green on VAG stuff but I know a thing or two about GM/FCA/Ford etc and a decent amount of that correlates to what I've seen so far.
That being said at this point I cant even get actual code data from a 2024, I see several adaptation options in the gateway that appear to be worded as if they may allow traffic to pass (If I'm able to unlock it) BUT I'm not sure exactly which one so I'm hoping one of you could tell me the EXACT adaptation to change to accomplish this or is it indeed IDE13756 (diagnosis filter)? Is there another option that will allow ALL traffic to pass?
Thank you!
It's rather difficult to answer that without knowing exactly what Gateway you have.
GTPprix
Metro Detroit, USA
C?ID=588547
Understood I'll grab that info; thank you. I incorrectly assumed there was commonality for 2024 UNECE applications.
GTPprix
Metro Detroit, USA
C?ID=588547
Friday,14,June,2024,16:49:28:02172
VCDS Version: Release 24.5.0 (x64)
Address 19: CAN Gateway
Control Module Part Number: 4KL 907 468 N
Component and/or Version: Gateway H06 3039
Software Coding: 03030001000806405407000000590132FC9A0000BC000200090000CE04030000
Work Shop Code: WSC 31414
VCID: DBE87BC743D58712E21-818E
Advanced Identification/FAZIT
Serial number: F0599778028641
Identification: BX1-247
Date: 31.01.24
Manufacturer number: 7780
Test stand number: 2864
Flash Status
Programming Attempts(application): 0/0/0/0/0/0
Flash Date: 00.01.01
Misc.
Hardware number: 4KL 907 468 L
Workshop System Name: J533
Equipment/PR Code: FFFFFFFFFFFFFFFFFFFFFFFF
Dataset Number: 4M0909515AK
Dataset Version: 0132
ASAM Dataset: EV_Gatew31xUNECE
ASAM Dataset Revision: 005017
Car Info
Chassis Number: WA1VWBF72RDXXXXXX
Engine code: ----
VCDS Info:
Labels: None
ROD: EV_Gatew31xUNECE_VW53.rod
Assuming this is what you're after :)
GTPprix
Metro Detroit, USA
C?ID=588547
@Uwe Any thoughts on the above and should I move to 24.6.0 Beta for this application?
It doesn't cost much to try, does it? ;)
GTPprix
Metro Detroit, USA
C?ID=588547
No sir! I meant more of the question as to which specific Adaptation to flip for diagnostic traffic to pass :) But I guess as long as I can eventually read all of the default configs I can throw a little bit of caution to the wind :D
I think it might be this one:
IDE16611 -- Diagnosis filter: temporary deactivation
But I don't personally have a car with this nonsense, and I doubt I ever will. The Eurocrats and VW have stepped over the line with this stuff as far as I'm concerned. I refuse to drive a car that requires the manufacturer's permission in real-time to read fault codes.
vwflappie
C?ID=970
Admin Edit: An ID.7 is not an A4 and doesn't belong in this thread. Previous content now here.
vwflappie
C?ID=970
Hello Uwe,
It was more of that this was the same issue, and it workt. I thought that was usefull to mention.
so before you can't see anything exept 19-gateway, after the mentioned steps everything was visible.
if these up-date's are not apriciated let me know...
They are, but need to be in the right place; you're not asking for product support, and at this point, the OP's issue is well understood.
