Wednesday,24,April,2024,19:33:42:56187
VCDS Version: 23.11.0.0 (x64)
VIN: WAUZZZF49HA104856 License Plate: CA66NSJ
Mileage: 89574km-55658mi Repair Order:
Chassis Type F4-AU49 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 81 A5
AC BB BC D6 D7
VIN: WAUZZZF49HA104856 Mileage: 89574km-55658miles
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CRTC) Labels: Redir Fail!
Part No SW: 8W0 907 401 E HW: 059 907 309 F
Component: 3,0l V6 TDI H23 0003
Revision: C7H23--- CVN: E2E68915FF37B1B7B866C2ADB866C2AD
Coding: 122A40320526050324080000000000000000000000000000
Shop #: WSC 39361 002 1048576
ASAM Dataset: EV_ECM30TDI0118W0907401E 001003
ROD: EV_ECM30TDI0118W0907401E.rod
VCID: 39793309B882E959C4-806C
VINID: 9D196AAAA5842584410042051838FBD299
9645 - Reductant
P20E8 00 [01100000] - Pressure too Low
Mileage: 87775 km
Date: 2024.03.23
Time: 06:29:25
Engine RPM: 948.50 /min
Normed load value: 40.0 %
Coolant temperature: 30 °C
Intake air temperature: 5 °C
Voltage terminal 30: 14.940 V
Unlearning counter according OBD: 34
Outside temperature: 3.5 °C
Pressure sensor for reducing agent: measured pressure: 82 hPa
Pump for reducing agent: speed: 2996.0 /min
Sensor for reducing agent tank temperature: temperature: 4.5 °C
Reducing agent pump: activation: 50.00 %
Sensor for reducing agent fill level: fill level height: 106 mm
Sensor 2 for temp. reducing agent: act. value: 4.0 °C
Part No SW: 8W0 927 158 HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H05 1010
Revision: --H05--- CVN: 46A456EC
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011_AU49.rod
VCID: 7F0D1D11E6260769BA-802A
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Dataset Number: 8W0909504K 0003 CVN: B085950A
Coding: 14AA309930A20A9A11A6489600835292E6A5D2280C0C508812004A4967A54B
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 499943C9E86279D954-801C
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 F HW: 8W0 820 043 F
Component: Klima Zone 3 H32 0071
Coding: 2618002D5544440D02000100880000000000000000000000000000000000
Shop #: WSC 06325 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 36633835899C062129-8062
Subsystem 1 - Part No SW: 4M2 820 021 HW: 4M2 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001152962
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: 3F388B5800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: Klima Heck H40 0073
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CF HW: 8W0 907 063 BF
Component: BCM1 MLBevo H13 0266
Dataset Number: 8W0909514J 0042
Coding: 07501143C13900CD054C51185B2F00F9110B3108000000000000000020001C810A450222025601
VCID: 01099BE990D27199CC-8054
Subsystem 1 - Part No SW: 8W2 955 119 HW: 8V2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 160830 043 0813
Serial number: 89425300301624305720
Coding: 5BC7F7
Serial number: 20136901X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 05 07 2016 00581309
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE108091611521024
Coding: 230000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 D HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B10421729
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000134824006
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0103
Serial number: 003UP000KZA. Dataset Number: 8W0909602AH 0001
Coding: AACCF0C00C800000585400F3D08C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005013
ROD: EV_AirbaAU10BPAAU736_005.rod
VCID: 4C977ADDE7106CF16F-8018
Subsystem 1 - Part No SW: ----------- HW: 442 060 211 16
Serial number: 3577Y00A720DD061448
Subsystem 2 - Part No SW: ----------- HW: 442 062 710 16
Serial number: 3587Y00A320DD06251E/
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 810 16
Serial number: 3517700B722160F2D376
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 810 16
Serial number: 35277009B22160F5D1AD
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 510 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C521FBEE4E41-
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 510 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C521FBEE3537W
Subsystem 7 - Part No SW: ----------- HW: 442 0C1 610 16
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500AB21FBEE5923S
Subsystem 8 - Part No SW: ----------- HW: 442 431 410 16
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00BD1FFD130E3A+
Subsystem 9 - Part No SW: ----------- HW: 442 431 410 16
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00A51FFD112644K
Part No SW: 4M0 907 129 HD HW: 4M0 907 129 HD
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 79F9F309F802295984-802C
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 941 A HW: 8W5 920 941 A
Component: MMA4M17DIEUK H06 0361
Revision: 0361v1.0 Serial number: SHLFHAFBS
Coding: 24A469D0288006000123E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 3E732015A1ACCE61F1-806A
Part No SW: 4M1 907 468 D HW: 4M1 907 468 A
Component: Gateway H16 0107
Revision: 4V010003 Serial number: 0344V00C016B13 Dataset Number: 8W0909515F 0050
Coding: 03010001000086407F07000000590012C8100007100000000100000000000000
GVL: 01503C0008040200408C08000000C80000080000000000000000000000000000
ASAM Dataset: EV_GatewCONTIAU736 002040
ROD: EV_GatewCONTIAU736_002_AU49.rod
VCID: 387F360D8388F0513B-806C
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20161114021314 20288
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 8109022104
Address 29: Left Light
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 16000272204013
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 326B042565F41A0105-8066
Address 39: Right Light
Part No SW: 8W0 959 593 E HW: 8W0 959 593
Component: TSG FS 005 0055
Serial number: 0000226606706 Dataset Number: 8W0909872D 0024
Coding: 001D8A215001000000001082
ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Dataset Number: 8W0909852P 0033
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 41895BE9D052B1998C-8014
Address 46: Central Conv.
Part No SW: 8W0 959 592 E HW: 8W0 959 592
Component: TSG BFS 005 0055
Serial number: 0000228436735 Dataset Number: 8W0909873D 0024
Coding: 001D8A215C01000000001080
VCID: 4B9579C1E21E6BC966-801E
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGS2.clb
Part No SW: 8W0 035 192 E HW: 8W0 035 192 A
Component: MU-HS-LND-EU 045 0170
Serial number: Dataset Number: 8W0909545M 0036
Coding: 01940201FF0A000013111101000A00102F0002C601F00100CE
ROD: EV_MUHigScl6C3DELP.rod
Subsystem 1 - Part No SW: 8W0 919 866 M HW: -----------
Component: ECE 2017 --- 0024
Multimedia System 1:
Subsystem 2 - Part No SW: 8W2 919 604 HW: 8W2 919 604
Component: AU49x_DU_STD H40 0008
Serial number: AUZ8Z9GBH00MJW
Subsystem 3 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
Component: ControlUnit_B H22 0134
Serial number: APVAK101111600020076
2562 - Navigation System
B126C F0 [00001000] - Navigation Database Faulty
Reset counter: 206
Mileage: 88519 km
Date: 2024.03.29
Time: 16:09:57
Voltage terminal 30: 12.4 V
3084 - GSM antenna 2
B1533 13 [00001001] - Open Circuit
Fault Frequency: 11
Reset counter: 182
Mileage: 87412 km
Date: 2024.03.20
Time: 11:04:57
Voltage terminal 30: 12.0 V
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31068646700000 Dataset Number: 8W0909541C 0013
Coding: 0550
0038 - Motor for Load Space Cover
B12F0 4B [00001000] - Over Temperature
Mileage: 88457 km
Date: 2024.03.28
Time: 16:05:19
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W2 713 041 H HW: 4M2 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20161114000573
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736_AU49.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H15 0042
Dataset Number: 8W0909466D 0031
Coding: 0404090200000403024023A0A50000FC00F0C020C280
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
VCID: 3B752901B2BEDB49D6-806E
1123600 - Predictive Route Data
B1630 02 [00001000] - Signal Failure
Reset counter: 211
Mileage: 88385 km
Date: 2024.03.27
Time: 17:03:57
Control Module temperature: 16 °C
Voltage terminal 15: 14.80 V
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 B HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0005
Dataset Number: 8W0909571C 0003
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736_AU49.rod
VCID: 306F0E2D6BF8281173-8064
Part No SW: 8W0 959 595 E HW: 8W0 959 595
Component: TSG HFS 005 0055
Serial number: 0000228662498 Dataset Number: 8W0909897D 0025
Coding: 000D88200001000000001080
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 4E9370D5110C5EE101-801A
Component: TSG HBFS 005 0055
Serial number: 0000228662499 Dataset Number: 8W0909896D 0025
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 05:58)--------------------------
