Label file support
   #21
golfi_vend
Tartu, Estonia
C?ID=195131
I'd highly appreciate it if something from following goes to next dataset of vcds because I've confirmed some of these bits.
Tests were carried on MY07 Passat 3C Saloon with halogen headlights.
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 0000000000000000009800209400802443517788406005600080C7200001
0000000000000000008800208000028C47C0908855200160E40804200001
Test coding: 0000000000000000008800A0850000EC47F1908857200920648820200001
   Shop #: WSC 05311 123 12345
   VCID: 3979DFA1B05F10F679-806C
   Subsystem 1 - Part No SW: 3C1 955 419 A    HW: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 28110  03  0205
   Coding: 00BF95
   Component: RLS 110213 05  54  0403
   Coding: 8F9028
                    Reset counter: 29
                    Mileage: 173779 km
                    Date: 2016.04.16
                    Time: 01:33:59
                    Voltage: 11.35 V
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 29
                    Mileage: 173779 km
                    Date: 2016.04.16
                    Time: 01:33:59
                    Voltage: 11.35 V
                    Reset counter: 29
                    Mileage: 173779 km
                    Date: 2016.04.16
                    Time: 01:34:00
                    Voltage: 11.35 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 29
                    Mileage: 173779 km
                    Date: 2016.04.16
                    Time: 01:34:03
                    Voltage: 11.35 V
02198 - Bulb for Tail Light 2; Left (M49)
                    Reset counter: 29
                    Mileage: 173779 km
                    Date: 2016.04.16
                    Time: 01:34:00
                    Voltage: 11.35 V
02199 - Bulb for Tail Light 2; Right (M50)
                    Reset counter: 29
                    Mileage: 173779 km
                    Date: 2016.04.16
                    Time: 01:34:00
                    Voltage: 11.35 V
BCM puuduvad codingud:
Byte00-08 - It's written it's always 00, but I've seen otherwise.
Byte 9 Bit 2 - This bit active will generate a fault code about kessy terminal module(the one that handles the START button next to gear shifter. - confirmed
Byte 9 Bit 7 -
Byte 11 Bit 0 - DRL off with handbrake NAR - confirmed
byte 11 bit 1 - Horn active with term.15 off ? - Copied from 1k0 bcm
Byte 11 Bit 3 - DLA coding? - will generate fault about HBA (FLA installed) confirmed
Byte 11 Bit 5 -
Byte 11 bit 6
Byte 14 Bit 5
byte 16 bit 3
Byte 16 Bit 5
Byte 17 Bit 2 - Bi-Xenon without addional high beam - i guess also copied from 1k0 bcm, but think ive seen elsewhere from different scans.
Byte 20 Bit 2 -
Byte 22 Bit 5 -
byte 25 bit 2 - high beam via shutter
Byte 26 bit 5 – DRL logo signal for instrument cluster, confirmed. This description is available in 1k0 bcm.
Byte 29 Bit 3 - Something about high beams, will generate faultcodes:
02498 - Left Low Beam Reflector Motor (V294)
007 - Short to Ground
02499 - Right Low Beam Reflector Motor (V295)
_Val
Latvia
C?ID=356659
If possible - 028-906-021-AFN.lbl
Not yet :D Engine is just ~25 years old.
Didn't VAG used AFN in USA cars? It is/was quite popular in Europe.
;SW:028-906-021-CE   HW: ---  Engine
;Component:1.9l R4 EDC   00SG  0803, Coding:00002
;Thursday,04,June,2020,13:41:08:44445
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: removed from post (ask if you need it)
1,0,,
1,1,,,
;0 /min,RPM,
1,2,,,
;0.0 mg/str,Inj. Quantity,
1,3,,,
;0.700 V,Voltage,
1,4,,,
;88.2°C,Temperature,
2,0,,
2,1,,,
;0 /min,RPM,
2,2,,,
;0.0 %,Load,
2,3,,,
; 0  1  0,Bin. Bits,
2,4,,,
3,0,,
3,1,,,
;0 /min,RPM,
3,2,,,
;595.0 mg/str,Mass Air / Rev.,
3,3,,,
;1275.0 mg/str,Mass Air / Rev.,
3,4,,,
;4.8 %,Duty Cycle,
4,0,,
4,1,,,
;0 /min,RPM,
4,2,,,
;7.0 °BTDC,Ign. Timing,
4,3,,,
;0.0 °BTDC,Ign. Timing,
4,4,,,
;94.4 %,Duty Cycle,
5,0,,
5,1,,,
;0 /min,RPM,
5,2,,,
5,3,,,
5,4,,,
6,0,,
6,1,,,
;0.0 km/h,Speed,
6,2,,,
; 0  0  0,Bin. Bits,
6,3,,,
;  000000,Bin. Bits,
6,4,,,
;255.0,(no units),
7,0,,
7,1,,,
;47.7°C,Temperature,
7,2,,,
7,3,,,
;136.8°C,Temperature,
7,4,,,
8,0,,
8,1,,,
;0 /min,RPM,
8,2,,,
;17.2 mg/str,Inj. Quantity,
8,3,,,
;0.2 mg/str,Inj. Quantity,
8,4,,,
;32.8 mg/str,Inj. Quantity,
9,0,,
9,1,,,
;0 /min,RPM,
9,2,,,
9,3,,,
;51.0 mg/str,Inj. Quantity,
9,4,,,
10,0,,
10,1,,,
10,2,,,
;989.4 mbar,Absolute Pres.,
10,3,,,
;979.2 mbar,Absolute Pres.,
10,4,,,
;0.0 %,Load,
11,0,,
11,1,,,
;0 /min,RPM,
11,2,,,
;183.6 mbar,Absolute Pres.,
11,3,,,
11,4,,,
;99.6 %,Duty Cycle,
12,0,,
12,1,,,
;01010000,Bin. Bits,
12,2,,,
;0.00,(no units),
12,3,,,
;12.69 V,Voltage,
12,4,,,
13,0,,
13,1,,,
;0.00 mg/str,Inj. Quantity,
13,2,,,
13,3,,,
13,4,,,
14,0,,
14,1,,,
14,2,,,
14,3,,,
14,4,,,
15,0,,
15,1,,,
;0 /min,RPM,
15,2,,,
15,3,,,
;0.00 l/h,Fuel Consump.,
15,4,,,
16,0,,
16,1,,,
;99.6 %,Load,
16,2,,,
;00111001,Bin. Bits,
16,3,,,
;      00,Bin. Bits,
16,4,,,
;12.69 V,Voltage,
17,0,,
17,1,,,
17,2,,,
17,3,,,
17,4,,,
18,0,,
18,1,,,
;0.0 km/h,Speed,
18,2,,,
;      01,Bin. Bits,
18,3,,,
18,4,,,
19,0,,
19,1,,,
;0.700 V,Voltage,
19,2,,,
;4.160 V,Voltage,
19,3,,,
19,4,,,
20,0,,
20,1,,,
;0 /min,RPM,
20,2,,,
20,3,,,
;0.700 V,Voltage,
20,4,,,
;0.0 %,Load,
21,0,,
21,1,,,
21,2,,,
21,3,,,
;4.8 %,Duty Cycle,
21,4,,,
; 010 000,Bin. Bits,
22,0,,
22,1,,,
22,2,,,
22,3,,,
;94.4 %,Duty Cycle,
22,4,,,
;0.0 km/h,Speed,
23,0,,
23,1,,,
23,2,,,
23,3,,,
;99.6 %,Duty Cycle,
23,4,,,
24,0,,
24,1,,,
24,2,,,
24,3,,,
24,4,,,
;255.0,(no units),
25,0,,
25,1,,,
25,2,,,
25,3,,,
25,4,,,
;Thursday,04,June,2020,13:42:15:44445
;01 N/A
;02 N/A
;03 N/A
;04 N/A
;05 N/A
;06 N/A
;07 N/A
;08 N/A
;09 N/A
;10 N/A
;11 N/A
;12 N/A
;13 N/A
;14 N/A
;15 N/A
;16 N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
;21 N/A
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
;50 N/A
;51 N/A
;52 N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
Nope. The only VE (distributor pump) TDI engines we got were 1Z, AHU, and ALH.
It looks like there is a German file for it though: 038-906-012-AFN and it's a plain-text .LBL.
