I would like to retrofit footwell lights, door warning lights and puddle (boarding) lights to Octavia III (sorry for the mistake in the heading) 1.6 TDI, MY2016.
I have one question regarding physical connection of door warning lights and puddle lights. I already found a case of retrofiting footwell lights on Golf 7. Footwell lights should, according to that retrofit, physically connect to BCM connector C pin 72 on BCM 5Q0 937 086 Q. Is this the same for my module 5Q0 937 086 AH?
Also I can't find any info where to connect door warning lights and puddle (boarding) lights. Does anyone have any experience on this?
Thx.
Full autoscan:
Thx.
Full autoscan:
Friday,18,September,2015,06:26:02:46154
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Mileage: 1321km-820mi Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: Mileage: 1321km-820miles
Address 01: Engine (2D2D2-CXXB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2370
Revision: 22004001
Coding: 01114012432401090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI03004L906056CL 002005
ROD: EV_ECM16TDI03004L906056CL_SK37.rod
VCID: 79F9BFF9F86D18F61A-802C
25347 - Loading Mode active
P169A 00 [096] - -
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 61585000003341
Coding: 1C07629114230970007D060841C7243846289000608224F200400070C002
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
VCID: 4B953531E2715A66F8-801E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 Q HW: 5E0 907 044 Q
Component: Climatronic H04 1002
Revision: 00001K07
Coding: 02010104002100011005000000101000
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 33654DD19A8122A690-8066
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 086 AH HW: 5Q0 937 086 AH
Revision: -------- Serial number: 86581806151286
Coding: 0C000842424700DB47E04000000407080000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 000FD21D9BB7493E5D-8054
Slave 1:
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 150602 041 0570
Serial number: 150612080552
Coding: 065DDD
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559 Labels: 8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 21119634
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39291515702274
Coding: 0001050001
ROD: EV_EPHVA14AU3700000_SK37.rod
VCID: 3C7766EDB7DFEDDE41-8068
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQPBGKBT/
Coding: 98CCC000000000005C5400CC000800000065
ROD: EV_AirbaVW20TS6VW48X_SK37.rod
VCID: 0F2DE121D6E92646D4-805A
Subsystem 1 - Part No SW: ----------- HW: 454 000 606 15
Serial number: 3576U000000AEC90E41T
Subsystem 2 - Part No SW: ----------- HW: 454 000 506 15
Serial number: 3586U00000040B90E419
Subsystem 3 - Part No SW: ----------- HW: 454 801 706 15
Serial number: 3516R2B2D3207000000$
Subsystem 4 - Part No SW: ----------- HW: 454 801 506 15
Serial number: 3526RB62B3207000000%
Subsystem 5 - Part No SW: ----------- HW: 454 802 404 15
Component: FrontSensor_D 114 0149
Serial number: 3556V22FC3A06000000E
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 M HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20150621400488
Coding: 1400
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 5E0 920 781 B HW: 5E0 920 781 B
Component: KOMBI 206 7640
Coding: 07A40A002180000801082A001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_SK37.rod
VCID: 275DA9815E595E063C-8072
16777024 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Fault Frequency: 194
Reset counter: 72
Mileage: 9 km
Date: 2000.03.08
Time: 07:58:18
Part No SW: 5Q0 907 530 AE HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1223
Revision: -------- Serial number: 0003654141
Coding: 030100040F087300EB000248080F00010001050000000000000000000000
ROD: EV_GatewLear.rod
VCID: 74E78ECDDF0F659E49-8020
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000A1624110615
Subsystem 3 - Part No SW: 5Q0 915 181 F HW: 5Q0 915 181 F
Component: J367-BDM H08 0223
Serial number: 52162N56484290566752
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0031
Serial number: 0000155316642
Coding: 001001208000040000001100
ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
VCID: 45810309C415AC162E-8010
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000006505260
Coding: 010200
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0103
ROD: EV_SteerAssisMQB.rod
VCID: 43851D11CA21922600-8016
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0031
Serial number: 0000155413532
ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
VCID: 44871E0DCF2F951E39-8010
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000006454842
Coding: 190200
Part No SW: 5Q0 035 840 A HW: 5Q0 035 840 A
Component: MU-S--ER H24 0241
Serial number: SKZAZ2R8645499
Coding: 03730200FF00000011110001000000002F0200C40120010002
Shop #: WSC 73430 790 00063
ROD: EV_MUStd4CTSAT_SE25.rod
VCID: 2B5555B142B17A66D8-807E
Media Player Position 1:
Subsystem 1 - Part No SW: 5E0 919 605 H HW: 5E0 919 605 H
Component: ABT_Std-2 H41 1028
Serial number: SKZ8Z9RBS0080L
End-------------------------(Elapsed Time: 03:18)--------------------------
