2022 Audi Q3: All 4 Cam Adjustment Actuator Bs Implausible
PatQ3
Syosset, NY, USA
C?ID=575888
Looking for help on what to check/try next on my Q3's Camshaft Adj Actuators. All the Bs are faulting as implausible (scan below). When I clear them with the key on, no ignition, they go away, but pop right back upon ignition. If I try to clear them while the car is running they don't clear and just pop right back up. I have traced all the individual wiring through the harness per the wiring diagram to their pin locations. I have also pulled all of the actuators out (they look ok to me) and moved them around and the faults don't change (so the As don't seem to ever come up even when swapping the solenoids around). I am not getting any misfires and the car seems to run ok otherwise. I have read through the "case study" thread (https://forums.ross-tech.com/index.php?threads/25709/) but I haven't found anything there to help with my particular case. When I try to run the Camshaft Adjustment test in Basic Settings it immediately tells me that it ran ok but system not ok (I assume because these are faulting?). The other Camshaft tests in Basic Settings are running and completing with an OK. Are there any other means of diagnosing these for a cause in Basic Settings or Advanced Measurements? Are there any usual potential culprits to explore (i.e., spark plugs, etc)? Thank you for any thoughts...
Tuesday,02,April,2024,20:55:13:45997
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
VIN: WA1BUCF34N1131296   License Plate:
Chassis Type: F3-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 22 36 3C 42 44 4B 52 5F 6C 6D
          75 A5 BB BC CA CF D6 D7 DE
VIN: WA1BUCF34N1131296   Mileage: 9867km-6131miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DSPA)       Labels: None
   Part No SW: 83A 907 115 H    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0001
   Revision: 1DH31000    CVN: 73F8B002
   Coding: 022A00122466010F24000000000000000000000000000000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS01183A907115H 001002
   ROD: EV_ECM20TFS01183A907115G.rod
   VCID: 2B0310E7238E0A82AA1-807E
   VINID: 9D105295358311E0410C108918A46FEBEB
25845 - Cam Adjustment Actuator B; Cylinder 1
          P11A4 00 [10101111] - Implausible Signal
                    Fault Frequency: 13
                    Mileage: 9867 km
                    Date: 2024.04.02
                    Time: 19:27:11
                    Engine RPM: 1222.50 /min
                    Normed load value: 7.8 %
                    Coolant temperature: 48 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 11.860 V
                    Engine status: COENG_RUNNING
25847 - Cam Adjustment Actuator B; Cylinder 3
          P11AC 00 [10101111] - Implausible Signal
                    Fault Frequency: 13
                    Mileage: 9867 km
                    Date: 2024.04.02
                    Time: 19:27:11
25848 - Cam Adjustment Actuator B; Cylinder 4
          P11B0 00 [10101111] - Implausible Signal
                    Fault Frequency: 13
                    Mileage: 9867 km
                    Date: 2024.04.02
                    Time: 19:27:11
25846 - Cam Adjustment Actuator B; Cylinder 2
          P11A8 00 [10101111] - Implausible Signal
                    Fault Frequency: 13
                    Mileage: 9867 km
                    Date: 2024.04.02
                    Time: 19:27:11
Readiness: 0000 0100
Address 02: Auto Trans (J217)       Labels: 09P-927-749-V1.clb
   Part No SW: 09G 927 158 GD    HW: 09G 927 158
   Component: AISIN AQ8     206 3820
   CVN: 1825B020
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 7BA3E0A7936E5A027A1-802E
   Part No SW: 5Q0 614 517 GB    HW: 5Q0 614 517 BP
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 93581000010845 Dataset Number: F30909504J  0003
   Coding: 14FF6B7F5023236D89790B09A2C94828D60AC491D04512FE1841555492AD4A0100602F531A1A0B112E35351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049.rod
   VCID: 77ABFC97AF467E621E9-8022
   Part No SW: 83A 820 043 AA    HW: 83A 820 043 AA
   Component: AC Automat    H04 0070
   Revision: 20026000    Serial number: 00000001005137 Dataset Number: 83A909862D
   Coding: 070000240100000010011000000014000000000000000000
   ASAM Dataset: EV_AirCondiFrontVaAU326 001010
   ROD: EV_AirCondiFrontVaAU326.rod
   VCID: 5F9BB43727B6A622769-800A
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H05 0010
   Serial number: B21983D600PAG0MUFU04
   Part No SW: 5Q0 937 085 CK    HW: 5Q0 937 085 CK
   Component: BCM MQBAB HNA H44 0511
   Serial number: 01102212500454 Dataset Number: 83A909514H  0071
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 04519B5BEE9025FA0BB-8050
   Subsystem 1 - Part No SW: 83B 955 119 A    HW: 83B 955 119
   Component: J400FRWISCH  063 0050
   Serial number: 890153F0402210702261
   Coding: 5DC72F
   Component: G397_RLFSS  H06 0004
   Serial number: 43420325X81A955555B0
   Coding: 00005D
   Subsystem 3 - Part No SW: 4K1 941 501 N    HW: 4K1 941 501 N
   Component: E1 - LTM  H06 0060
   Serial number: 17S18.04.2200300259
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00VN02
   Coding: 250000
   Subsystem 5 - Part No SW: 5Q0 951 177 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  004 0403
   Serial number: 000000000ZL2209400PN
   Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000050773940
   Steering Column Switch:
   Subsystem 7 - Part No SW: 82A 953 521 MR    HW: 5Q1 953 549 E
   Serial number: 00000014042204220415
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058422101 Dataset Number: 83A909526D  0033
   Coding: 8471255811
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_VW41.rod
   VCID: 53F368075B7E7242C21-8006
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: 83A909863P  0006
   Coding: B20087D21CFF8728747C61458040A700080000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 73B3C887BB3E1242221-8026
   Part No SW: 5Q0 959 655 BQ    HW: 5Q0 959 655 BQ
   Component: AirbagVW21    010 0421
   Serial number: 003FKR89WXY9 Dataset Number: 83A909602L  0003
   Coding: BFCCFCC000000000A000001FC248000000C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 1079A70BAAE8495ABF3-8044
   Left seat belt tensioner:
   Component: BeltPretRevFL  506 1062
   Serial number: 83A857705D0119W00371
   Coding: 802006
   Right seat belt tensioner:
   Component: BeltPretRevFR  506 1062
   Serial number: 83A857706D0119W00935
   Coding: 802006
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000HXK17
   Coding: 303032
   Subsystem 4 - Part No SW: -----------    HW: 480 002 904 22
   Serial number: 357000000004A731CE5S
   Subsystem 5 - Part No SW: -----------    HW: 480 002 904 22
   Serial number: 35800000000ED731CE5%
   Subsystem 6 - Part No SW: -----------    HW: 480 402 604 22
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A7092CA7526B5
   Subsystem 7 - Part No SW: -----------    HW: 480 402 604 22
   Component: SideSensor_Pr  003 6149
   Serial number: 35200019D09198A2133-
   Subsystem 8 - Part No SW: -----------    HW: 480 402 801 22
   Component: FrontSensor_D  003 6149
   Serial number: 3550001B907487D38569
   Subsystem 9 - Part No SW: -----------    HW: 480 402 801 22
   Component: FrontSensor_P  003 6149
   Serial number: 3560001B707487D3118%
   Part No SW: 83A 920 800 E    HW: 83A 920 800 E
   Component: KOMBI         H03 6170
   Dataset Number: 83A909525T  0036
   Coding: 09D4020A6F88CF050280A0401800030000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001046
   ROD: EV_DashBoardVDDMQBA0_001_AU37.rod
   VCID: 2411FBDB4E50C5FA6BB-8070
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 09042210802911 Dataset Number: 83A909515H  0045
   Coding: 030900043F0859005B00205E1A0B00000001010000000000000000000000
   GVL: 01C63C000800000040DC80008002C80010040000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 79AFFAAF9952681268D-802C
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 83A 951 523 G    HW: 83A 951 523 G
   Component: J453 MFL  H07 0004
   Serial number: 20220204230424 32273
   Component: J367-BDMHella  H11 9070
   Serial number: 7163319505
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00014.03.22 Dataset Number: v1260x015G0 0000
   Coding: 0101
   VCID: 4CC1737B86402DBA83B-8018
   Part No SW: 8Y0 959 760     HW: 8Y0 959 760
   Component: MEM-FS        009 0362
   Serial number: 2222801KA00925 Dataset Number: 83A909856A  0003
   Coding: 015C12000000B0010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
   VCID: 0557865FE5AA1CF21C5-8050
   Part No SW: 3Q0 907 566 L    HW: 3Q0 907 566
   Component: MRR1Rear      H27 0550
   Revision: --------    Dataset Number: 83A909535B  0009
   Coding: 06C002
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
   VCID: 41DF524FB102F0D260D-8014
1188157 - Databus
          [databus unreasonable message - Perso_Status]
                    Reset counter: 221
                    Mileage: 9867 km
                    Date: 2024.04.02
                    Time: 17:28:56
                    Control Module temperature: 21 °C
                    Voltage terminal 30: Measuring value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measuring value not available
                    Voltage terminal 15: 11.90 V
   Part No SW: 8Y0 959 593 L    HW: 8Y0 959 593
   Component: TSG FS003 0350
   Serial number: YE007VCB25959 Dataset Number: 83A909872C  0027
   Coding: 001E8B005E00108000010032
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 55F7961F558A6C722C5-8000
   Part No SW: 5TA 907 145 D    HW: 5TA 907 145
   Component: BASGEN1MQB37  502 1051
   Serial number: 01516382 Dataset Number: 83A909852AA 0003
   Coding: 01000000010000010001020101000100000001010100
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 009050
   ROD: EV_SteerAssisBASGEN1MQB37_009_VW27.rod
   VCID: 48C94F6B9238C19AA73-801C
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 K
   Component: FCM MQB Low   005 0367
   Serial number: 24042211600283 Dataset Number: 83A909583E  0011
   Coding: 000000050900197200112300010000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372B3C97EFC6BE62DE9-8062
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YE007VDR17381 Dataset Number: 83A909873C  0027
   Coding: 001E8B005E00108000010030
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 49CF4A6F89323892B8D-801C
   Part No SW: 82A 035 018 G    HW: 82A 035 018 A
   Component: MU-TB-S-US    044 3696
   Serial number: GRO-63309.05.22 Dataset Number: 83C909545E  0022
   Coding: 13260000804000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: 2313F8C74B5EC2C2121-8076
   Multimedia System 1:
   Subsystem 1 - Part No SW: 83A 919 604 D    HW: 83A 919 604 D
   Component: DU AU326 Std   H71 0142
   Serial number: MA48N0AEA1390842
   Compact disc data bank:
   Volume Control 1:
   Subsystem 3 - Part No SW: 83A 919 616 A    HW: 83A 919 616
   Component: LSR-D5/C8      H33 0110
   Serial number: 00007522000070437018
   Media socket:
   Part No SW: 83A 907 428 C    HW: 4M0 907 428
   Component: Areaview 2    H18 0056
   Serial number: C854611JA028375 Dataset Number: 83B909460D  0017
   Coding: 02230602A20FA10038004004
   ASAM Dataset: EV_CamSysRVAV2CE2AU326 002001
   ROD: EV_CamSysRVAV2CE2AU326_002.rod
   VCID: 2D071EFF1D9A04B2B45-8078
   Part No SW: 5WB 959 107     HW: 5WB 959 107
   Component: HDSG-Modul    H04 0430
   Revision: --------    Serial number: A2-C767-1200-5 Dataset Number: 83A909541D  0008
   Coding: 2900
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536_AU37.rod
   VCID: 0D47BE7FBDDA64B2545-8058
   Part No SW: 5WA 035 285     HW: 5WA 035 285
   Component: OCUGen3High   H12 0316
   Serial number: 0000000111VIEYB Dataset Number: 83A909612L  0021
   Coding: 013260201FE82C009025460120012E07
   ASAM Dataset: EV_OCUGen3High 003005
   ROD: EV_OCUGen3High_003_VW41.rod
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004221030 Dataset Number: 83A909466F  0011
   Coding: 00040A88016E4020A89F10000020002000410000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   VCID: 3537369FF5CA4C72CC5-8060
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007VDD1263D Dataset Number: 83A909897C  0028
   Coding: 000E8B004000108000000020
   ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
   Component: TSG HBFS005 0350
   Serial number: YE007VDD12639 Dataset Number: 83A909896C  0028
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
   Part No SW: 89A 907 594 BC    HW: 89A 907 594
   Component: SAD_STG_1     006 0031
   Dataset Number: 83A909469D  0011
   Coding: 228040032602
   ASAM Dataset: EV_SunRoofCONTIAU736 009012
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   Part No SW: 3Q0 907 590 L    HW: 3Q0 907 590
   Revision: --------
   Coding: 06C002
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   VCID: 3E2529B3C0FC8F2A1DF-806A
   Part No SW: 4K0 941 572 CC    HW: 4K0 941 572 C
   Component: LMS_MQB       H06 0032
   Dataset Number: 83A909471F  0015
   ROD: EV_LMSLeftHELLAAU58X_AU37.rod
   VCID: 71BFC28FC1222052D0D-8024
   Dataset Number: 83A909472F  0015
   ROD: EV_LMSRightHELLAAU58X_AU37.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Dataset Number: 4N0909485A  0007
   Coding: 800080
   ROD: EV_Charg1MobilDevicAU651_004_AU37.rod
End----------(Elapsed Time: 02:12, VBatt start/end: 13.3V/13.3V)-----------
PatQ3
Syosset, NY, USA
C?ID=575888
Also, I seem to only get one fault recorded per ignition cycle. My scan shows 13 for frequency because I have not cleared them for I suppose 13 start ups.
2022? 6000 miles? MIL ON? -> Dealer.
