B8 S4 bypass value issue/Terminal Voltage issue.
   #61
B8boi
California, USA
C?ID=530730
Post updated auto scan of faults that are currently present. Fault for J808 is usually the flap. Recommend to flash ecm back to stock and recheck.
Cant flash back to stock because car is running test pipes/catless. But this was asked to be done in the beginning of debugging and was fruitless anyway. Ive got 4 bypass valves and replaced them and they all give the same code. I have checked bypass with a multi meter. I am 99% certain it is not the bypass.
The issue only seems to arise when something "warms up" i say this because I had the car idling to warm up for 10 minutes no issue. Ran her hard at wot a few miles no issue. Pulled over to plug in VCDS and log, before i could initiate the logger the CEL popped up while sitting in a driveway. no throttle input nothing.
Wednesday,25,September,2024,01:05:04:01176
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUMGBFL5AA105927   License Plate:
Mileage: 174850km-108646mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 36 3C 3E 42 46 47 52 53 55 56
          5F 62 6C 72
VIN: WAUMGBFL5AA105927   Mileage: 174850km-108646miles
3E-Media Player 4 -- Status: Cannot be reached 1100
Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
   Component: 3.0T SIMOS84  H06 0003
   Revision: --H06---    CVN: 3A01E652
   Coding: 0104000A180F0128
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
   ROD: EV_ECM30TFS0218K0907551D.rod
   VCID: 323D168464AF281A997-8066
   VINID: 9D195D5D259C1514410052421CD2EB98FF
9831 - Intake Air Regulating Flap
          P10A4 00 [10100111] - Mechanical Malfunction
                    Mileage: 174858 km
                    Date: 2024.09.24
                    Time: 22:03:27
                    Engine RPM: 679.00 /min
                    Normed load value: 6.3 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 13.507 V
                    Engine speed: actual: 672 /min
                    PDT_ENVD: 302.47852 hPa
                    RFP_SP_ENVD: 76.8898
                    RFP_AV_ENVD: 0.0000
                    VP_RFP_1_ENVD: 0.00000 V
                    RFPPWM_ENVD: 0.00000 %
7804 - Position Sensor for Intake Air Regulating Flap
          P10A6 00 [10100111] - Signal too Low
                    Mileage: 174858 km
                    Date: 2024.09.24
                    Time: 22:03:27
                    Engine RPM: 681.00 /min
                    Engine speed: actual: 640 /min
                    V_PVS_1_ENVD: 0.74219 V
7814 - Coolant Pump for Intercooler
          P190C 00 [00100111] - No Signal
                    Mileage: 174858 km
                    Date: 2024.09.24
                    Time: 22:03:30
                    Engine RPM: 659.00 /min
                    Normed load value: 7.8 %
                    MAF_ENVD: 98.04706 mg/stroke
                    Coolant temperature (unfiltered): 95.3 °C
                    Engine: operating status: IS
                    Engine load: 7.812500 %
                    Vehicle speed: actual: 0 km/h
Readiness: 1100 0100
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 280D18
   VCID: 7AADFEA4FCDF105A117-802E
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0326
   Coding: 0F0100
   VCID: 78A9E4ACC2D3024A673-802C
   Serial number: 0209000098730006
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01081220091769
   Coding: 66102000
   VCID: 00598C4C9A034A8A5F3-8054
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000533828
   Coding: 26001091063CAF010000080300003D0D0F1C120800010161000000
   VCID: 3C2138BCB66BEE6A43B-8068
   Component: WWS 081209  H06 0070
   Serial number: SWF09120085708
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10706270
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000003011091353
02258 - Door Opener Transmitter
                    Reset counter: 227
                    Mileage: 173687 km
                    Date: 2009.07.18
                    Time: 10:55:00
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940934305034
   Coding: 20000D
   VCID: 3E2532B4A077FC7A6DF-806A
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EGD05C80S   Dataset Number: 8K0909602H  0005
   Coding: 303936354230303030304A55304C384B3053
   VCID: 42DD4644D40F989A097-8016
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R09000057ZJ
   Serial number: 6334MSME4E632710A
   Serial number: 6344MSME4E342F3CV
   Serial number: 6352QSME084637229
   Serial number: 6362QSME06463D16H
   Serial number: 63732SME42463F280
   Serial number: 63832SME4346230AW
   Revision: --------    Serial number: 90319ILA000K3
   Coding: 000016
   VCID: 3D2735B8AD71E762745-8068
   Part No SW: 8K0 920 980 Q    HW: 8K0 920 980 Q
   Component: KOMBIINSTR.   H05 0255
   Revision: 00100000    Serial number: CJ241LYC9
   Coding: 8B1D09000300D705020000
   VCID: 40D94C4CDA838A8A1F3-8014
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0105
   Revision: FB900055    Serial number: 5500F09B2780A4
   Coding: 00C003
   Shop #: WSC 06325 123 12345
   Component: J367-BDM  H06 0170
   Serial number: 1909E63E301109
02079 - Media Player Position 4 (R121)
                    Reset counter: 1
                    Mileage: 174852 km
                    Date: 2024.09.24
                    Time: 20:00:44
                    Bin. Bits:    11111
                    Voltage: 12.60 V
                    Count: 6
                    Bin. Bits:    10011
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001010045032
   Coding: 00581B00000000000000
   VCID: 3B233BA0B365E9524A1-806E
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   Coding: 0000001
   VCID: 3C2138BCBA6BEE6A43B-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F05.12.0900H010003C321180ÿ
   Subsystem 4 - Serial number: 321180ÿ
Address 3E: Media Player 4
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009740561
   Coding: 011C13204E00410001
   VCID: 45D75D58C5A1AFA22C5-8010
   Revision: 00002001    Serial number: 0124212742
   Coding: 0106023A007A444500B0013200000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000198323
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS037  H06 0041
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34882000738801
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009769163
   VCID: 44D1405CCE9B96AA3BB-8010
   Revision: 00000003    Serial number: 00000000520634
   VCID: 3431109C9E3B262A8BB-8060
                    Fault Status: 00101101
                    Reset counter: 37
                    Mileage: 174820 km
                    Date: 2024.09.15
                    Time: 01:19:35
                    Voltage: 12.50 V
                    Count: 58
                    Hex Value: 0x0263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 77ABE790C3CD0D326E9-8022
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335L+097543690
   Coding: 020000010000000001
   VCID: 1D67D5380DB18762545-8048
02984 - Connection between Impedance Converter 2 and Window Antenna
                    Reset counter: 227
                    Mileage: 173687 km
                    Date: 2009.07.18
                    Time: 10:56:49
                    Voltage: 12.40 V
   Part No SW: 8T1 035 664 F    HW: 8T1 035 664 B
   Component: H-BN-NA       H47 0189
   Revision: --------    Serial number: 490CR0A7551602
   Coding: 010200000206A1EF51000F0E000000030000
   Shop #: WSC 34413 001 1048576
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356LV091151724
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000422851
   Component: CD-Database  1293
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102492704
   Coding: 010C13204000210001
   VCID: 42DD4644D48F989A097-8016
   Revision: --H03---    Serial number: 525PA8-J9Y91A3
   Coding: 1000006
   VCID: 382924AC8E53C24AA73-806C
02203 - Audio / Video Input 1
                    Fault Frequency: 62
                    Reset counter: 0
                    Mileage: 173687 km
                    Date: 2009.07.18
                    Time: 10:57:06
                        Reverse OFF
                    Count: 3
                    Fault Frequency: 25
                    Reset counter: 33
                    Mileage: 174064 km
                    Date: 2009.07.22
                    Time: 13:05:30
                        Reverse OFF
                    Count: 3
   Revision:             Serial number: 0000102492726
End----------(Elapsed Time: 01:57, VBatt start/end: 13.9V/14.0V)-----------
   #63
B8boi
California, USA
C?ID=530730
As stated before replace J808 if basic settings cannot be performed.
AS I HAVE STATED BEFORE :
"Ive got 4 bypass valves( 1 New, 1 old, and 2 off of known used working superchargers) and replaced them all and they all give the same code. I have checked bypass with a multi meter. I am 99% certain it is not the bypass."
And p10a4 is only one of the codes. The other is p10a6 and the fact that both show leads me to believe is it an issue at the ECU.
I have a spare ECU with a different VIN which doesnt let me start the car (immobilizer) but it does connect to VCDS. But for some reason my VCDS cable doesnt let me connect to the ECU even when I tell it I want to use 1 of my VINs. Why would that be?
Westbury, UK
... or with the wiring and connectors between the ECU and the valves.
   #65
B8boi
California, USA
C?ID=530730
Checked the connector and thought it was bad so replaced the connecter for brand new pigtail from audi. Bypass valve and wiring at its end are not the issue. I am now stuck between it being the ECU connector pins or the ECU itself. (Although if you read prior i had a ebay ecu jockey confirm the Ecu was good even thought he coudnt clone it)
but i am in disbelief because the car works fine for the first 10 minutes of driving. Then when warm it just triggers the codes that just wont clear until its cool again. Additionally, bypass adaptation just acts weird, the car will say successful adaptation sometimes, without even moving the valve.
   #66
EuroX
Northern NJ USA
C?ID=208579
When swapping J808 were basic settings run and performed correctly with each valve? Were faults cleared each time prior to adaption?
   #67
B8boi
California, USA
C?ID=530730
Sadly Yes, every single valve went through numerous fault clears and adaptations. Ive even went as far as letting the fault trigger with the valve installed on the car and then let unplugged the mounted valve and done adaptation on a valve not mounted to the car ( just to see if there was any effect). same issue.
B8boi
California, USA
C?ID=530730
So I watched a video of a guy using VCDS on a skoda or bug. He had an issue with an adaptation and wasn't sure where to start, so what he did, he went through all the channels for the module and looked for sensor values that might be out of wack. He found a coolant temp sensor shorting out (showed -40C). But i am unable to scroll through channels like that so i figured i would take a block map before and after my bypass valve code triggered to see what might be awry. So I took 2 blockmaps of the ECU, one before CEL trigger and one after hoping we could agree what looks out of wack and maybe narrow down what quadrant of the engine bay I throw my credit card at.
Do you think my 02 sensor values could be shorting out the bypass valve sensor line? Comparing ENG102380 and ENG102703 and noticing how IDE00566 rises after being warm. I am thinking maybe I have a sensor short when cold and causing issue?
For sake of discussion. My car throws a P10A4 and P10A6 randomly after warming up. When the car is cold, and initially warming up, it adapts the valve fine, and runs ok. I have changed and adapted the valve many times. After warming it randomly triggers the code, and sets, and even if I clear the codes they immediately come back until I let the car cool. If I try to adapt the valve after the code is set, it will sometimes adapt successfully, but still trigger the code. Many new bypass valves tried, adapted and failed. Thanks
;SW:8K0-907-551-D   HW:8K0-907-551-A ---  Engine
;Component:3.0T SIMOS84  H06 0003     Coding:0104000A180F0128
;EV_ECM30TFS0218K0907551D    1003        EV_ECM30TFS0218K0907551D.rod
;Tuesday    1        October        2024    00:35:16:01176
;VCDS Version: Release 24.7.0 (x64)  Data version: 20240715 DS356.3
;VCID: 323D168464AF281A997-8066
Group    Description        Actual
IDE00019    Voltage terminal 30        13.507    13.609     V
IDE00021    Engine RPM        718    680     /min
IDE00025    Coolant temperature        53    91     °C
IDE00075    Vehicle speed        0    0     km/h
IDE00078    Time since engine start        261    665     s
IDE00083    Throttle valve position (absolute)        8.6    8.6     %
IDE00084    Absolute load value        31    30     %
IDE00085    Normed load value        7.8    6.3     %
IDE00086    Accelerator pedal position        14.5    14.5     %
IDE00097    OBD - requirements for which this vehicle is designed        OBD + OBD II    OBD + OBD II
IDE00167    Exhaust temperature 1 bank 1        247.4    429     °C
IDE00168    Exhaust temperature 1 bank 2        248.9    421.2     °C
IDE00190-ENG103225    Charge air pressure: specified value-MAP_SP        318.98    310.44     hPa
IDE00349    Throttle valve position: normed        0.4    0.4     %
IDE00400-ENG100810    Intake manifold Runner Control (IMRC): activation-LV_PORT_DEAC        1    1
IDE00401-ENG111851    Intake manifold Runner Control (IMRC): acknowledgment-FAC_PORT_DEAC[0]        0.99998    0.99998
IDE00402-ENG100810    Intake manifold runner control 2: activation-LV_PORT_DEAC        1    1
IDE00403-ENG111852    Intake manifold runner control 2: acknowledgment-FAC_PORT_DEAC[1]        0.99998    0.99998
IDE00445    Unlearning counter according OBD        255    255
IDE00450    Operating instruction        ---    ---
IDE00451    Currently running routine        Unknown (0)    Unknown (0)
IDE00474    Ambient air pressure        96    96     kPa abs
IDE00495    Calculated oil temperature        4B    80
IDE00496    Oil pressure switch valve activation        Low pressure    Low pressure
IDE00497-MAS00627    Status of oil pressure switches-Oil pressure switch for high pressure        Open    Open
IDE00497-MAS00628    Status of oil pressure switches-Oil pressure switch for low pressure        closed    closed
IDE00556    Outside temperature        24    25     °C
IDE00559    Current of oxygen sensor bank 1 sensor 1 (broadband sensor)        0.999 Lambda / -0.008 mA    0.992 Lambda / -0.047 mA
IDE00560-MAS04121    Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage        0.165    0.62     V
IDE00560-MAS04122    Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation        99.2    99.2     %
IDE00565    Current of oxygen sensor bank 2 sensor 1 (broadband sensor)        1.003 Lambda / 0.008 mA    0.986 Lambda / -0.078 mA
IDE00566-MAS04121    Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage        0.085    0.775     V
IDE00566-MAS04122    Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation        99.2    99.2     %
IDE00582    Specified value of equivalence ratio        1.001    0.995     Lambda
IDE00583    Throttle valve specified value        0.4    0.4     %
IDE00584    Distance driven since erasing DTC memory        0    0     km
IDE00585    Dist. driven with exh. Malfunction Indicator Lamp activated        0    0     km
IDE00589    Fuel pressure        3810    3640     kPa rel
IDE00592    Status of oxygen sensor control        Closed loop    Closed loop      / using O2 sensors
IDE00593    Ignition timing adjustment cylinder 1        8    14.5     Degrees
IDE00595    Allocation of oxygen sensors        B1S1 B1S2   / B2S1 B2S2      B1S1 B1S2   / B2S1 B2S2
IDE00597    Long term adaptation of mixture formation bank 1        0    0     %
IDE00598    Long-term adaptation of mixture formation: B2        0    0     %
IDE00601    Monitoring status since erasing DTC memory
IDE00602    Monitoring status in current driving cycle
IDE00603    Number of driving cycles since erasing DTC memory        0    0
IDE00604    Short term adaptation of mixture formation bank 1        10.2    15.6     %
IDE00605    Short term adaptation of mixture formation bank 2        0    3.1     %
IDE00612    Target position of EVAP canister valve        0    0     %
IDE00727    Test steps still to be performed        0    0
IDE00787    Cause for cancellation        0    0
IDE00949-ENG98517    Hide cylinder-Cylinder 1        not active    not active
IDE00949-ENG98491    Hide cylinder-Cylinder 10        not active    not active
IDE00949-ENG98492    Hide cylinder-Cylinder 11        not active    not active
IDE00949-ENG98493    Hide cylinder-Cylinder 12        not active    not active
IDE00949-ENG98518    Hide cylinder-Cylinder 13        not active    not active
IDE00949-ENG98519    Hide cylinder-Cylinder 14        not active    not active
IDE00949-ENG98520    Hide cylinder-Cylinder 15        not active    not active
IDE00949-ENG98494    Hide cylinder-Cylinder 16        not active    not active
IDE00949-ENG98521    Hide cylinder-Cylinder 2        not active    not active
IDE00949-ENG98522    Hide cylinder-Cylinder 3        not active    not active
IDE00949-ENG98523    Hide cylinder-Cylinder 4        not active    not active
IDE00949-ENG98495    Hide cylinder-Cylinder 5        not active    not active
IDE00949-ENG98524    Hide cylinder-Cylinder 6        not active    not active
IDE00949-ENG98496    Hide cylinder-Cylinder 7        not active    not active
IDE00949-ENG98497    Hide cylinder-Cylinder 8        not active    not active
IDE00949-ENG98498    Hide cylinder-Cylinder 9        not active    not active
IDE01369-ENG103168    Intake manifold runner control (IMRC): offset closed-V_PORT_1_OFS        0.005    0.029     V
IDE01371-ENG103327    Intake manifold runner control (IMRC) 2: offset closed-V_PORT_2_OFS        0    0.034     V
IDE01650    Throttle valve position 2        9    9     %
IDE01880    Accelerator pedal position 2        14.5    14.5     %
IDE02119    Long term adaptation of oxygen sensor control: bank 1        0    0     %
IDE04000    Intake air temperature sensor        IAT 11:29    IAT 11:43     °C
IDE04001    Turbocharger intake pressure sensor        TCA_PRESS: 31    TCA_PRESS: 30     kPa abs
IDE04002    Charge air pressure control        BP_A act:30.7 kPa / BP_B act:32.8 kPa    BP_A act:29.8 kPa / BP_B act:31.5 kPa
IDE04003    Charge air temperature sensor        B1S1:29 °C / B2S1:30 °C    B1S1:46 °C / B2S1:48 °C
IDE04324    Long term adaptation of oxygen sensor control: bank 2        0    0     %
ENG102981    AC compressor: speed increase        0    0
ENG103860    AC request: speed increase        0    0
ENG103226    Accelerator pedal sender 1: voltage ratio        0.757    0.752     V
ENG103029    Accelerator pedal sender 2: voltage ratio        0.371    0.376     V
ENG103042    Accelerator pedal sender: learned end stop        4.126    4.126     V
ENG103719    Accelerator position        0    0     %
ENG101488    ACF: load        0    0.14301
ENG103474    Activation of oil pressure switching valve        1    1
ENG103654    Activation: throttle valve positioner        -18.704    -17.215     %
ENG101818    Actual fuel rail pressure        38357    36616.4     hPa
ENG103323    Additional water pump        0    0
ENG101828    Air mass        13.8125    11.375     kg/h
ENG100339    Air mass integral: actual        0.69    0     kg
ENG99216    Air mass integral: specified        11.44    11.44     kg
ENG104264    Alternator load        650    500     W
ENG99319    Ambient pressure        963.92    963.83     hPa
ENG103910    Ambient temperature        24    24     °C
ENG101830    AMP_ENVD        960.502    960.502     hPa
ENG101473    AR_RED_AD_ADD_MMV        0    0     cm²
ENG102979    AR_RED_AD_FAC        0    0     %
ENG98377    As        none    none
ENG103165    Battery voltage        13.507813    13.507813     V
ENG100763    Brake Light Switch        0    0
ENG103466    Brake test switch        0    0
ENG102002    CAM_OFS_IVVT_IN[1]        0    0     °
ENG101927    CAM_OFS_IVVT_IN[2]        0    0     °
ENG101169    CAM_PHA_OFS_MAF[IN][1]        0    0     °
ENG101535    CAM_PHA_OFS_MAF[IN][2]        0    0     °
ENG103031    Camshaft adjustment: inlet phase: bank 1        -47.25    -47.25     °
ENG99898    Camshaft adjustment: inlet phase: bank 2        -46.875    -47.25     °
ENG99173    Camshaft adjustment: inlet: bank 1/2: specified        127.875    127.875     °
ENG100104    Camshaft adjustment: inlet: bank 1: actual        0    0     °
ENG102242    Camshaft adjustment: inlet: bank 1: duty cycle        0    9.766     %
ENG100701    Camshaft adjustment: inlet: bank 2: actual        0    0     °
ENG101781    Camshaft adjustment: inlet: bank 2: duty cycle        0    9.766     %
ENG101975    CAN messages: status for ABS        0    0     s
ENG99096    CAN messages: status for AC        0    0     s
ENG103515    CAN messages: status for ACC        0    0     s
ENG103345    CAN messages: status for airbag        0    0     s
ENG99384    CAN messages: status for battery energy management        0    0     s
ENG101540    CAN messages: status for dash panel insert        0    0     s
ENG100217    CAN messages: status for electronic ignition lock        0    0     s
ENG103239    CAN messages: status for electronic parking brake        0    0     s
ENG104136    CAN messages: status for gateway        0    0     s
ENG101579    CAN messages: status for gearbox        0    0     s
ENG100306    CAN messages: status for steering column module        0    0     s
ENG99220    CAN messages: status for trailer recognition        0    0     s
ENG102251    Cat conversion: bank1: meas.value        0    0
ENG99627    Cat conversion: bank2: meas.value        0    0
ENG103849    Cat. ageing: bank 1: actual        0    0
ENG101836    Cat. ageing: bank 2: actual        0    0
ENG101785    Cat. temperature: bank 1        251.4125    455.9125     °C
ENG100075    Cat. temperature: bank 2        252.475    451.975     °C
ENG101837    Cause of irreversible brake cut-in disable        0    0
ENG103793    Cause of irreversible disable (CCS)        0    0
ENG101960    Cause of reversible brake cut-in disable        0    0
ENG102021    Cause of reversible disable (CCS)        393233    393233
ENG103399    CCS shut-off criterion: switch position        0    0
ENG100798    CCS shut-off criterion: switch position        1    1
ENG99361    CCS shut-off criterion: switch position        0    0
ENG100479    Charge air cooling water pump: actual duty cycle        0    0     %
ENG102583    Charge air cooling water pump: result        OK    OK
ENG99256    Charge air cooling water pump: specified duty cycle        88    88     %
ENG102333    Charge air cooling water pump: status        00000000 00000000     00000000 00000000
ENG103690    Charge pressure control: charge press.before throttle valve        311.44    300.33     hPa
ENG100992    Compressor regulating flap: PWM activation        10.522    0     %
ENG100398    Consumption equivalent: substitute value        0.00000144    0.0000002
ENG102996    Coolant temperature        54    92.3     °C
ENG99145    Coolant temperature (unfiltered)        54    92.3     °C
ENG100260    Coolant temperature at engine start        28.5    77.3     °C
ENG101525    Coolant temperature: specified        114.8    114.8     °C
ENG102214    CPU_LOAD        42.8    42.5     %
ENG102284    CRU_SWI_POS_CAN        0    0
ENG102136    Cruise control: switch settings        1    1
ENG101127    CTR_CDN_OBD_RBM        29    29
ENG103696    CTR_CDN_RBM_CAT_1        29    29
ENG100331    CTR_CDN_RBM_CAT_2        29    29
ENG99655    CTR_COMP_RBM_CAT_1        0    0
ENG103187    CTR_COMP_RBM_CAT_2        0    0
ENG100536    CTR_IGK_CYC_RBM        120    122
ENG102005    CTR_KM_CAN        174858    174858     km
ENG102445    CTR_MIS_DC_MMV_CYL[0]        0    0
ENG99590    CTR_MIS_DC_MMV_CYL[1]        0    0
ENG99754    CTR_MIS_DC_MMV_CYL[2]        0    0
ENG102025    CTR_MIS_DC_MMV_CYL[3]        0    0
ENG101583    CTR_MIS_DC_MMV_CYL[4]        0    0
ENG102075    CTR_MIS_DC_MMV_CYL[5]        0    0
ENG102250    CTR_MIS_TOT_NVMY        0    0
ENG100764    CTR_SUM_SRV_INTL        464.8    563.3
ENG99084    Cycle flags: (completed cycles): cat: lambda probe heater        127    95
ENG100943    Cycle flags: (completed cycles): lambda probes: EGR        28    30
ENG103229    Cycle flags: (completed tests): camshaft adj.: knock sensors        207    207
ENG99495    Cycle flags: (completed tests): lambda adaption:        232    232
ENG103597    Cycle flags:(completed cycles):lambda probes:sec.air sys.        28    30
ENG102526    Cycle flags:(completed tests):clutch: brake:idle controller        37    1
ENG101652    Cylinder shut-off: cylinder suppression        0    0
ENG100989    DELTA_CRK_CYL_LAM_1        0    0     °
ENG99927    DELTA_CRK_CYL_LAM_2        0    0     °
ENG102657    DIAG_INST[0]        cwp_2    n_max_rfp_lih
ENG99120    DIAG_INST[1]        no_error    rfp_1
ENG103260    DIAG_INST[2]        no_error    cwp_2
ENG99710    DIAG_INST[3]        no_error    no_error
ENG102667    DIAG_INST[4]        no_error    no_error
ENG102739    DIAG_INST[5]        no_error    no_error
ENG100162    DIAG_INST[6]        no_error    no_error
ENG99103    DIAG_INST[7]        no_error    no_error
ENG99261    DIAG_INST[8]        no_error    no_error
ENG103622    DIAG_INST[9]        no_error    no_error
ENG99472    DIST_DTC_CLR        0    0     km
ENG103766    DIST_ENG_RUN_IN        172467156.6    172467440.7     m
ENG100531    DIST_ST        1.19E+06    1.19E+06     m
ENG103712    EFPPWM_MIN_AD        37    49.605     %
ENG104044    Engine load        7.421875    6.640625     %
ENG103936    Engine mount 1: right (only vehicles with engine mounting)        0    0
ENG102957    Engine mounting 2: left (only vehicles with engine mounting)        0    0
ENG102494    Engine speed: actual        704    672     /min
ENG99273    Engine speed: specified        720    680     /min
ENG104182    Engine temperature: thermostat diagnosis        75.75    75.75     °C
ENG100261    Engine torque        42.75    35.71875     Nm
ENG102783    Engine: operating status        IS    IS
ENG101147    ENVD_0_CRU_ACT_MON        40    40
ENG102968    ENVD_0_GS_INC_MON        0    0
ENG99874    ENVD_0_MAF_NOT_PLAUS_MON        0    0
ENG103667    ENVD_0_MON        0    0
ENG100777    ENVD_0_MON_3        0    0
ENG102888    ENVD_0_MSR_MON        0    0
ENG99438    ENVD_0_N_MAX_MON        13    13
ENG100658    ENVD_0_TQI_MON        0    0
ENG102106    ENVD_1_CRU_ACT_MON        234    234
ENG103210    ENVD_1_GS_INC_MON        0    0
ENG101907    ENVD_1_MAF_NOT_PLAUS_MON        0    0
ENG99424    ENVD_1_MON        0    0
ENG100344    ENVD_1_MON_3        0    0
ENG102767    ENVD_1_MSR_MON        0    0
ENG100092    ENVD_1_N_MAX_MON        168    168
ENG99136    ENVD_1_TQI_MON        0    0
ENG103816    ENVD_2_CRU_ACT_MON        50    50
ENG100080    ENVD_2_GS_INC_MON        0    0
ENG101890    ENVD_2_MAF_NOT_PLAUS_MON        0    0
ENG99790    ENVD_2_MON        0    0
ENG100541    ENVD_2_MON_3        0    0
ENG100185    ENVD_2_MSR_MON        0    0
ENG103232    ENVD_2_N_MAX_MON        60    60
ENG101780    ENVD_2_TQI_MON        0    0
ENG103490    ENVD_3_CRU_ACT_MON        85    85
ENG102482    ENVD_3_GS_INC_MON        0    0
ENG102566    ENVD_3_MAF_NOT_PLAUS_MON        0    0
ENG99455    ENVD_3_MON        0    0
ENG101268    ENVD_3_MON_3        0    0
ENG101949    ENVD_3_MSR_MON        0    0
ENG100841    ENVD_3_N_MAX_MON        215    215
ENG99810    ENVD_3_TQI_MON        0    0
ENG100532    ENVD_CAM_IN_1        0    0
ENG101418    ENVD_CAM_IN_2        0    0
ENG99852    ENVD_CRK        0    0
ENG99600    ENVD_EEPROM        0    0
ENG102271    ENVD_KNK_RTD_LIM        0    0
ENG101912    ENVD_LSL_UP_1        0    0
ENG101170    ENVD_LSL_UP_2        0    0
ENG99752    Error flags: (completed cycles): cat: lambda probe heater        0    0
ENG101275    Error flags: (completed cycles): lambda probes: EGR        0    0
ENG104132    Error flags: (completed cycles): lambda probes:sec.air sys.        0    0
ENG102855    ESI (extended service intervals) oil level        54.6875    55.5     mm
ENG101942    ESI (extended service intervals) oil warning threshold        50    51.375     mm
ENG104194    FAC_H_RNG_LAM_AD[1]        0    0     %
ENG103178    FAC_H_RNG_LAM_AD[2]        0    0     %
ENG104151    FAC_L_RNG_LAM_AD[1]        0    0     %
ENG101035    FAC_L_RNG_LAM_AD[2]        0    0     %
ENG100298    FAC_LAM_CP        6.657    9.387     %
ENG100108    FAC_LAM_LIM[1]        12.451    15.921     %
ENG100987    FAC_LAM_LIM[2]        1.164    2.948     %
ENG99722    FAC_LAM_TCO_A[1]        0.119    0     %
ENG99699    FAC_LAM_TCO_A[2]        0.089    0     %
ENG103521    FAC_LAM_TCO_B[1]        0.119    0     %
ENG99478    FAC_LAM_TCO_B[2]        0.089    0     %
ENG103641    FAC_LAM_TCO_C[1]        0.119    0     %
ENG102483    FAC_LAM_TCO_C[2]        0.089    0     %
ENG101578    FAC_LAM_TCO_D[1]        11.252    0     %
ENG103438    FAC_LAM_TCO_D[2]        -2.327    0     %
ENG100685    FAC_LAM_TCO_E[1]        11.053    0     %
ENG103729    FAC_LAM_TCO_E[2]        -1.994    0     %
ENG103307    FAC_MAF_MAX        0.07941    0.06998
ENG99791    FAC_SLOP_IV[1]        0    0
ENG99070    FAC_SLOP_IV[2]        0    0
ENG103161    Fan control relay: auxiliary water pump        0    0
ENG99630    Fan control relay: fan run-on        0    0
ENG101437    Fan request from air conditioner        0    0     %
ENG103644    FRF_IMMO_SNAPSHOT_BYTE1        0    0
ENG102892    FRF_IMMO_SNAPSHOT_BYTE2        0    0
ENG100521    FRF_IMMO_SNAPSHOT_BYTE3        0    0
ENG101852    FRF_IMMO_SNAPSHOT_BYTE4        0    0
ENG99312    FRF_IMMO_SNAPSHOT_BYTE5        0    0
ENG103956    FRF_IMMO_SNAPSHOT_BYTE6        0    0
ENG104248    Fuel consumption signal        10292    23837     µl
ENG99715    Fuel pump: activation        51.535    51.596     %
ENG100489    Fuel pump: actual fuel pressure        5067.92    4940.56     hPa
ENG101667    Fuel pump: adaption value        0    4.567     %
ENG100969    Fuel pump: fuel pressure: I-controller        4.535    0.055     %
ENG100409    Fuel rail pressure: specified        38256.2    36706.6     hPa
ENG100250    Fuel regulating valve: duty cycle        5.981    5.801     %
ENG101692    Fuel supply system: high-pressure regulator        135.32    281.25     hPa
ENG104057    Fuel sys.diag.pump:status tank leak detect(ULEV II only)        0    7
ENG103605    Fuel system diagnostic pump: cycle (ULEV II only)        1    1
ENG101053    Fuel system diagnostic pump: fault detection (ULEV II only)        0    0
ENG100362    FUEL_MASS_AD        -6    -6     mg
ENG103903    FUEL_MASS_AD_ENVD        -6.28125    -6.28125
ENG103916    FUEL_MASS_REQ_I_CTL_ENVD        -3.140625    0
ENG103559    FUP_EFP_ENVD        4091.48    4091.48     hPa
ENG103553    FUP_EFP_ST_H        173888    173888     hPa
ENG101056    FUP_EFP_ST_L        173888    173888     hPa
ENG99950    FUP_EFP_STOP_H        173888    173888     hPa
ENG100784    FUP_EFP_STOP_L        173888    173888     hPa
ENG102754    FUP_ENVD        40755.531    36679.9779     hPa
ENG102108    FUP_H        38022.7    36446.6     hPa
ENG98594    Gear        0    0
ENG103368    Gearbox -CAN bus messages        94071    94071
ENG100957    Height correction        960.502    960.502     hPa
ENG99170    Height correction        964    963.83     hPa
ENG103575    High-pressure system: regulator        0    0     mg
ENG103879    High-pressure system: regulator: mobile part        -1.76    0.85     mg
ENG102603    High-pressure system: status        MFP_CTL    MFP_CTL
ENG101567    Idling speed stabilisation: duty cycle/AC compressor torque        0.8    0.8     Nm
ENG102289    Idling speed stabilisation: idling speed controller        0.84375    0.0625     Nm
ENG101472    Idling speed stabilisation: learned value        5.8125    2.90625     Nm
ENG101946    Idling stabilisation: operating status        0    0
ENG100449    IGA_AD_1_KNK[0]        0    0     °
ENG101025    IGA_AD_1_KNK[1]        0    0     °
ENG100399    IGA_AD_1_KNK[2]        0    0     °
ENG99087    IGA_AD_1_KNK[3]        0    0     °
ENG100814    IGA_AD_1_KNK[4]        0    0     °
ENG100030    IGA_AD_1_KNK[5]        0    0     °
ENG103801    IGA_IGC_0        6.375    11.25     °
ENG101919    IGA_IGC_1        12    14.625     °
ENG102065    IGA_IGC_2        7.875    13.125     °
ENG103873    IGA_IGC_3        12.75    9.75     °
ENG99337    IGA_IGC_4        7.875    13.5     °
ENG100633    IGA_IGC_5        6.375    14.625     °
ENG102932    Ignition angle: actual        12.75    12     °
ENG100204    Intake air change-over: pressure        311.36    301.07     hPa
ENG101741    Intake air temperature        30    47.25     °C
ENG101388    Intake manifold pressure: absolute        316.91    307.04     hPa
ENG99742    Kickdown adaption: switch        0    0
ENG101640    Kilometres driven with MIL        0    0     km
ENG103143    Kilometres driven with MIL        0    0     min
ENG103876    Knock control: knock sensor voltage: cyl. 1        0.41016    0.41016     V
ENG99646    Knock control: knock sensor voltage: cyl. 2        0.41031    0.41016     V
ENG102129    Knock control: knock sensor voltage: cyl. 3        0.41016    0.41016     V
ENG102735    Knock control: knock sensor voltage: cyl. 4        0.62263    0.54832     V
ENG100457    Knock control: knock sensor voltage: cyl. 5        0.44312    0.42801     V
ENG100093    Knock control: knock sensor voltage: cyl. 6        0.74631    0.56519     V
ENG102464    LAM_CYL_SEL_ADJ_FAC[0]        0    0     %
ENG100498    LAM_CYL_SEL_ADJ_FAC[1]        0    0     %
ENG100758    LAM_CYL_SEL_ADJ_FAC[2]        0    0     %
ENG102261    LAM_CYL_SEL_ADJ_FAC[3]        0    0     %
ENG103470    LAM_CYL_SEL_ADJ_FAC[4]        0    0     %
ENG102999    LAM_CYL_SEL_ADJ_FAC[5]        0    0     %
ENG100097    LAMB_CAT_DOWN_MV[1]        0    0
ENG102198    LAMB_CAT_DOWN_MV[2]        0    0
ENG99741    LAMB_DELTA_AD_LAM_ADJ[1]        0    0
ENG102871    LAMB_DELTA_AD_LAM_ADJ[2]        0    0
ENG102085    LAMB_DELTA_AD_O2L_CAT[1]        -0.00214    -0.00214
ENG102521    LAMB_DELTA_AD_O2L_CAT[2]        -0.00604    -0.00604
ENG102144    Lambda control value: bank 1        12.326    15.298     %
ENG102393    Lambda control value: bank 2        1.63    3.021     %
ENG99674    Lambda controller: bank 1 (averaged value)        12.34    15.62     %
ENG100249    Lambda controller: bank 2 (averaged value)        1.57    2.858     %
ENG101381    Lambda probe 1: bank 1: status        1    1
ENG101039    Lambda probe 1: bank 1: status        0    0
ENG102886    Lambda probe 1: bank 1: status        0    0
ENG99812    Lambda probe 1: bank 2: status        1    1
ENG99373    Lambda probe 1: bank 2: status        0    0
ENG103920    Lambda probe 1: bank 2: status        0    0
ENG104200    Lambda probe 2: bank 1: status        0    0
ENG101336    Lambda probe 2: bank 1: status        0    1
ENG99313    Lambda probe 2: bank 2: status        0    0
ENG99124    Lambda probe 2: bank 2: status        0    1
ENG99661    Lambda probe ageing: bank 1: dynamic factor        0    0
ENG101869    Lambda probe ageing: bank 1: probe 1: short trip result        234.725    297.475     °C
ENG99891    Lambda probe ageing: bank 1: probe 2: short trip result        144.475    445.1     °C
ENG103962    Lambda probe ageing: bank 2: dynamic factor        0    0
ENG103203    Lambda probe ageing: bank 2: probe 1: short trip result        231.725    290.9125     °C
ENG103040    Lambda probe ageing: bank 2: probe 2: short trip result        146.2875    439.6625     °C
ENG100478    Lambda probe correction: duty cycle offset: bank 1        0    -0.00061
ENG100459    Lambda probe correction: duty cycle offset: bank 2        0    -0.00146
ENG101813    Lambda probe heater: bank 1: probe 1: short trip result        0    0
ENG103776    Lambda probe heater: bank 1: probe 2: short trip result        0    0
ENG101739    Lambda probe heater: bank 2: probe 1: short trip result        0    0
ENG101102    Lambda probe heater: bank 2: probe 2: short trip result        0    0
ENG102717    Lambda probe heater: resistance: bank 1: probe 1        79.5    79.75     Ohm
ENG102380    Lambda probe heater: resistance: bank 1: probe 2        2350    885     Ohm
ENG101429    Lambda probe heater: resistance: bank 2: probe 1        79.5    79.75     Ohm
ENG102703    Lambda probe heater: resistance: bank 2: probe 2        1064    429     Ohm
ENG103233    Lambda probe readiness: bank 1: probe 1: short trip result        1    1
ENG101214    Lambda probe readiness: bank 1: probe 2: short trip result        1    1
ENG103087    Lambda probe readiness: bank 2: probe 1: short trip result        1    1
ENG101319    Lambda probe readiness: bank 2: probe 2: short trip result        1    1
ENG99353    Lambda probe voltage: bank 1: probe 1 (broadband probe)        1.997    1.968     V
ENG102863    Lambda probe voltage: bank 1: probe 2        0.156    0.327     V
ENG100603    Lambda probe voltage: bank 2: probe 1 (broadband probe)        1.992    1.963     V
ENG103421    Lambda probe voltage: bank 2: probe 2        0.078    0.635     V
ENG102763    Lambda probes actual: bank1        1.001    0.9893
ENG102040    Lambda probes actual: bank2        1.001    0.9941
ENG102170    Lambda probes learned values: bank 1: probe 1: idle        0    0     %
ENG104246    Lambda probes learned values: bank 1: probe 1: part throttle        0    0     %
ENG104025    Lambda probes learned values: bank 2: probe 1: idle        0    0     %
ENG102016    Lambda probes learned values: bank 2: probe 1: part throttle        0    0     %
ENG100365    Lambda probes specification: bank 1        1.001    0.9951
ENG101457    Lambda probes specification: bank 2        1    0.9951
ENG104114    Lambda probes specified: bank1        1.001    0.9951
ENG102953    Lambda probes specified: bank2        1.001    0.9951
ENG101747    LOIL_DYN        10.25    10.25     mm
ENG102180    LOIL_DYN_TMP        9.3125    9     mm
ENG103837    LOIL_MAX_SRV_INTL        12.1875    12.1875     mm
ENG102184    LOIL_MIN_SRV_INTL        -0.1875    -0.1875     mm
ENG100402    LOIL_SUM_SRV_INTL        4344.0625    5076.0625     mm
ENG99162    LV_ACC_RED_CMD        0    0
ENG101153    LV_AD_END_IVVT        1    1
ENG102235    LV_ATB_ACT_1        0    0
ENG102541    LV_ATB_ACT_2        0    0
ENG99095    LV_CAN_HOOD_SWI        0    0
ENG103049    LV_EFPPWM_AD_STOP        1    0
ENG101712    LV_ENG_RUN_IN        0    0
ENG100267    LV_ENG_RUN_IN_EXT_ADJ        0    0
ENG99803    LV_IAF_SP        0    0
ENG99924    LV_INH_AUT_ST        0    0
ENG103773    LV_INH_STR_RLY        0    0
ENG100044    LV_LOIL_L_WARN        0    0
ENG103492    LV_LOIL_L_WARN_ACT        0    0
ENG103908    LV_LOIL_L_WARN_TMP        0    0
ENG102919    LV_MASS_SA_L_ERR[0]        0    0
ENG99986    LV_MASS_SA_L_ERR[1]        0    0
ENG103716    LV_POIL_SWI_H        0    0
ENG100912    LV_POIL_SWI_L        1    1
ENG100804    LV_RFP_AD_EXT_ADJ_ON        0    0
ENG99593    LV_RFP_CUR_OFF        0    1
ENG102334    LV_RFP_POS_GRD        1    1
ENG104247    LV_SA_MAX_H_ERR[0]        0    0
ENG104254    LV_SA_MAX_H_ERR[1]        0    0
ENG101515    LV_SA_SAV_END_DIAG[0]        0    0
ENG102750    LV_SA_SAV_END_DIAG[1]        0    0
ENG102150    LV_SA_SYS_END_DIAG[0]        0    0
ENG102206    LV_SA_SYS_END_DIAG[1]        0    0
ENG102417    LV_TPS_AD_ACT        0    0
ENG100842    LV_TPS_AD_DIAG_ERR        0    0
ENG103996    LV_TPS_AD_REQ        0    0
ENG99280    LV_VCV_RLY        1    1
ENG102523    MAF        100.91    89.25     mg/stroke
ENG103484    MAF_CYL        13.71875    11.40625     kg/h
ENG99288    MAF_DIF_CAM_OFS_AD_SQ_TOT        0    0     kg²/h²
ENG101509    MAF_ENVD        141.62353    103.49411     mg/stroke
ENG103984    MAF_RFP        61.28125    52.71875     kg/h
ENG103985    MAF_SCHA        74.75    64.40625     kg/h
ENG100807    MAF_THR        13.6875    11.375     kg/h
ENG101499    map        317.57    306.96     hPa
ENG102949    MAP_1_ENVD        360.85156    318.39844     hPa
ENG102680    MAP_1_MES        307.38    299.08     hPa
ENG99737    MAP_1_MES_BAS        307.13    298.92     hPa
ENG102960    MAP_2_ENVD        382.07813    334.31836     hPa
ENG102281    MAP_2_MES        327.11    316.33     hPa
ENG104243    MAP_2_MES_BAS        326.86    316.91     hPa
ENG103166    MAP_ENVD        0    0     hPa
ENG103501    MASS_SA_REL[0]        1    1
ENG102071    MASS_SA_REL[1]        1    1
ENG100896    MASS_SA_REL_21_PHA        1    1
ENG103045    MASS_SA_REL_22_PHA        1    1
ENG100077    MASS_SA_REL_PHA_1[0]        1    1
ENG99761    MASS_SA_REL_PHA_1[1]        1    1
ENG100529    MASS_SA_REL_PHA_2[0]        1    1
ENG101938    MASS_SA_REL_PHA_2[1]        1    1
ENG100705    MAX_HLD_FTL_SENS        0    0     s
ENG99929    MAX_HLD_ICH        0    0     s
ENG101558    MAX_HLD_LAMP_RE        0    0     s
ENG100434    MAX_HLD_PSTE        0    0     s
ENG99171    MAX_HLD_SCU        0    0     s
ENG102618    Mean engine air mass        14.94    0     kg/h
ENG103857    Mean vehicle speed        0    0     km/h
ENG99199    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[0]        0    0     mg/stroke
ENG103758    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[1]        0    0     mg/stroke
ENG100400    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[2]        0    0     mg/stroke
ENG103502    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[3]        0    0     mg/stroke
ENG100254    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[4]        0    0     mg/stroke
ENG100666    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[5]        0    0     mg/stroke
ENG103380    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[0]        0    -0.086     mg/stroke
ENG103050    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[1]        0    0.006     mg/stroke
ENG101085    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[2]        0    0.217     mg/stroke
ENG103812    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[3]        0    0.086     mg/stroke
ENG102659    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[4]        0    -0.133     mg/stroke
ENG102911    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[5]        0    -0.092     mg/stroke
ENG103346    MFF_ADD_LAM_AD[1]        0    0     mg/stroke
ENG100447    MFF_ADD_LAM_AD[2]        0    0     mg/stroke
ENG101360    Misfire detection active        1    1
ENG102335    Misfires all cylinders per 1000 rpm        0    0
ENG99926    Misfires cylinder 1 from engine start to engine stop        0    0
ENG103503    Misfires cylinder 1 per 1000 rpm        0    0
ENG100235    Misfires cylinder 2 from engine start to engine stop        0    0
ENG99825    Misfires cylinder 2 per 1000 rpm        0    0
ENG101055    Misfires cylinder 3 from engine start to engine stop        0    0
ENG101730    Misfires cylinder 3 per 1000 rpm        0    0
ENG101998    Misfires cylinder 4 from engine start to engine stop        0    0
ENG102032    Misfires cylinder 4 per 1000 rpm        0    0
ENG100222    Misfires cylinder 5 from engine start to engine stop        0    0
ENG101260    Misfires cylinder 5 per 1000 rpm        0    0
ENG101221    Misfires cylinder 6 from engine start to engine stop        0    0
ENG101947    Misfires cylinder 6 per 1000 rpm        0    0
ENG98787    N        721    682     /min
ENG110570    N_CAM_32_DIAG_CRK_SIG_LOSS        704    672     /min
ENG110571    N_TOOTH_32_DIAG_CRK_SIG_LOSS        704    672     /min
ENG107737-ENG102260    NC_NR_DIAG_RBM-IdentDec        75    75
ENG99870    O2L_1_MAX_BAS_AD_CAT[1]        0.15681    0.15681     g
ENG102018    O2L_1_MAX_BAS_AD_CAT[2]        0.15002    0.15002     g
ENG104137    O2L_1_MAX_BAS_AD_CAT_DIAG[1]        0.99998    0.99998     g
ENG100562    O2L_1_MAX_BAS_AD_CAT_DIAG[2]        0.99998    0.99998     g
ENG103698    Oil temperature        28    84     °C
ENG101106    PDT_ENVD        366.1582    318.39844     hPa
ENG99157    PRS_SA_DIF        0    0     hPa
ENG102451    PSN_EDGE_1_AD_CAM_IN_1        0.875    0.25     °
ENG103487    PSN_EDGE_2_AD_CAM_IN_1        2.875    2.3125     °
ENG102195    PV_AV_1        0    0     %
ENG99137    PV_AV_2        0    0     %
ENG101068    PV_AV_H        0    0     %
ENG102782    Radiator fan 1: activation        10.2    10.2     %
ENG101201    Radiator fan 1: run-on: status        600 W    600 W
ENG101514    Radiator fan 2: activation        10.2    10.2     %
ENG102359    Radiator fan 2: run-on: status        400 W    400 W
ENG100307    RATIO_MASS_O2_CAT_DIF[1]        0    0
ENG99168    RATIO_MASS_O2_CAT_DIF[2]        0    0
ENG102377    Ready and error flags        196    196
ENG102831    Ready bits (completed tests)        228    228
ENG100050    RFP_AD_STEP_CTR        255    255
ENG103162    RFP_AD_STOP        0    8192
ENG99149    RFP_AD_STOP_SAVE        4    4
ENG100790    RFP_AD_STOP_SAVE_HIGH_ENVD        0    0
ENG101524    RFP_AD_STOP_SAVE_LOW_ENVD        4    4
ENG99738    RFP_AV        68.47    83.16     °
ENG103313    RFP_AV_ENVD        74.4095    82.6772
ENG101571    RFP_SP        68.68    77.01     °
ENG102212    RFP_SP_ENVD        74.4095    76.8898
ENG100220    RFPPWM_ENVD        15.625    0     %
ENG103248    SEG_AD_MMV_ER[0]        0    0     ‰
ENG101135    SEG_AD_MMV_ER[1]        -1.8353    -1.8353     ‰
ENG99078    SEG_AD_MMV_ER[2]        -0.2944    -0.2944     ‰
ENG103257    SEG_AD_MMV_ER[3]        -0.611    -0.611     ‰
ENG100125    SEG_AD_MMV_ER[4]        -1.5762    -1.5762     ‰
ENG100241    SEG_AD_MMV_ER[5]        -0.51    -0.51     ‰
ENG102511    SEG_AD_MMV_ER_H[0]        0    0     ‰
ENG103258    SEG_AD_MMV_ER_H[1]        -1.4195    -1.4195     ‰
ENG99291    SEG_AD_MMV_ER_H[2]        -0.5562    -0.5562     ‰
ENG99954    SEG_AD_MMV_ER_H[3]        -0.0205    -0.0205     ‰
ENG100348    SEG_AD_MMV_ER_H[4]        -1.2462    -1.2462     ‰
ENG104100    SEG_AD_MMV_ER_H[5]        -0.5212    -0.5212     ‰
ENG100568    SEG_AD_MMV_ER_L[0]        0    0     ‰
ENG100601    SEG_AD_MMV_ER_L[1]        -1.8353    -1.8353     ‰
ENG102668    SEG_AD_MMV_ER_L[2]        -0.2944    -0.2944     ‰
ENG101232    SEG_AD_MMV_ER_L[3]        -0.611    -0.611     ‰
ENG102134    SEG_AD_MMV_ER_L[4]        -1.5762    -1.5762     ‰
ENG99992    SEG_AD_MMV_ER_L[5]        -0.51    -0.51     ‰
ENG101561    SEG_AD_MMV_ER_MID[0]        0    0     ‰
ENG102964    SEG_AD_MMV_ER_MID[1]        -1.8599    -1.8599     ‰
ENG100890    SEG_AD_MMV_ER_MID[2]        -0.4024    -0.4024     ‰
ENG99793    SEG_AD_MMV_ER_MID[3]        -0.277    -0.277     ‰
ENG103967    SEG_AD_MMV_ER_MID[4]        -1.5864    -1.5864     ‰
ENG99413    SEG_AD_MMV_ER_MID[5]        -0.5107    -0.5107     ‰
ENG103381    Shut-off time        1.69    1.69     s
ENG109006-ENG100882    Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX        0    0     %
ENG109007-ENG99938    Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX        0    0     %
ENG102971    Start adaption: temperature adaption factor 1        1    1
ENG102489    Start adaption: temperature adaption factor 2        1    1
ENG100723    Start adaption: temperature adaption factor 3        1    1
ENG101893    Starter control: clutch switch        0    0
ENG100919    Starter control: interlock switch        0    0
ENG102520    Starter: measure-back wire term. 50 R        0    0
ENG100800    Starter: start relay 1        0    0
ENG99979    Starter: start relay 2        0    0
ENG99368    Starter: starter request terminal 50        0    0
ENG101327    STATE_LS_ENVD[1]        2    2
ENG101384    STATE_LS_ENVD[2]        2    2
ENG101078    STATE_READY_OBD_1        7    7
ENG100369    STATE_READY_OBD_3        255    255
ENG109090-ENG101799    STATE_SW_MVB-Param to DOP        S84I2010 CBE0AL0    S84I2010 CBE0AL0
ENG103546    T_AST_ENVD        77.1    488.3     s
ENG104148    T_COOL_LOIL        642.5    633.5     ms
ENG101072    T_DTC_CLR        3    3     min
ENG102790    T_EFP_MEM_H        655.35    655.35     s
ENG102123    T_EFP_MEM_L        655.35    655.35     s
ENG99831    T_FAC_MAF_MAX_ORNG        0.5    0     s
ENG99128    T_INT_DIAG_TH        197    0     s
ENG112954    T_PER_MES_LEAK_ENVD        0    0     s
ENG112955    T_PER_MES_OBD_ENVD        0    0     s
ENG99398    T_POP_COC_INTER_1        0    0     s
ENG102747    T_PWL        0    0     s
ENG100808    T_RAMP_RFP_SP_OSC        4.69    1.47     s
ENG101325    T_TEMP_SIG_LOIL        44    61.5     ms
ENG112953    TAM_CAN        24    26.3     °C
ENG102048    Tank breather valve: duty cycle        11.328125    0     %
ENG101339    Tank breather valve: short trip result        0.4923    0     kg/h
ENG103627    Tank leaks test: fault message        NO_SYM    NO_SYM
ENG100439    Tank level        0    0
ENG104029    TCO_1_2        104.3    142.5     °C
ENG103434    TCO_A_LAM_AD_WUP[1]        -5.25    -5.25     °C
ENG100717    TCO_A_LAM_AD_WUP[2]        -5.25    -5.25     °C
ENG100381    TCO_B_LAM_AD_WUP[1]        9.75    9.75     °C
ENG101562    TCO_B_LAM_AD_WUP[2]        9.75    9.75     °C
ENG101581    TCO_C_LAM_AD_WUP[1]        24.75    24.75     °C
ENG101857    TCO_C_LAM_AD_WUP[2]        24.75    24.75     °C
ENG100354    TCO_D_LAM_AD_WUP[1]        35.25    35.25     °C
ENG101300    TCO_D_LAM_AD_WUP[2]        39    35.25     °C
ENG101973    TCO_E_LAM_AD_WUP[1]        42.75    45     °C
ENG103356    TCO_E_LAM_AD_WUP[2]        42.75    45     °C
ENG100390    TCO_MIN_INTER_LAM_AD_WUP[1]        39.75    94.5     °C
ENG103663    TCO_MIN_INTER_LAM_AD_WUP[2]        39    94.5     °C
ENG100853    TCO_MIN_LAM_AD_WUP[1]        39.75    50.25     °C
ENG103733    TCO_MIN_LAM_AD_WUP[2]        39    50.25     °C
ENG102279    TCS/ESP: specified torque        1022    1022     Nm
ENG99857    TCS: status        0    0
ENG103400    TEMP_CAT_ENVD[1]        100    455     °C
ENG102182    TEMP_CAT_ENVD[2]        100    455     °C
ENG101941    TEMP_CAT_STAT_MDL[1]        411.6625    394.1     °C
ENG99592    TEMP_CAT_STAT_MDL[2]        389.9125    385.2875     °C
ENG101721    Throttle actuator angle (potentiometer 2)        0    0
ENG104173    Throttle adjustment: potentiometer 1 emergency gap        0.674    0.669     V
ENG101024    Throttle adjustment: potentiometer 2: emergency gap        4.248    4.253     V
ENG99608    Throttle valve adjuster: adaption status        0    9
ENG100374    Throttle valve adjustment: potentiometer 1 lower adaption        0.42    0.42     V
ENG102367    Throttle valve adjustment: potentiometer 2 lower adaption        4.541    4.541     V
ENG101411    Throttle valve angle        0.817    0.715     °
ENG101155    Throttle valve angle: potentiometer 1        0.454    0.449     V
ENG101278    Throttle valve angle: potentiometer 2        4.497    4.502     V
ENG102845    Throttle valve deviation        -3.398    -0.029     %
ENG103149    TI_1_HOM[0]        0.628    0.592     ms
ENG101279    TI_1_HOM[1]        0.576    0.6     ms
ENG99190    TI_1_HOM[2]        0.628    0.608     ms
ENG100436    TI_1_HOM[3]        0.568    0.6     ms
ENG100317    TI_1_HOM[4]        0.616    0.592     ms
ENG102588    TI_1_HOM[5]        0.584    0.572     ms
ENG104034    TI_2_HOM[0]        0    0     ms
ENG103041    TI_2_HOM[1]        0    0     ms
ENG100076    TI_2_HOM[2]        0    0     ms
ENG100292    TI_2_HOM[3]        0    0     ms
ENG101541    TI_2_HOM[4]        0    0     ms
ENG99751    TI_2_HOM[5]        0    0     ms
ENG99834    TIA[NC_IDX_TIA_IM_CYL_1]        30    47.25     °C
ENG101962    TIA[NC_IDX_TIA_IM_CYL_2]        30    48     °C
ENG102627    TIA_AM_SCHA        29.25    44.25     °C
ENG103343    TIA_MES[NC_IDX_TIA_AM_SCHA]        29.25    44.25     °C
ENG101694    TIA_MES[NC_IDX_TIA_IM_CYL_1]        30    47.25     °C
ENG102135    TIA_MES[NC_IDX_TIA_IM_CYL_2]        30    48     °C
ENG103351    Time since engine start        308.5    715.5     s
ENG100558    TPS_ENVD        1.2    0     %
ENG103021    TQ_CONV        0    0     Nm
ENG102012    TQ_DIF_IS_AD_ACC        2.09375    2.09375     Nm
ENG99851    TQ_LOSS        -40.40625    -35.0625     Nm
ENG99317    TQ_LOSS_ACC        0    0     Nm
ENG103625    TQI_AV_ENVD        54    42     Nm
ENG100768    TQI_GS_FAST_DEC        1023.97    1023.97     Nm
ENG101426    TQI_GS_FAST_INC        0    0     Nm
ENG100355    V_FUP_EFP_MV        2.017    2.3     V
ENG101255    V_PORT_1_ENVD        0.64453    0.66406     V
ENG99922    V_PORT_1_RAW        3.843    3.818     V
ENG100742    V_PORT_2_ENVD        0.64453    0.68359     V
ENG99200    V_PORT_2_RAW        0.654    0.698     V
ENG99867    V_PVS_1_ENVD        0.74219    0.74219     V
ENG100593    V_PVS_2_ENVD        0.37109    0.37109     V
ENG100956    V_TPS_1_ENVD        4.45313    4.49219     V
ENG99904    V_TPS_2_ENVD        0.46875    0.44922     V
ENG103201    VCV_CLOSE_RNG        20.6    22.1     °
ENG99527    Vehicle speed: actual        0    0     km/h
ENG102311    Vehicle speed: filtered        0    0     km/h
ENG102035    Vehicle speed: specified        0    0     km/h
ENG103235    VLS_DOWN_1_ENVD        0.41016    0.03906     V
ENG103269    VLS_DOWN_2_ENVD        0.41016    0.05859     V
ENG103710    VLS_UP_1_ENVD        2.1875    2.20703     V
ENG99196    VLS_UP_2_ENVD        1.89453    1.99219     V
ENG100719    VLS_UP_DIAG_SAVE_PUC_LSL_UP[1]        0    0     V
ENG103416    VLS_UP_DIAG_SAVE_PUC_LSL_UP[2]        0    0     V
ENG102798    VP_RFP_1        3.8232    0.0049     V
ENG102004    VP_RFP_1_ENVD        4.02344    0     V
ENG101126    VP_RFP_AD_BOL_1        0.4742    0.5278     V
ENG102969    VP_RFP_AD_BOL_1_ENVD        0.46875    0.52734     V
ENG102249    VP_RFP_AD_LIH_1        4.4922    4.4922     V
ENG103425    VP_RFP_AD_LIH_1_ENVD        4.49219    4.49219     V
ENG101394    VP_RFP_BOL_1        0.4742    0.5278     V
ENG100243    VP_RFP_BOL_MTC_1        0.4742    0.5278     V
ENG100671    VP_RFP_BOL_MTC_1_ENVD        0.46875    0.52734     V
ENG101523    VP_RFP_LIH_1        4.4873    4.4873     V
Elapsed Time: 00:51
   #69
B8boi
California, USA
C?ID=530730
Autoscan during car warmup, codes cleared, no issue yet.
Then codes for ECU module thrown after warmup after autoscan
uesday,01,October,2024,00:39:26:01176
          5F 62 6C 72
                    Mileage: 174858 km
                    Date: 2024.09.30
                    Time: 21:33:26
                    Engine RPM: 689.00 /min
                    Normed load value: 9.8 %
                    Coolant temperature: 38 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.202 V
                    Engine speed: actual: 704 /min
                    MAF_ENVD: 141.62353 mg/stroke
                    Coolant temperature (unfiltered): 38.3 °C
                    Engine load: 9.765625 %
   Coding: 280D18
   Coding: 0F0100
   Coding: 66102000
   Coding: 00FD11
   Coding: 025028
                    Reset counter: 2
                    Mileage: 174858 km
                    Date: 2024.09.24
                    Time: 22:06:00
   Coding: 20000D
   Coding: 000016
   Coding: 00C003
                    Reset counter: 2
                    Mileage: 174858 km
                    Date: 2024.09.24
                    Time: 22:07:16
                    Bin. Bits:    11111
                    Voltage: 13.90 V
                    Count: 6
                    Bin. Bits:    10011
   Coding: 0000001
   Coding: 0000004
                    Reset counter: 2
                    Mileage: 174858 km
                    Date: 2024.09.24
                    Time: 22:06:25
                    Voltage: 13.90 V
   Coding: 1000006
                    Reset counter: 2
                    Mileage: 174858 km
                    Date: 2024.09.24
                    Time: 22:06:16
                        Reverse OFF
                    Count: 3
End----(Elapsed Time: 01:51, VBatt start/end: 14.0V/14.0V. VIgn 0.0V)------
Tuesday,01,October,2024,00:58:23:01176
                Address 01: Engine       Labels: 06E-907-551-CAK.clb
Control Module Part Number: 8K0 907 551 D    HW: 8K0 907 551 A
  Component and/or Version: 3.0T SIMOS84  H06 0003
           Software Coding: 0104000A180F0128
            Work Shop Code: WSC 06325 000 00000
              ASAM Dataset: EV_ECM30TFS0218K0907551D 001003 (AU48)
Fault Codes have been Erased
                    Mileage: 174858 km
                    Date: 2024.09.30
                    Time: 21:58:49
                    Engine RPM: 688.00 /min
                    Normed load value: 6.7 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 13.609 V
                    RFP_AV_ENVD: 0.0000
                    Mileage: 174858 km
                    Date: 2024.09.30
                    Time: 21:58:50
                    Mileage: 174858 km
                    Date: 2024.09.30
                    Time: 21:58:49
                    RFP_AV_ENVD: 0.0000
                    Mileage: 174858 km
                    Date: 2024.09.30
                    Time: 21:58:50
   #70
B8boi
California, USA
C?ID=530730
AIMING THE PARTS CANNON AT THE OXYGEN SENSOR
Anyway to test my theory before i proceed?
   #71
EuroX
Northern NJ USA
C?ID=208579
But why o2?
B8boi
California, USA
C?ID=530730
But why o2?
Because from the Blockmap the [Lambda probe heater: resistance: bank 2: probe 2 ] value seems out of alignment with its twin on the other bank.
So last night I got the CEL to trip and usually when it does, I can clear the faults and they immediately come back. BUT THIS TIME I UNPLUGGED THE SECONDARY 02 sensor and it allowed me to clear the codes!!!!! So a glint of light. Because I believe this isolates my issue to either a bad sensor in the ECM network or bad ECM internal circuitry. I was worried that it might be the pins on the ECU connector but the ability to immediately clear the codes leads me to believe otherwise.
   #73
EuroX
Northern NJ USA
C?ID=208579
I fail to see what an o2 has to do with a bypass valve fault. Or have those been resolved?
   #74
B8boi
California, USA
C?ID=530730
Because the standard list of bypass valve fixes has not worked for me. So I started to look deeper. and like I said 3 posts above... saw someone on youtube who diagnosed a throttle body issue by looking at sensors on the ecu network and seeing which sensor had a farfetched value ( IAT -40C) in his case. Representing a short or issue with the sensor. I was thinking maybe I have an issue with the secondary oxygen sensor creating a short and overworking the ECM. And because I am catless I am thinking it maybe is tuned to not throw a code?
EuroX
Northern NJ USA
C?ID=208579
Doubtful unless ecm is fucked internally. Most likely modified flash no to throw a code.
   #76
Westbury, UK
Many tuners have an annoying habit of disabling some diagnostic reporting - which is why when someone posts they have a tune one suggestion is always to return to stock and re-enable the full diagnostics.
   #77
B8boi
California, USA
C?ID=530730
Can you please elaborate on why its doubtful? I have an electrical schematic and the O2 sensor isnt part of the loop that powers the bypass motor and its sensor. But i thought it was interesting that on the ECM harness the B2S2 have a few pins right next to the bypass pin.
   #78
EuroX
Northern NJ USA
C?ID=208579
Based on some of the vehicles I used to modify back in the day disabling or rear o2's was always a work around for not setting catalyst faults. So "to meet emissions " per say. Per say because readiness would be set and no cat fault would be present whether the vehicle had no cats at all, or high flow garbage they call a catalyst installed.
   #79
Dr Sheldon
Windsor UK
C?ID=334979
Uwe, thats what Ive seen. But i found a "gentleman" willing to clone a used wrecked car ecu which is identical to mine, but he says he will have to remove the immobilizer feature and that worries me. Dont want to just throw money at a ECU, albeit im getting there, and also dont want my baby getting stolen
if he can truly clone it then there is no need to remove the Immo
   #80
B8boi
California, USA
C?ID=530730
So I am f*kd. I have followed the diagnosis manual to all extents and it has not sufficiently addressed the issue. Do i need ot pay VCDS for some support here? I feel like this issue is beyond the realm of a standard mechanic and i worry ill be throwing away money doing that first.
