B8 S4 bypass value issue/Terminal Voltage issue.
   #41
B8boi
California, USA
C?ID=530730
Maybe, maybe not , I think that fault may be a clue and also could be misleading you. I would keep an open mind as some times faults aren't so definitive.
The factory mounts when they fail, ARE known to cause misfires and poor running conditions! Commonly known. (Scanner Danner and others). Yours I believe are 034 with the internal resistors and then the factory harnesses plugged into them.
I would unplug the harnesses from the 034 mounts and place the available individual resistors into each side harness. (plug into factory harness on both sides).
That engine mount(s) harness IS connected to the CAN-Bus system and can cause all sorts of running issues.
Mine are 034 but they definitely dont have resistors, i can test cycle them in VCDS and i hear them audibly click on and off.
   #42
The 034 mounts are not active like the factory mounts are (hydraulic/oil filled) and they have an internal resistor or device for keeping the CAN happy ; they are solid. I would unplug them to eliminate that possibility of sorting your issue. You can then source external plug in resistors to plug into the factory wiring. I'm not so sure what you are hearing is the mounts when you output test them. (there is nothing in them!)
   #43
B8boi
California, USA
C?ID=530730
So I installed the motor mount resistors...... and it seems to have fixed the issue. But I am weary because my bypass valve took multiple attempts to adapt as well as the throttle body. And there is also a minor "popping" that would hear at low speed from a stop that no longer happens.
I will report back, but as of the swap I cannot initiate a single hiccup. Go figure.......:confused::confused::confused:
   #44
B8boi
California, USA
C?ID=530730
So the epc came back this morning :( Im at a loss now, not sure why me not driving the car for a few days allows it to work proper for a few moments. But I will persevere. When the car was functioning stellar I monitored voltage at the ECU and it still seemed to be around 13.5V when driving. Maybe I need to do an adaptation with a charger hooked up? Not sure why its sucha damn struggle to do the adaptation
   #45
B8boi
California, USA
C?ID=530730
BUMP Hellllpppp!
What should be my next step to debug? Ecu is next? it weird some moments the car works stellar and then a moment later not.
one key thing, the ECU with give me an EPC light. Then I will clear it, but the bypass will stop working even though I clear the fault and it prevents any boost by allowing recirc.
B8boi
California, USA
C?ID=530730
So I've checked for any major harness damage underneath and removed the under body panels, and there is nothing awry it seems. So I tried to do an adaptation before leaving work yesterday. The throttle adaptation failed and immediately cause a whole myriad of EPC/TPMS the whole cluster lit up. Then later I tried the adaptation for the throttle one more time. It worked and there was no issue, car started fine. Left the car overnight and it took 3 tries to start.
Its gotta be the ECU right? I mean adapting is sporadic and not really consistent. If it was a bad connection, or a bad hardware connection the issue would rear its head repeat-ably during adaptation??
most recent P10A06 CODE:
@4519 RPM
VOLTAGE : 11.679 VOLTS
V_PVS_1_ENVD: 3.945 VOLTS
RFP_SP_ENVD: 000
VP_RFP_1_ENVD: 0000 VOLT
RFPPWM_ENVD: 21.875%
   #47
B8boi
California, USA
C?ID=530730
Bump for input! thanks
   #48
B8boi
California, USA
C?ID=530730
So an update. I decided to look at voltages of various modules, and during an autoscan the abs module populates ok. but when I try to enter the module directly, it fails 9/10 times and will even trigger a traction control light.
I am going to double check grounds and possibly ground splices because it is odd the ABS module is not communicating.
   #49
B8boi
California, USA
C?ID=530730
I have the downloaded manual but its kind of stupid and describes grounds that are slightly different from what I have.
says:
685/638/671/615/12
The one in particular that I cant seem to get is 671. Its says its on the front left long memeber, but I only have a ground underneath the coolant tank on a bent bracket. No ground on the member.
I checked and cleaned all grounds and rings in the engine bay. Even so, its still not working. Whenever I disconnect power entirely from the ECU, (like needed to clean the grounds) the car works great for a few solid WOT pulls, but then as the car gets fully warm it starts to hiccup. I guess my next step in to check interior grounds? The car still struggles to connect to the ABS module but after cleaning the grounds I am at a loss. Additionally, whenever I attempt to connect to the ABS module with VCDS the dash illuminates the traction control light. My car would do this during VCDS autoscans as well but I thought this was just a check of functionality. Is this proper???
What I don't get is why it works superb for a few moments, and then fails, just not right away, I figure a bad ground would be an issue irrespective of temperature or engine "warmness"?
Also,
RFP_SP_ENVD: 000
There's these values that show 0. If a component was poorly grounded and issue, wouldn't these values have SOME voltage?
Am dying here please help. I will try to clean the cabin grounds next but I am back at that brick wall. Thanks
   #50
B8boi
California, USA
C?ID=530730
So further, I re-downloaded the trouble shooting manuals for the car and the codes. and I found an updated version, where the troubleshooting logic allows the ECU to be the culprit of my issues. Which I guess could also cause my abs module connection issues right?
   #51
B8boi
California, USA
C?ID=530730
So i sent the ECU to be cloned. The guy said because it has a tune on it, he couldnt clone it. But he said he was able to test the outputs for the issue and he doesn't seem to find an issue.
do i trust it?
   #52
Dr Sheldon
Windsor UK
C?ID=334979
I dont speak with absolute certainty here but I am happy impart what I do think i know !!
A tune or a remap on an ECU should not make any difference to extracting data from one electronic component and then write that data to a another.
However, Some Tuners, Mappers do lock the ECU to protect their work from software pirates. Speak to the Ebay guy and ask if this is the case ??
VAG group are about the only VM that will allow the dealer tool ODIS to code in a used ECU
Equally a SVM Software update with ODIs may override what is in your ECU and return it to Factory !! Then that can be cloned !!
Rather than Ebay which is great but no personal "touch" - Google a Tuner, Mapper near you and go meet him ??
There is a 50% chance he is bang on right !!
Are you fixing problems that you dont have ??
Dr Sheldon
Windsor UK
C?ID=334979
Elaborate on that - What are you disconnecting - where , what, how .... ?
   #54
B8boi
California, USA
C?ID=530730
I appreciate any help I can get at this point because I am out of leads for troubleshooting. I mean my tuner offers unlimited map flashes because i do it from home so I am not worried about losing a tune. I just might have to return it to factory flash. I figured a Ebay contact would be better as i could make my decision off of reviews I could read, and it seems not a lot of issues happen with b8 S4 ecus so there's not many clone/tuners locally.
If my VCDS scan shows issues with modules but no MIL illuminated, does that mean I have a problem? I think so. Ideally I want to be able to not have any codes or have only some that are rationale i.e. code for water pump in ECU module (I can explain that.)
   #55
B8boi
California, USA
C?ID=530730
Like, I had an issue with my bypass valve. Decided to send my ecu out for cloning and after 3 weeks of being disconnected from the car, I reinstalled it, drive around and the code hasn't shown up after a day of driving. Adaptation still acts funny and says completed when its not yet done....which leads me to believe that its going to rear its head again.
Essentially, disconnecting the ECU entirely from the system yields good results albeit temporarily.
I finally learned how to take a log of values during an adaptation and here is one from when i try to adapt the bypass valve. Clearly battery voltage is low, the car is on the 2 amp trickle charger but also shows a lack of change in RFP_AV vs SP. I dont believe the bypass is adapting or working properly. The valve opens and closes, i see it move (when off the charger) and hear it, but I am not sure if the values show a proper sweep during an adaptation of the valve.
Friday    2    August    2024    01:25:58:01176-VCID:323D168464AF281A997-8066    VCDS Version: Release 24.7.0 (x64)    Data version: 20240715 DS356.3
8K0 907 551 D    ADVMB    3.0T SIMOS84  H06 0003
        G001    F0    G099    F0    G511    F0    G512    F0    G513    F0    G514    F0    G515
Marker    TIME    Loc. IDE00019    TIME    Loc. ENG103165    TIME    Loc. ENG99738    TIME    Loc. ENG103313    TIME    Loc. ENG101571    TIME    Loc. ENG102212    TIME    Loc. ENG100220
    STAMP    Voltage terminal 30    STAMP    Battery voltage    STAMP    RFP_AV    STAMP    RFP_AV_ENVD    STAMP    RFP_SP    STAMP    RFP_SP_ENVD    STAMP    RFPPWM_ENVD
         V         V         °                  °                  %
    0.2    11.882    0.24    11.882813    0.29    83.34    0.34    82.6772    0.03    0    0.07    0    0.12    0
    0.55    11.984    0.58    11.882813    0.62    83.34    0.67    82.6772    0.38    0    0.42    0    0.46    0
    0.89    11.882    0.94    11.882813    0.98    83.34    1.03    82.6772    0.71    0    0.76    0    0.81    0
    1.24    11.882    1.29    11.882813    1.34    83.34    1.38    82.6772    1.08    0    1.12    0    1.17    0
    1.61    11.882    1.65    11.984375    1.7    83.34    1.74    82.6772    1.44    0    1.48    0    1.52    0
    1.93    11.882    1.98    11.882813    2.03    83.34    2.07    82.6772    1.79    0    1.84    0    1.88    0
    2.28    11.882    2.32    11.882813    2.37    83.34    2.42    82.6772    2.12    0    2.16    0    2.2    0
    2.64    11.882    2.68    11.882813    2.73    83.34    2.77    82.6772    2.46    0    2.51    0    2.55    0
    2.96    11.882    3.01    11.984375    3.06    83.34    3.1    82.6772    2.83    0    2.87    0    2.92    0
    3.33    11.882    3.36    11.882813    3.4    83.34    3.45    82.6772    3.15    0    3.2    0    3.24    0
    3.63    11.882    3.66    11.882813    3.7    83.34    3.74    82.6772    3.49    0    3.52    0    3.55    0
    3.9      11.882    3.95    11.882813    4    83.34    4.04    82.6772    3.77    0    3.81    0    3.85    0
    4.26    11.882    4.31    11.882813    4.36    83.34    4.4    82.6772    4.09    0    4.14    0    4.18    0
    4.59    11.882    4.63    11.882813    4.66    83.34    4.7    82.6772    4.45    0    4.5    0    4.54    0
    4.92    11.882    4.96    11.882813    5.01    83.34    5.05    82.6772    4.74    0    4.79    0    4.84    0
    5.26    11.882    5.3    11.882813    5.34    83.34    5.38    82.6772    5.09    0    5.13    0    5.18    0
    5.59    11.882    5.63    11.984375    5.66    83.34    5.7    82.6772    5.42    0    5.46    0    5.51    0
    6.11    11.882    6.15    11.882813    6.2    83.34    6.24    82.6772    5.74    0    5.79    0    6.03    0
    6.44    11.882    6.48    11.882813    6.52    83.34    6.55    82.6772    6.29    0    6.34    0    6.38    0
    6.73    11.882    6.77    11.882813    6.82    83.34    6.87    82.6772    6.59    0    6.63    0    6.66    0
    7.07    11.882    7.12    11.882813    7.17    83.34    7.21    82.6772    6.91    0    6.95    0    7    0
    7.42    11.882    7.46    11.882813    7.51    83.34    7.56    82.6772    7.26    0    7.3    0    7.34    0
    7.78    11.882    7.82    11.984375    7.87    83.34    7.91    82.6772    7.6    0    7.65    0    7.7    0
    8.1      11.882    8.15    11.882813    8.19    83.34    8.23    82.6772    7.94    0    7.98    0    8.03    0
    8.44    11.882    8.48    11.882813    8.53    83.34    8.58    82.6772    8.28    0    8.32    0    8.37    0
    8.79    11.882    8.84    11.882813    8.89    83.34    8.94    82.6772    8.62    0    8.67    0    8.71    0
    9.14    11.882    9.18    11.882813    9.23    83.34    9.28    82.6772    8.98    0    9.02    0    9.05    0
    9.46    11.882    9.51    11.984375    9.56    83.34    9.6    82.6772    9.32    0    9.37    0    9.41    0
    9.82    11.882    9.86    11.882813    9.9    83.34    9.95    82.6772    9.65    0    9.7    0    9.75    0
    10.17  11.882    10.21    11.882813    10.26    83.34    10.3    82.6772    9.99    0    10.04    0    10.09    0
    10.5    11.882    10.54    11.882813    10.59    83.34    10.64    82.6772    10.34    0    10.38    0    10.42    0
    10.86    11.882    10.9    11.882813    10.94    83.34    10.98    82.6772    10.68    0    10.73    0    10.77    0
    11.18    11.882    11.23    11.882813    11.28    83.34    11.32    82.6772    11.02    0    11.06    0    11.1    0
    11.54    11.882    11.58    11.882813    11.62    83.34    11.67    82.6772    11.37    0    11.42    0    11.46    0
    11.89    11.882    11.93    11.882813    11.98    83.34    12.03    82.6772    11.72    0    11.76    0    11.81    0
    12.21    11.882    12.26    11.882813    12.3    83.34    12.34    82.6772    12.07    0    12.12    0    12.16    0
    12.9      11.882    12.95    11.882813    12.99    83.34    13.04    82.6772    12.38    0    12.43    0    12.48    0
    13.39    11.882    13.43    11.984375    13.48    83.34    13.52    82.6772    13.09    0    13.13    0    13.18    0
    13.86    11.882    13.9    11.984375    13.94    83.34    13.97    82.6772    13.56    0    13.6    0    13.65    0
    14.27    11.882    14.32    11.882813    14.37    83.34    14.42    82.6772    14.01    0    14.06    0    14.1    0
    14.76    11.882    14.8    11.882813    14.83    0    14.87    82.6772    14.47    0    14.51    0    14.56    0
    15.21    11.78    15.26    11.78125    15.3    0.56    15.33    82.6772    14.92    0    14.96    0    15.01    0
    15.67    11.882    15.71    11.882813    15.76    1.51    15.8    82.6772    15.37    0    15.42    0    15.46    0
    16.13    11.882    16.19    11.882813    16.23    16.28    16.27    82.6772    15.84    1.49    15.89    0    15.93    0
    16.59    11.882    16.63    11.882813    16.69    83.34    16.73    82.6772    16.32    70.01    16.37    0    16.42    0
    17.08    11.882    17.11    11.882813    17.15    83.34    17.2    82.6772    16.77    0    16.82    0    16.87    0
    17.52    11.882    17.57    11.882813    17.61    83.34    17.66    82.6772    17.25    0    17.29    0    17.33    0
    17.96    11.882    18.01    11.882813    18.06    83.34    18.1    82.6772    17.7    0    17.74    0    17.79    0
    18.45    11.882    18.49    11.882813    18.54    83.34    18.58    82.6772    18.15    0    18.2    0    18.25    0
    18.91    11.882    18.95    11.882813    19    83.34    19.04    82.6772    18.61    0    18.65    0    18.7    0
    19.34    11.882    19.39    11.882813    19.43    83.34    19.47    82.6772    19.08    0    19.12    0    19.17    0
    19.77    11.882    19.82    11.882813    19.87    83.34    19.92    82.6772    19.51    0    19.56    0    19.6    0
    20.26    11.882    20.3    11.882813    20.34    83.34    20.39    82.6772    19.96    0    20.01    0    20.06    0
    20.71    11.882    20.76    11.882813    20.81    83.34    20.85    82.6772    20.43    0    20.47    0    20.51    0
    21.2      11.882    21.24    11.882813    21.29    83.34    21.34    82.6772    20.91    0    20.95    0    20.99    0
    21.65    11.882    21.69    11.882813    21.73    83.34    21.77    82.6772    21.39    0    21.43    0    21.48    0
    22.11    11.882    22.15    11.882813    22.2    83.34    22.24    82.6772    21.82    0    21.87    0    21.92    0
    22.55    11.882    22.59    11.882813    22.63    83.34    22.68    82.6772    22.29    0    22.34    0    22.38    0
    23.01    11.882    23.06    11.882813    23.11    83.34    23.15    82.6772    22.72    0    22.76    0    22.81    0
    23.49    11.882    23.54    11.882813    23.59    83.34    23.64    82.6772    23.2    0    23.25    0    23.29    0
    23.98    11.882    24.02    11.882813    24.06    83.34    24.1    82.6772    23.68    0    23.73    0    23.77    0
    24.44    11.882    24.48    11.882813    24.53    83.34    24.57    82.6772    24.15    0    24.2    0    24.24    0
    24.87    11.882    24.92    11.882813    24.96    83.34    25.01    82.6772    24.62    0    24.66    0    24.69    0
    25.37    11.882    25.42    11.882813    25.46    83.34    25.51    82.6772    25.06    0    25.1    0    25.16    0
    25.8      11.882    25.83    11.882813    25.87    83.34    25.92    82.6772    25.55    0    25.58    0    25.61    0
    26.25    11.882    26.29    11.882813    26.34    83.34    26.38    82.6772    25.96    0    26    0    26.04    0
    26.65    11.882    26.7    11.882813    26.75    83.34    26.79    82.6772    26.41    0    26.44    0    26.48    0
    27.12    11.882    27.16    11.882813    27.19    83.34    27.23    82.6772    26.84    0    26.88    0    26.92    0
    27.45    11.882    27.49    11.882813    27.54    83.34    27.58    82.6772    27.28    0    27.32    0    27.37    0
    27.79    11.882    27.84    11.882813    27.88    83.34    27.93    82.6772    27.62    0    27.66    0    27.72    0
    28.17    11.882    28.21    11.984375    28.26    83.34    28.3    82.6772    27.98    0    28.02    0    28.08    0
    28.49    11.882    28.54    11.882813    28.59    83.34    28.63    82.6772    28.34    0    28.38    0    28.44    0
    28.84    11.882    28.88    11.882813    29.14    83.34    29.18    82.6772    28.68    0    28.72    0    28.76    0
    29.38    11.882    29.43    11.882813    29.48    83.34    29.53    82.6772    29.22    0    29.26    0    29.31    0
    29.74    11.882    29.79    11.882813    29.84    83.34    29.88    82.6772    29.57    0    29.62    0    29.67    0
    30.1      11.882    30.15    11.882813    30.2    83.34    30.24    82.6772    29.94    0    29.98    0    30.02    0
    30.43    11.882    30.48    11.882813    30.53    83.34    30.57    82.6772    30.29    0    30.34    0    30.38    0
    30.76    11.882    30.8    11.882813    30.84    83.34    30.88    82.6772    30.62    0    30.66    0    30.69    0
    31.1      11.882    31.14    11.882813    31.18    83.34    31.23    82.6772    30.93    0    30.98    0    31.03    0
    31.43    11.882    31.48    11.882813    31.52    83.34    31.56    82.6772    31.28    0    31.32    0    31.36    0
    31.77    11.882    31.82    11.882813    31.87    83.34    31.91    82.6772    31.6    0    31.65    0    31.7    0
    32.05    11.882    32.08    11.882813    32.12    83.34    32.16    82.6772    31.94    0    31.97    0    32.01    0
    32.38    11.882    32.43    11.882813    32.48    83.34    32.52    82.6772    32.21    0    32.26    0    32.31    0
    32.71    11.882    32.76    11.882813    32.81    83.34    32.85    82.6772    32.56    0    32.6    0    32.66    0
    33.03    11.882    33.07    11.984375    33.12    83.34    33.16    82.6772    32.9    0    32.94    0    32.97    0
    33.71    11.882    33.76    11.882813    33.81    83.34    33.85    82.6772    33.21    0    33.49    0    33.54    0
    34.18    11.882    34.23    11.882813    34.27    83.34    34.32    82.6772    33.9    0    33.94    0    33.98    0
    34.65    11.882    34.7    11.882813    34.74    1.79    34.79    82.6772    34.37    0    34.41    0    34.45    0
    35.11    11.78    35.16    11.78125    35.2    0.67    35.24    82.6772    34.83    0    34.87    0    34.92    0
    35.57    11.78    35.62    11.882813    35.66    1.46    35.7    82.6772    35.29    0    35.33    0    35.36    0
    36.04    11.882    36.08    11.882813    36.12    1.41    36.17    82.6772    35.74    1.49    35.79    0    35.83    0
    36.51    11.882    36.56    11.882813    36.6    83.24    36.64    82.6772    36.21    70.01    36.26    0    36.3    0
    36.98    11.882    37.02    11.882813    37.07    83.34    37.12    82.6772    36.68    0    36.73    0    36.77    0
    37.46    11.882    37.51    11.984375    37.55    83.34    37.58    82.6772    37.16    0    37.21    0    37.26    0
    37.86    11.882    37.9    11.882813    37.95    83.34    37.99    82.6772    37.62    0    37.66    0    37.69    0
    38.32    11.882    38.37    11.882813    38.41    83.34    38.44    82.6772    38.04    0    38.08    0    38.12    0
    38.76    11.882    38.8    11.882813    38.83    83.34    38.86    82.6772    38.47    0    38.51    0    38.55    0
    39.14    11.882    39.18    11.882813    39.23    83.34    39.27    82.6772    38.9    0    38.94    0    38.97    0
    39.6    11.882    39.65    11.984375    39.69    83.34    39.75    82.6772    39.32    0    39.36    0    39.4    0
   #56
B8boi
California, USA
C?ID=530730
Shouldnt RFP_AV and RFP_ SP be within a certain percentage of each other? And because the car is off and not idling, the values should be close to zero no?
Can you guys confirm something looks awry with the feedback from the bypass valve position sensor?
   #57
B8boi
California, USA
C?ID=530730
Back to bump. Need help guys, I took a blockmap of my car and wanted to ask.
For other CCBA engines does the car idle at a lower charging voltage than 14.4? My car shows charging at 13.71 when warmed up but with all the issues i have going on I am wondering if the car is not charging right?
;SW:8K0-907-551-D   HW:8K0-907-551-A ---  Engine
;Component:3.0T SIMOS84  H06 0003     Coding:0104000A180F0128
;EV_ECM30TFS0218K0907551D    1003    EV_ECM30TFS0218K0907551D.rod
;Sunday    15    September    2024
;VCDS Version: Release 24.7.0 (x64)  Data version: 20240715 DS356.3
;VCID: 323D168464AF281A997-8066
Group    Description    Actual
IDE00019    Voltage terminal 30    13.812     V
IDE00021    Engine RPM    682     /min
IDE00025    Coolant temperature    84     °C
IDE00075    Vehicle speed    0     km/h
IDE00078    Time since engine start    608     s
IDE00083    Throttle valve position (absolute)    8.6     %
IDE00084    Absolute load value    31     %
IDE00085    Normed load value    7.1     %
IDE00086    Accelerator pedal position    14.5     %
IDE00097    OBD - requirements for which this vehicle is designed    OBD + OBD II
IDE00167    Exhaust temperature 1 bank 1    389.8     °C
IDE00168    Exhaust temperature 1 bank 2    380.1     °C
IDE00190-ENG103225    Charge air pressure: specified value-MAP_SP    319.81     hPa
IDE00349    Throttle valve position: normed    0.4     %
IDE00400-ENG100810    Intake manifold Runner Control (IMRC): activation-LV_PORT_DEAC    1
IDE00401-ENG111851    Intake manifold Runner Control (IMRC): acknowledgment-FAC_PORT_DEAC[0]    0.99998
IDE00402-ENG100810    Intake manifold runner control 2: activation-LV_PORT_DEAC    1
IDE00403-ENG111852    Intake manifold runner control 2: acknowledgment-FAC_PORT_DEAC[1]    0.99998
IDE00445    Unlearning counter according OBD    255
IDE00450    Operating instruction    ---
IDE00451    Currently running routine    Unknown (0)
IDE00474    Ambient air pressure    96     kPa abs
IDE00495    Calculated oil temperature    6C
IDE00496    Oil pressure switch valve activation    Low pressure
IDE00497-MAS00627    Status of oil pressure switches-Oil pressure switch for high pressure    Open
IDE00497-MAS00628    Status of oil pressure switches-Oil pressure switch for low pressure    closed
IDE00556    Outside temperature    21     °C
IDE00559    Current of oxygen sensor bank 1 sensor 1 (broadband sensor)    0.990 Lambda / -0.059 mA
IDE00560-MAS04121    Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage    0.78     V
IDE00560-MAS04122    Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation    99.2     %
IDE00565    Current of oxygen sensor bank 2 sensor 1 (broadband sensor)    0.991 Lambda / -0.051 mA
IDE00566-MAS04121    Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage    0.11     V
IDE00566-MAS04122    Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation    99.2     %
IDE00582    Specified value of equivalence ratio    0.997     Lambda
IDE00583    Throttle valve specified value    0.4     %
IDE00584    Distance driven since erasing DTC memory    0     km
IDE00585    Dist. driven with exh. Malfunction Indicator Lamp activated    0     km
IDE00589    Fuel pressure    3660     kPa rel
IDE00592    Status of oxygen sensor control    Closed loop      / using O2 sensors
IDE00593    Ignition timing adjustment cylinder 1    12.5     Degrees
IDE00595    Allocation of oxygen sensors    B1S1 B1S2   / B2S1 B2S2
IDE00597    Long term adaptation of mixture formation bank 1    11.7     %
IDE00598    Long-term adaptation of mixture formation: B2    5.5     %
IDE00601    Monitoring status since erasing DTC memory
IDE00602    Monitoring status in current driving cycle
IDE00603    Number of driving cycles since erasing DTC memory    1
IDE00604    Short term adaptation of mixture formation bank 1    2.3     %
IDE00605    Short term adaptation of mixture formation bank 2    -2.3     %
IDE00612    Target position of EVAP canister valve    16.5     %
IDE00727    Test steps still to be performed    0
IDE00787    Cause for cancellation    0
IDE00949-ENG98517    Hide cylinder-Cylinder 1    not active
IDE00949-ENG98491    Hide cylinder-Cylinder 10    not active
IDE00949-ENG98492    Hide cylinder-Cylinder 11    not active
IDE00949-ENG98493    Hide cylinder-Cylinder 12    not active
IDE00949-ENG98518    Hide cylinder-Cylinder 13    not active
IDE00949-ENG98519    Hide cylinder-Cylinder 14    not active
IDE00949-ENG98520    Hide cylinder-Cylinder 15    not active
IDE00949-ENG98494    Hide cylinder-Cylinder 16    not active
IDE00949-ENG98521    Hide cylinder-Cylinder 2    not active
IDE00949-ENG98522    Hide cylinder-Cylinder 3    not active
IDE00949-ENG98523    Hide cylinder-Cylinder 4    not active
IDE00949-ENG98495    Hide cylinder-Cylinder 5    not active
IDE00949-ENG98524    Hide cylinder-Cylinder 6    not active
IDE00949-ENG98496    Hide cylinder-Cylinder 7    not active
IDE00949-ENG98497    Hide cylinder-Cylinder 8    not active
IDE00949-ENG98498    Hide cylinder-Cylinder 9    not active
IDE01369-ENG103168    Intake manifold runner control (IMRC): offset closed-V_PORT_1_OFS    0.01     V
IDE01371-ENG103327    Intake manifold runner control (IMRC) 2: offset closed-V_PORT_2_OFS    0.015     V
IDE01650    Throttle valve position 2    9     %
IDE01880    Accelerator pedal position 2    14.5     %
IDE02119    Long term adaptation of oxygen sensor control: bank 1    0     %
IDE04000    Intake air temperature sensor    IAT 11:30     °C
IDE04001    Turbocharger intake pressure sensor    TCA_PRESS: 31     kPa abs
IDE04002    Charge air pressure control    BP_A act:30.8 kPa / BP_B act:32.7 kPa
IDE04003    Charge air temperature sensor    B1S1:35 °C / B2S1:36 °C
IDE04324    Long term adaptation of oxygen sensor control: bank 2    0     %
ENG102981    AC compressor: speed increase    0
ENG103860    AC request: speed increase    0
ENG103226    Accelerator pedal sender 1: voltage ratio    0.747     V
ENG103029    Accelerator pedal sender 2: voltage ratio    0.376     V
ENG103042    Accelerator pedal sender: learned end stop    4.126     V
ENG103719    Accelerator position    0     %
ENG101488    ACF: load    0.08231
ENG103474    Activation of oil pressure switching valve    1
ENG103654    Activation: throttle valve positioner    -17.041     %
ENG101818    Actual fuel rail pressure    36690.7     hPa
ENG103323    Additional water pump    0
ENG101828    Air mass    11.875     kg/h
ENG100339    Air mass integral: actual    0     kg
ENG99216    Air mass integral: specified    11.56     kg
ENG104264    Alternator load    600     W
ENG99319    Ambient pressure    962.67     hPa
ENG103910    Ambient temperature    19.5     °C
ENG101830    AMP_ENVD    960.502     hPa
ENG101473    AR_RED_AD_ADD_MMV    -0.0134     cm²
ENG102979    AR_RED_AD_FAC    0     %
ENG98377    As    none
ENG103165    Battery voltage    13.710938     V
ENG100763    Brake Light Switch    0
ENG103466    Brake test switch    0
ENG102002    CAM_OFS_IVVT_IN[1]    0     °
ENG101927    CAM_OFS_IVVT_IN[2]    0     °
ENG101169    CAM_PHA_OFS_MAF[IN][1]    0     °
ENG101535    CAM_PHA_OFS_MAF[IN][2]    0     °
ENG103031    Camshaft adjustment: inlet phase: bank 1    -46.125     °
ENG99898    Camshaft adjustment: inlet phase: bank 2    -48     °
ENG99173    Camshaft adjustment: inlet: bank 1/2: specified    127.875     °
ENG100104    Camshaft adjustment: inlet: bank 1: actual    0     °
ENG102242    Camshaft adjustment: inlet: bank 1: duty cycle    0     %
ENG100701    Camshaft adjustment: inlet: bank 2: actual    0     °
ENG101781    Camshaft adjustment: inlet: bank 2: duty cycle    0     %
ENG101975    CAN messages: status for ABS    0     s
ENG99096    CAN messages: status for AC    0     s
ENG103515    CAN messages: status for ACC    0     s
ENG103345    CAN messages: status for airbag    0     s
ENG99384    CAN messages: status for battery energy management    0     s
ENG101540    CAN messages: status for dash panel insert    0     s
ENG100217    CAN messages: status for electronic ignition lock    0     s
ENG103239    CAN messages: status for electronic parking brake    0     s
ENG104136    CAN messages: status for gateway    0     s
ENG101579    CAN messages: status for gearbox    0     s
ENG100306    CAN messages: status for steering column module    0     s
ENG99220    CAN messages: status for trailer recognition    0     s
ENG102251    Cat conversion: bank1: meas.value    0
ENG99627    Cat conversion: bank2: meas.value    0
ENG103849    Cat. ageing: bank 1: actual    0
ENG101836    Cat. ageing: bank 2: actual    0
ENG101785    Cat. temperature: bank 1    406.35     °C
ENG100075    Cat. temperature: bank 2    399.35     °C
ENG101837    Cause of irreversible brake cut-in disable    0
ENG103793    Cause of irreversible disable (CCS)    0
ENG101960    Cause of reversible brake cut-in disable    0
ENG102021    Cause of reversible disable (CCS)    393233
ENG103399    CCS shut-off criterion: switch position    0
ENG100798    CCS shut-off criterion: switch position    1
ENG99361    CCS shut-off criterion: switch position    0
ENG100479    Charge air cooling water pump: actual duty cycle    0     %
ENG102583    Charge air cooling water pump: result    OK
ENG99256    Charge air cooling water pump: specified duty cycle    88     %
ENG102333    Charge air cooling water pump: status    00000000 00000000
ENG103690    Charge pressure control: charge press.before throttle valve    312.1     hPa
ENG100992    Compressor regulating flap: PWM activation    18.237     %
ENG100398    Consumption equivalent: substitute value    0.0000004
ENG102996    Coolant temperature    84.8     °C
ENG99145    Coolant temperature (unfiltered)    84.8     °C
ENG100260    Coolant temperature at engine start    57     °C
ENG101525    Coolant temperature: specified    114.8     °C
ENG102214    CPU_LOAD    42.7     %
ENG102284    CRU_SWI_POS_CAN    0
ENG102136    Cruise control: switch settings    1
ENG101127    CTR_CDN_OBD_RBM    28
ENG103696    CTR_CDN_RBM_CAT_1    28
ENG100331    CTR_CDN_RBM_CAT_2    28
ENG99655    CTR_COMP_RBM_CAT_1    0
ENG103187    CTR_COMP_RBM_CAT_2    0
ENG100536    CTR_IGK_CYC_RBM    107
ENG102005    CTR_KM_CAN    174820     km
ENG102445    CTR_MIS_DC_MMV_CYL[0]    0
ENG99590    CTR_MIS_DC_MMV_CYL[1]    0
ENG99754    CTR_MIS_DC_MMV_CYL[2]    0
ENG102025    CTR_MIS_DC_MMV_CYL[3]    0
ENG101583    CTR_MIS_DC_MMV_CYL[4]    0
ENG102075    CTR_MIS_DC_MMV_CYL[5]    0
ENG102250    CTR_MIS_TOT_NVMY    0
ENG100764    CTR_SUM_SRV_INTL    0
ENG99084    Cycle flags: (completed cycles): cat: lambda probe heater    87
ENG100943    Cycle flags: (completed cycles): lambda probes: EGR    28
ENG103229    Cycle flags: (completed tests): camshaft adj.: knock sensors    207
ENG99495    Cycle flags: (completed tests): lambda adaption:    232
ENG103597    Cycle flags:(completed cycles):lambda probes:sec.air sys.    28
ENG102526    Cycle flags:(completed tests):clutch: brake:idle controller    33
ENG101652    Cylinder shut-off: cylinder suppression    0
ENG100989    DELTA_CRK_CYL_LAM_1    0     °
ENG99927    DELTA_CRK_CYL_LAM_2    0     °
ENG102657    DIAG_INST[0]    cwp_2
ENG99120    DIAG_INST[1]    esp
ENG103260    DIAG_INST[2]    no_error
ENG99710    DIAG_INST[3]    no_error
ENG102667    DIAG_INST[4]    no_error
ENG102739    DIAG_INST[5]    no_error
ENG100162    DIAG_INST[6]    no_error
ENG99103    DIAG_INST[7]    no_error
ENG99261    DIAG_INST[8]    no_error
ENG103622    DIAG_INST[9]    no_error
ENG99472    DIST_DTC_CLR    0     km
ENG103766    DIST_ENG_RUN_IN    172430340.2     m
ENG100531    DIST_ST    1.15E+06     m
ENG103712    EFPPWM_MIN_AD    49.635     %
ENG104044    Engine load    7.03125     %
ENG103936    Engine mount 1: right (only vehicles with engine mounting)    0
ENG102957    Engine mounting 2: left (only vehicles with engine mounting)    0
ENG102494    Engine speed: actual    672     /min
ENG99273    Engine speed: specified    680     /min
ENG104182    Engine temperature: thermostat diagnosis    93     °C
ENG100261    Engine torque    38.84375     Nm
ENG102783    Engine: operating status    IS
ENG101147    ENVD_0_CRU_ACT_MON    40
ENG102968    ENVD_0_GS_INC_MON    0
ENG99874    ENVD_0_MAF_NOT_PLAUS_MON    0
ENG103667    ENVD_0_MON    0
ENG100777    ENVD_0_MON_3    0
ENG102888    ENVD_0_MSR_MON    0
ENG99438    ENVD_0_N_MAX_MON    4
ENG100658    ENVD_0_TQI_MON    0
ENG102106    ENVD_1_CRU_ACT_MON    238
ENG103210    ENVD_1_GS_INC_MON    0
ENG101907    ENVD_1_MAF_NOT_PLAUS_MON    0
ENG99424    ENVD_1_MON    0
ENG100344    ENVD_1_MON_3    0
ENG102767    ENVD_1_MSR_MON    0
ENG100092    ENVD_1_N_MAX_MON    169
ENG99136    ENVD_1_TQI_MON    0
ENG103816    ENVD_2_CRU_ACT_MON    50
ENG100080    ENVD_2_GS_INC_MON    0
ENG101890    ENVD_2_MAF_NOT_PLAUS_MON    0
ENG99790    ENVD_2_MON    0
ENG100541    ENVD_2_MON_3    0
ENG100185    ENVD_2_MSR_MON    0
ENG103232    ENVD_2_N_MAX_MON    60
ENG101780    ENVD_2_TQI_MON    0
ENG103490    ENVD_3_CRU_ACT_MON    85
ENG102482    ENVD_3_GS_INC_MON    0
ENG102566    ENVD_3_MAF_NOT_PLAUS_MON    0
ENG99455    ENVD_3_MON    0
ENG101268    ENVD_3_MON_3    0
ENG101949    ENVD_3_MSR_MON    0
ENG100841    ENVD_3_N_MAX_MON    215
ENG99810    ENVD_3_TQI_MON    0
ENG100532    ENVD_CAM_IN_1    0
ENG101418    ENVD_CAM_IN_2    0
ENG99852    ENVD_CRK    0
ENG99600    ENVD_EEPROM    0
ENG102271    ENVD_KNK_RTD_LIM    0
ENG101912    ENVD_LSL_UP_1    0
ENG101170    ENVD_LSL_UP_2    0
ENG99752    Error flags: (completed cycles): cat: lambda probe heater    0
ENG101275    Error flags: (completed cycles): lambda probes: EGR    0
ENG104132    Error flags: (completed cycles): lambda probes:sec.air sys.    0
ENG102855    ESI (extended service intervals) oil level    53.875     mm
ENG101942    ESI (extended service intervals) oil warning threshold    50.0625     mm
ENG104194    FAC_H_RNG_LAM_AD[1]    0     %
ENG103178    FAC_H_RNG_LAM_AD[2]    0     %
ENG104151    FAC_L_RNG_LAM_AD[1]    0     %
ENG101035    FAC_L_RNG_LAM_AD[2]    0     %
ENG100298    FAC_LAM_CP    0.075     %
ENG100108    FAC_LAM_LIM[1]    2.602     %
ENG100987    FAC_LAM_LIM[2]    -2.33     %
ENG99722    FAC_LAM_TCO_A[1]    0     %
ENG99699    FAC_LAM_TCO_A[2]    0     %
ENG103521    FAC_LAM_TCO_B[1]    0     %
ENG99478    FAC_LAM_TCO_B[2]    0     %
ENG103641    FAC_LAM_TCO_C[1]    0     %
ENG102483    FAC_LAM_TCO_C[2]    0     %
ENG101578    FAC_LAM_TCO_D[1]    0     %
ENG103438    FAC_LAM_TCO_D[2]    0     %
ENG100685    FAC_LAM_TCO_E[1]    0     %
ENG103729    FAC_LAM_TCO_E[2]    0     %
ENG103307    FAC_MAF_MAX    0.07062
ENG99791    FAC_SLOP_IV[1]    0
ENG99070    FAC_SLOP_IV[2]    0
ENG103161    Fan control relay: auxiliary water pump    0
ENG99630    Fan control relay: fan run-on    0
ENG101437    Fan request from air conditioner    0     %
ENG103644    FRF_IMMO_SNAPSHOT_BYTE1    0
ENG102892    FRF_IMMO_SNAPSHOT_BYTE2    0
ENG100521    FRF_IMMO_SNAPSHOT_BYTE3    0
ENG101852    FRF_IMMO_SNAPSHOT_BYTE4    0
ENG99312    FRF_IMMO_SNAPSHOT_BYTE5    0
ENG103956    FRF_IMMO_SNAPSHOT_BYTE6    0
ENG104248    Fuel consumption signal    45922     µl
ENG99715    Fuel pump: activation    51.553     %
ENG100489    Fuel pump: actual fuel pressure    4906.06     hPa
ENG101667    Fuel pump: adaption value    4.529     %
ENG100969    Fuel pump: fuel pressure: I-controller    0.064     %
ENG100409    Fuel rail pressure: specified    36818     hPa
ENG100250    Fuel regulating valve: duty cycle    5.464     %
ENG101692    Fuel supply system: high-pressure regulator    249.41     hPa
ENG104057    Fuel sys.diag.pump:status tank leak detect(ULEV II only)    7
ENG103605    Fuel system diagnostic pump: cycle (ULEV II only)    1
ENG101053    Fuel system diagnostic pump: fault detection (ULEV II only)    0
ENG100362    FUEL_MASS_AD    -6     mg
ENG103903    FUEL_MASS_AD_ENVD    -6.28125
ENG103916    FUEL_MASS_REQ_I_CTL_ENVD    0
ENG103559    FUP_EFP_ENVD    4773.4     hPa
ENG103553    FUP_EFP_ST_H    173888     hPa
ENG101056    FUP_EFP_ST_L    6238.05     hPa
ENG99950    FUP_EFP_STOP_H    173888     hPa
ENG100784    FUP_EFP_STOP_L    5237.73     hPa
ENG102754    FUP_ENVD    62491.8142     hPa
ENG102108    FUP_H    36531.5     hPa
ENG98594    Gear    0
ENG103368    Gearbox -CAN bus messages    94071
ENG100957    Height correction    960.502     hPa
ENG99170    Height correction    962.76     hPa
ENG103575    High-pressure system: regulator    0     mg
ENG103879    High-pressure system: regulator: mobile part    0     mg
ENG102603    High-pressure system: status    MFP_CTL
ENG101567    Idling speed stabilisation: duty cycle/AC compressor torque    0.8     Nm
ENG102289    Idling speed stabilisation: idling speed controller    0.34375     Nm
ENG101472    Idling speed stabilisation: learned value    1.71875     Nm
ENG101946    Idling stabilisation: operating status    0
ENG100449    IGA_AD_1_KNK[0]    0     °
ENG101025    IGA_AD_1_KNK[1]    0     °
ENG100399    IGA_AD_1_KNK[2]    0     °
ENG99087    IGA_AD_1_KNK[3]    0     °
ENG100814    IGA_AD_1_KNK[4]    0     °
ENG100030    IGA_AD_1_KNK[5]    0     °
ENG103801    IGA_IGC_0    6.375     °
ENG101919    IGA_IGC_1    10.5     °
ENG102065    IGA_IGC_2    6.75     °
ENG103873    IGA_IGC_3    9.75     °
ENG99337    IGA_IGC_4    6.375     °
ENG100633    IGA_IGC_5    11.625     °
ENG102932    Ignition angle: actual    12.75     °
ENG100204    Intake air change-over: pressure    312.43     hPa
ENG101741    Intake air temperature    35.25     °C
ENG101388    Intake manifold pressure: absolute    317.74     hPa
ENG99742    Kickdown adaption: switch    0
ENG101640    Kilometres driven with MIL    0     km
ENG103143    Kilometres driven with MIL    0     min
ENG103876    Knock control: knock sensor voltage: cyl. 1    0.41016     V
ENG99646    Knock control: knock sensor voltage: cyl. 2    0.41016     V
ENG102129    Knock control: knock sensor voltage: cyl. 3    0.41016     V
ENG102735    Knock control: knock sensor voltage: cyl. 4    0.74768     V
ENG100457    Knock control: knock sensor voltage: cyl. 5    0.47638     V
ENG100093    Knock control: knock sensor voltage: cyl. 6    0.58548     V
ENG102464    LAM_CYL_SEL_ADJ_FAC[0]    0     %
ENG100498    LAM_CYL_SEL_ADJ_FAC[1]    0     %
ENG100758    LAM_CYL_SEL_ADJ_FAC[2]    0     %
ENG102261    LAM_CYL_SEL_ADJ_FAC[3]    0     %
ENG103470    LAM_CYL_SEL_ADJ_FAC[4]    0     %
ENG102999    LAM_CYL_SEL_ADJ_FAC[5]    0     %
ENG100097    LAMB_CAT_DOWN_MV[1]    0
ENG102198    LAMB_CAT_DOWN_MV[2]    0
ENG99741    LAMB_DELTA_AD_LAM_ADJ[1]    0
ENG102871    LAMB_DELTA_AD_LAM_ADJ[2]    0
ENG102085    LAMB_DELTA_AD_O2L_CAT[1]    -0.00214
ENG102521    LAMB_DELTA_AD_O2L_CAT[2]    -0.00586
ENG102144    Lambda control value: bank 1    2.461     %
ENG102393    Lambda control value: bank 2    -2.17     %
ENG99674    Lambda controller: bank 1 (averaged value)    2.521     %
ENG100249    Lambda controller: bank 2 (averaged value)    -2.347     %
ENG101381    Lambda probe 1: bank 1: status    1
ENG101039    Lambda probe 1: bank 1: status    0
ENG102886    Lambda probe 1: bank 1: status    0
ENG99812    Lambda probe 1: bank 2: status    1
ENG99373    Lambda probe 1: bank 2: status    0
ENG103920    Lambda probe 1: bank 2: status    0
ENG104200    Lambda probe 2: bank 1: status    0
ENG101336    Lambda probe 2: bank 1: status    1
ENG99313    Lambda probe 2: bank 2: status    0
ENG99124    Lambda probe 2: bank 2: status    0
ENG99661    Lambda probe ageing: bank 1: dynamic factor    0
ENG101869    Lambda probe ageing: bank 1: probe 1: short trip result    289.725     °C
ENG99891    Lambda probe ageing: bank 1: probe 2: short trip result    399.1     °C
ENG103962    Lambda probe ageing: bank 2: dynamic factor    0
ENG103203    Lambda probe ageing: bank 2: probe 1: short trip result    282.6625     °C
ENG103040    Lambda probe ageing: bank 2: probe 2: short trip result    390.725     °C
ENG100478    Lambda probe correction: duty cycle offset: bank 1    -0.00287
ENG100459    Lambda probe correction: duty cycle offset: bank 2    0
ENG101813    Lambda probe heater: bank 1: probe 1: short trip result    0
ENG103776    Lambda probe heater: bank 1: probe 2: short trip result    0
ENG101739    Lambda probe heater: bank 2: probe 1: short trip result    0
ENG101102    Lambda probe heater: bank 2: probe 2: short trip result    0
ENG102717    Lambda probe heater: resistance: bank 1: probe 1    80     Ohm
ENG102380    Lambda probe heater: resistance: bank 1: probe 2    997     Ohm
ENG101429    Lambda probe heater: resistance: bank 2: probe 1    79.5     Ohm
ENG102703    Lambda probe heater: resistance: bank 2: probe 2    418     Ohm
ENG103233    Lambda probe readiness: bank 1: probe 1: short trip result    1
ENG101214    Lambda probe readiness: bank 1: probe 2: short trip result    1
ENG103087    Lambda probe readiness: bank 2: probe 1: short trip result    1
ENG101319    Lambda probe readiness: bank 2: probe 2: short trip result    1
ENG99353    Lambda probe voltage: bank 1: probe 1 (broadband probe)    1.987     V
ENG102863    Lambda probe voltage: bank 1: probe 2    0.547     V
ENG100603    Lambda probe voltage: bank 2: probe 1 (broadband probe)    1.978     V
ENG103421    Lambda probe voltage: bank 2: probe 2    0.088     V
ENG102763    Lambda probes actual: bank1    0.9941
ENG102040    Lambda probes actual: bank2    0.9961
ENG102170    Lambda probes learned values: bank 1: probe 1: idle    12.033     %
ENG104246    Lambda probes learned values: bank 1: probe 1: part throttle    0     %
ENG104025    Lambda probes learned values: bank 2: probe 1: idle    6.116     %
ENG102016    Lambda probes learned values: bank 2: probe 1: part throttle    0     %
ENG100365    Lambda probes specification: bank 1    0.9971
ENG101457    Lambda probes specification: bank 2    0.9971
ENG104114    Lambda probes specified: bank1    0.9971
ENG102953    Lambda probes specified: bank2    0.9971
ENG101747    LOIL_DYN    10.25     mm
ENG102180    LOIL_DYN_TMP    0     mm
ENG103837    LOIL_MAX_SRV_INTL    12.1875     mm
ENG102184    LOIL_MIN_SRV_INTL    -0.1875     mm
ENG100402    LOIL_SUM_SRV_INTL    0     mm
ENG99162    LV_ACC_RED_CMD    0
ENG101153    LV_AD_END_IVVT    1
ENG102235    LV_ATB_ACT_1    0
ENG102541    LV_ATB_ACT_2    0
ENG99095    LV_CAN_HOOD_SWI    0
ENG103049    LV_EFPPWM_AD_STOP    0
ENG101712    LV_ENG_RUN_IN    0
ENG100267    LV_ENG_RUN_IN_EXT_ADJ    0
ENG99803    LV_IAF_SP    0
ENG99924    LV_INH_AUT_ST    0
ENG103773    LV_INH_STR_RLY    0
ENG100044    LV_LOIL_L_WARN    0
ENG103492    LV_LOIL_L_WARN_ACT    0
ENG103908    LV_LOIL_L_WARN_TMP    0
ENG102919    LV_MASS_SA_L_ERR[0]    0
ENG99986    LV_MASS_SA_L_ERR[1]    0
ENG103716    LV_POIL_SWI_H    0
ENG100912    LV_POIL_SWI_L    1
ENG100804    LV_RFP_AD_EXT_ADJ_ON    0
ENG99593    LV_RFP_CUR_OFF    0
ENG102334    LV_RFP_POS_GRD    1
ENG104247    LV_SA_MAX_H_ERR[0]    0
ENG104254    LV_SA_MAX_H_ERR[1]    0
ENG101515    LV_SA_SAV_END_DIAG[0]    0
ENG102750    LV_SA_SAV_END_DIAG[1]    0
ENG102150    LV_SA_SYS_END_DIAG[0]    0
ENG102206    LV_SA_SYS_END_DIAG[1]    0
ENG102417    LV_TPS_AD_ACT    0
ENG100842    LV_TPS_AD_DIAG_ERR    0
ENG103996    LV_TPS_AD_REQ    0
ENG99280    LV_VCV_RLY    1
ENG102523    MAF    97.84     mg/stroke
ENG103484    MAF_CYL    12.59375     kg/h
ENG99288    MAF_DIF_CAM_OFS_AD_SQ_TOT    0     kg²/h²
ENG101509    MAF_ENVD    332.27058     mg/stroke
ENG103984    MAF_RFP    58.28125     kg/h
ENG103985    MAF_SCHA    70.6875     kg/h
ENG100807    MAF_THR    11.84375     kg/h
ENG101499    map    317.33     hPa
ENG102949    MAP_1_ENVD    795.99609     hPa
ENG102680    MAP_1_MES    309.12     hPa
ENG99737    MAP_1_MES_BAS    308.95     hPa
ENG102960    MAP_2_ENVD    811.91602     hPa
ENG102281    MAP_2_MES    326.7     hPa
ENG104243    MAP_2_MES_BAS    326.61     hPa
ENG103166    MAP_ENVD    0     hPa
ENG103501    MASS_SA_REL[0]    1
ENG102071    MASS_SA_REL[1]    1
ENG100896    MASS_SA_REL_21_PHA    1
ENG103045    MASS_SA_REL_22_PHA    1
ENG100077    MASS_SA_REL_PHA_1[0]    1
ENG99761    MASS_SA_REL_PHA_1[1]    1
ENG100529    MASS_SA_REL_PHA_2[0]    1
ENG101938    MASS_SA_REL_PHA_2[1]    1
ENG100705    MAX_HLD_FTL_SENS    0     s
ENG99929    MAX_HLD_ICH    0     s
ENG101558    MAX_HLD_LAMP_RE    0     s
ENG100434    MAX_HLD_PSTE    0     s
ENG99171    MAX_HLD_SCU    0     s
ENG102618    Mean engine air mass    0     kg/h
ENG103857    Mean vehicle speed    0     km/h
ENG99199    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[0]    0     mg/stroke
ENG103758    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[1]    0     mg/stroke
ENG100400    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[2]    0     mg/stroke
ENG103502    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[3]    0     mg/stroke
ENG100254    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[4]    0     mg/stroke
ENG100666    MFF_ADD_H_CUR_LAM_CYL_SEL_ADJ[5]    0     mg/stroke
ENG103380    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[0]    -0.167     mg/stroke
ENG103050    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[1]    -0.106     mg/stroke
ENG101085    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[2]    0.345     mg/stroke
ENG103812    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[3]    0.186     mg/stroke
ENG102659    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[4]    -0.178     mg/stroke
ENG102911    MFF_ADD_L_CUR_LAM_CYL_SEL_ADJ[5]    -0.081     mg/stroke
ENG103346    MFF_ADD_LAM_AD[1]    0.91     mg/stroke
ENG100447    MFF_ADD_LAM_AD[2]    0.45     mg/stroke
ENG101360    Misfire detection active    1
ENG102335    Misfires all cylinders per 1000 rpm    0
ENG99926    Misfires cylinder 1 from engine start to engine stop    0
ENG103503    Misfires cylinder 1 per 1000 rpm    0
ENG100235    Misfires cylinder 2 from engine start to engine stop    0
ENG99825    Misfires cylinder 2 per 1000 rpm    0
ENG101055    Misfires cylinder 3 from engine start to engine stop    0
ENG101730    Misfires cylinder 3 per 1000 rpm    0
ENG101998    Misfires cylinder 4 from engine start to engine stop    0
ENG102032    Misfires cylinder 4 per 1000 rpm    0
ENG100222    Misfires cylinder 5 from engine start to engine stop    0
ENG101260    Misfires cylinder 5 per 1000 rpm    0
ENG101221    Misfires cylinder 6 from engine start to engine stop    0
ENG101947    Misfires cylinder 6 per 1000 rpm    0
ENG98787    N    682     /min
ENG110570    N_CAM_32_DIAG_CRK_SIG_LOSS    672     /min
ENG110571    N_TOOTH_32_DIAG_CRK_SIG_LOSS    672     /min
ENG107737-ENG102260    NC_NR_DIAG_RBM-IdentDec    75
ENG99870    O2L_1_MAX_BAS_AD_CAT[1]    0.15002     g
ENG102018    O2L_1_MAX_BAS_AD_CAT[2]    0.15002     g
ENG104137    O2L_1_MAX_BAS_AD_CAT_DIAG[1]    0.99998     g
ENG100562    O2L_1_MAX_BAS_AD_CAT_DIAG[2]    0.99998     g
ENG103698    Oil temperature    64     °C
ENG101106    PDT_ENVD    774.76953     hPa
ENG99157    PRS_SA_DIF    0.04     hPa
ENG102451    PSN_EDGE_1_AD_CAM_IN_1    0.4375     °
ENG103487    PSN_EDGE_2_AD_CAM_IN_1    2.5     °
ENG102195    PV_AV_1    0     %
ENG99137    PV_AV_2    0     %
ENG101068    PV_AV_H    0     %
ENG102782    Radiator fan 1: activation    10.2     %
ENG101201    Radiator fan 1: run-on: status    600 W
ENG101514    Radiator fan 2: activation    10.2     %
ENG102359    Radiator fan 2: run-on: status    400 W
ENG100307    RATIO_MASS_O2_CAT_DIF[1]    0
ENG99168    RATIO_MASS_O2_CAT_DIF[2]    0
ENG102377    Ready and error flags    196
ENG102831    Ready bits (completed tests)    228
ENG100050    RFP_AD_STEP_CTR    255
ENG103162    RFP_AD_STOP    0
ENG99149    RFP_AD_STOP_SAVE    4
ENG100790    RFP_AD_STOP_SAVE_HIGH_ENVD    0
ENG101524    RFP_AD_STOP_SAVE_LOW_ENVD    4
ENG99738    RFP_AV    69.19     °
ENG103313    RFP_AV_ENVD    67.7953
ENG101571    RFP_SP    69.42     °
ENG102212    RFP_SP_ENVD    67.7953
ENG100220    RFPPWM_ENVD    17.1875     %
ENG103248    SEG_AD_MMV_ER[0]    0     ‰
ENG101135    SEG_AD_MMV_ER[1]    -1.7614     ‰
ENG99078    SEG_AD_MMV_ER[2]    -0.1178     ‰
ENG103257    SEG_AD_MMV_ER[3]    -0.6356     ‰
ENG100125    SEG_AD_MMV_ER[4]    -1.3783     ‰
ENG100241    SEG_AD_MMV_ER[5]    -0.4191     ‰
ENG102511    SEG_AD_MMV_ER_H[0]    0     ‰
ENG103258    SEG_AD_MMV_ER_H[1]    -1.0178     ‰
ENG99291    SEG_AD_MMV_ER_H[2]    -0.4456     ‰
ENG99954    SEG_AD_MMV_ER_H[3]    -0.2978     ‰
ENG100348    SEG_AD_MMV_ER_H[4]    -0.9417     ‰
ENG104100    SEG_AD_MMV_ER_H[5]    -0.4067     ‰
ENG100568    SEG_AD_MMV_ER_L[0]    0     ‰
ENG100601    SEG_AD_MMV_ER_L[1]    -1.7614     ‰
ENG102668    SEG_AD_MMV_ER_L[2]    -0.1178     ‰
ENG101232    SEG_AD_MMV_ER_L[3]    -0.6356     ‰
ENG102134    SEG_AD_MMV_ER_L[4]    -1.3783     ‰
ENG99992    SEG_AD_MMV_ER_L[5]    -0.4191     ‰
ENG101561    SEG_AD_MMV_ER_MID[0]    0     ‰
ENG102964    SEG_AD_MMV_ER_MID[1]    -1.7698     ‰
ENG100890    SEG_AD_MMV_ER_MID[2]    -0.5874     ‰
ENG99793    SEG_AD_MMV_ER_MID[3]    -0.2763     ‰
ENG103967    SEG_AD_MMV_ER_MID[4]    -1.5714     ‰
ENG99413    SEG_AD_MMV_ER_MID[5]    -0.545     ‰
ENG103381    Shut-off time    1.73     s
ENG109006-ENG100882    Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX    0     %
ENG109007-ENG99938    Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX    0     %
ENG102971    Start adaption: temperature adaption factor 1    1
ENG102489    Start adaption: temperature adaption factor 2    1
ENG100723    Start adaption: temperature adaption factor 3    1
ENG101893    Starter control: clutch switch    0
ENG100919    Starter control: interlock switch    0
ENG102520    Starter: measure-back wire term. 50 R    0
ENG100800    Starter: start relay 1    0
ENG99979    Starter: start relay 2    0
ENG99368    Starter: starter request terminal 50    0
ENG101327    STATE_LS_ENVD[1]    2
ENG101384    STATE_LS_ENVD[2]    2
ENG101078    STATE_READY_OBD_1    7
ENG100369    STATE_READY_OBD_3    255
ENG109090-ENG101799    STATE_SW_MVB-Param to DOP    S84I2010 CBE0AL0
ENG103546    T_AST_ENVD    0     s
ENG104148    T_COOL_LOIL    644     ms
ENG101072    T_DTC_CLR    11     min
ENG102790    T_EFP_MEM_H    655.35     s
ENG102123    T_EFP_MEM_L    24.43     s
ENG99831    T_FAC_MAF_MAX_ORNG    0     s
ENG99128    T_INT_DIAG_TH    0     s
ENG112954    T_PER_MES_LEAK_ENVD    0     s
ENG112955    T_PER_MES_OBD_ENVD    0     s
ENG99398    T_POP_COC_INTER_1    0     s
ENG102747    T_PWL    0     s
ENG100808    T_RAMP_RFP_SP_OSC    4.83     s
ENG101325    T_TEMP_SIG_LOIL    54.7     ms
ENG112953    TAM_CAN    21     °C
ENG102048    Tank breather valve: duty cycle    16.796875     %
ENG101339    Tank breather valve: short trip result    0.7949     kg/h
ENG103627    Tank leaks test: fault message    NO_SYM
ENG100439    Tank level    0
ENG104029    TCO_1_2    134.3     °C
ENG103434    TCO_A_LAM_AD_WUP[1]    -5.25     °C
ENG100717    TCO_A_LAM_AD_WUP[2]    -5.25     °C
ENG100381    TCO_B_LAM_AD_WUP[1]    9.75     °C
ENG101562    TCO_B_LAM_AD_WUP[2]    9.75     °C
ENG101581    TCO_C_LAM_AD_WUP[1]    24.75     °C
ENG101857    TCO_C_LAM_AD_WUP[2]    24.75     °C
ENG100354    TCO_D_LAM_AD_WUP[1]    35.25     °C
ENG101300    TCO_D_LAM_AD_WUP[2]    35.25     °C
ENG101973    TCO_E_LAM_AD_WUP[1]    45     °C
ENG103356    TCO_E_LAM_AD_WUP[2]    45     °C
ENG100390    TCO_MIN_INTER_LAM_AD_WUP[1]    55.5     °C
ENG103663    TCO_MIN_INTER_LAM_AD_WUP[2]    55.5     °C
ENG100853    TCO_MIN_LAM_AD_WUP[1]    50.25     °C
ENG103733    TCO_MIN_LAM_AD_WUP[2]    50.25     °C
ENG102279    TCS/ESP: specified torque    1022     Nm
ENG99857    TCS: status    0
ENG103400    TEMP_CAT_ENVD[1]    325     °C
ENG102182    TEMP_CAT_ENVD[2]    330     °C
ENG101941    TEMP_CAT_STAT_MDL[1]    386.6625     °C
ENG99592    TEMP_CAT_STAT_MDL[2]    392.0375     °C
ENG101721    Throttle actuator angle (potentiometer 2)    0
ENG104173    Throttle adjustment: potentiometer 1 emergency gap    0.674     V
ENG101024    Throttle adjustment: potentiometer 2: emergency gap    4.248     V
ENG99608    Throttle valve adjuster: adaption status    9
ENG100374    Throttle valve adjustment: potentiometer 1 lower adaption    0.42     V
ENG102367    Throttle valve adjustment: potentiometer 2 lower adaption    4.541     V
ENG101411    Throttle valve angle    0.715     °
ENG101155    Throttle valve angle: potentiometer 1    0.449     V
ENG101278    Throttle valve angle: potentiometer 2    4.502     V
ENG102845    Throttle valve deviation    -5.214     %
ENG103149    TI_1_HOM[0]    0.588     ms
ENG101279    TI_1_HOM[1]    0.556     ms
ENG99190    TI_1_HOM[2]    0.632     ms
ENG100436    TI_1_HOM[3]    0.576     ms
ENG100317    TI_1_HOM[4]    0.596     ms
ENG102588    TI_1_HOM[5]    0.564     ms
ENG104034    TI_2_HOM[0]    0     ms
ENG103041    TI_2_HOM[1]    0     ms
ENG100076    TI_2_HOM[2]    0     ms
ENG100292    TI_2_HOM[3]    0     ms
ENG101541    TI_2_HOM[4]    0     ms
ENG99751    TI_2_HOM[5]    0     ms
ENG99834    TIA[NC_IDX_TIA_IM_CYL_1]    35.25     °C
ENG101962    TIA[NC_IDX_TIA_IM_CYL_2]    36.75     °C
ENG102627    TIA_AM_SCHA    31.5     °C
ENG103343    TIA_MES[NC_IDX_TIA_AM_SCHA]    31.5     °C
ENG101694    TIA_MES[NC_IDX_TIA_IM_CYL_1]    36     °C
ENG102135    TIA_MES[NC_IDX_TIA_IM_CYL_2]    36.75     °C
ENG103351    Time since engine start    658.4     s
ENG100558    TPS_ENVD    0.4     %
ENG103021    TQ_CONV    0     Nm
ENG102012    TQ_DIF_IS_AD_ACC    4.125     Nm
ENG99851    TQ_LOSS    -38.71875     Nm
ENG99317    TQ_LOSS_ACC    0     Nm
ENG103625    TQI_AV_ENVD    168     Nm
ENG100768    TQI_GS_FAST_DEC    1023.97     Nm
ENG101426    TQI_GS_FAST_INC    0     Nm
ENG100355    V_FUP_EFP_MV    2.202     V
ENG101255    V_PORT_1_ENVD    0.64453     V
ENG99922    V_PORT_1_RAW    3.828     V
ENG100742    V_PORT_2_ENVD    0.66406     V
ENG99200    V_PORT_2_RAW    0.674     V
ENG99867    V_PVS_1_ENVD    0.74219     V
ENG100593    V_PVS_2_ENVD    0.37109     V
ENG100956    V_TPS_1_ENVD    4.47266     V
ENG99904    V_TPS_2_ENVD    0.46875     V
ENG103201    VCV_CLOSE_RNG    21.4     °
ENG99527    Vehicle speed: actual    0     km/h
ENG102311    Vehicle speed: filtered    0     km/h
ENG102035    Vehicle speed: specified    0     km/h
ENG103235    VLS_DOWN_1_ENVD    0.41016     V
ENG103269    VLS_DOWN_2_ENVD    0.41016     V
ENG103710    VLS_UP_1_ENVD    2.03125     V
ENG99196    VLS_UP_2_ENVD    2.01172     V
ENG100719    VLS_UP_DIAG_SAVE_PUC_LSL_UP[1]    0     V
ENG103416    VLS_UP_DIAG_SAVE_PUC_LSL_UP[2]    0     V
ENG102798    VP_RFP_1    3.9258     V
ENG102004    VP_RFP_1_ENVD    3.76953     V
ENG101126    VP_RFP_AD_BOL_1    0.5231     V
ENG102969    VP_RFP_AD_BOL_1_ENVD    0.50781     V
ENG102249    VP_RFP_AD_LIH_1    4.4922     V
ENG103425    VP_RFP_AD_LIH_1_ENVD    4.49219     V
ENG101394    VP_RFP_BOL_1    0.5231     V
ENG100243    VP_RFP_BOL_MTC_1    0.5231     V
ENG100671    VP_RFP_BOL_MTC_1_ENVD    0.50781     V
ENG101523    VP_RFP_LIH_1    4.4922     V
Elapsed Time: 00:53
   #58
EuroX
Northern NJ USA
C?ID=208579
Please check coolat shut off valve located behind engine for heater core hose. It should have a vacuum line going to it, It is common for them to fail and bleed vacuum at the valve or the valve fails internally. If needed plug vacuum line and retest. Update with results
   #59
B8boi
California, USA
C?ID=530730
A vacuum leak could result in low voltage charging and bypass valve issues? I mean at this point Ill try anything but ok will check
   #60
EuroX
Northern NJ USA
C?ID=208579
Post updated auto scan of faults that are currently present. Fault for J808 is usually the flap. Recommend to flash ecm back to stock and recheck.
