2018 R MIB2 into 2016 GTI Autobahn
C?ID=313143
The MIB2 in my 2016 GTI Autobahn has had some issues for a while (NAV not working, CarPlay taking a few minutes to load, the "APP" button not doing anything on my 8" screen retrofit, etc). I decided to replace it. I got a MIB2 out of a 2018 R and replaced my old unit. I have a buddy at our local dealer removing component protection this week so that part will be fixed. I have a few questions about some of the other settings (mainly 2). The unit is throwing a full because it's looking for the digital cockpit that was in the R. I can't find the setting to disable this. I'm likely blind. Also, the startup screen is set to "E-Golf" and the UI has blue accents. I don't see a GTI options with the Red like my old one. Am I blind here too?
Here's my Autoscan from a couple days ago (at work).
Friday,29,March,2024,12:25:13:41190
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(VMWare)
VCDS Version 23.11.0.0 (arm64)  HEX-V2 CB: 0.4643.4
VIN: 3VW447AU6GM023920   License Plate:
Mileage: 130001km-80778mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 2B 32 42 44 47 52 55 5F 75
          A9
VIN: 3VW447AU6GM023920   Mileage: 130001km-80778miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---    CVN: 5E75E924
   Coding: 091D00124424002F1000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F381BEDF7974212869-807B
   VINID: 0E69C4107465197740083242000181A378
Readiness: 1000 1000
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4902
   Revision: 06253104    Serial number: TFK01507291364 CVN: 0000EE8B
   ROD: EV_TCMDQ250021.rod
   VCID: 1C62DC219621C98AD3B-8049
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 52285000001036
   Coding: 01FA6BA15422096F0080020241C36880D62A9000408216B6004300D1C009
   Shop #: WSC 01383 790 50316
   VCID: 4BC06F7D634F1E328A1-801F
   Revision: 00021000    Serial number: 0375865515 Dataset Number: V03935226DW 0001
   Coding: 030C0C
   VCID: 3A2E3AB93CD597BA217-806F
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000005000012111402
   VCID: 42DE42595405DF7A797-8017
   Air quality sensor:
          B10CD 00 [00001000] - -
                    Reset counter: 178
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:18:04
                    Voltage terminal 30: 11.1 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86580408150376 Dataset Number: 5GM063v____ 0061
   Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00150
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AAEFAB97C5557BA617-802F
   Component: WWS    150715  043 0581
   Serial number:         150928122341
   Component: RLHS  037 0059
   Serial number: S5Y15M08D05H10M53S07
   Coding: 90A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03694800381503150622
   Coding: 181803
   Humidity sensor: interior:
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 30071541350619 Dataset Number: V03935209LD 0002
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3728238D0FC78AD2DE9-8063
   Serial number: 003GCR02X4HS Dataset Number: 5GM003V____ 0046
   VCID: 47C8534D7F27FA52AE9-8013
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000000000039P5SU
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 607 15
   Serial number: 35700000000340F4751B
   Subsystem 3 - Part No SW: -----------    HW: 480 001 607 15
   Serial number: 3580000000068C09651K
   Subsystem 4 - Part No SW: -----------    HW: 480 402 907 15
   Serial number: 3510002A31B7E8E48229
   Subsystem 5 - Part No SW: -----------    HW: 480 402 907 15
   Serial number: 35200029B1B7E8E142BJ
   Subsystem 6 - Part No SW: -----------    HW: 480 401 209 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B2F20D052F0D6
   Subsystem 7 - Part No SW: -----------    HW: 480 401 612 20
   Component: FrontSensor_P  004 6149
   Serial number: 356000126638A6B27583
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20180913400575
   Coding: 0410
   Shop #: WSC 34557 003 1048576
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C223CA136E1A98A33B-8069
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BAD091AB980CF0502086A001000000000000000
   Shop #: WSC 00066 790 00219
   VCID: 2C020CE1C681390AA3B-8079
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 18081510801186 Dataset Number: 5G0067V____ 2214
   Coding: 0101000830085900FB00022B9C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   GVL: 01503C5000000600400C10008000CC0000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B4E985554B38C20C5-8021
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160000919640076195
   Coding: 31FFFF
          U1101 00 [00001001] - Active
                    Reset counter: 140
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 12:52:18
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
   Revision: 00000000    Serial number: 15000177777008
   Coding: 5D00000000000000
   VCID: 343214811EB161CAFBB-8061
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00014.07.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 260815060500DI Dataset Number: V03935214VB 0007
   Coding: 003F13205000040000000000
   VCID: 43D0475D4B1FD672721-8017
   Serial number: 00000000000001871160
   Coding: 011000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Dataset Number: 5GM074V____ 0418
   Coding: 8102
   VCID: 392C25B539D39CA228D-806D
   Component: MIB2_lite_amp H20 0110
   Revision: 00000001    Serial number: VWZ8Z1FBA00NTFU Dataset Number: 5GM050v____ 0212
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 6D84C1E53D1BF002F45-8039
   Serial number: 24061506050D5T Dataset Number: V03935214VC 0007
   Serial number: 00000000000001876615
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0021
   Coding: 021203010B000400
   VCID: 40DA48515A09CD6A6F3-8015
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0842
   Serial number:                Dataset Number: V03935262VW 0001
   Coding: 027310020000000051220002001808009F0507F401200405C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3330179D1BBF66F2E21-8067
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT2851154
   Subsystem 2 - Part No SW: 3G0 919 866 BH    HW: -----------
   Component: NAR 2017/18  --- 0620
10 Faults Found:
          B201A 00 [00001001] - -
                    Reset counter: 138
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:06:16
                    Voltage terminal 30: 11.7 V
                    Status_Software_Version_Management-module_name: C
15360768 - Component Protection
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 138
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:06:16
                    Reset counter: 138
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:07:15
                    Voltage terminal 30: 11.6 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: available.
                    SDARS_tuner_status_2-Antenna current: 138 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
2565 - GPS Antenna
          B1054 13 [00001000] - Open Circuit
          [GPS aerial - open circuit]
                    Reset counter: 178
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:25:29
                    Voltage terminal 30: 11.9 V
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [00001001] - No Communication
          [Control module for instrument cluster display: no communication]
                    Reset counter: 138
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:06:20
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 138
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:06:19
                    BAP-BAP_Function_ID: 02
7178 - Function Restricted due to Missing Message(s)
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 138
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:06:19
7193 - Function Restricted due to Missing Message(s)
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 138
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:06:19
7194 - Function Restricted due to Missing Message(s)
          [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 138
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:06:19
7195 - Function Restricted due to Missing Message(s)
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 138
                    Mileage: 129942 km
                    Date: 2024.03.28
                    Time: 15:06:19
   Component: OCULowMQBUS   007 0568
   Dataset Number: 561098V____ 0409
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 150723200470
   VCID: 6B80CFFD030FFE32EA1-803F
End----(Elapsed Time: 01:42, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
C?ID=313143
Should this go in the repair forum or is it more appropriate here?
I believe it belongs here since the MIB you're having problems with was clearly retrofit into this car.
Reactions: 801
downtime
Finland
C?ID=280813
Copy the coding and adaptations from your old unit. Problem solved
C?ID=313143
I thought that was frowned upon. That makes this much simpler.
Do we have a scan from your old one to see how similar or different they are?
C?ID=313143
Yeah. Here is the coding
Old: 027300020000000051220002001808001F0203F401200105C6
New: 027310020000000051220002001808009F0507F401200405C6
Here is the coding
It would be best if you could post all the ID data from the old MIB (assuming you have it).
Cuzoe
C?ID=279487
I don't know if copying coding is frowned upon as much as not recommended. But that not recommended, especially in the retrofit section, is because newer modules by definition often have new features and the coding could be very different.
Coding hasn't changed very much. And in your case the unit that you installed could very well be the recommended replacement for the unit you're removing. So it's a retrofit technically because it's newer but it's practically the same thing.
I would copy over the coding and adaptations as suggested and then see where you're at. For more help from The forum, which many people will gladly provide, you'll probably want to go ahead and post everything you have from the old and new unit.
downtime
Finland
C?ID=280813
It will work just fine for MIB units. They are generally same coding. Even from MIB1 -> MIB2 the coding is almost the same. Only the car type on the first 4 bytes needs to be modified to match MIB2. Otherwise pretty much 1:1.
Adaptations you generally need to fix manually as they change from unit gen to another.
And the original post does not say if OP replaced the unit with same part number as old MIB2 unit. This is not retrofit as you see.
Reactions: 801
C?ID=313143
Now, without sounding stupid (which I know I do anyways), where do I grab ID data?
C?ID=313143
The original part number was 3Q0 035 880
The new one's part number is 3Q0 035 876 B
From an Auto-Scan. Your new one looks like this:
Part numbers alone don't do much for me with this.
C?ID=313143
Dur. Sorry. This is the old
Part No SW: 3Q0 035 880 HW: 3Q0 035 880
Component: MU-S-NS-US H25 0245
Serial number: VWZAZ2S0403266 Dataset Number: 5G0CV1v____ 0001
Coding: 027300020000000051220002001808001F0203F401200105C6
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 6C82CCE10601F90AE3B-8039
downtime
Finland
C?ID=280813
They’re close enough. So copy the old long coding to new unit. Adaptations you need to do one by one. Take adamap from old unit, then adamap from new unit. Compare with notepad++ or excel or similar and change the adaptations to match your old unit.
Job done, errors gone😉
C?ID=313143
So funny thing happened. When applying the long code for the old unit to the new and doing a soft boot, the unit froze on the Fender splash screen. I tracked down the issue to bite 17. The new one WAS set to 05 (e-golf) and the old 02 (Hybrid). Setting the new one to ANYTHING other than 05 causes the hang on boot. 05 will boot fine, but still loads the "R" splash screen before the "Fender" screen. Also, obviously all the accents are blue.
I was able to clear up some of the faults by changing some adaptions. I'm going to wait until after my appointment today to have CP removed to mess with anything else as I'm not sure what is a result of CP being active or an actual issue.
Cuzoe
C?ID=279487
CP Is not going to mess with any of your adaptations. Those need to be matched, separately from CP.
This is the old
New is EV_MUStd4CDELP -- I assume that's Delphi
Old is EV_MUStd4CTSAT -- I'm not sure who that is, but they're different vendors.
I'd be careful. I'd probably make an Adaptation Channel Map from each of them and compare them rather than copying willy-nilly.
downtime
Finland
C?ID=280813
TSAT is Technisat
And yes, to OP, the skin needs to be adapted correctly. Let it be at 05 for now. I'll try to find from my memory slots the link to a page where it explains different byte values on the MIB
