Airbag fault code
M4HUY
C?ID=573417
Hi
Have a fault code on my airbags and light is on dash
Monday,01,April,2024,09:57:57:34429
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
VIN: TRUZZZ8N451012743 License Plate:
Address 15: Airbags Labels: 8N0-959-655.LBL
Control Module Part Number: 8N0 959 655 D
Component and/or Version: Airbag Front+Seite 1000
Software Coding: 01102
Work Shop Code: WSC 01236
VCID: 41DF52071891ADD260D-5160
32-00 - Resistance Too High
Anyone got a fix for this, which airbag is it?
thanks
2kaa52
Ceska Republica, Praha
C?ID=319193
What do you dont understand ? " Driver Side "
M4HUY
C?ID=573417
Wasnt sure if it was seat or steering wheel but now understand it iz the steering wheeel airbag
Jef
HQ
M4HUY
C?ID=573417
hi
full scan, doesnt show the airbag fault, also cant seem to access live data, not sure if i am doing it correctly?
Monday,01,April,2024,17:44:01:34429
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine        Labels: 06A-906-032-AJQ.clb
   Part No: 8N0 906 018 CN
   Component: 1.8L R4/5VT         0010
   Coding: 11570
   Shop #: WSC 01236
   VCID: 7F5B14FF2EE51B22569-513C
   VINID: 92296AAAA21E1050400421C40C83B589E4
   TRUZZZ8N451012743     AUZ5Z0DD036014
Readiness: 0110 1101
   Part No: 09G 927 750 CA
   Component: AQ 250 6F           0622
   Coding: 0008200
   Shop #: WSC 01236 785 00200
   VCID: 72BDCDCB68B7464A297-513C
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-F.lbl
   Part No: 8N0 907 379 J
   Coding: 0019473
   VCID: 43D3580F078DBFC2721-5160
00813 - Sensor 2 for Brake Pressure (G214)
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00041
   Shop #: WSC 01236
   VCID: 2809EFA39BEB7C9A473-2580
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 D
   Component: Airbag Front+Seite 1000
   Coding: 01102
   Shop #: WSC 01236
Address 35: Centr. Locks        Labels:. 8Nx-962-267.clb
   Part No: 8N7 962 267 E
   Component: Zentralverrieg.,DWA D09
   Coding: 07162
   Shop #: WSC 00050
   VCID: 42DD5D0B1D97B6CA797-4F0C
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8N7 951 177
   Component: Innenraumueberw.    D15
   Coding: 00001
   VCID: 7BA3E0EF3AFD07027A1-50D0
End----(Elapsed Time: 03:41, VBatt start/end: 12.5V/11.9V. VIgn 11.9V)-----
M4HUY
C?ID=573417
Hi
If i select either meaursing blocks or adv meas values i see nothing in the graph but get this in the log
VCDS Label File
; Copyright © 2007-2010 Ross-Tech, LLC
; Audi TT (8N)
; Component: J234 - Airbag (#15) - AIRBAG8
; P/N: 8N0-959-655-???
; includes measuring blocks, adaptation and coding
; created on 04/Nov/2007 by Sebastian Stange (Sebastian@Ross-Tech.com)
; last modification on 04/Aug/2010
; requires VCDS 805.0 or newer
; measuring blocks
001,0,Ignitiers I (Front Airbags && Front Belt Tensioners)
001,1,Airbag,Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
001,2,Airbag,Passenger Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
001,3,Belt Tensioner,Front Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
001,4,Belt Tensioner,Front Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,0,Ignitiers II (Rear Belt Tensioners)
002,1,Belt Tensioner,Rear Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,2,Belt Tensioner,Rear Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,3,Belt Tensioner,Rear Center,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,4,Battery Disconnect,Igniter,Display Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
003,0,Voltage && Seat. Occupation && Belt Inquiry I (Front)
003,1,Voltage Supply,,Specification: Correct
003,2,Occupied Seat,Sensor Pass. Side,Display Range: child/child seat/light adult/heavy adult/occupied/not occupied/not installed
003,3,Belt Inquiry,Front Driver Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
003,4,Belt Inquiry,Front Pass. Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
004,0,Belt Inquiry II (Rear)
004,1,Belt Inquiry,Rear Driver Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
004,2,Belt Inquiry,Rear Pass. Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
004,3,Belt Inquiry,Rear Center,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
006,0,Igniters III (Side Airbags)
006,1,Side Airbag,Front Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
006,2,Side Airbag,Front Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
006,3,Side Airbag,Rear Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
006,4,Side Airbag,Rear Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
007,0,Seat Occupation (Rear)
007,1,Seat Occupation,Rear Driver Side,Display Range: Too High
007,2,Seat Occupation,Rear Pass. Side,Display Range: Too High
008,0,Igniter Status (Head Airbag)
008,1,Airbag (Stage 2),Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
008,2,Airbag (Stage 2),Passenger Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
008,3,Driver Head,Airbag Igniter,Display Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
008,4,Passenger Head,Airbag Igniter,Display Range: Correct/Signal too Low/Signal too High/Short to Ground/Short to Plus/Not Installed
009,0,Key Switch Status
009,1,Key Switch,Passenger Airbag,Display Range: ON/OFF
; adaptation
A001,0,Front Passenger Airbag Deactivation
A001,1,Front Passenger,Airbag
A001,2,Current Status
A001,5,Front Passenger Airbag Deactivation
A001,6,0 = Airbag Enabled
A001,7,1 = Airbag Disabled
A001,8,
A001,9,Note: Refer to Service Manual!
; coding
C00,Airbag 8 (J234) Coding
C01,Standard: Front Airbags/Front Belt Tensioners
C02,
C03,0?x0x: Key Switch for Pass. Airbag Deactivation
C04,0 = Key Switch not installed
C05,1 = Key Switch installed
C06,0x?0x: Side/Head Airbags
C07,0 = Side/Head Airbags not installed
C08,1 = Front Side Airbags installed
C09,0xx0?: Belt Tensioners
C10,2 = Front Belt Tensioners installed
C11,3 = Front Belt Tensioners & Belt Inquiry installed
M4HUY
C?ID=573417
VCDS Label File
; Audi TT (8N)
; measuring blocks
; adaptation
A001,8,
; coding
C02,
M4HUY
C?ID=573417
Ran another auto scan and got this, i then cleared the faults and i have posted result below this
Tuesday,02,April,2024,08:27:51:34429
   Coding: 11570
   Shop #: WSC 01236
   Coding: 0008200
   Coding: 0019473
   Coding: 00041
   Shop #: WSC 01236
   Coding: 01102
   Shop #: WSC 01236
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N2 920 980 A
   Component: KOMBI+WEGFAHRS. M73 D14
   Coding: 05444
   Shop #: WSC 00050
   VCID: 353736D75C591172CC5-4B00
01304 - Radio
            49-00 - No Communications
            37-10 - Faulty - Intermittent
   Coding: 07162
   Shop #: WSC 00050
01616 - Signal Wire to Interior Monitor
            36-00 - Open Circuit
01559 - Drivers Door
            58-10 - Can't Lock - Intermittent
            60-10 - Won't Safe - Intermittent
            77-00 - Internal Supply Voltage
   Coding: 00001
   VCID: 7BA3E0EF3AFD07027A1-50F4
            00-00 - -
End----------(Elapsed Time: 02:52, VBatt start/end: 13.0V/13.3V)-----------
M4HUY
C?ID=573417
After clearing faults, airbag ;light still on
Tuesday,02,April,2024,08:32:22:34429
   Coding: 11570
   Shop #: WSC 01236
   Coding: 0008200
   Coding: 0019473
   Coding: 01102
   Shop #: WSC 01236
   Coding: 05444
   Shop #: WSC 00050
01304 - Radio
   Coding: 07162
   Shop #: WSC 00050
   Coding: 00001
End----------(Elapsed Time: 03:00, VBatt start/end: 13.7V/13.5V)-----------
Why do you want to graph live data from an Airbag module?
nugentp
C?ID=6386
N95 is absolutely the airbag in the steering wheel - you wouldn't know that just be reading the error code - the N95 is a schematic reference from the WD - very commonly used across a bunch of VAG machines since a long time back.
I suspect the error is going away when you clear it momentarily, but on the next power up the airbag controller decides that it is unhappy with the N95 resistance value. These aren't things you go messing about with if you are unaware of the dangers, but the most likely cause is a bad connection from N95 (the actual airbag) through the plug where is connects via the slip-ring (aka clock-spring) to present itself to the airbag controller.
M4HUY
C?ID=573417
Ive booked it into garage, i was confused by the comment 15-08-001.1 will show you live data from the driver's airbag. Wiggle test connections and see if the data changes. Did not want to wiggle anything tbh so im leaving this to someone with more experience.
If you're not comfortable working on airbags, that's probably a wise decision.
