Needle sweep question.
CompleteN00b
Newcastle Upon Tyne, UK
C?ID=570363
Hi, I have a 2007 EOS TDi and with my shiny new Ross Tech toy in hand I would like to enable needle sweep. When I select module 17 then adaptation, the list of things isn't very long and I can't see anything like needle sweep or indicator celebration etc. Now I've read that some clusters don't support this feature which I fully understand, but what has confused me is I can test every dial on the cluster so the ability to move the needles is definitely there.....and if that's there how can needle sweep not be there too as it's essentally the same thing. If it helps, the software reports a VAG number of 1Q0 920 964 A which I assume if the dealer part number.
Much head scratching going on here, and I'm VERY new to the VCDS software so a it of a learning curve in play too, so any advice would be greatly appreciated.
Thanks in advance.
That sounds good, but not how it works! I would post a complete Auto-Scan for additional feed back (and Insurance..... ie a copy will be kept here on the forum as well as your PC).
Congratulations on your purchase of VCDS.
Not sure if you have seen this link/wiki :
Feel free to look and explore, but I would post any questions before you make any changes!
Demo Manual:
Your instrument cluster may not support that. Most that old do not.
CompleteN00b
C?ID=570363
I'll get that done tomorrow.
@Uwe, is there a list of compatible/incompatible clusters or are there too many different parts to make that impractical?
CompleteN00b
C?ID=570363
Monday,25,March,2024,16:47:56:18646
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WVWZZZ1FZ8V012416   License Plate:
Mileage: 150240km-93354mi   Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 52 56 62 72
VIN: WVWZZZ1FZ8V012416   Mileage: 150240km-93354miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 TA    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  1210
   Revision: --H07---    Serial number: VWX7Z0G63N380C
   Coding: 0000072
   Shop #: WSC 00020 790 00000
   VCID: 71BFC568BDAD97E2D0D-8024
   VINID: 9E69EAAAA056A889800421011869A4DBB7
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
                    Fault Status: 01110000
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
005785 - Powertrain Data Bus
               P1699 - 000 - Missing Message from Steering Wheel Electronics
                    Fault Frequency: 18
                    Mileage: 150201 km
                    Time: 14:59:35
                    Voltage: 12.31 V
                    Bin. Bits: 00001100
                    Bin. Bits: 00000000
                    (no units): 0.0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Revision: 00H11001
   Coding: 0006882
   VCID: 73B3CF60C7B1A5F2221-8026
   Part No SW: 1Q0 907 044 J    HW: 1Q0 907 044 J
   Component: ClimatronicPQ35 121 0303
   Revision: 00121021    Serial number: 00000000000000
   VCID: 34310C7C823FE2CAFBB-8060
   Revision: 00H54000    Serial number: 00000007352621
   Coding: 05888F0700041500470A00000F00000000085D035C000100000000000000
   Component: Wischer 170707 021  0501
   Coding: 00038805
   Shop #: WSC 00020
                    Fault Status: 00101100
                    Reset counter: 142
                    Mileage: 150201 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.30 V
                    Fault Status: 00111010
                    Reset counter: 138
                    Mileage: 149889 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.85 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475     HW: 1K0 919 475
   Component: PARKHILFE     005 1104
   Revision: 00005000    Serial number: 0 263 004 193
   Coding: 001001
   VCID: 6FBBC310A7998112C69-803A
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 6P Airbag VW8C      0180
   Revision: 92009018    Serial number: 003B3002A4SI
   Coding: 0013904
   VCID: 3A2D2244A05B14BA217-806E
   Subsystem 1 - Serial number: 6332SRB405698E0FC
   Subsystem 2 - Serial number: 6342SRB40555851E%
   Subsystem 3 - Serial number: 637  RB4        8
   Subsystem 4 - Serial number: 638  RB4        9
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0000011
   VCID: 005990AC86078E6A2F3-8054
   Part No SW: 1Q0 920 964 A    HW: 1Q0 920 964 A
   Revision: V0002000    Serial number: VWX7Z0G63N380C
   Coding: 0019403
   Shop #: WSC 00632 067 57207
   VCID: 313F05687D2DD7E290D-8064
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K077110030
   Coding: E9A07F260002025001
   VCID: 3039006C7627DEEA9F3-8064
                    Reset counter: 188
                    Mileage: 80122 km
                    Time: 11:02:07
01304 - Radio
                    Reset counter: 67
                    Mileage: 80122 km
                    Time: 11:02:10
   Component: IMMO            VDD 1212
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 C    HW: 1Q0 959 255 C
   Component: Verdecksteuergeraet 0720
   Revision: 0032000L    Serial number: 071930385
   Coding: 0655362
   VCID: 3829384C9E5706AAD73-806C
   Part No SW: 1Q0 959 701 D    HW: 1Q0 959 701 D
   Component: Tuer-SG         006 1210
   Coding: 0000693
   VCID: 353731788945FBC2CC5-8060
00915 - Window Regulator Switch; Rear Right; Driver (E55)
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   VCID: 363536749443F0DAC5F-8062
   Coding: 81908A000186285B080484057008DEC690FCA0
   VCID: 03539FA097119572321-8056
   Component: LIN BACKUP HORN H07 9001
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1Q0 951 177 A
   Component: Innenraumueberw.158 0502
   Part No SW: 1Q0 959 702 E    HW: 1Q0 959 702 E
   Coding: 0000948
   VCID: 372B3B70934909D2DE9-8062
Address 56: Radio
   Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
   Component: Tuer-SG         006 1203
   Coding: 0000128
   Shop #: WSC 00020 790 1012544
00934 - Electric Window Motor; Rear Left (V26)
   Part No SW: 1Q0 959 704 A    HW: 1Q0 959 704 A
   Coding: 0000128
End----------(Elapsed Time: 01:16, VBatt start/end: 14.1V/14.1V)-----------
   Coding: 0000072
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
                    Fault Frequency: 18
                    Mileage: 150201 km
                    Time: 14:59:35
                    Voltage: 12.31 V
                    Bin. Bits: 00001100
                    Bin. Bits: 00000000
                    (no units): 0.0
   Revision: 00H11001
   Coding: 0006882
   Coding: 00038805
   Shop #: WSC 00020
                    Reset counter: 142
                    Mileage: 150201 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.30 V
                    Reset counter: 138
                    Mileage: 149889 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.85 V
   Coding: 001001
   Coding: 0013904
   Coding: 0000011
   Coding: 0019403
                    Reset counter: 188
                    Mileage: 80122 km
                    Time: 11:02:07
01304 - Radio
                    Reset counter: 67
                    Mileage: 80122 km
                    Time: 11:02:10
   Coding: 0655362
   Coding: 0000693
   Coding: 0000948
Address 56: Radio
   Coding: 0000128
   Coding: 0000128
End----------(Elapsed Time: 01:15, VBatt start/end: 14.2V/14.2V)-----------
   Coding: 0000072
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
                    Mileage: 148413 km
                    Time: 07:46:37
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Temperature: 5.4°C
                    Bin. Bits: 00110000
                    Fault Frequency: 18
                    Mileage: 150201 km
                    Time: 14:59:35
                    Voltage: 12.31 V
                    Bin. Bits: 00001100
                    Bin. Bits: 00000000
                    (no units): 0.0
   Revision: 00H11001
   Coding: 0006882
   Coding: 00038805
   Shop #: WSC 00020
   Coding: 001001
   Coding: 0013904
   Coding: 0000011
   Coding: 0019403
                    Reset counter: 102
                    Mileage: 150243 km
                    Time: 16:50:58
01304 - Radio
                    Reset counter: 102
                    Mileage: 150243 km
                    Time: 16:51:02
   Coding: 0655362
   Coding: 0000693
   Coding: 0000948
Address 56: Radio
   Coding: 0000128
   Coding: 0000128
End----------(Elapsed Time: 01:15, VBatt start/end: 14.1V/14.2V)-----------
Hope this helps.
CompleteN00b
C?ID=570363
Yup. Kinda old-school. I do not think that cluster supports needle-sweep/staging.
I just can't get my head around the fact that the engine ECU can activate every dial in the cluster using VCDS output tests, but not enable needle sweep.
Another thing I can't get my head around, lol.
That's not the Engine ECU doing that; it's the cluster doing it directly.
It's simply not a "feature" that those clusters had in the configuration options (Coding & Adaptation) in the API that VCDS uses.
Westbury, UK
Needle sweep needs the firmware in the cluster to have this feature included, if VAG didn't include that in the firmware then it cannot be enabled.
  • Agree
AINils
Germany (AIB)
C?ID=56975
Red MFA aren't capable at all. Need new 24C32/64 Black & White MFA
Zagor
Italy
C?ID=96696
A way to do this has been found on the red matrix clusters Audi TT and A3 8P (e.g. 8J0 920 930 F or 8P0 920 931 xx), but it is necessary read the eeprom, change a few bytes and rewrite it. Unfortunately for the VW clusters with red matrix, however, this is not yet possible
