2013 VW Passat S - replaced clock spring and steering angle issues
tplarso
Las Vegas, NV, USA
C?ID=578723
Any suggestions or ideas. I replaced the clock spring, but, I cant get the original code to match exactly as it shows no communication with the steering angle. Any suggestions on how to code or if I need to get a different clock spring?
Original data
Saturday,30,March,2024,13:00:25:03977
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240322 DS351.0
steering wheel code 498A140000
VIN: 1VWAP7A35DC008789   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 46 4F 52 56 62 72 77
VIN: 1VWAP7A35DC008789   Mileage: 155960km-96909miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CR    HW: 07K 907 309 A
   Component: 2,5l R5/4V      G01 4340
   Revision: T6H02---    Serial number:
   Coding: 0000075
   Shop #: WSC 09003 957 00200
   VCID: 005997925603FB9A2F3-8054
   VINID: 0669D18074431544C00081C824B8DDDE2F
005707 - Oil Pressure Switch
               P164B - 000 - Malfunction - Intermittent
                    Mileage: 155840 km
                    Date: 2018.08.15
                    Time: 19:01:22
                    RPM: 2841 /min
                    Load: 88.2 %
                    Speed: 70.0 km/h
                    Temperature: 38.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 880.0 mbar
                    Voltage: 14.351 V
   Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
   Component: AQ 250 6F           2251
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 025D9D9A580FE98A397-8056
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: C54BC0F549220802A31203EC92221061A61000
   VCID: 7CA1E36236EB9F7A73B-8028
   Part No SW: 561 907 426     HW: 561 907 426
   Component: AC Manuell    H01 0101
   Revision: 00001K05
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 58E99FF2E293935A373-800C
   Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
   Component: BCM PQ35 B+   021 0068
   Revision: BH021001
   Coding: 6F200E18902B08D408800001160004480071008640801960648060000C70
   VCID: 43D3589E0B952082721-8016
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 157
                    Mileage: 154847 km
                    Date: 2018.07.10
                    Time: 16:54:19
                        Term 15 Off
                    Voltage: 10.35 V
02742 - Bulb for Brake/Turn Signal Light; Left
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 34
                    Reset counter: 225
                    Mileage: 155466 km
                    Date: 2018.07.27
                    Time: 11:40:29
                    Voltage: 12.20 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM034AD6   Dataset Number: 560003v__A_ 0049
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBBC42E771DF4E2C69-803A
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000GFHL0$
   Coding: 303048
   Serial number: 3572MSME4B13446DZZZ$
   Serial number: 3582MSME092C726EZZZ3
   Serial number: 3516KSME0213171CZZZG
   Serial number: 3526KSME3924171CZZZT
   Serial number: 3556LSME5C081218ZZZV
   Serial number: 3566LSME6B0E1118ZZZ.
          B1000 1B [10001001] - Resistance Too High
                    Mileage: 154982 km
                    Date: 2024.02.18
                    Time: 19:40:19
   Part No SW: 1K5 953 501 R    HW: 5K0 953 569 H
   Revision: FF010041    Serial number: 20120625201799
   Coding: 498A140000
   VCID: 3A2D257A7CDF614A217-806E
365080 - Controls in Steering Wheel
          U108E 00 [00001001] - No Communications
                    Reset counter: 167
                    Mileage: 154982 km
                    Date: 2024.02.18
                    Time: 19:40:19
   Part No SW: 561 920 960 C    HW: 561 920 960 C
   Component: KOMBI         H06 0705
   Coding: 230E01
   VCID: 196FDAF6D9194A52C8D-804C
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 01071203290805
   Coding: 461000
   VCID: 41DF52961189329260D-8014
   Component: IMMO          H06 0705
   VCID: 6A8DD53A4CFF11CA917-803E
   Revision: 13110009    Serial number: 0004923334
   Coding: 0404D5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE380FE93A578421A1-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
67074 - Motors for Central Locking
          B122B 01 [00001001] - Electrical Failure
                    Reset counter: 85
67330 - Switch for Central Locking
          B122D 29 [00001001] - Signal Implausible
                    Reset counter: 240
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 00000008
   VCID: 6FBBC42E779DF4E2C69-803A
   Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0004
   Revision: 15110009    Serial number: 0004960055
   Coding: 0404D4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE183E296AB7F7A13B-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
          B122B 01 [00001000] - Electrical Failure
                    Fault Frequency: 30
                    Reset counter: 3
                    Mileage: 152793 km
                    Date: 2023.12.23
                    Time: 04:14:59
          B122D 29 [00001000] - Signal Implausible
                    Fault Frequency: 22
                    Reset counter: 247
                    Mileage: 154458 km
                    Date: 2024.02.04
                    Time: 07:56:46
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0006
   Revision: -----06S    Serial number: VWZ4Z6N3573312
   Coding: 05000400010006
   Shop #: WSC 00066 000 00000
   VCID: 2313F81EEBD50082121-8076
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007662704480 Dataset Number: 7P6035730K  0001
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
End----------(Elapsed Time: 00:54, VBatt start/end: 12.5V/12.5V)-----------
New Data
3rd time
Saturday,30,March,2024,16:09:35:03977
04-Steering Angle -- Status: Cannot be reached 1100
   Coding: 0000075
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 000 -
                    Mileage: 155967 km
                    Date: 2018.08.21
                    Time: 02:12:13
                    Temperature: 92.0°C
                    Temperature: 36.0°C
                    Voltage: 12.192 V
Readiness: 1110 1101
   Coding: 0000840
   Revision: 00H31001
                    Reset counter: 240
                    Mileage: 155961 km
                    Date: 2018.08.21
                    Time: 00:02:10
                    Count: 14
                    Count: 12288
                    Count: 166
                    Count: 45056
                    Reset counter: 240
                    Mileage: 155961 km
                    Date: 2018.08.21
                    Time: 00:02:21
                    Count: 2
                    Count: 14
                    Count: 12288
                    Count: 16390
                    Count: 45056
   Revision: 00001K05
   Coding: 0010001002
   Revision: BH021001
                    Reset counter: 240
                    Mileage: 155961 km
                    Date: 2018.08.21
                    Time: 00:02:13
                    Voltage: 12.55 V
                    Reset counter: 157
                    Mileage: 154847 km
                    Date: 2018.07.10
                    Time: 16:54:19
                        Term 15 Off
                    Voltage: 10.35 V
                    Fault Frequency: 34
                    Reset counter: 225
                    Mileage: 155466 km
                    Date: 2018.07.27
                    Time: 11:40:29
                    Voltage: 12.20 V
   Coding: 00003548
   Coding: 303048
          B1000 1B [10001000] - Resistance Too High
                    Mileage: 154982 km
                    Date: 2024.02.18
                    Time: 19:40:19
   Part No SW: 5K0 953 569 BC    HW: 5K0 953 569 BC
   Revision: --X01---    Serial number: 20230902000002
   Coding: 488A100000
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7AADE57A3C5FA14A617-802E
   Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
   Component: E221__MFL-YVJ  H06 0022
   Serial number: 00000000000000476746
   Coding: 620000
   Coding: 230E01
   Coding: 461000
                    Reset counter: 240
                    Mileage: 155961 km
                    Date: 2018.08.21
                    Time: 00:02:11
   Coding: 0404D5
   Slave Driver:
   Coding: 800000
                    Reset counter: 85
                    Reset counter: 241
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 240
   Coding: 00000008
   Coding: 0404D4
   Slave Passenger:
   Coding: 800000
                    Fault Frequency: 30
                    Reset counter: 3
                    Mileage: 152793 km
                    Date: 2023.12.23
                    Time: 04:14:59
                    Fault Frequency: 22
                    Reset counter: 247
                    Mileage: 154458 km
                    Date: 2024.02.04
                    Time: 07:56:46
                    Reset counter: 240
End----(Elapsed Time: 00:57, VBatt start/end: 12
............as it shows no communication with the steering angle. Any suggestions on how to code or if I need to get a different clock spring?
Did you replace the CS with the same PN? New , oem and genuine? or a ebay used replacement?
Note:
00778 - Steering Angle Sensor (G85): No Signal/Communication​
Possible Causes​
  • Steering Angle Sensor (G85) faulty
  • Steering Angle Sensor (G85) configured incorrectly due to replacement control modules or incorrect coding
  • Buggy ABS controller software
Possible Solutions​
  • Check Steering Angle Sensor (G85)
  • Check Steering Angle Sensor (G85) location and configuration on the vehicle in question
  • Check ABS controller software per TPIs, TSBs and recall publications .
Special Notes​
  • When found in the VW Jetta, Beetle and Beetle Convertible with MK60EC1 ABS control modules numbers; 1K0 907 379 BM and 1K0 907 379 BS may have a flash update for model years 2014-2015. US Market RVU # 45D7 (TPMS/ESC Software (FED_EMS) includes the following DTCs: 00778 and 01325
  • When found in a MLB based chassis vehicle with Address 16 both fault free and communicating make sure ALL fused powers to J527 are OK. The example here may be helpful: https://forums.ross-tech.com/showthread.php?22543-Audi-A4-B8-Steering-Angle-sensor-no-signal-(G85)
tplarso
Las Vegas, NV, USA
C?ID=578723
Original PN = 5K0-953-569-H
New part from VW PN = 5K0-953-569 BC
I am thinking this may be the issue as CCS is on lever and not steering wheel
Original code for Clockspring is 498A140000 - right now i can only code it to 488A100000, when I try to update the code it gives me a code 31
2kaa52
Ceska Republica, Praha
C?ID=319193
569BC dont Work for your Car.
You need a clock spring with internal steering angle Sensor.
Look for 569H so you can be Sure it will work
