Tuesday,06,October,2015,12:38:43:28317
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVWZZZAUZFW802903 License Plate:
Chassis Type: AU (5QE)
Scan: 01 02 03 08 09 10 15 16 17 19 23 42 44 51 52 55 5F 75 8C A9
C6
VIN: WVWZZZAUZFW802903 Mileage: 5598km-3478miles
8C-Hybrid Battery -- Status: Malfunction 0010
Address 01: Engine (J623-CUKB) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 023 M HW: 04E 907 309 F
Component: 1.4l TFSI hy H20 8163
Revision: X3H20---
Coding: 011D0012632405082000
ASAM Dataset: EV_ECM14TFS01104E906023M 004008
ROD: EV_ECM14TFS01104E906023M.rod
VCID: 2A5B58064D91B46E23-807E
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0DD 300 045 E HW: 0DD 927 770 A
Component: GSG DQ400E H30 0601
Revision: 00030000 Serial number: TFK01410140003
ROD: EV_TCMDQ400021.rod
VCID: 2959A70A4897BF762A-807C
18 Faults Found:
60352 - ROD - Unknown Error Code
- 00 [002]
60353 - ROD - Unknown Error Code
- 00 [002]
60354 - ROD - Unknown Error Code
- 00 [002]
60355 - ROD - Unknown Error Code
- 00 [002]
60356 - ROD - Unknown Error Code
- 00 [002]
60357 - ROD - Unknown Error Code
- 00 [002]
60358 - ROD - Unknown Error Code
- 00 [002]
60359 - ROD - Unknown Error Code
- 00 [002]
60360 - ROD - Unknown Error Code
- 00 [002]
60361 - ROD - Unknown Error Code
- 00 [002]
60362 - ROD - Unknown Error Code
- 00 [002]
60363 - ROD - Unknown Error Code
- 00 [002]
60364 - ROD - Unknown Error Code
- 00 [002]
60365 - ROD - Unknown Error Code
- 00 [002]
60366 - ROD - Unknown Error Code
- 00 [002]
60367 - ROD - Unknown Error Code
- 00 [002]
60368 - ROD - Unknown Error Code
- 00 [002]
60369 - ROD - Unknown Error Code
- 00 [002]
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 907 379 AE HW: 5Q0 907 379 H
Component: ESC H31 0808
Revision: 00000000 Serial number: 63244000001057
Coding: 01FA40A13820316E0380060041C62980021C8CC0608294F302A10078C205
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_AU37.rod
VCID: 7F0D5952E693E1C624-802A
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GE 907 044 AC HW: 5GE 907 044 AC
Component: Climatronic H02 1104
Revision: 00001K07
Coding: 00021014200100010005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 005134
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 7DF1A35AEC9FF3D636-8028
Subsystem 3 - Part No SW: 12E 963 231 E HW: 12E 963 231 E
Component: J848 HV-PTC H09 0205
Serial number: T143533003805000303
H02
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011500900382
Coding: 00101A42C35102F36BEC5080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 000FDAAE9B6D9E3E5D-8054
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 141207 043 0551
Serial number: 141212201604
Slave 2:
Component: RLHS 037 0059
Serial number: S4Y15M01D09H19M29S59
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY143421VJQ
Serial number: 00000000000031416657
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H02 0003
Serial number: 0000FST0002DI7400000
Coding: 181901
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 H HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0053
Revision: -------- Serial number: 39391435011938
Coding: 0031051011
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 408F1AAEDBED5E3E1D-8014
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 009 0870
Serial number: 003MFR00BR8R
Coding: 98CCC000002000005C0000CF004800000065
VCID: 50AF2AEE0B8DAEBE8D-8004
Seat belt tensioner; left:
Component: BeltPretRevFL H36 0350
Serial number: 34169667B08011571239
Coding: 333135
Seat belt tensioner; right:
Component: BeltPretRevFR H36 0350
Serial number: 34169668B08011540575
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 812 14
Serial number: 357000000004F7104216
Subsystem 4 - Part No SW: ----------- HW: 480 001 612 14
Serial number: 358000000003F0AC421K
Subsystem 5 - Part No SW: ----------- HW: 480 401 612 14
Serial number: 3510002A1196FF6503A6
Subsystem 6 - Part No SW: ----------- HW: 480 401 612 14
Serial number: 3520002AD1901DA1216-
Subsystem 7 - Part No SW: ----------- HW: 480 401 612 14
Serial number: 3550002BF1901DA3F0DK
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150102500156
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F8D1952A61321C664-806A
Part No SW: 5G1 920 754 HW: 5G1 920 754
Component: KOMBI 306 4300
Coding: 07A51B082BC0000800087F101600000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009042
VCID: 68DFE20E931D467EF5-803C
1246803 - Dynamometer Mode Detected
C10A7 00 [008] - -
Reset counter: 112
Mileage: 5598 km
Date: 2015.10.06
Time: 12:28:15
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5QE 907 530 C HW: 5QE 907 530 A
Component: GW MQB EV 312 3203
Revision: -------- Serial number: 01121410800004
Coding: 0201001726F16400FF00526C5C1F00000001050100010000000000000000
ASAM Dataset: EV_GatewEVConti 011020
ROD: EV_GatewEVConti.rod
VCID: 46830CB6F9C9700E27-8012
Subsystem 1 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M
Component: E221__MFL-DC1 H10 0101
Serial number: 27140003174750025011
Coding: 29FFFF
Subsystem 2 - Part No SW: 5QE 915 181 HW: 5QE 915 181
Component: J367-BDMHella H04 8050
Serial number: 1763304703
131703 - No Communication with Transmission Control Module
U0101 00 [008] - -
Reset counter: 108
Mileage: 5367 km
Date: 2015.10.02
Time: 17:42:06
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5QE 909 059 A HW: 5QE 909 059 A
Component: EBKV H12 0160
Serial number: 085430010107
Coding: 02720100331902020002060500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
ROD: EV_BrakeBoostBoschMQBOMG_VW37.rod
VCID: 4C973E9EE7A58A5EF1-8018
Subsystem 2 - Part No SW: 5QE 909 057 A HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0140
Serial number: 05802861171214100308
180736 - Implausible Data Received from Engine Control Module
U0401 00 [040] - -
Mileage: 3017 km
Date: 2015.09.19
Time: 11:00:36
239616 - Implausible Data Received from Engine Control Module
U0401 00 [040] - -
Mileage: 5574 km
Date: 2015.10.06
Time: 08:57:56
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 221214BLL01935
Coding: 003F0720D000048000001000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 428B10A6D5E14C2E0B-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000004780157
Coding: 110000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: C102
ROD: EV_SteerAssisMQB.rod
VCID: 438515A2CAFB452600-8016
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 C HW: 5G0 907 080 C
Component: VW370P3815010 H04 4482
Revision: 00H04000
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM09550115G0907080C 001016
ROD: EV_DMCM09550115G0907080C.rod
VCID: 275DA1325E8389063C-8072
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 171214BLH02515
Coding: 003F0120DE00048000801000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 41891FAAD0E7573612-8014
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000004792799
Coding: 090000
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 029A000001010000
ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
VCID: 75E1BB7AD4AFAB967E-8020
Part No SW: 5G0 035 043 E HW: 5G0 035 043 D
Component: MU-H-N-EU H44 0376
Serial number: A309L0EB015092
Coding: 02730001FF00000011110001000802001F0204C401000100D7
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 204FBA2E3BAD7E3E7D-8074
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9PU300GFP
Engine Control Module 2:
Subsystem 2 - Part No SW: V03 959 800 LH HW: -----------
Component: ECE 2015/2016 --- 0123
Door Electronics Rear Left:
Component: Gracenote --- 1010
7179 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 71
Mileage: 5574 km
Date: 2015.10.05
Time: 16:52:44
Address 75: Telematics (J949) Labels: None
Part No SW: 5QE 035 284 A HW: 5QE 035 284 A
Component: OCULowMQBEU 008 0559
Coding: 027390011082BA0100F800000000
ROD: EV_OCULowMQB.rod
7170 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 111
Mileage: 5364 km
Date: 2015.10.01
Time: 18:55:00
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5Q0 915 182 C HW: 5Q0 915 182 C
Component: BECM H05 0532
Serial number: S9230044
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 005034
ROD: EV_BECM06020115C6915182_AU37.rod
VCID: 336545629A5BF5A690-8066
Subsystem 2 - Part No SW: 5Q0 915 250 B HW: 5Q0 915 250 B
Component: BJB H26 0240
Subsystem 3 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D1 H14 0460
Serial number: V013C13B0530399
Subsystem 4 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D2 H14 0460
Serial number: V013C13B0530135
Subsystem 5 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D3 H14 0460
Serial number: V013C13B0530125
Subsystem 6 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D4 H14 0460
Serial number: V013C13B0530126
Subsystem 7 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D5 H14 0460
Serial number: V013C13B1230003
Subsystem 8 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D6 H14 0460
Serial number: V013C13B1230395
Subsystem 9 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D7 H14 0460
Serial number: V013C13B0530098
Subsystem 10 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D8 H14 0460
Serial number: V013C13B1230039
26703 - Control Pilot
P0CF4 00 [104] - Implausible Signal
Fault Frequency: 11
Mileage: 311 km
Date: 2015.09.03
Time: 10:08:32
Part No SW: 5G0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0016
Serial number: 141028201855
VCID: 2E5354167179D84EFF-807A
Address C6: Batt. Chrg. (J1050) Labels: None
Part No SW: 5QE 915 682 K HW: 5QE 915 682 K
Component: OBC KOSTAL H51 3008
Revision: -------- Serial number: 1912140KP000BA
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
ROD: EV_OBCSinglPhaseKLOVW3709_AU37.rod
VCID: 55A1DBFA346FCB965E-8000
14746880 - LED Module for Charging Socket A
P31C9 00 [009] - Electrical Malfunction
Fault Frequency: 35
Reset counter: 64
Mileage: 15 km
Date: 2015.09.02
Time: 13:35:00
2097664 - Charging Socket A
P33E3 00 [008] - Communications Error
Fault Frequency: 12
Reset counter: 91
Mileage: 311 km
Date: 2015.09.03
Time: 10:08:32
End---------------------(Elapsed Time: 05:12, Deb=2)-----------------------
