2015 Golf TDI S - Want to add ACC but need High Gateway..?
byrangc
C?ID=398877
I've had my 2015 Golf TDI S for about 4 years now and decided I want to bite the bullet and add ACC and Lane Assist/Blind Spot monitoring at a minimum. It looks like I will need to upgrade my CAN Gateway from the mid I have to a High. Does anyone have tips or a link to a post about the upgrade, like the part number I'm looking for and difficulty in making it work? Attaching my auto-scan.
Thanks!
Monday,19,February,2024,17:30:52:56173
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
VIN: 3VWRA7AU8FM089480   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWRA7AU8FM089480   Mileage: 125874km-78214miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 M    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9458
   Revision: 85H23---    CVN: 500D7A2038D3FF82B866C2AD
   Coding: 01190012032410080000
   Shop #: WSC 05036 444 00000
   ASAM Dataset: EV_ECM20TDI01104L997022M 004002
   ROD: EV_ECM20TDI01104L997022M.rod
   VCID: 3A2D344D4CD22F0A217-806E
   VINID: 0E69E244746521674020910800757943BE
5231 - Fuel Rail/System Pressure
          P0087 00 [01100000] - Too Low
17158 - Databus
          U1123 00 [00100000] - Received Error Message
22589 - Reductant Tank Temperature Sensor
          P205B 00 [01100000] - Implausible Signal
          U0428 00 [00100000] - -
22564 - Control Circuit for Reductant Pump 2
          P20FB 00 [01100000] - Mechanical Malfunction
25147 - Control Circuit for Reductant Pump 1
          P208B 00 [01100000] - Implausible Signal
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 50775000000976
   Coding: 01FA6AA124280975007B020881C32580562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: 47CB5DB90F2042E2AE9-8012
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 67
                    Mileage: 64571 km
                    Date: 2019.11.15
                    Time: 21:22:19
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020104202100000000000000000000
   VCID: 055797B175AC90F21C5-8050
329220 - Motor for Air Distribution Flap
          B109D 71 [00001000] - Actuator Stuck
                    Reset counter: 161
                    Mileage: 125776 km
                    Date: 2024.02.12
                    Time: 18:25:08
                    Voltage terminal 30: 13.0 V
                    Outside temperature: 25.0 °C
                    Air distribution flap: actual value: 0.0 %
                    Air distribution flap: actual value: 222
                    Air distribution flap: specified value: 26
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Revision: --------    Serial number: 86580603151222 Dataset Number: 5GM063v____ 0050
   Coding: 000008424041804169E44000000403001000000000000000000000000000
   Shop #: WSC 00066 790 00205
   ROD: EV_BCMBOSCH_014.rod
   VCID: 49CF5B811934B492B8D-801C
   Component: WWS    140902  043 0581
   Serial number:         150421150252
8 Faults Found:
131330 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [VersorgungsspannungSpannung zu niedrig]
          U1400 00 [00001000] - -
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [00001000] - Open or Short to Plus
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [00001000] - Open or Short to Plus
10762 - Bulb for Right Tail Light
          B12BF 15 [00001000] - Open or Short to Plus
12307 - License Plate Light
          B12CA 01 [00001000] - Electrical Failure
17674 - Bulb for Front Left Side Marker Lamp
          B12BA 15 [00001000] - Open or Short to Plus
          B1806 F0 [00001000] - Safety Shut-Off due to Occupant Detection
                    Reset counter: 159
                    Mileage: 62156 km
                    Date: 2019.09.17
                    Time: 15:59:57
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: operated
                    Voltage: 12.5 V
                    Outside temperature: 35.5 °C
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM023X0G Dataset Number: 5GM003V____ 0041
   VCID: 51FF73E1F1648C52F0D-8004
   Serial number: IBH0000J150002MZI80R
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 000 303 15
   Serial number: 35700000000A58414318
   Subsystem 3 - Part No SW: -----------    HW: 480 000 303 15
   Serial number: 35800000000F615CC31S
   Subsystem 4 - Part No SW: -----------    HW: 480 400 403 15
   Serial number: 3510002B51941313420C
   Subsystem 5 - Part No SW: -----------    HW: 480 400 403 15
   Serial number: 3520002A319DB8B61188
   Subsystem 6 - Part No SW: -----------    HW: 480 400 203 15
   Serial number: 3550002A719DB8B5218F
   Subsystem 7 - Part No SW: -----------    HW: 480 400 203 15
   Serial number: 3560002A719DB8B4A0BP
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [10001000] - Open or Short to Ground
                    Mileage: 120538 km
                    Date: 2023.07.30
                    Time: 18:55:03
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150227400997
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BB41A022180CF0502086A001000000000000000
   Shop #: WSC 00066 790 00221
   VCID: 6597B73195EC70F2BC5-8030
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 25031510001312 Dataset Number: 5G0067v____ 2011
   Coding: 0101000800087300EF000008080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   GVL: 01503C0000000000400C00008000480000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 71BFD3615124AC52D0D-8024
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150000560100115124
   Coding: 30FFFF
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 10041506050EPP Dataset Number: V03935206HY 0006
   Coding: 003003200000040000000000
   VCID: 3E25385D50FA032A1DF-806A
   Serial number: 00000000000001004724
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Dataset Number: 5GM074V____ 0515
   Coding: 0102
   VCID: 43D349A93B186EC2721-8016
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 06041506050BZG Dataset Number: V03935206HZ 0006
   VCID: 3D273F515DFC1832045-8068
   Serial number: 00000000000001038298
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Serial number:                Dataset Number: V03935247DB 0001
   Coding: 02730000FF00000051220001001828001F0100D40120010002
   Shop #: WSC 00046 000 00000
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D070F118D9C88B2B45-8078
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZHT1941145
          B201A 00 [00001001] - -
                    Fault Frequency: 9
                    Reset counter: 125
                    Mileage: 121104 km
                    Date: 2023.09.20
                    Time: 09:43:47
                    Voltage terminal 30: 11.2 V
                    Status_Software_Version_Management-module_name: >
   Component: OCULowMQBUS   007 0564
   Dataset Number: 561098V____ 0408
   Coding: 02730002C2821A017F1E06000000
   Shop #: WSC 00066 790 00323
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:19, VBatt start/end: 12.2V/12.1V)-----------
downtime
Finland
C?ID=280813
I presume you do, but just asking, you are aware that adding ACC is not just coding?
Gateway 530 AM works good. And it is still 5Q0 gateway.
Gateway needs component protection removed and feature enable codes restored after swap. And nowadays removing CP from gateway, ACC and BCM needs written authorization from VW before you can remove CP.
So you need someone with authentic GEKO account.
byrangc
C?ID=398877
Thanks for the response, downtime! Yes. I know I'll need to get a few additional parts to get ACC. I believe I will need a different bumper bar, radar and possibly a different ABS module.
Can you recommend anyone with a GEKO account?
Cuzoe
C?ID=279487
Yep, different bumper bar and lower bumper insert. Your ABS is fine (same hardware and software I had in my TDI S, with ACC retrofit). You will need bi-directional rear wheel speed sensors. Inexpensive and easy to replace though.
byrangc
C?ID=398877
Cool. Thanks! So 5Q0907530AM is a p/n for the high CAN gateway? Does it matter if I get new or used?
Cuzoe
C?ID=279487
That is correct. I am on my 3rd gateway, all used. Whatever is on it will get cleared by whoever you have do the online work anyway.
I would also recommend one of these...https://www.aliexpress.us/item/3256806301851873.html?
Your car is not going to have any wires going to the pins for Extended Can Bus. This will let you connect to that bus without disturbing your factory harness.
I didn't pick that seller for any particular reason other than they offer free shipping. It will be slow but you can get it coming now and have it when the time comes.
Reactions: aso
byrangc
C?ID=398877
Just curious why you're on your 3rd one. Were the other 2 used ones bad? Thanks for the link to the harness. Who did the online work for you if you don't mind sharing?
Cuzoe
C?ID=279487
No failures, just later retrofits. I retrofitted the 5Q0907530AM that you will be retrofitting now initially. Ran it for several years, zero issues. I then retrofitted the Mk8 steering wheel so had to switch to the later 3Q0 gateway, which is in my car now with zero issues.
Switching to the 3Q0 gateways is no trivial matter these days. @downtime has elaborated on this elsewhere so you can search his recent posts if curious.
byrangc
C?ID=398877
Thanks! Any leads as to who can help remove CP online? I upgraded my MIB1 to MIB2 and had Jack Kirry help me get that working using TeamViewer. But he's in Poland so not the easiest to get ahold of.
Cuzoe
C?ID=279487
I don't know of anyone in the states. I've had lots of work done by the guys at VAG Retrofit & Coding. They are somewhere in Europe. Easy to get a hold of but sessions are typically scheduled early in the morning here on the west coast... like between midnight and 3 am.
11 PM West Coast is 8 AM Central European Time, so on occasion I've scheduled a session mid morning, which would be towards the end of their work day. Midnight ends up being easier for me to manage.
byrangc
C?ID=398877
Cool. Thanks for the info. I have a good relationship with my dealership's service manager. I'm going to try and see what they say about removing the CP if I get a new gateway.
Cuzoe
C?ID=279487
The AM gateway is the replacement one for your current gateway I believe. VW will often show the highline module as the replacement for any low or mid. That way they only need to stock one replacement part and then the coding, adaptations and FEC restoration will make it work in whatever car it gets put into.
In your case, with the "proper" replacement part the dealer can follow the guided function as if they were doing a warranty replacement like they would have to do if you had some maintenance issue. That will not get you ACC unless you go with the older (round) style front radar. That style is harder to find, more expensive and less capable.
The newer style flat radar you're still going to need some remote work. And if you're having remote work done anyway may as well let them take care of the component protection while they're in there.
downtime
Finland
C?ID=280813
For gateway and ACC CP removal, your dealer needs to apply for permission from VW and only after permission is given, you can do the CP removal. This is for used parts, for new parts no permission request is needed and CP can be removed directly. So this step can only be done by authorized workshops. China Geko accounts don't work here.
  • Informative
byrangc
C?ID=398877
Thanks for all of the info! So if I go with the newer flat style radar, does that still mount the same as the round style? Will the 5Q0907530AM still be good for the flat radar?
Cuzoe
C?ID=279487
Yes, mounting and connector all the same. Gateway should be good too.
teal2
C?ID=578564
Deleted due to incorrect information.
teal2
C?ID=578564
You will need to have component protection removed, firmware checked for compatibility, FeC & SWaP codes programmed, and DataSet flashed. I have a guide on this, or you can contact me.
downtime
Finland
C?ID=280813
DO NOT BUY A -AM GATEWAY IT WILL NOT WORK! IT DOES NOT NAVE EXTENDED CAN-BUS.
You need 5Q0907530AN.
I have done an ACC retrofit myself and I replaced my 530AM gateway for a 530AN gateway.
That's not correct. I had 2017 MQB Tiguan with AM gateway and that had ACC, 3Q0 camera from factory. And I can 100% confirm that CAN has can extended.
teal2
C?ID=578564
IIRC it doesn't, maybe they updated it. I just replaced the one in my 2016 Passat, but thats NMS so it may be different, although the part number is the same.
downtime
Finland
C?ID=280813
No they have not. There's 2 manufacturers. Continental and Lear. Continental hardware is index M and that has CAN extended. Lear is hardware index F which has been used from 2013 onwards and it also has CAN extended.
And there is no AN gateway for MQB cars. For gateway part nbr 7N0 there is AN index as well, so are you sure you're not mixing up now different platforms? AFAIK 2016 NA Passat is not MQB car.
Reactions: TTT
