Audi A6 C7 4G 02850 J770 fault code
AudiA6C7
Norway
On my Audi A7 A6 C7 I received an error some time back saying "ACC and braking guard not available" and "audi side assist system fault" After checking with vcds a long time ago we found out that the part that needs to be changed is 02850 J770 slave module in the left side rear bumper. I know the code for the slave module, but seems like the reason we cant get the code to appear is because it has no signal/communication with the master. I've also read that when changing the slave module, you will be left with error 005 instead of 004, which is probably when you have to calibrate the slave module with the master to make it work, do you think it matters if I purchase a used or completely new module?
02850 - Control Module 2 for Lane Change Assistance (J770)
                    Reset counter: 224
                    Mileage: 206826 km
                    Date: 2024.03.25
                    Time: 17:17:54
Wednesday,27,March,2024,15:16:46:34585
VCDS Version: 23.11.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WAUZZZ4G4CN055211   License Plate:
Mileage: 206898km-128560mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 18 19 20 22 28 34 36 3B
          3C 42 44 46 47 52 53 55 56 57 5F 62 69 6C 6D 72 82 84 85 8B
          8E 8F 90
VIN: WAUZZZ4G4CN055211   Mileage: 206898km-128560miles
Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  X37 0004
   Revision: 53X37---    CVN: C336EA01
   Coding: 1225401A057601020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 261E9854886F7CAA75F-8072
   VINID: 9D196AAAA117113780145081049B7CEDEF
5587 - Particulate Trap Bank 1
          P2002 00 [01100000] - Efficiency Below Threshold
                    Fault Frequency: 146
                    Mileage: 206848 km
                    Date: 2024.03.25
                    Time: 20:12:18
                    Engine RPM: 1916.00 /min
                    Vehicle speed: 44 km/h
                    Coolant temperature: 69 °C
                    Intake air temperature: -2 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 14.560 V
                    Ambient temperature: -10.2 °C
                    Engine status: COENG_RUNNING
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000000656 CVN: 0000FA13
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 2C0A6A7C968346FAA3B-8078
   Part No SW: 4G0 907 379 G    HW: 4G0 907 379 G
   Component: ESP PREMIUM   H09 0250
   Coding: 27B6C701E46DE380EB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 353C4F1845C90732CC5-8060
   Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
   Component: BCM2 2.0      H31 0330
   Coding: 05892F06000000000000
   VCID: 78A2862C12DB3A5A173-802C
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0062
   Serial number: 11091100040698
   Coding: 361200B83C
   ASAM Dataset: EV_AirCondiComfoUDS 002033
   VCID: 270095508F6565A24E9-8072
0291 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Sensor für Luftgüte: kein Signal / Kommunikation]
                    Reset counter: 4
                    Mileage: 206657 km
                    Date: 2024.03.22
                    Time: 22:25:24
                    Voltage terminal 30: 13.13 V
                    Terminal 15 status: Terminal 15 on
                    Outside temperature: 9.0 °C
0314 - Function Restricted due to Missing Message(s)
          [Sensor für Luftfeuchte aussen: kein Signal / Kommunikation]
                    Reset counter: 4
                    Mileage: 206657 km
                    Date: 2024.03.22
                    Time: 22:25:28
                    Voltage terminal 30: 13.20 V
                    Engine RPM: 817 /min
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001214018
   Coding: 0907A09109749FE2A9810083A0001800CF9CE7082E080101000108542F01
   Shop #: WSC 12345 123 61029
   VCID: 6E8EA074609F74EACDF-803A
   Component: WWS57X 110817  H35 0051
   Serial number:         110830192836
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11674068
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
   Component: E1 - LDS  H07 0044
   Serial number: 12 08 2011  00000250
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000003081100010082
   Coding: 110000
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000023081100010615
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: C30806C5000000000001
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Reset counter: 4
                    Mileage: 206657 km
                    Date: 2024.03.22
                    Time: 22:25:00
                    Fault Status: 00100101
                    Reset counter: 4
                    Mileage: 206657 km
                    Date: 2024.03.22
                    Time: 22:25:00
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 B    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0480
   Revision: 00000007
   VCID: 2C0A6A7C960346FAA3B-8078
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4H0 919 475 P    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0030
   Revision: --------    Serial number: 56261122100688
   Coding: B92B08
   ASAM Dataset: EV_EPHVA2CAU57X0000 002008
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 3FD02D3077F5CD62169-806A
   Part No SW: 4G0 907 561     HW: 4G0 907 561
   Component: ACC3          H15 0160
   Serial number: 00000000000000 Dataset Number: 4G0909863A  0018
   Coding: 3F04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 001003
   ROD: EV_AdaptCruisContrAU57X_001.rod
   VCID: 6780D5504FE5A5A28E9-8032
145152 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FAULT_CIS_SWA_FAIL]
                    Fault Frequency: 9
                    Reset counter: 225
                    Mileage: 204718 km
                    Date: 2024.02.20
                    Time: 13:16:43
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 12.176 V
                    Velocity_vehicle_reference: -0.00 m/s
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG0042RD+ Dataset Number: 4G0909602G  0010
   Coding: 30323436313330303437554A304C34473053
   VCID: 363E481458CF0C2AC5F-8062
   Serial number: 3575HRB405N0Q3SKC98+
   Serial number: 3585HRB405J0OPI2504A
   Serial number: 3515JRB40530NHDGIP2P
   Serial number: 3525JRB40570NHDGOHB.
   Serial number: 3554VRB40570NVAMG0VK
   Serial number: 3564VRB40570NVAMH10Z
   Revision: --------    Serial number: 90372KI9000ZR
   Coding: 0000FD
   VCID: 372045105F45F522DE9-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
   Serial number: 08 08 2011  B0036794
   Part No SW: 4G8 920 931 K    HW: 4G8 920 931 K
   Component: TDieRdwAccNv  H71 0375
   Revision: 26181114    Serial number: 658150911593013
   Coding: 138F11009F150008000000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K_AU57.rod
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 E    HW: 4H0 265 105 E
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20130213075859
   Coding: 5D3501
   Shop #: WSC 59402 001 104857
   VCID: 241A825CFED38EBA6BB-8070
01407 - Flame Extinguished
                    Reset counter: 230
                    Mileage: 205487 km
                    Date: 2024.02.26
                    Time: 14:09:57
                    Temperature: 34.0°C
                    Temperature: -4.0°C
                    Voltage: 10.50 V
                        Full Throt
                    Count: 185
                    Temperature: -1.0°C
                        No
01406 - No Flame
                    Reset counter: 230
                    Mileage: 205543 km
                    Date: 2024.02.27
                    Time: 00:28:27
                    Temperature: 4.0°C
                    Temperature: 24.0°C
                    Voltage: 10.70 V
                        Start
                    Count: 71
                    Temperature: -7.0°C
                        No
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000242413
   Coding: 00CD077D00
   GVL: FDEFF9CCFFE76C0D40
   ROD: EV_GatewUDS_AU57.rod
   VCID: 32367404B4A7100AE97-8066
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650488790
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 11259000685021200410
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00001000] - -
                    Reset counter: 242
                    Mileage: 206003 km
                    Date: 2024.03.09
                    Time: 10:47:50
                    Voltage terminal 30: 12.0 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 12 °C
                    System status: Awake_Timer_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [00001000] - Too High
                    Fault Frequency: 123
                    Reset counter: 10
                    Mileage: 204736 km
                    Date: 2024.02.20
                    Time: 17:45:38
                    Voltage terminal 30: 12.7 V
                    Control Module temperature: 4 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [00001000] - -
          [Powermanagement active]
                    Fault Frequency: 46
                    Reset counter: 10
                    Mileage: 204736 km
                    Date: 2024.02.20
                    Time: 21:49:58
                    Voltage terminal 30: 12.6 V
                    Control Module temperature: 0 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 04018264747464545425363E
   VCID: 333871004B3D1902E21-8066
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H15 0013
   Serial number: 001208110001006 Dataset Number: 4G0909104A  0016
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   ROD: EV_AllWheelDiffeQSPFR_AU57.rod
   Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
   Component: KLIMA FOND    H07 0062
   Serial number: 31081100040301
   Coding: 01
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
   VCID: 30327E0CBAAB221A9F3-8064
0025 - Motor for Rear Left Upper Body Vent
          B10D3 22 [00001001] - Signal Amplitude Too High
                    Fault Frequency: 66
                    Reset counter: 225
                    Mileage: 204985 km
                    Date: 2024.02.22
                    Time: 15:58:11
                    Voltage terminal 30: 13.36 V
                    Outside temperature: 12.5 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 11701
                    Left Rear Upper Body Vent Motor-Target value: 11701
                    Left Rear Upper Body Vent Motor-Stop open: 11405
                    Left Rear Upper Body Vent Motor-Stop closed: 10000
0026 - Motor for Rear Left Upper Body Vent
          B10D3 21 [00001000] - Signal Amplitude Too Low
                    Reset counter: 247
                    Mileage: 205079 km
                    Date: 2024.02.23
                    Time: 00:30:43
                    Voltage terminal 30: 14.86 V
                    Outside temperature: 2.5 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 9849
                    Left Rear Upper Body Vent Motor-Target value: 9849
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [00001000] - Signal Amplitude Too High
                    Reset counter: 251
                    Mileage: 205807 km
                    Date: 2024.03.05
                    Time: 14:15:38
                    Voltage terminal 30: 14.69 V
                    Outside temperature: 1.0 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 11701
                    Right Rear Upper Body Vent Motor-Target value: 11701
                    Right Rear Upper Body Vent Motor-Stop open: 11406
                    Right Rear Upper Body Vent Motor-Stop closed: 10000
   Part No SW: 4G0 907 553 C    HW: 4G0 907 553
   Component: LUFE-DAEMPFER H17 0779
   Dataset Number: 4G0909553D  0030
   Coding: 008003
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2B086960938D41C2AA1-807E
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000013746133
   VCID: 77A085101FC535221E9-8022
   Part No SW: 4G0 907 637 C    HW: 4G0 907 637 C
   Component: SARA 6D red   H02 0004
   Revision: --------    Serial number: EJ1BPA3E0052Y90
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2E0E6074A09F34EA8DF-807A
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0020
   Revision: 00H02000    Serial number: 6PZ 010 287-03
   Coding: 0010102
   VCID: 30327E0CB62B221A9F3-8064
                    Reset counter: 224
                    Mileage: 206826 km
                    Date: 2024.03.25
                    Time: 17:17:54
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F16205E00628002080013
   Shop #: WSC 02312 785 00200
   VCID: 41D42BC80181BB9260D-8014
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 01101100
                    Reset counter: 221
                    Mileage: 204719 km
                    Date: 2024.02.20
                    Time: 13:57:51
                    Reset counter: 241
                    Mileage: 205872 km
                    Date: 2024.03.07
                    Time: 07:41:25
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0001154577 Dataset Number: 4G0909852H  0027
   Coding: 101101010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0158538933
   Coding: 01000E2020B93495832009802E0304000000000000000000000000000000
   Subsystem 1 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.006  H02 0007
   Serial number:     WOO13190941
   Coding: 901F00
   Subsystem 2 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00000371651
   Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.006  H02 0007
   Serial number:     WOO13190884
   Coding: 001F00
   Subsystem 4 - Part No SW: 3AA 962 243 C    HW: 3AA 962 243 C
   Component: GEB.F.Heckoef  H15 0721
   Serial number: 94015382
01512 - Control Module for Sliding Roof
                    Fault Status: 01100101
                    Reset counter: 180
                    Mileage: 204718 km
                    Date: 2024.02.20
                    Time: 13:16:13
                    Fault Status: 11101100
                    Reset counter: 180
                    Mileage: 204718 km
                    Date: 2024.02.20
                    Time: 13:36:58
                    Reset counter: 180
                    Mileage: 204718 km
                    Date: 2024.02.20
                    Time: 13:36:58
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 00101001
                    Fault Frequency: 11
                    Reset counter: 248
                    Mileage: 205548 km
                    Date: 2024.02.27
                    Time: 14:10:58
02615 - Fuel Tank Cap; Lock
                    Fault Frequency: 11
                    Reset counter: 248
                    Mileage: 205563 km
                    Date: 2024.02.27
                    Time: 14:28:33
00984 - Left Tail Light (M4)
                    Fault Status: 00101100
                    Reset counter: 252
                    Mileage: 206434 km
                    Date: 2024.03.16
                    Time: 22:01:35
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000022874
   Coding: 030000
   VCID: 1C6ABABCC6A3B67AD3B-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F16205E00628002080002
00110 - Right Mirror Turn Signal Lamp (L132)
                    Fault Frequency: 54
                    Reset counter: 216
                    Mileage: 206620 km
                    Date: 2024.03.21
                    Time: 18:41:00
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000140659
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A066C649C7758CA517-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 110922-0002-092
   Coding: 11226F601002A300
   ROD: EV_HeadlRegulBasic_AU21.rod
   Part No SW: 4G1 035 053 C    HW: 4G1 035 053
   Component: Radio U Basic H41 0079
   Revision: AB001007    Serial number: 049I$0BB022771
   Coding: 010003010000000001
   VCID: 1F108DB0D7B5AD62369-804A
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129     HW: 4G0 919 129
   Component: NGTV-DVB      H04 0390
   Revision: R0043000    Serial number: 06800800078201
   Coding: 01000000
   VCID: 6A86AC645C7798CA917-803E
   Part No SW: 4G0 035 666 E    HW: 4G0 035 666
   Component: H-BN-EU       H47 0410
   Revision: --------    Serial number: 426I00B7613379
   Coding: 050100010303FFEF7D34EB3E00000003E80101020000000000
   VCID: 2A066C649CF758CA517-807E
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1301HDW.
   Subsystem 3 - Part No SW: 4G1 919 610 A    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0203
   Serial number: 90349KIF0005P
   Component: CD-Database  3371
02244 - Button in Control Head is Stuck
                    Reset counter: 227
                    Mileage: 205145 km
                    Date: 2024.02.23
                    Time: 01:55:03
                    Voltage: 14.80 V
                    Hex Value: 0x000A
                        not available
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14204000628002080002
   VCID: 44DA22DC1E93AEBA4BB-8010
02123 - Door Warning Light / Entry Light
                    Reset counter: 193
                    Mileage: 205658 km
                    Date: 2024.02.29
                    Time: 21:54:37
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Revision: 5G001001    Serial number: 00000155490711
   Coding: 0109080000000000
   VCID: 71B4BB0871A16B12D0D-8024
   Part No SW: 4H0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0090
   Revision: 11001001    Serial number: 82330JF0008360
   Coding: 0202000001010100010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 003019
   ROD: EV_CamerSysteTopViewAUDI_003.rod
   VCID: 6A86AC645CF798CA917-803E
9616433 - Video Signal Line for Front Surroundings Camera
          B1278 01 [00001000] - Electrical Failure
                    Reset counter: 0
                    Mileage: 206538 km
                    Date: 2024.03.19
                    Time: 14:07:38
                    Voltage terminal 30: 11.8 V
9616969 - Front Surroundings Camera
          B127C 04 [00001001] - Internal System Fault
                    Reset counter: 195
                    Mileage: 204718 km
                    Date: 2024.02.20
                    Time: 13:16:11
   Part No SW: 4G9 959 107 A    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0139
   Revision: 14003001    Serial number: 245100200 Dataset Number: 4G0909541B  0022
   Coding: 097205C011
   ASAM Dataset: EV_HDSGAu572 001001
   ROD: EV_HDSGAu571.rod
   VCID: 343A721C4EB31E3AFBB-8060
   Component: TSG HR        H04 0212
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 G    HW: 4G0 919 604 G
   Component: HeadUpDisplay 005 0106
   Coding: D70000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
   VCID: 2F307D70A7953DE2869-807A
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 E    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0028
   Serial number: 0K84AE40044936
   Coding: 1311
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   VCID: 31347B08B1A12B1290D-8064
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H08 0007
   Serial number: 00000000001110400021
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0036
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G0909547A  0023
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 659CDF58B5E9B7B2BC5-8030
   Part No SW: 4G0 907 541     HW: 4G0 907 541
   Coding: 3F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
   ROD: EV_AdaptCruisContr2AU57X_001.rod
                    Fault Frequency: 9
                    Reset counter: 225
                    Mileage: 204718 km
                    Date: 2024.02.20
                    Time: 13:16:11
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 12.171 V
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H29 0034
   Serial number: 000040181708117 Dataset Number: 4G0909548A  0021
   Coding: 04C0BB1E1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 251C9F58F56977B27C5-8070
0063 - Function Restriction due to Faults in Other Modules
          [SWA_Signal_error]
                    Reset counter: 224
                    Mileage: 204718 km
                    Date: 2024.02.20
                    Time: 13:16:12
                    Outside temperature: -2.0 °C
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 12.0 °C
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Dataset Number: 4G0909614A  0010
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FB0BD7067157DE2C69-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   Dataset Number: 4G0909615A  0010
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70B2BE0C7A2B621ADF3-8024
End----(Elapsed Time: 03:03, VBatt start/end: 12.3V/12.0V. VIgn 11.9V)-----
AudiA6C7
Norway
Accidently wrote A7 in the top text, it is an A6
davisev5225
Democratic People's Republic of Commifornia, USA
C?ID=263265
Have you checked the wiring and connections? "No Signal/Communication" is a pretty clear indication of what the issue is - your car can't talk to that replacement module. Maybe it doesn't have power or ground, maybe the data line(s) aren't connected properly, or maybe your replacement module is no good. Only way to be sure is to break out a multimeter, get the wiring diagram (that's a clickable link...), and start probing.
And yes, it definitely matters that you bought a used module. You have no idea what condition that module was in prior to your purchase, and I have my doubts that the seller offered a warranty on it.
AudiA6C7
Norway
Me and my friend decided to disable the module yesterday and found some interesting things, and I think we found the problem there tbh. If you look at the imgur link, there is 4 images showing you how it looks inside, and it doesn't look good at all, from what we saw before opening it, it was already a tiny bit open around the edges which is shown in 1 of the images. I assume this is the reason for the fault code, not to say, it could be issues with the wiring system also, but will have to look at replacing this module first, then see what happens. I also talked to a guy who works at Norbit, who works with things like this, and he might be able to repair it, but will have to see what he says when I show him the module.
You are very right regarding an used module, we probably have no idea what condition it is, but if it seems to be closed on the edges, it should be fine inside I assume? It actually has a 3 month warranty, its pretty big market here in Norway at least, that covers all the scrap companies on a website that offers warranty and other things. But in terms of a replacement module, what do you recommend? Because buying a used or new, it seems the price is pretty much the same, this is due to Norway being expensive, can get a used slave module for 130-200EUR, but it's also an option to purchase a new for 150EUR at AUTODOC. My only concern is doing the wrong thing, because what I've learned from posting on some audi facebook groups and talking to some mechanics that screws a lot of VW, is that I will either need to get 1 module and calibrate it, or I'll need to buy a set of 2 used modules from same car and then it shouldn't be needed to calibrate at all, just remove the fault code. Another person said there is a component lock on used modules too, which requires you to visit audi workshop I think, but the other person who told me to buy 2 used or calibrate 1, said that this is wrong, there is no component lock on these modules, but he said its component lock on the radars in the front, none of them have mentioned me buying a new one yet. Perhaps it requires a lot more work due to the fact its never been in a car? This makes me very confused and I'm stuck with not knowing what to do.
Highly appreciate any intel on this if you know, or anyone else who reads this!
davisev5225
C?ID=263265
That is one crunchy looking module! :eek:
I wouldn't trust AUTODOC to sell a genuine part, especially if it's similar to used part prices. Definitely check with the dealer for a new one, or at least try to find one from a reputable parts supplier.
A relatively quick Google search says the "D" revision part has been discontinued, superseded by an "M" revision. 4G0907568M I have no idea if it's compatible with your "D" revision master module or if you'd have to replace the master as well, but I highly recommend a new part instead of continuing to roll the dice on used. You will probably have to deal with component protection either way, so be prepared to visit the dealer once you get a functioning module installed.
AudiA6C7
Norway
Yeah I will for sure not use the module for any sort of modelling :cry:
I am not sure what experience you have with AUTODOC, but they don't sell non-original parts when it says "hella" as a manufacturer, but they buy them in very large quantities to get them cheap, they wouldn't have been able to run a business for a long time if they had sold non-volatile branded parts. I can always ask the dealer, but Audi dealership is also known to be one of the most expensive branded dealership, especially in Norway. One example is getting 2x injectors was somewhere around 5500EUR, meanwhile getting 2 at AUTODOC was around 900EUR. I did read on a forum that someone got a set of these j769 & j770 and it was insanely expensive, but I'll look into it and make a decision soon.
That I have no idea about, but I am able to purchase both the master and slave D version as new and used. I could call the dealership and ask them what they think, but one problem I find with dealership, at least Audi, and that's with experience from many friends, is that their service is pretty lame, they rarely want to help, unless you get an appointment. I have experienced this a few time myself, that day I called a different dealership and ended up talking with a very nice guy who was very helpful, but I never got his name, so will be hard to locate him again. Most of the times they don't even want to give you an estimated price either, I'm sure there is other branded dealerships out there that do the same, but so far I haven't had much good experience with them sadly.
I did mention in the last message that the reason for AUTODOC pricing being around the same as a used part, is because Norwegian pricing is extremely high in comparison to other EU countries, specially Germany and Poland. It's the same for most other parts, a car scrap in Norway will take about the same price for a used injector, headlight or anything else you want, as a new one would cost at AUTODOC etc.
Tomorrow I will give the module to a guy I know who might be able to repair it, if he can't, I will call the dealership and see what progress I can make from a phone call with them.
I appreciate the informative answers, it is nice to finally get further with this, because this happened 1.5 years ago, and first now, I've managed to get pretty far and hopefully I'll have it fixed soon, I miss my ACC :cry:
davisev5225
C?ID=263265
I have no experience with them, I'm just gun-shy about web stores that appear to sell Chinese Replacement Auto Parts (thanks @Uwe for that acronym :D). If you trust them, then go for it. The worst thing that can happen in most cases is you waste your time pulling it back out and sending it back for a refund.
Happy to help. I'd also be going nuts without my ACC, my drives tend to be long due to stop-and-go traffic. ACC makes that a much more pleasant experience (at least, as pleasant as endless traffic jams can be...)
There are lots of fake parts in circulation that are shamelessly made in Asia with no regard for trademarks or country-of-origin labeling. Parts labelled "Bosch", "Hella" and various other brands have all been faked.
Here is another example (fake NGK spark plugs).
AudiA6C7
Norway
I totally agree with you, it's not always easy to know, I myself try to research a bit before buying, I am not a fan of just purchasing the cheapest possible product. Honestly I don't have insanely amount of experience with AUTODOC either, but I do know a lot of people purchase car parts from there, simply because Norwegian pricing is insane, 2 brake discs and 4 brake pads from Bosch would cost me around 800-950EUR from shops here, instead if purchasing from shops like AUTODOC in Norway, it would cost me ish 200EUR, that's also Bosch. Maybe it's fake, but again, I'd need to buy minimum 4x the amount to reach Norwegian prices, which is crazy, and sad.
I appreciate the good info regarding this tho, It's nice to hear this from people who most likely have a lot more experience then me regarding this, I don't rly know that much, I'm just a middle man who appreciates any form of advice and tips in terms of this matter.
Regarding the labelling, isn't it illegal to fake products like Bosch or Hella, and that all legit companies who sell this, needs some sort of branding on them? I believe Bosch uses fingerprint technology to optically capture the natural surface of a original part that they sell.
Of course it is. But try to enforce that in certain Asian countries. You may or may not get any results at all, but even if you do, somebody else will pop up and do the same thing.
AudiA6C7
Norway
So to finish of this topic in the first place, do you guys have any last recommendations? Do you think I should get a slave module and get it calibrated, or perhaps get a slave and a master from the same car? This is supposed to be without calibration, at least from what I've been told so far. Right now I have no idea what the difference would be if I bought a used or new slave alone or a slave and master, I just know that a new one requires activation since it's never been in a car. Honestly I don't care that much about the price for fixing this, unless It's a very big difference. I also get 3 months of warranty on a used part, with that I have a bit of safety if it doesn't work.
Also forgot to mention that I visit a guy who works in a shop where they make circuit boards and he told me after opening my module that its completely dead, several parts of the circuit board was rusted away due to water getting through there, from what he said, the module has been opened before, those who tried to seal it did a poorly job, and doesn't look very fabricated, so that can be a reason for it breaking, or it was already broken and they fixed it, and it broke again because it was poorly sealed, will never know, but was fun and interesting to take a look at it, since I got it done for free!
davisev5225
C?ID=263265
Most diagnostics-capable modules in your generation of car will trigger component protection. You're likely not going to avoid a visit to the dealer to remove CP no matter which way you go, so I guess take whichever route is least expensive.
siLc
Tallinn, Estonia
C?ID=330192
According to this, the very common failure item of the Side Assist radars isn't under the CP umbrella.
davisev5225
C?ID=263265
A cursory glance shows they only detail out what's locked out under Gen 1. @AudiA6C7's car is Gen 2.
AudiA6C7
Norway
Hello!
After removing the rear bumper and replacing the slave module j769, I then received new fault codes. I used to have
And now I received 2 new fault codes which is
02849 - Control Module for Lane Change Assistance (J769)
I feel like progress has been made, since the light on the blind spot mirror was gone before replacing the slave module, but after replacing it now lights up again, after enabling it on in VCDS. But I still have "Audi Side Assist System Fault" and "ACC and Braking Guard not available" Everything else in the mmi menu is working, except for the side assist, that menu is dark, so I'd assume that the side assist is the thing that needs calibration, which is probably the 2 modules in the rear? I called Audi dealership, and they are saying that you need this plate to calibrate the radar in the rear, which will cost me 450 EUR.
What do you think about this, is there possibly any way to calibrate or fix this with vcds, or is Audi the only way to go here? I've already asked a few other workshops if they are able to calibrate this, but seems like the side assist requires special equipment according to Audi.
AudiA6C7
Norway
Then I will have to ask someone with VCDS to do a full scan again, and then send it to me, and I think they are getting tiny bit tired of me asking every week.. Last time I got it checked it was a workshop guy, and he just took his laptop in my car and took it back in to look if he could calibrate it for me, sadly he didn't have the equipment required. My other friend also did a scan same day, just to check if there was a small chance we would make it work by going into adaptation or security access, sadly we didn't get any further and that got me to call Audi dealership, which made me come here.
I will however ask him if he has the scan from last time, if not we'll see what he says. Is it the freeze frame info you are looking for? Or do you require the full scan to see every single detail?
davisev5225
C?ID=263265
Primarily we need the current data from your 3C Lane Change module to see its current status, but it will help to see what complaints the rest of your car has developed as a result of this repair.
Also, there's a strong possibility you'll need to go to someone with the necessary equipment to do the calibration portion. There are ways to DIY it, but after you invest the necessary time, effort, and funds to get the equipment, modify it to suit your calibration need, and set everything up, you might as well have paid a shop to do it. Stealership is going to be the most expensive option (but they're guaranteed to have the equipment), 3rd party repair such as body shops or "German tech" shops might have the necessary equipment and would likely be cheaper.
AudiA6C7
Norway
Sorry for the delay, have been very busy last couple of days. I have not been able to get anyone with VCDS to help me, but to be fair, it is probably not that much of a point I guess? I've been told that that I will need to go to a workshop that has the equipment to calibrate the side assist radars anyway. I myself don't know any 3rd party repair shops that do this in Norway, I live in a very small town, and I need to drive like 5hrs to get to Oslo, so the question is if its worth the trouble and time to locate one who does it, might write on one of the facebook forums and see if anyone has this equipment and will do it cheap, but if there's no luck there I might as well just do it at Audi for 450EUR.
